path: root/drivers/net/dm9000.c
2011-08-12dm9000: Move the Davicom driverJeff Kirsher
Move the Davicom driver into drivers/net/ethernet/davicom/ and make the necessary Kconfig and Makefile changes. CC: Ben Dooks <ben@simtec.co.uk> CC: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-06-11net: DM9000: Add support for byte EEPROM accessBen Dooks
Given many versions of ethtool's reluctance to do anything other than byte accesses to the EEPROM interface, it is easier to update the driver to support byte accesses so that all the ethtool versions that have been observed in Debian can write the EEPROM. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01net: dm9000: Get the chip in a known good state before enabling interruptsMark Brown
Currently the DM9000 driver requests the primary interrupt before it resets the chip and puts it into a known good state. This means that if the chip is asserting interrupt for some reason we can end up with a screaming IRQ that the interrupt handler is unable to deal with. Avoid this by only requesting the interrupt after we've reset the chip so we know what state it's in. This started manifesting itself on one of my boards in the past month or so, I suspect as a result of some core infrastructure changes removing some form of mitigation against bad behaviour here, even when things boot it seems that the new code brings the interface up more quickly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-18net: dm9000: Fix buildMark Brown
Commit c88fcb (net: dm9000: convert to hw_features) broke the build of the dm9000 driver since it merged functions which use different names for the board info structure used for I/O operations without updating all the references to use the same name. Fix that. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-15net: dm9000: convert to hw_featuresMichał Mirosław
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-29drivers: Final irq namespace conversionThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-02-28DM9000: Allow randomised ethernet addressBen Dooks
Allow randomised ethernet address if the device does not have a valid EEPROM or pre-set MAC address. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23DM9000B: Fix PHY power for network down/upHenry Nestler
DM9000 revision B needs 1 ms delay after PHY power-on. PHY must be powered on by writing 0 into register DM9000_GPR before all other settings will change (see Davicom spec and example code). Remember, that register DM9000_GPR was not changed by reset sequence. Without this fix the FIFO is out of sync and sends wrong data after sequence of "ifconfig ethX down ; ifconfig ethX up". Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-23DM9000B: Fix reg_save after spin_lock in dm9000_timeoutHenry Nestler
The spin_lock should hold before reading register. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17drivers/net: Remove unnecessary casts of netdev_privJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03drivers/net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in drivers/net/ Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17dm9000: fix "BUG: spinlock recursion"Baruch Siach
dm9000_set_rx_csum and dm9000_hash_table are called from atomic context (in dm9000_init_dm9000), and from non-atomic context (via ethtool_ops and net_device_ops respectively). This causes a spinlock recursion BUG. Fix this by renaming these functions to *_unlocked for the atomic context, and make the original functions locking wrappers for use in the non-atomic context. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-17net: convert multiple drivers to use netdev_for_each_mc_addrJiri Pirko
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-11DM9000: Wake on LAN supportBen Dooks
Add support for Wake on LAN (WOL) reception and waking the device up from this signal via the ethtool interface. Currently we are only supporting the magic-packet variant of wakeup. WOL is enabled by specifying a second interrupt resource to the driver which indicates where the interrupt for the WOL is being signalled. This then enables the necessary ethtool calls to leave the device in a state to receive WOL frames when going into suspend. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Signed-off-by: Simtec Linux Team <linux@simtec.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-09dm9000: Use resource_size instead of private macroTobias Klauser
The macro res_size in drivers/net/dm9000.c is a copy of resource_size in linux/ioport.h. Remove the function and use resource_size instead. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-09dm9000: Remove unnecessary memset of netdev private dataTobias Klauser
The memory for the private data is allocated using kzalloc in alloc_etherdev (or alloc_netdev_mq respectively) so there is no need to set it to 0 again. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-23dm9000: switch to dev_pm_opsMike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-06dm9000: add checksum offload supportYeasah Pell
Add checksum offload support for DM9000A and DM9000B chips. v2 changes: added a local copy of ip_summed to save IO cycles in dm9000_send_packet v3 changes: trans_start updating is removed. Signed-off-by: Yeasah Pell <yeasah@comrex.com> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16dm9000: convert to net_device_opsAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-02workqueue: add to_delayed_work() helper functionJean Delvare
It is a fairly common operation to have a pointer to a work and to need a pointer to the delayed work it is contained in. In particular, all delayed works which want to rearm themselves will have to do that. So it would seem fair to offer a helper function for this operation. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Greg KH <greg@kroah.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-22dm9000: locking bugfixDavid Brownell
This fixes a locking bug in the dm9000 driver. It calls request_irq() without setting IRQF_DISABLED ... which is correct for handlers that support IRQ sharing, since that behavior is not guaranteed for shared IRQs. However, its IRQ handler then wrongly assumes that IRQs are blocked. So the fix just uses the right spinlock primitives in the IRQ handler. NOTE: this is a classic example of the type of bug which lockdep currently masks by forcibly setting IRQF_DISABLED on IRQ handlers that did not request that flag. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16dm9000: Fix build error.David S. Miller
Reported by Stephen Rothwell: drivers/net/dm9000.c:1450: error: expected ')' before ';' token drivers/net/dm9000.c:1455: error: expected ';' before '}' token Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-2Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-22netdev: DM9000: remove BLACKFIN hacking in DM9000 netdev driverBryan Wu
remove integer casting in the read/write IO accessors, because Blackfin now provides those functions Tested-by: Javier Herrero <jherrero@hvsistemas.es> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-07dm9000: Support MAC address setting through platform data.Laurent Pinchart
The dm9000 driver reads the chip's MAC address from the attached EEPROM. When no EEPROM is present, or when the MAC address is invalid, it falls back to reading the address from the chip. This patch lets platform code set the desired MAC address through platform data. Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22DM9000: Remove magic numbersBen Dooks
Remove magic numbers for items that we already have defined in the register header file. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24DM9000: Remove DEFAULT_TRIGGER for request_irq() flags.Ben Dooks
Currently all but one user (AT91SAM9261EK) of the dm9000 driver passes their IRQ flags through the resources attached to the platform device. This means we can remove the use of DEFAULT_TRIGGER as the blackfin machines all seem to have their triggers set properly. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24DM9000: Add missing msleep() in EEPROM wait code.Ben Dooks
The msleep() call in the code that checks for the EEPROM controller's busy status was missing. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24DM9000: Allow the use of the NSR register to get link status.Ben Dooks
The DM9000's internal PHY reports a copy of the link status in the NSR register of the chip. Reading the status when polling for link status is faster as it eliminates the need to sleep, but does not print as much information. Add an platform flag to force this behaviour, and a Kconfig option to allow it to be forced to the faster method always. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24DM9000: Use NSR to determine link-status on internal PHYBen Dooks
The DM9000_NSR register contains a copy of the internal PHY's link status which we can use to determine if the link is up or down. This eliminates the more costly (and sleeping) PHY read when using the DM9000's own PHY. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24DM9000: Cleanup source code - remove forward declerationsBen Dooks
Cleanup the source code by moving the code around to avoid having to declare the functions before they are used. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24DM9000: Cleanup source codeBen Dooks
Cleanup bits of the DM9000 driver to make the code neater and easier to read. This is includes removing some old definitions, re-indenting areas, etc. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24DM9000: Cleanups after the resource changesBen Dooks
Remove the now extraneous checks in dm9000_release_board() now that the two-resource case is removed. Also remove the check on pdev->num_resources, as we check the return data from platform_get_resource() to ensure we have not only the right number but the right type of resources as well. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24DM9000: Add support for DM9000A and DM9000B chipsBen Dooks
Add support for both the DM9000A and DM9000B versions of the DM9000 networking chip. This includes adding support for the Link-Change IRQ which is used instead of polling the PHY every 2 seconds. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-24DM9000: Remove the 2 resources probe scheme.Laurent Pinchart
The dm9000 driver accepts either 2 or 3 resources to describe the platform devices. The 2 resources case abuses the ioresource mechanism by passing ioremap()ed memory through the platform device resources. This patch removes that case and converts boards that were using it to the 3 resources scheme. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Laurent Pinchart <laurentp@cse-semaphore.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-25Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/cpmac.c net/mac80211/mlme.c
