path: root/drivers/net/cxgb3/regs.h
2011-08-10chelsio: Move the Chelsio driversJeff Kirsher
Moves the drivers for the Chelsio chipsets into drivers/net/ethernet/chelsio/ and the necessary Kconfig and Makefile changes. CC: Divy Le Ray <divy@chelsio.com> CC: Dimitris Michailidis <dm@chelsio.com> CC: Casey Leedom <leedom@chelsio.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-09-03cxgb3: Add register bit definition for Fatal Parity Error.Casey Leedom
Signed-off-by: Casey Leedom <leedom@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-24RDMA/cxgb3: Doorbell overflow avoidance and recoverySteve Wise
T3 hardware doorbell FIFO overflows can cause application stalls due to lost doorbell ring events. This has been seen when running large NP IMB alltoall MPI jobs. The T3 hardware supports an xon/xoff-type flow control mechanism to help avoid overflowing the HW doorbell FIFO. This patch uses these interrupts to disable RDMA QP doorbell rings when we near an overflow condition, and then turn them back on (and ring all the active QP doorbells) when when the doorbell FIFO empties out. In addition if an doorbell ring is dropped by the hardware, the code will now recover. Design: cxgb3: - enable these DB interrupts - in the interrupt handler, schedule work tasks to call the ULPs event handlers with the new events. - ring all the qset txqs when an overflow is detected. iw_cxgb3: - disable db ringing on all active qps when we get the DB_FULL event - enable db ringing on all active qps and ring all active dbs when we get the DB_EMPTY event - On DB_DROP event: - disable db rings in the event handler - delay-schedule a work task which rings and enables the dbs on all active qps. - in post_send and post_recv logic, don't ring the db if it's disabled. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2009-03-13cxgb3: detect mac link faults.Divy Le Ray
The driver currently ignores the local or remote link faults raised at the mac layer. This patch fixes it. Our mac however only advertizes link events, so wait for the phy to stabilize the link, then enable mac link events interrupts. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13cxgb3: disable high freq non-data interruptsDivy Le Ray
Under RX pressure, The HW might generate a high load of interrupts to signal mac fifo or free lists overflow. Disable the interrupts, and poll the relevant status bits to maintain stats. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08cxgb3: More flexible support for PHY interrupts.Divy Le Ray
Do not require PHY interrupts to be connected to GPIs in ascending order. Base interrupt availability both on PHYs supporting them and on GPIs being hooked up. Allows boards to specify interrupt GPIs though the PHYs don't use them. Remove spurious PHY interrupts due to clearing T3DBG interrupts before setting their polarity. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-11cxgb3 - Add iscsi supportKaren Xie
Add iSCSI (S3xx) support. Signed-off-by: Karen Xie <kxie@chelsio.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13cxgb3 - fix EEHDivy Le Ray
Reset the chip when the PCI link goes down. Preserve the napi structure when a sge qset's resources are freed. Replay only HW initialization when the chip comes out of reset. Signed-off-by: Divy Le ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28cxgb3 - parity initialization for T3C adapters.Divy Le Ray
Add parity initialization for T3C adapters. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-01-28cxgb3 - HW set up updatesDivy Le Ray
Disable PEX errors. The HW generates false positives. Update RSS hash function to a symmetric algorithm. Update T3C HW support Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07cxgb3 - T3C support updateDivy Le Ray
Update GPIO mapping for T3C. Update xgmac for T3C support. Fix typo in mtu table. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - Update internal memory managementDivy Le Ray
Set PM1 internal memory to round robin mode It balances access to this internal memory for multiport adapters. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10cxgb3 - SGE doorbell overflow warningDivy Le Ray
Log doorbell Fifo overflow Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-08cxgb3 - TP SRAM updateDivy Le Ray
The chip executes microcode present in internal RAM, whose content is loaded from EEPROM on power cycle. This patch allows an update of the microcode through PIO without forcing a power cycle. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-08cxgb3 - Firmware updateDivy Le Ray
Update FW to 4.1. Proceed to subsequent HW tuning to improve RDMA perfs.. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-20cxgb3 - Stop mac RX when changing MTUDivy Le Ray
Rx traffic needs to be halted when the MTU is changed to avoid a potential chip hang. Reset/restore MAC filters around a MTU change. Also fix the pause frames high materwark setting. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-20cxgb3 - Fix direct XAUI supportDivy Le Ray
Check all lanes for link status on direct XAUI cards. Don't assume that direct XAUI always uses XGMAC 1. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-11cxgb3 - missing CPL hanler and register setting.Divy Le Ray
Remove specific CPL handler. Add missing CPL handler. Add missing register setting when the interface is brought up. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-03cxgb3 - Tighten xgmac workaroundDivy Le Ray
Run the watchdog task when the link is up. Flush the XGMAC Tx FIFO when the link drops. Also remove a statistics update that should have gone in the previous modification of xgmac.c. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-03-23cxgb3 - Fix potential MAC hangDivy Le Ray
Under rare conditions, the MAC might hang while generating a pause frame. This patch fine tunes the MAC settings to avoid the issue, allows for periodic MAC state check, and triggers a recovery if hung. Also fix one MAC statistics counter for the rev board T3B2. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-05Add support for the latest 1G/10G Chelsio adapter, T3.Divy Le Ray
This driver is required by the Chelsio T3 RDMA driver posted by Steve Wise. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
