path: root/drivers/net/cnic_defs.h
2011-06-15New 7.0 FW: bnx2x, cnic, bnx2i, bnx2fcVlad Zolotarov
New FW/HSI (7.0): - Added support to 578xx chips - Improved HSI - much less driver's direct access to the FW internal memory needed. New implementation of the HSI handling layer in the bnx2x (bnx2x_sp.c): - Introduced chip dependent objects that have chip independent interfaces for configuration of MACs, multicast addresses, Rx mode, indirection table, fast path queues and function initialization/cleanup. - Objects functionality is based on the private function pointers, which allows not only a per-chip but also PF/VF differentiation while still preserving the same interface towards the driver. - Objects interface is not influenced by the HSI changes which do not require providing new parameters keeping the code outside the bnx2x_sp.c invariant with regard to such HSI chnages. Changes in a CNIC, bnx2fc and bnx2i modules due to the new HSI. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2010-12-23cnic: Add FCoE support on 57712Michael Chan
- Connection ID (cid) management - Slow-path command and response support - Update version to 2.2.11. Reviewed-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-06bnx2x, cnic, bnx2i: use new FW/HSIDmitry Kravkov
This is the new FW HSI blob and the relevant definitions without logic changes. It also included code adaptation for new HSI. New features are not enabled. New FW/HSI includes: - Support for 57712 HW - Future support for VF (not used) - Improvements in FW interrupts scheme - FW FCoE hooks (stubs for future usage) Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26cnic: Update version to 2.1.1.Michael Chan
And update copyright to 2010. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11cnic: Add bnx2x data structures.Michael Chan
Add hardware and software structures for bnx2x devices. Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09[SCSI] cnic: Add new Broadcom CNIC driver.Michael Chan
The CNIC driver controls BNX2 hardware rings and resources used by iSCSI. Most hardware resources for iSCSI are separate from those used for ethernet networking. iSCSI uses a separate MAC address and IP address. The CNIC driver creates a UIO interface to handle the non-offloaded packets such as ARP, etc in userspace. Signed-off-by: Michael Chan <mchan@broadcom.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
