path: root/drivers/net/cxgb3/common.h
2010-02-17cxgb3: convert to use netdev_for_each_addrJiri Pirko
Removed whole t3_rx_mode structure and appropriate helpers cause they are no longer needed. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10cxgb3: declare MODULE_FIRMWAREBen Hutchings
Replace run-time string formatting with preprocessor string manipulation. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08cxgb3: use request_firmware() for the EDC registers setupDivy Le Ray
use request_firmware() to load the phy's EDC programmation Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29cxgb3: add support for the Aquantia 10G-BT phyDivy Le Ray
Add support for the Aquantia AQ1002 10G-BaseT phy. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29cxgb3: Add Aeluros 2020 phy supportDivy Le Ray
Add support for the AEL2020 phy. Add PCI IDs of the boards using this phy. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-20cxgb3: Use generic XENPAK LASI register definitionsBen Hutchings
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29cxgb3: Use generic MDIO definitions and mdio_mii_ioctl()Ben Hutchings
Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27cxgb3: differentiate portx and Tx channelsDivy Le Ray
Separate ports from H/W Tx channels. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13cxgb3: detect mac link faults.Divy Le Ray
The driver currently ignores the local or remote link faults raised at the mac layer. This patch fixes it. Our mac however only advertizes link events, so wait for the phy to stabilize the link, then enable mac link events interrupts. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16cxgb3: untie strict FW matchingDivy Le Ray
The NIC driver can work with mutliple versions of the FW. Let the driver load when the embedded FW does not match, and the FW update mechanism failed. The iWARP module will make its own loading decision. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-13cxgb3: extend copyrights to 2008Divy Le Ray
Update copyright banner to 2008. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08cxgb3: Add 1G fiber supportDivy Le Ray
Add support for 1G optical Vitesse PHY. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08cxgb3: Support for Aeluros 2005 PHYDivy Le Ray
Add support for SR PHY. Auto-detect phy module type, and report type changes. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08cxgb3: commnonize LASI phy codeDivy Le Ray
Add generic code to manage interrupt driven PHYs. Do not reset the phy after link parameters update, the new values might get lost. Return early from link change notification when the link parameters remain unchanged. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08cxgb3: More flexible support for PHY interrupts.Divy Le Ray
Do not require PHY interrupts to be connected to GPIs in ascending order. Base interrupt availability both on PHYs supporting them and on GPIs being hooked up. Allows boards to specify interrupt GPIs though the PHYs don't use them. Remove spurious PHY interrupts due to clearing T3DBG interrupts before setting their polarity. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08cxgb3: simplify port type struct and usageDivy Le Ray
Second step in overall phy layer reorganization. Clean up the port_type_info structure. Support coextistence of clause 22 and clause 45 MDIO devices. Select the type of MDIO transaction on a per transaction basis. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08cxgb3: allow for PHY reset statusDivy Le Ray
First step towards overall PHY layering re-organization. Allow a status return when a PHY is reset. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08cxgb3: Allocate multiqueues at init timeDivy Le Ray
Allocate a queue set per core, up to the maximum of available qsets. Share the queue sets on multi port adapters. Rename MSI-X interrupt vectors ethX-N, N being the queue set number. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08cxgb3: reset the adapter on fatal errorDivy Le Ray
when a fatal error occurs, bring ports down, reset the chip, and bring ports back up. Factorize code used for both EEH and fatal error recovery. Fix timer usage when bringing up/resetting sge queue sets. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/powerpc/booting-without-of.txt drivers/atm/Makefile drivers/net/fs_enet/fs_enet-main.c drivers/pci/pci-acpi.c net/8021q/vlan.c net/iucv/iucv.c
2008-07-10cxgb3: treat firmware data as constDavid Woodhouse
2008-05-22cxgb3 - Add LRO supportDivy Le Ray
Add LRO support. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13cxgb3 - fix EEHDivy Le Ray
Reset the chip when the PCI link goes down. Preserve the napi structure when a sge qset's resources are freed. Replay only HW initialization when the chip comes out of reset. Signed-off-by: Divy Le ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28annotate cxgb3Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3: trivial endianness annotationsAl Viro
2007-10-10cxgb3 - Update engine microcode versionDivy Le Ray
The new microcode engine version is set to 1.1.0 Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - Add T3C revDivy Le Ray
add driver recognition for T3C rev board. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - remove false positive in xgmac workaroundDivy Le Ray
Qualify toggling of xgmac tx enable with not getting pause frames, we might not make forward progress because the peer is sending lots of pause frames. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - Firmware updateDivy Le Ray
Update firmware version. Allow the driver to be up and running with older FW image Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - log adapter serial numberDivy Le Ray
Log HW serial number when cxgb3 module is loaded. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - Update rx coalescing lengthDivy Le Ray
Reduce Rx coalescing length to 12288 Large bursts from the adapter to the host create back pressure on the chip. Reducing the burst size avoids the issue. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - MAC workaround updateDivy Le Ray
Update the MAC workaround to deal with switches that do not honor pause frames. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-31- cxgb3 engine microcode loadDivy Le Ray
Load the engine microcode when an interface is brought up, instead of of doing it when the module is loaded. Loosen up tight binding between the driver and the engine microcode version. There is no need for microcode update with T3A boards. Fix the file naming. Do a better job at logging the loading activity. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-08cxgb3 - TP SRAM updateDivy Le Ray
The chip executes microcode present in internal RAM, whose content is loaded from EEPROM on power cycle. This patch allows an update of the microcode through PIO without forcing a power cycle. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11cxgb3 - MAC watchdog updateDivy Le Ray
The MAC watchdog was failing if the peer interface was brought down. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-03cxgb3 - detect NIC only adaptersDivy Le Ray
Differentiate NIC only adapters from RNICs. Initialize offload capabilities for RNICs only. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-03cxgb3 - Safeguard TCAM size usageDivy Le Ray
Ensure that the TCAM active region size is at least 16. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-23cxgb3 - Fix potential MAC hangDivy Le Ray
Under rare conditions, the MAC might hang while generating a pause frame. This patch fine tunes the MAC settings to avoid the issue, allows for periodic MAC state check, and triggers a recovery if hung. Also fix one MAC statistics counter for the rev board T3B2. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-05cxgb3 - Add dual licensingDivy Le Ray
Dual licensing, needed for OFED 1.2 Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-05Add support for the latest 1G/10G Chelsio adapter, T3.Divy Le Ray
This driver is required by the Chelsio T3 RDMA driver posted by Steve Wise. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
