[ Upstream commit 6e46e2d821bb22b285ae8187959096b65d063b0d ]
The switch maintains u64 counters for the number of octets sent and
received. These are kept as two u32's which need to be combined. Fix
the combing, which wrongly worked on u16's.
Fixes: 80c4627b2719 ("dsa: mv88x6xxx: Refactor getting a single statistic")
Reported-by: Chris Healy <Chris.Healy@zii.aero>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Remove EEPROM flags in favor of new {get,set}_eeprom chip-wide
functions in the mv88e6xxx_ops structure.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Add a set_switch_mac chip-wide function to mv88e6xxx_ops and remove
MV88E6XXX_FLAG_G2_SWITCH_MAC flags.
Introduce a mv88e6xxx_ops structure to describe supported chip-wide
functions and assign the correct variant to the chip models.
For the moment, add only PHY access routines. This allows to get rid of
the PHY ops structures and the usage of PHY flags.
The mv88e6xxx_ops is used to describe how to access the chip registers.
It can be through SMI (via an MDIO bus), or via another interface such
as crafted remote management frames.
The correct BUS operations structure is chosen at runtime, depending on
the chip address and connectivity.
We will need the mv88e6xxx_ops name for future chip-wide operation
structure, thus rename mv88e6xxx_ops to more explicit mv88e6xxx_bus_ops.
The STU (if the switch has one) is abstracted and accessed through the
VTU operations and data registers.
Thus rename the mv88e6xxx_vtu_stu_entry struct to mv88e6xxx_vtu_entry.
Add an mv88e6xxx_num_ports helper instead of digging in the chip info
structure.
The mv88e6xxx_num_databases will be used by shared code, so move it
inline to the header file.
Add flags to describe the presence of Global 1 ATU FID register (0x01)
and VTU FID register (0x02), instead of checking families.
The Global (1) internal SMI device is an extended set of registers
containing ATU, PPU, VTU, STU, etc.
It is present on every switches, usually at SMI address 0x1B. But old
models such as 88E6060 access it at address 0xF, thus using REG_GLOBAL
is erroneous.
Add a global1_addr info member used by mv88e6xxx_g1_{read,write} and
mv88e6xxx_g1_wait helpers in a new global1.c file.
This patch finally removes _mv88e6xxx_reg_{read,write}, in favor on the
appropriate helpers. No functional changes here.
Fixes the following sparse warnings:
drivers/net/dsa/mv88e6xxx/chip.c:219:5: warning:
symbol 'mv88e6xxx_port_read' was not declared. Should it be static?
drivers/net/dsa/mv88e6xxx/chip.c:227:5: warning:
symbol 'mv88e6xxx_port_write' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Reviewed-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Now that the DSA layer handles port fast ageing on correct STP change,
simplify _mv88e6xxx_port_state and implement mv88e6xxx_port_fast_age.
There is a device coming soon which places its port registers
somewhere different to all other Marvell switches supported so far.
Add helper functions for reading/writing port registers, making it
easier to handle this new device.
An address can be loaded in the ATU with multiple ports, for instance
when adding multiple ports to a Multicast group with "bridge mdb".
The current code doesn't allow that. Add an helper to get a single entry
from the ATU, then set or clear the requested port, before loading the
entry back in the ATU.
Note that the required _mv88e6xxx_atu_getnext function is defined below
mv88e6xxx_port_db_load_purge, so forward-declare it for the moment. The
ATU code will be isolated in future patches.
Fixes: 83dabd1fa84c ("net: dsa: mv88e6xxx: make switchdev DB ops generic")
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Since not every chip has a Global2 set of registers, make its support
optional, in which case the related functions will return -EOPNOTSUPP.
This also allows to reduce the size of the mv88e6xxx driver for devices
such as home routers embedding Ethernet chips without Global2 support.
It is present on most recent chips, thus enable its support by default.
Marvell chips are composed of multiple SMI devices. One of them at
address 0x1C is called Global2. It provides an extended set of
registers, used for interrupt control, EEPROM access, indirect PHY
access (to bypass the PHY Polling Unit) and cross-chip related setup.
Most chips have it, but some others don't (older ones such as 6060).
Now that its related code is isolated in mv88e6xxx_g2_* functions, move
it to its own global2.c file, making most of its setup code static.
Document each registers in the meantime.
Its compilation can be later avoided for chips without such registers.
Access the priv member of the dsa_switch structure directly, instead of
having an unnecessary helper.
Add support for the MDB operations. This consists of
loading/purging/dumping multicast addresses for a given port in the ATU.
The MDB support for the mv88e6xxx driver will be very similar to the FDB
support, since it consists of loading/purging/dumping address to/from
the Address Translation Unit (ATU).
Prepare the support for MDB by making the FDB code accessing the ATU
generic. The FDB operations now provide access to the unicast addresses
while the MDB operations will provide access to the multicast addresses.
All three conflicts were cases of simple overlapping
changes.
Now that the dsa_switch_driver structure contains only function pointers
as it is supposed to, rename it to the more appropriate dsa_switch_ops,
uniformly to any other operations structure in the kernel.
No functional changes here, basically just the result of something like:
s/dsa_switch_driver *drv/dsa_switch_ops *ops/g
However keep the {un,}register_switch_driver functions and their
dsa_switch_drivers list as is, since they represent the -- likely to be
deprecated soon -- legacy DSA registration framework.
In the meantime, also fix the following checks from checkpatch.pl to
make it happy with this patch:
CHECK: Comparison to NULL could be written "!ops"
#403: FILE: net/dsa/dsa.c:470:
+ if (ops == NULL) {
CHECK: Comparison to NULL could be written "ds->ops->get_strings"
#773: FILE: net/dsa/slave.c:697:
+ if (ds->ops->get_strings != NULL)
CHECK: Comparison to NULL could be written "ds->ops->get_ethtool_stats"
#824: FILE: net/dsa/slave.c:785:
+ if (ds->ops->get_ethtool_stats != NULL)
CHECK: Comparison to NULL could be written "ds->ops->get_sset_count"
#835: FILE: net/dsa/slave.c:798:
+ if (ds->ops->get_sset_count != NULL)
total: 0 errors, 0 warnings, 4 checks, 784 lines checked
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
The PORT_RATE_CONTROL register works differently on 88e6095/6095f/6131
in comparison to 6123/61/65, and 0x0 disables. The distinction was lost
Linux 4.1 --> 4.2
Signed-off-by: Jamie Lentin <jm@lentin.co.uk>
Without it, a mv88e6131 switch will not forward incoming unicast
packets to the CPU port.
The PPU method of accessing PHYs makes use of a timer. Make sure this
timer is deleted before unloading the driver.
Reported-by: Jamie Lentin <jm@lentin.co.uk>
Older chips only support DSA tagging on the CPU port. New devices
support both DSA and EDSA. The driver needs to tell the core the tag
protocol to use, and configure the switch for what is available.
DSA drivers may drive different families of switches which need
different tag protocol. Rather than hard code the tag protocol in the
driver structure, have a callback for the DSA core to call.
When mv88e6xxx_wait() returns a timeout, something bad has
happened. Make sure it is noticed by logging an error.
Now that mv88e6xx_wait() iterated on a counter than a fixed time
interval, it implements the same mechanism as mv88e6xxx_update() uses.
So use it in mv88e6xx_wait().
The mv88e6xxx driver times out operations on the switch based on
looping until an elapsed wall clock time is reached. However, if
usleep_range() sleeps much longer than expected, it could timeout with
an error without actually checking to see if the devices has completed
the operation. So replace the elapsed time with a fixed upper bound on
the number of loops.
Testing on various switches has shown that switches takes either 0 or
1 iteration, so a maximum of 16 iterations is a safe limit.
This commit replaces every MDIO direct or indirect access with the new
generic mv88e6xxx_phy_* routines.
This allows us to get rid of the mv88e6xxx_mdio_{read,write}_{,in}direct
and {_,}mv88e6xxx_mdio_page_{read,write} functions.
Add mv88e6xxx_phy_page_{read,write} routines and use them to access the
SerDes PHY device registers.
Old chips use a direct access to the PHY devices registers. Next chips
have a PHY Polling Unit (PPU) which needs to be disabled before
accessing PHY registers. Newer chips have an indirect access to the PHY
devices so that disabling the PPU is not necessary.
Introduce a new phy_ops structure in the chip to describe the required
Describe the presence of the Global2 SMI PHY registers, used to
indirectly access the internal SMI devices registers on some chips.
Also temporarily forward declare mv88e6xxx_g2_smi_phy_{read,write} to
use them in mv88e6xxx_mdio_{read,write}_indirect, before getting rid of
the later.
Add flags to describe the presence of SMI Command and Data registers
used to indirectly access internal SMI devices registers when the switch
SMI address is not zero.
Now that there is no locked version of the wait routine anymore, rename
the _ prefixed version and make it use the new read API.
When CONFIG_NET_DSA_HWMON is disabled, we get warnings about two unused
functions whose only callers are all inside of an #ifdef:
drivers/net/dsa/mv88e6xxx.c:3257:12: 'mv88e6xxx_mdio_page_write' defined but not used [-Werror=unused-function]
drivers/net/dsa/mv88e6xxx.c:3244:12: 'mv88e6xxx_mdio_page_read' defined but not used [-Werror=unused-function]
This adds another ifdef around the function definitions. The warnings
appeared after the functions were marked 'static', but the problem
was already there before that.
Fixes: 57d3231057e9 ("net: dsa: mv88e6xxx: fix style issues")
Get rid of the last usage of the locked mv88e6xxx_reg_read function with
a new mv88e6xxx_port_read helper, useful later for chips with different
port registers base address.
The 6352 family of switches and compatibles provide a 8-bit address and
16-bit data access to an optional EEPROM.
Newer chip such as the 6390 family slightly changed the access to 16-bit
address and 8-bit data.
This commit cleans up the EEPROM access code for 16-bit access and makes
it easy to eventually introduce future support for 8-bit access.
Here's a list of notable changes brought by this patch:
- provide Global2 unlocked helpers for EEPROM commands
- remove eeprom_mutex, only reg_lock is necessary for driver functions
- eeprom_len is 0 for chip without EEPROM, so return it directly
- the Running bit must be 0 before r/w, so wait for Busy *and* Running
- remove now unused mv88e6xxx_wait and mv88e6xxx_reg_write
- other than that, the logic (in _{get,set}_eeprom16) didn't change
Chips with an 8-bit EEPROM access will require to implement the
8-suffixed variant of G2 helpers and the related flag:
#define MV88E6XXX_FLAGS_EEPROM8 \
(MV88E6XXX_FLAG_G2_EEPROM_CMD | \
MV88E6XXX_FLAG_G2_EEPROM_ADDR)
Implement the DSA driver function to configure the bridge ageing time.
All Marvell switch chips from (88E6060 to 88E6390) have a ATU Control
register containing bits 11:4 to configure an ATU Age Time quotient.
However the coefficient used to calculate the ATU Age Time vary with the
models. E.g. 88E6060, 88E6352 and 88E6390 use respectively 16, 15 and
3.75 seconds.
Add a age_time_coeff to the info structure to handle this and a Global 1
helper to set the default age time of 5 minutes in the setup code.
Add capability flags to describe the presence of Ingress Rate Limit unit
registers and an helper function to clear it.
In the meantime, fix a few harmless issues:
- 6185 and 6095 don't have such registers (reserved)
- the previous code didn't wait for the IRL operation to complete
Add flags and helpers to describe the presence of Priority Override
Table (POT) related registers and simplify the setup of Global 2.
Add flags to describe the presence of Cross-chip Port VLAN Table (PVT)
Switches such as 88E6185 as 3 Switch MAC registers in Global 1. Newer
chips such as 88E6352 have freed these registers in favor of an indirect
access in a Switch MAC/WoL/WoF register in Global 2.
Explicit this difference with G1 and G2 helpers and flags.
Also, note that this indirect access is a single-register which doesn't
require to wait for the operation to complete (like Switch MAC, Trunk
Mapping, etc.), in contrary to multi-registers indirect accesses with
several operations and a busy bit.
Some switches provide a Rsvd2CPU mechanism used to choose which of the
16 reserved multicast destination addresses matching 01:80:c2:00:00:0x
should be considered as MGMT and thus forwarded to the CPU port.
Other switches extend this mechanism to also configure as MGMT the
additional 16 reserved multicast addresses matching 01:80:c2:00:00:2x.
This mechanism is exposed via two registers in Global 2, and an Rsvd2CPU
enable bit in the management register.
Newer chip (such as 88E6390) has replaced these registers with a new
indirect MGMT mechanism in Global 1.
The patch adds two MV88E6XXX_FLAG_G2_MGMT_EN_{0,2}X flags to describe
the presence of these Global 2 registers. If 88E6390 support is added, a
MV88E6XXX_FLAG_G1_MGMT_CTRL flag will be needed to setup Rsvd2CPU.
Note: all switches still support in parallel the ATU Load operation with
an MGMT Entry State to forward such frames in a less convenient way.
The Trunk Mask and Trunk Mapping registers are two Global 2 indirect
accesses to trunking configuration.
Add helpers for these tables and simplify the Global 2 setup.
The Device Mapping register is an indirect table access.
Provide helpers to access this table and explicit the checking of the
new DSA_RTABLE_NONE routing table value.
Separate the setup of Global 1 and Global 2 internal SMI devices and add
a flag to describe the presence of this second registers set.
Also rearrange the G1 setup in the registers order.
All 88E6xxx Marvell switches (even the old not supported yet 88E6060)
have at least an ATU, per-port STP states and VLAN map, to run basic
switch functions such as Spanning Tree and port based VLANs.
Get rid of the related MV88E6XXX_FLAG_{ATU,PORTSTATE,VLANTABLE} flags,
as they are defaults to every chip.
This enables STP on 6185 and removes many inconsistencies on others.
With the upcoming support for cross-chip operations, it will be hard to
distinguish portions of code supporting a single-chip or a switch fabric
of interconnected chips.
Make the code clearer now, by renaming the mv88e6xxx_priv_state chip
structure to mv88e6xxx_chip. This patch brings no functional changes.
