path: root/drivers/net/e1000
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02e1000: remove use of skb_dma_map from e1000 driverAlexander Duyck
Remove the use of skb_dma_map from the e1000 driver in order to avoid issues when HW iommu are in use. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13e1000: Fix erroneous display of stats by ethtool -SAjit Khaparde
Commit 23d26497 overlooked the way offsets for netdev stats were considered. Because of this some of the stats shown by ethtool -S were wrong. This patch fixes it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07e1000: Use the instance of net_device_stats from net_device.Ajit Khaparde
Since net_device has an instance of net_device_stats, we can remove the instance of this from the adapter structure. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: cleanup unused prototypeDon Skidmore
The function e1000_enable_tx_pkt_filtering() was removed in a previous cleanup patch. this removes the no longer used prototype. Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: fix namespacecheck warningsJesse Brandeburg
a couple of functions needed to be removed/declared static Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: drop unused functionality for eeprom write/readJesse Brandeburg
eerd and eewr don't exist on pre PCIe devices Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: updated whitespace and commentsJesse Brandeburg
A large whitespace change to e1000_hw.[ch] in order to update it to kernel coding style (by running lindent). Updated function header comments into kdoc style. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: drop redunant line of code, cleanupJesse Brandeburg
adapter was being assigned twice, also clarified variable name and unwrapped line. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: remove races when changing mtuJesse Brandeburg
this patch fixes a bug that occurs when routing packets and simultaneously changing the mtu. the rx_buffer_len variable is used during the rx cleanup and if that changes on the fly without stopping traffic bad things happen Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: two workarounds were incomplete, fix themJesse Brandeburg
1) 82544 does not need last_tx_tso workaround, it interferes with the 82544 workaround too 2) 82544 hang workaround was using the address of the page struct instead of the physical address as its "workaround decider" not sure how that ever worked Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: fix tx waking queue after queue stopped during shutdownJesse Brandeburg
This fix closes a race where the adapter can be shutting down while hard_start_xmit is being called and interrupts are being handled. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: test link state conclusivelyJesse Brandeburg
e1000 was using one particular way to detect link, but with the advent of some of the newer hardware designs using SERDES connections, tests for link must completely cover all cases. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: stop timers at appropriate timesJesse Brandeburg
there were some hotplug cases that made timers still run after the driver had been removed, make sure to stop all the timers and not allow racy reschedules. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: use netif_tx_disableJesse Brandeburg
we can use netif_tx_disable now because LLTX has been removed. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: remove unused functionsJesse Brandeburg
after removal of pcie, need to remove some unnecessary functions Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26e1000: drop dead pcie code from e1000Jesse Brandeburg
this patch is the first in a series of clean up patches for e1000 to drop unused code, and update the driver to kernel spec, and then, to update the driver to have all available bug fixes. Call it the e1000 weight loss plan. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-03netdev: Remove redundant checks for CAP_NET_ADMIN in MDIO implementationsBen Hutchings
dev_ioctl() already checks capable(CAP_NET_ADMIN) before calling the driver's implementation of MDIO ioctls. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01e1000: Fix for e1000 kills IPMI on a tagged vlan.Graham, David
Enabling VLAN filters (VFE) when the primary interface is brought up (per commit 78ed11a) has caused problems for some users who manage their systems using IPMI over a VLAN. This is because when the driver enables the VLAN filter, this same filter table is enabled for the management channel, and the table is initially empty, which means that the IPMI/VLAN packets are filtered out and not received by the BMC. This is a problem only on e1000 class adapters, as it is only on e1000 that the filter table is common to the management and host streams. With this change, filtering is only enabled when one or more host VLANs exist, and is disabled when the last host VLAN is removed. VLAN filtering is always disabled when the primary interface is in promiscuous mode, and will be (re)enabled if VLANs exist when the interface exits promiscuous mode. Note that this does not completely resolve the issue for those using VLAN management, because if the host adds a VLAN, then the above problem occurs when that VLAN is enabled. However, it does mean the there is no problem for configurations where management is on a VLAN and the host is not. A complete solution to this issue would require further driver changes. The driver would need to discover if (and which) management VLANs are active before enabling VLAN filtering, so that it could ensure that the managed VLANs are included in the VLAN filter table. This discovery requires that the BMC identifies its VLAN in registers accessible to the driver, and at least on Dell PE2850 systems the BMC does not identify its VLAN to allow such discovery. Intel is pursuing this issue with the BMC vendor. Signed-off-by: Dave Graham <david.graham@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Krzysztof Piotr Oledzki <ole@ans.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01intel: convert drivers to netdev_tx_tStephen Hemminger
Get rid of some bogus return wrapping as well. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-26e1000: Remove unused function e1000_mta_set.Graham, David
Remove function e1000_mta_set, as it is no longer called Signed-off-by: Dave Graham <david.graham@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-06e1000: fix flow control thresholdsJesse Brandeburg
when testing the jumbo frames with pages patch, the stats would show rx_missed errors (dropped packets) even when connected to a link partner with flow control enabled. this indicates that for this MTU (9000) the flow control thresholds are not adjusting correctly. In fact, before this change, the FCRTH (xoff threshold) is 36864 when the fifo size is only 40000, with 9000 byte MTU. fix it so that we at least have room for one frame after we send the xoff. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-06e1000: implement jumbo receive with partial descriptorsJesse Brandeburg
This is code extremely similar to what is committed in e1000e already. e1000 will no longer request 32kB slab buffers to support jumbo frames on PCI/PCI-X adapters. This will significantly reduce the likelyhood of order:3 allocation failures. This new code adds support for using pages as receive buffers, and the driver will chain multiple pages together to build a jumbo frame for OS consumption. The hardware takes a power of two buffer size and will dump as much data as it can receive into 1 or more buffers. The benefits of applying this are 1) stop akpm's dissing :-) of this lame e1000 behavior [1] 2) more efficient memory allocation (half) when using jumbo frames, which will also allow for much better socket utilization with jumbos since the socket is charged for the full allocation of each receive buffer, regardless of how much is used. 3) this was a feature request by a customer 4) copybreak for small packets < 256 bytes still applies [1] http://lkml.org/lkml/2008/7/10/68 http://article.gmane.org/gmane.linux.network/130986 Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> CC: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-06e1000: allow ethtool coalesece to adjust interrupts per secondJesse Brandeburg
This patch allows on-the-fly adjustment of the interrupts per second generated by e1000 devices 82545/82546 (hardware support of ITR register is a requirement) adjust using this command: ethtool -C eth0 rx-usecs 10 where 10 is 10 microseconds per interrupt interval, so 10 = 100,000 interrupts per second, and 125 = 8000 interrupts per second. changes should be immediate. 1,3 are special values and indicate the automatic tuning mode to the driver, where 1 is 4000-90000 interrupts per second and 3 is 4000-20000 interrupts per second and is the driver default. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30e1000: return PCI_ERS_RESULT_DISCONNECT on permanent errorAndre Detsch
PCI drivers that implement the io_error_detected callback should return PCI_ERS_RESULT_DISCONNECT if the state passed in is pci_channel_io_perm_failure. This state is not checked in many of the network drivers. The patch fixes the omission in the e1000 driver. Based on Mike Mason's similar patch for e1000e. Signed-off-by: Andre Detsch <adetsch@br.ibm.com> CC: Mike Mason <mmlnx@us.ibm.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-30e1000: fix unmap bugJesse Brandeburg
as reported by kerneloops.org [ 121.781161] ------------[ cut here ]------------ [ 121.781171] WARNING: at lib/dma-debug.c:793 check_unmap+0x14e/0x577() [ 121.781173] Hardware name: S5520HC [ 121.781177] e1000 0000:0a:00.0: DMA-API: device driver tries to free DMA memory it has not allocated [device address=0x00000001d688b0fa] [size=1522 bytes] [ 121.781180] Modules linked in: e1000 mdio dca [last unloaded: ixgbe] [ 121.781187] Pid: 4793, comm: bash Tainted: P 2.6.30-master-06161113 #3 [ 121.781190] Call Trace: [ 121.781195] [<ffffffff8123056f>] ? check_unmap+0x14e/0x577 [ 121.781201] [<ffffffff81057a19>] warn_slowpath_common+0x77/0x8f [ 121.781205] [<ffffffff81057ae1>] warn_slowpath_fmt+0x9f/0xa1 [ 121.781212] [<ffffffff81477ce2>] ? _spin_lock_irqsave+0x3f/0x49 [ 121.781216] [<ffffffff8122fa97>] ? get_hash_bucket+0x28/0x33 [ 121.781220] [<ffffffff8123056f>] check_unmap+0x14e/0x577 [ 121.781225] [<ffffffff810e4f48>] ? check_bytes_and_report+0x38/0xcb [ 121.781230] [<ffffffff81230bbf>] debug_dma_unmap_page+0x80/0x92 [ 121.781234] [<ffffffff8122e549>] ? unmap_single+0x1a/0x4e [ 121.781239] [<ffffffff813901e1>] ? __kfree_skb+0x74/0x78 [ 121.781250] [<ffffffffa00662ef>] pci_unmap_single+0x64/0x6d [e1000] [ 121.781259] [<ffffffffa0066344>] e1000_clean_rx_ring+0x4c/0xbf [e1000] [ 121.781268] [<ffffffffa00663df>] e1000_clean_all_rx_rings+0x28/0x36 [e1000] [ 121.781277] [<ffffffffa0067464>] e1000_down+0x138/0x141 [e1000] [ 121.781286] [<ffffffffa00681c2>] __e1000_shutdown+0x6b/0x198 [e1000] [ 121.781296] [<ffffffffa0068405>] e1000_suspend+0x17/0x50 [e1000] [ 121.781301] [<ffffffff81237665>] pci_legacy_suspend+0x3b/0xbe [ 121.781305] [<ffffffff81237bc6>] pci_pm_suspend+0x3e/0xf1 [ 121.781310] [<ffffffff812eaf1c>] pm_op+0x57/0xde [ 121.781314] [<ffffffff812eb444>] dpm_suspend_start+0x31e/0x470 [ 121.781319] [<ffffffff810877da>] suspend_devices_and_enter+0x3e/0x1a2 [ 121.781323] [<ffffffff81087a0f>] enter_state+0xd1/0x127 [ 121.781327] [<ffffffff8108717a>] state_store+0xa7/0xc9 [ 121.781332] [<ffffffff81221843>] kobj_attr_store+0x17/0x19 [ 121.781336] [<ffffffff8113c01e>] sysfs_write_file+0xe5/0x121 [ 121.781341] [<ffffffff810ed165>] vfs_write+0xab/0x105 [ 121.781344] [<ffffffff810ed279>] sys_write+0x47/0x6d [ 121.781349] [<ffffffff81027aab>] system_call_fastpath+0x16/0x1b [ 121.781352] ---[ end trace 97bacaaac2ed7786 ]--- Fix is to correctly zero out internal ->dma value when unmapping and make sure never to unmap unless there specifically was a mapping done. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: group address list and its countJiri Pirko
This patch is inspired by patch recently posted by Johannes Berg. Basically what my patch does is to group list and a count of addresses into newly introduced structure netdev_hw_addr_list. This brings us two benefits: 1) struct net_device becames a bit nicer. 2) in the future there will be a possibility to operate with lists independently on netdevices (with exporting right functions). I wanted to introduce this patch before I'll post a multicast lists conversion. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 4 +- drivers/net/e1000/e1000_main.c | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/mv643xx_eth.c | 2 +- drivers/net/niu.c | 4 +- drivers/net/virtio_net.c | 10 ++-- drivers/s390/net/qeth_l2_main.c | 2 +- include/linux/netdevice.h | 17 +++-- net/core/dev.c | 130 ++++++++++++++++++-------------------- 9 files changed, 89 insertions(+), 90 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08net: skb_shared_info optimizationEric Dumazet
skb_dma_unmap() is quite expensive for small packets, because we use two different cache lines from skb_shared_info. One to access nr_frags, one to access dma_maps[0] Instead of dma_maps being an array of MAX_SKB_FRAGS + 1 elements, let dma_head alone in a new dma_head field, close to nr_frags, to reduce cache lines misses. Tested on my dev machine (bnx2 & tg3 adapters), nice speedup ! Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/forcedeth.c
2009-06-02e1000: add missing length check to e1000 receive routineNeil Horman
Patch to fix bad length checking in e1000. E1000 by default does two things: 1) Spans rx descriptors for packets that don't fit into 1 skb on recieve 2) Strips the crc from a frame by subtracting 4 bytes from the length prior to doing an skb_put Since the e1000 driver isn't written to support receiving packets that span multiple rx buffers, it checks the End of Packet bit of every frame, and discards it if its not set. This places us in a situation where, if we have a spanning packet, the first part is discarded, but the second part is not (since it is the end of packet, and it passes the EOP bit test). If the second part of the frame is small (4 bytes or less), we subtract 4 from it to remove its crc, underflow the length, and wind up in skb_over_panic, when we try to skb_put a huge number of bytes into the skb. This amounts to a remote DOS attack through careful selection of frame size in relation to interface MTU. The fix for this is already in the e1000e driver, as well as the e1000 sourceforge driver, but no one ever pushed it to e1000. This is lifted straight from e1000e, and prevents small frames from causing the underflow described above Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Tested-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: convert unicast addr listJiri Pirko
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. It also relaxes the locking. Original spinlock (still used for multicast addresses) is not needed and is no longer used for a protection of this list. All reading and writing takes place under rtnl (with no changes). I also removed a possibility to specify the length of the address while adding or deleting unicast address. It's always dev->addr_len. The convertion touched especially e1000 and ixgbe codes when the change is not so trivial. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 13 +-- drivers/net/e1000/e1000_main.c | 24 +++-- drivers/net/ixgbe/ixgbe_common.c | 14 ++-- drivers/net/ixgbe/ixgbe_common.h | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/ixgbe/ixgbe_type.h | 4 +- drivers/net/macvlan.c | 11 +- drivers/net/mv643xx_eth.c | 11 +- drivers/net/niu.c | 7 +- drivers/net/virtio_net.c | 7 +- drivers/s390/net/qeth_l2_main.c | 6 +- drivers/scsi/fcoe/fcoe.c | 16 ++-- include/linux/netdevice.h | 18 ++-- net/8021q/vlan.c | 4 +- net/8021q/vlan_dev.c | 10 +- net/core/dev.c | 195 +++++++++++++++++++++++++++----------- net/dsa/slave.c | 10 +- net/packet/af_packet.c | 4 +- 18 files changed, 227 insertions(+), 137 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_startEric Dumazet
Second round of drivers for Gb cards (and NIU one I forgot in the 10GB round) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: include/net/tcp.h
2009-05-07e1000/e1000e/igb/ixgb: don't txhang after link downJesse Brandeburg
after the recent changes to wired drivers to use only netif_carrier_off the driver can have outstanding tx work to complete that will never complete once link is down. Since the intel hardware will hold this tx work forever, the driver notices a tx timeout condition internally and might try to instigate printk and reset of the part with a netif_stop_queue, which doesn't work because link is down. Don't bother arming to tx hang detection when link is down. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-04e1000: fix virtualization bugJesse Brandeburg
a recent fix to e1000 (commit 15b2bee2) caused KVM/QEMU/VMware based virtualized e1000 interfaces to begin failing when resetting. This is because the driver in a virtual environment doesn't get to run instructions *AT ALL* when an interrupt is asserted. The interrupt code runs immediately and this recent bug fix allows an interrupt to be possible when the interrupt handler will reject it (due to the new code), when being called from any path in the driver that holds the E1000_RESETTING flag. the driver should use the __E1000_DOWN flag instead of the __E1000_RESETTING flag to prevent interrupt execution while reconfiguring the hardware. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-22e1000/e1000e/igb/ixgb: do not use netif_wake_queue un-necessarilyJesse Brandeburg
It was pointed out that the Intel wired ethernet drivers do not need to wake the tx queue since netif_carrier_on/off will take care of the qdisc management in order to guarantee the correct handling of the transmit routine enable state. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/dev.c
2009-04-20e1000: init link state correctlyJesse Brandeburg
As reported by Andrew Lutomirski <amluto@gmail.com> All the intel wired ethernet drivers were calling netif_carrier_off and netif_stop_queue (or variants) before calling register_netdevice This is incorrect behavior as was pointed out by davem, and causes ifconfig and friends to report a strange state before first link after the driver was loaded. This apparently confused *some* versions of networkmanager. Andy tested this for e1000e and confirmed it was working for him. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Reported-by: Andrew Lutomirski <amluto@gmail.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-17e1000: fix transmit routine exit bugJesse Brandeburg
If the e1000 transmit cleanup inner loop exited early, then cleaned might not be true. This could cause tx hangs or other badness. Use count to track the total number of descriptors cleaned instead of basing a tx queue restart off of a temporary working state variable. This code now makes the flow the same for e1000/e1000e/igb/ixgbe Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-16NET/e1000: Fix powering off during shutdownRafael J. Wysocki
Prevent e1000 from putting the adapter into D3 during shutdown except when we're going to power off the system, since doing that may generally cause problems with kexec to happen (such problems were observed for igb and forcedeth). For this purpose seperate e1000_shutdown() from e1000_suspend() and use the appropriate PCI PM callbacks in both of them. Signed-off-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-14e1000/e1000: fix compile warningJesse Brandeburg
e1000/e1000e compile report a possible unused variable, fix that for now. Shortly after this a small refactor and bug fix will follow in the same code. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-04e1000: fix loss of multicast packetsJesse Brandeburg
e1000 (and e1000e, igb, ixgbe, ixgb) all do a series of operations each time a multicast address is added. The flow goes something like 1) stack adds one multicast address 2) stack passes whole current list of unicast and multicast addresses to driver 3) driver clears entire list in hardware 4) driver programs each multicast address using iomem in a loop This was causing multicast packets to be lost during the reprogramming process. reference with test program: http://kerneltrap.org/mailarchive/linux-netdev/2009/3/14/5160514/thread Thanks to Dave Boutcher for his report and test program. This driver fix prepares an array all at once in memory and programs it in one shot to the hardware, not requiring an "erase" cycle. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-26e1000: fix close race with interruptJesse Brandeburg
this is in regards to http://bugzilla.kernel.org/show_bug.cgi?id=12876 where it appears that e1000 can leave its interrupt enabled after exiting the driver. Fix the bug by making the interrupt enable paths more aware of the driver exiting. Thanks to Alan Cox for the poke and initial investigation. CC: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-26e1000: cleanup clean_tx_irq routine so that it completely cleans ringAlexander Duyck
The tx cleanup routine was stopping after 64 packets and this was causing issues resulting in the ring not being completely cleaned. This change updates the driver to clean the entire ring and if it doesn't it then will retry on the next pass. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-26e1000: fix tx hang detect logic and address dma mapping issuesAlexander Duyck
This patch changes the dma mapping to better support skb_dma_map/skb_dma_unmap and addresses and redefines the tx hang logic to be based off of time stamp instead of if the dma field is populated Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
