Moves the drivers for the Chelsio chipsets into
drivers/net/ethernet/chelsio/ and the necessary Kconfig and Makefile
changes.
CC: Divy Le Ray <divy@chelsio.com>
CC: Dimitris Michailidis <dm@chelsio.com>
CC: Casey Leedom <leedom@chelsio.com>
- unify vlan and nonvlan rx path
- kill pi->vlan_grp and vlan_rx_register
- allow to turn on/off rx/tx vlan accel via ethtool (set_features)
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
This removes some of the remnants of LRO -> GRO conversion.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Make local functions static. Remove functions that are
defined and never used. Compile tested only.
Acked-by: Divy Le Ray <divy@chelsio.com>
T3 hardware doorbell FIFO overflows can cause application stalls due
to lost doorbell ring events. This has been seen when running large
NP IMB alltoall MPI jobs. The T3 hardware supports an xon/xoff-type
flow control mechanism to help avoid overflowing the HW doorbell FIFO.
This patch uses these interrupts to disable RDMA QP doorbell rings
when we near an overflow condition, and then turn them back on (and
ring all the active QP doorbells) when when the doorbell FIFO empties
out. In addition if an doorbell ring is dropped by the hardware, the
code will now recover.
Design:
cxgb3:
- enable these DB interrupts
- in the interrupt handler, schedule work tasks to call the ULPs event
handlers with the new events.
- ring all the qset txqs when an overflow is detected.
iw_cxgb3:
- disable db ringing on all active qps when we get the DB_FULL event
- enable db ringing on all active qps and ring all active dbs when we get
the DB_EMPTY event
- On DB_DROP event:
- disable db rings in the event handler
- delay-schedule a work task which rings and enables the dbs on
all active qps.
- in post_send and post_recv logic, don't ring the db if it's disabled.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
This patch added support of private MAC address per port and provisioning
packet handler for iSCSI traffic only.
The above changes are isolated to the cxgb3 driver, independent of any scsi or iscsi driver changes.
Acked-by: Karen Xie <kxie@chelsio.com>
Signed-off-by: Rakesh Ranjan <rakesh@chelsio.com>
In a couple of cases collapse some extra code like:
int retval = NETDEV_TX_OK;
return retval;
into
return NETDEV_TX_OK;
use request_firmware() to load the phy's EDC programmation
Signed-off-by: Divy Le Ray <divy@chelsio.com>
We don't always see the link status update interrupt
when we come out of reset and the peer is up.
Check and report the link status right before enabling interrupts.
Also fix LED settings, to get a consistent link status.
Pre-allocate a skb at init time to be used for control messages to the HW
if skb allocation fails.
Tolerate failures to send messages initializing some memories at the cost of
parity error detection for these memories.
Retry sending connection id release messages if both alloc_skb(GFP_ATOMIC)
and alloc_skb(GFP_KERNEL) fail.
Do not bring the interface up if messages binding queue set to port fail to
be sent.
drivers/net/forcedeth.c
Commit 5e68b772e6efd189d6aca76f6872fb75d51ace60
cxgb3: map entire Rx page, feed map+offset to Rx ring.
introduced a regression on platforms defining DECLARE_PCI_UNMAP_ADDR()
and related macros as no-ops.
Rx descriptors are fed with the a page buffer bus address + page chunk offset.
The page buffer bus address is set and retrieved through
pci_unamp_addr_set(), pci_unmap_addr().
These functions being meaningless on x86 (if CONFIG_DMA_API_DEBUG is not set).
The HW ends up with a bogus bus address.
This patch saves the page buffer bus address for all plaftorms.
It turns out that copying a 16-byte area at ~800k times a second
can be really expensive :) This patch redesigns the frags GRO
interface to avoid copying that area twice.
The two disciples of the frags interface have been converted.
DMA mapping can be expensive in the presence of iommus.
Reduce the Rx iommu activity by mapping an entire page, and provide the H/W
the mapped address + offset of the current page chunk.
Reserve bits at the end of the page to track mapping references, so the page
can be unmapped.
Start queue set reclaim timers after the queue sets have been
allocated successfully.
The driver currently ignores the local or remote link faults
raised at the mac layer. This patch fixes it.
Our mac however only advertizes link events, so wait for the
phy to stabilize the link, then enable mac link events interrupts.
Separate TX and RX reclaim handlers
Don't disable interrupts in RX reclaim handler.
Ring free lists door bell less frequently,
specifically every quarter of the active FL
size.
This patch makes cxgb3 invoke the GRO hooks instead of LRO. As
GRO has a compatible external interface to LRO this is a very
straightforward replacement.
I've kept the ioctl controls for per-queue LRO switches. However,
we should not encourage anyone to use these.
Because of that, I've also kept the skb construction code in
cxgb3. Hopefully we can phase out those per-queue switches
and then kill this too.
The driver currently drops to line interrupt mode
if it did not get all the msi-x vectors it requested.
Allow msi-x settings when a minimal amount of vectors
is provided.
I have a system with a Chelsio adapter (driven by cxgb3) whose ports are
part of a Linux bridge. Recently I updated the kernel and discovered
that things stopped working because cxgb3 was doing LRO on packets that
were passed into the bridge code for forwarding. (Incidentally, this
problem manifested itself in a strange way that made debugging a bit
interesting -- for some reason, the skb_warn_if_lro() check in bridge
didn't trigger and these LROed packets were forwarded out a forcedeth
interface, and caused the forcedeth transmit path to get stuck)
This is because cxgb3 has no way of keeping state for the LRO flag until
the interface is brought up, so if the bridging code disables LRO while
the interface is down, then cxgb3_up() will just reenable LRO, and on my
Debian system at least, the init scripts add interfaces to a bridge
before bringing the interfaces up.
Fix this by keeping track of each interface's LRO state in cxgb3 so that
when bridge disables LRO, it stays disabled in cxgb3_up() when the
interface is brought up. I did this by changing the rx_csum_offload
flag into a pair of bit flags; the effect of this on the rx_eth() fast
path is miniscule enough that it should be fine (eg on x86, a cmpb
instruction becomes a testb instruction).
The accelerated iSCSI traffic could use a private IP address unknown to the OS:
- The IP address is required in both drivers to manage ARP requests and connection set up.
- Added an control call to retrieve the ip address.
- Reply to ARP requests dedicated to the private IP address.
Signed-off-by: Karen Xie <kxie@chelsio.com>
Implement NIC Tx multiqueue.
Bump up driver version.
Update copyright banner to 2008.
Second step in overall phy layer reorganization.
Clean up the port_type_info structure.
Support coextistence of clause 22 and clause 45 MDIO devices.
Select the type of MDIO transaction on a per transaction basis.
when a fatal error occurs, bring ports down, reset the chip,
and bring ports back up.
Factorize code used for both EEH and fatal error recovery.
Fix timer usage when bringing up/resetting sge queue sets.
A SGE queue set timer might access registers while in EEH recovery,
triggering an EEH error loop. Stop all timers early in EEH process.
Add LRO support.
Add page support to Jumbo frame Rx queues.
Fix faiures path when ports are stopped and restarted
in EEH recovery.
None of these files use any of the functionality promised by
asm/semaphore.h. It's possible that they rely on it dragging in some
unrelated header file, but I can't build all these files, so we'll have
fix any build failures as they come up.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Add parity initialization for T3C adapters.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Rather than hand-rolling our own prototype, make the code more
future-proof by using the standard irq_handler_t typedef.
remove asm/bitops.h includes
including asm/bitops directly may cause compile errors. don't include it
and include linux/bitops instead. next patch will deny including asm header
directly.
Cc: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Several devices have multiple independant RX queues per net
device, and some have a single interrupt doorbell for several
queues.
In either case, it's easier to support layouts like that if the
structure representing the poll is independant from the net
device itself.
The signature of the ->poll() call back goes from:
int foo_poll(struct net_device *dev, int *budget)
to
int foo_poll(struct napi_struct *napi, int budget)
The caller is returned the number of RX packets processed (or
the number of "NAPI credits" consumed if you want to get
abstract). The callee no longer messes around bumping
dev->quota, *budget, etc. because that is all handled in the
caller upon return.
The napi_struct is to be embedded in the device driver private data
structures.
Furthermore, it is the driver's responsibility to disable all NAPI
instances in it's ->stop() device close handler. Since the
napi_struct is privatized into the driver's private data structures,
only the driver knows how to get at all of the napi_struct instances
it may have per-device.
With lots of help and suggestions from Rusty Russell, Roland Dreier,
Michael Chan, Jeff Garzik, and Jamal Hadi Salim.
Bug fixes from Thomas Graf, Roland Dreier, Peter Zijlstra,
Joseph Fannin, Scott Wood, Hans J. Koch, and Michael Chan.
[ Ported to current tree and all drivers converted. Integrated
Stephen's follow-on kerneldoc additions, and restored poll_list
handling to the old style to fix mutual exclusion issues. -DaveM ]
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
cxgb3 used netdev_priv() and dev->priv for different purposes.
In 2.6.23, netdev_priv() == dev->priv, cxgb3 needs a fix.
This patch is a partial backport of Dave Miller's changes in the
net-2.6.24 git branch.
Without this fix, cxgb3 crashes on 2.6.23.
Streamline sge page management.
Fix dma mappings when buffers are recycled.
Populate Rx free list with pages.
Improve the traffic recovery after the HW ran out of response queue entries.
Dual licensing, needed for OFED 1.2
Include <linux/mutex.h> in adapter.h
Inform FW about the queue set->interface mapping.
This driver is required by the Chelsio T3 RDMA driver posted by
Steve Wise.
