path: root/drivers/net/e1000e
2011-07-12e1000e: use GFP_KERNEL allocations at init timeJeff Kirsher
In process and sleep allowed context, favor GFP_KERNEL allocations over GFP_ATOMIC ones. -v2: fixed checkpatch.pl warnings CC: Eric Dumazet <eric.dumazet@gmail.com> CC: Ben Greear <greearb@candelatech.com> CC: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-12e1000e: Add Jumbo Frame support to 82583 devicesCarolyn Wyborny
This patch adds support for the Jumbo Frames feature on 82583 devices. Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-11e1000e: remove e1000_queue_statsEric Dumazet
struct e1000_queue_stats is not used, lets remove it Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-04net: e1000e: Use is_multicast_ether_addr helperTobias Klauser
Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-27e1000e: remove unnecessary reads of PCI_CAP_ID_EXPJon Mason
The PCIE capability offset is saved during PCI bus walking. It will remove an unnecessary search in the PCI configuration space if this value is referenced instead of reacquiring it. Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09e1000e: update driver versionBruce Allan
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-09e1000e: Clear host wakeup bit on 82577/8 without touching PHY page 800Bruce Allan
The Host Wakeup Active bit in the PHY Port General Configuration register (page 769 register 17) must be cleared after every PHY reset to prevent an unexpected wake signal from the PHY. Originally, this was accomplished by simply reading the PHY Wakeup Control register on page 800 which clears the Host Wakeup Active bit as a side-effect. Unfortunately, a hardware bug on the 82577 and 82578 PHY can cause unexpected behavior when registers on page 800 are accessed while in gigabit mode. This patch changes the remaining instances when the Host Wakeup Active bit needs to be cleared while possibly in gigabit mode by accessing the Port General Configuration register directly instead of accessing any register on page 800. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-09e1000e: access multiple PHY registers on same page at the same timeBruce Allan
Doing a PHY page select can take a long time, relatively speaking. This can cause a significant delay when updating a number of PHY registers on the same page by unnecessarily setting the page for each PHY access. For example when going to Sx, all the PHY wakeup registers (WUC, RAR[], MTA[], SHRAR[], IP4AT[], IP6AT[], etc.) on 82577/8/9 need to be updated which takes a long time which can cause issues when suspending. This patch introduces new PHY ops function pointers to allow callers to set the page directly and do any number of PHY accesses on that page. This feature is currently only implemented for 82577, 82578 and 82579 PHYs for both the normally addressed registers as well as the special- case addressing of the PHY wakeup registers on page 800. For the latter registers, the existing function for accessing the wakeup registers has been divided up into three- 1) enable access to the wakeup register page, 2) perform the register access and 3) disable access to the wakeup register page. The two functions that enable/disable access to the wakeup register page are necessarily available to the caller so that the caller can restore the value of the Port Control (a.k.a. Wakeup Enable) register after the wakeup register accesses are done. All instances of writing to multiple PHY registers on the same page are updated to use this new method and to acquire any PHY locking mechanism before setting the page and performing the register accesses, and release the locking mechanism afterward. Some affiliated magic number cleanup is done as well. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-09e1000e: do not schedule the Tx queue until readyBruce Allan
Start the Tx queue when the interface is brought up in e1000e_up() but do not schedule the queue until link is up as detected in the watchdog task which sets netif_carrier_on. Also flush the descriptors and clean the Tx and Rx rings before resetting the hardware when bringing the interface down otherwise there is a small window where the watchdog task can be triggered with netif_carrier_off and the Tx ring not yet empty which causes an additional and unnecessary reset. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-09e1000e: log when swflag is cleared unexpectedly on ICH/PCH devicesBruce Allan
Since EXTCNF_CTRL.SWFLAG (used in the ownership arbitration of shared resources, e.g. the PHY shared between the s/w, f/w, and h/w clients) can be cleared by any of those clients, log a debug message when software attempts to clear it and it is already cleared unexpectedly. And since the swflag is cleared by a hardware reset, the driver does not need to do that, but the mutex acquired when the bit is set must still be cleared. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-09e1000e: 82579 intermittently disabled during S0->SxBruce Allan
When repeatedly cycling Sx->S0 states with the network cable unplugged, the 82579 PHY may not initialize as expected and may require a full power cycle to recover functionality to the device. Workaround this by testing access of the PHY registers after resuming; if that returns unexpected results toggle the LANPHYPC signal to power cycle the PHY. This is implemented in the new function e1000_resume_workarounds_pchlan() which calls another new function, e1000_toggle_lanphypc_value_ich8lan(), which has been created to reduce code duplication (same functionality required by a previous workaround). Also, e1000e_disable_gig_wol_ich8lan is now e1000_suspend_workarounds_ich8lan to better reflect what it does. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-09e1000e: disable far-end loopback mode on ESB2Bruce Allan
The ESB2 LAN includes a debug feature that enables far-end loopback (FELB) of the SerDes/Kumeran interface. This feature is activated when receiving a sequence of symbols that includes a reserved codeword. On a perfect link, FELB would never be activated. In the presence of bit errors, there is a very small, but non-zero, probability of FELB being activated. If the FELB is activated, the SerDes link becomes non-functional and must be reset. It could also corrupt the switching tables in the switch since the ESB2 is transmitting packets with a different source MAC address. This patch disables the FELB feature. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-21PCI/e1000e: Add and use pci_disable_link_state_locked()Yinghai Lu
Need to use it in _e1000e_disable_aspm. This routine is used for error recovery, where the pci_bus_sem is already held, and we don't want pci_disable_link_state to try to take it again. So add a locked variant for use in cases like this. Found lock up: [ 2374.654557] kworker/32:1 D ffff881027f6b0f0 0 6075 2 0x00000000 [ 2374.654816] ffff88503f099a68 0000000000000046 ffff88503f098000 0000000000004000 [ 2374.654837] 00000000001d1ec0 ffff88503f099fd8 00000000001d1ec0 ffff88503f099fd8 [ 2374.654860] 0000000000004000 00000000001d1ec0 ffff88503dcc8000 ffff88503f090000 [ 2374.654880] Call Trace: [ 2374.654898] [<ffffffff810b1302>] ? __lock_acquired+0x3a/0x224 [ 2374.654914] [<ffffffff81c2b59c>] ? _raw_spin_unlock_irq+0x30/0x36 [ 2374.654925] [<ffffffff810b069d>] ? trace_hardirqs_on_caller+0x1f/0x178 [ 2374.654936] [<ffffffff81c2ab24>] rwsem_down_failed_common+0xd3/0x103 [ 2374.654945] [<ffffffff810b158f>] ? __lock_contended+0x3a/0x2a2 [ 2374.654955] [<ffffffff81c2ab7b>] rwsem_down_read_failed+0x12/0x14 [ 2374.654967] [<ffffffff813371e4>] call_rwsem_down_read_failed+0x14/0x30 [ 2374.654981] [<ffffffff8135df20>] ? pci_disable_link_state+0x5f/0xf5 [ 2374.654990] [<ffffffff81c2a0e6>] ? down_read+0x7e/0x91 [ 2374.654999] [<ffffffff8135df20>] ? pci_disable_link_state+0x5f/0xf5 [ 2374.655008] [<ffffffff8135df20>] pci_disable_link_state+0x5f/0xf5 [ 2374.655024] [<ffffffff81661796>] e1000e_disable_aspm+0x55/0x5a [ 2374.655037] [<ffffffff816677eb>] e1000_io_slot_reset+0x59/0xea [ 2374.655048] [<ffffffff8135fe0d>] ? report_mmio_enabled+0x5d/0x5d [ 2374.655057] [<ffffffff8135fe3b>] report_slot_reset+0x2e/0x5d [ 2374.655072] [<ffffffff8135369e>] pci_walk_bus+0x8a/0xb7 [ 2374.655081] [<ffffffff8135fe0d>] ? report_mmio_enabled+0x5d/0x5d [ 2374.655091] [<ffffffff813603be>] broadcast_error_message+0xa4/0xb2 [ 2374.655101] [<ffffffff81352c71>] ? pci_bus_read_config_dword+0x72/0x80 [ 2374.655110] [<ffffffff813606df>] do_recovery+0x9e/0xf9 [ 2374.655120] [<ffffffff81360786>] handle_error_source+0x4c/0x51 [ 2374.655129] [<ffffffff81360974>] aer_isr_one_error+0x1e9/0x21a [ 2374.655138] [<ffffffff81360a6c>] aer_isr+0xc7/0xcc [ 2374.655147] [<ffffffff813609a5>] ? aer_isr_one_error+0x21a/0x21a [ 2374.655159] [<ffffffff81096d9f>] process_one_work+0x237/0x3ec [ 2374.655168] [<ffffffff81096d10>] ? process_one_work+0x1a8/0x3ec [ 2374.655178] [<ffffffff8109728d>] worker_thread+0x17c/0x240 [ 2374.655186] [<ffffffff810b0803>] ? trace_hardirqs_on+0xd/0xf [ 2374.655196] [<ffffffff81097111>] ? manage_workers+0xab/0xab [ 2374.655209] [<ffffffff8109c8ed>] kthread+0xa0/0xa8 [ 2374.655223] [<ffffffff81c332d4>] kernel_thread_helper+0x4/0x10 [ 2374.655232] [<ffffffff81c2b880>] ? retint_restore_args+0xe/0xe [ 2374.655243] [<ffffffff8109c84d>] ? __init_kthread_worker+0x5b/0x5b [ 2374.655252] [<ffffffff81c332d0>] ? gs_change+0xb/0xb when aer happens, pci_walk_bus already have down_read(&pci_bus_sem)... then report_slot_reset ==> e1000_io_slot_reset ==> e1000e_disable_aspm ==> pci_disable_link_state... We can not use pci_disable_link_state, and it will try to hold pci_bus_sem again. Try to have __pci_disable_link_state that will not need to hold pci_bus_sem. -v2: change name to pci_disable_link_state_locked() according to Jesse. [jbarnes: make sure new function is exported for modules] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-14e1000e: minor comment cleanupsBruce Allan
2011-04-29net/igb/e1000/e1000e: more robust ethtool duplex/speed configurationDavid Decotigny
This makes sure that one cannot request a 99Mbps full-duplex and get a 100Mbps half-duplex configuration in return due to the way the speed/duplex parameters are handled internally. Tested: e1000 works Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: Use full 32 bit speed range in ethtool's set_settingsDavid Decotigny
This makes sure the ethtool's set_settings() callback of network drivers don't ignore the 16 most significant bits when ethtool calls their set_settings(). All drivers compiled with make allyesconfig on x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-27e1000e: implement ethtool set_phys_idBruce Allan
Based on a patch from Stephen Hemminger <shemminger@vyatta.com>. The new ethtool set_phys_id takes over controlling the LED for identifying boards. This fixes the lockout during that period. For this device lots of extra infrastructure can also be removed by using set_phys_id. v2: - return blink frequency for parts that do not support blink in h/w - add blink_led function pointers for devices that do support blink in h/w to cleanup the test for this functionality Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-04-13e1000e: If ASPM L0s needs to be disabled, do it prior to enabling deviceBruce Allan
Based on a patch from Naga Chumbalkar <nagananda.chumbalkar@hp.com>: If ASPM L0s needs to be disabled due to HW errata, do it prior to "enabling" the device. This way if the kernel ever defaults its aspm_policy to POLICY_POWERSAVE, then the e1000e driver will get a chance to disable ASPM on the misbehaving device *prior* to calling pci_enable_device_mem(). This will be useful in situations where the BIOS indicates ASPM support on the server by clearing the ACPI FADT "ASPM Controls" bit. Note: The kernel (2.6.38) currently uses the BIOS "default" as its aspm_policy. However, Linux distros can diverge from that and set the default to "powersave". v2: o cleanup namespace pollution of e1000e_disable_aspm(), o fix type and initialization of the new aspm_disable_flag in a few functions, and o redefine FLAG2_DISABLE_ASPM_L0S to the first unused bit in adapter->flags2. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Cc: Naga Chumbalkar <nagananda.chumbalkar@hp.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-04-13e1000e: fix stats locking in e1000_watchdog_taskFlavio Leitner
Just move the unlock down a bit because it unlocks too early leaving a chance for get_stats64() run in parallel while it is still accessing the stats. Signed-off-by: Flavio Leitner <fleitner@redhat.com> Acked-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-04-13e1000e: convert to new VLAN modelJeff Kirsher
This switches the e1000e driver to use the new VLAN interfaces. CC: Jesse Gross <jesse@nicira.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
2011-04-13e1000e: PCIe link speed in GT/s, not GB/sBruce Allan
Correct the log message when driver loads. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-04-13e1000e: convert short duration msleep() to usleep_range()Bruce Allan
With durations less than 20ms, the jiffies or legacy timer backed msleep() may sleep ~20ms which might not be what the caller expects. Instead, it is recommended to use the hrtimers backed usleep_range(). For more, see Documentation/timers/timers-howto.txt. Issues reported by checkpatch. In addition, remove unnecessary sleep in e1000e_write_nvm_spi(). Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-15PM: Remove CONFIG_PM_OPSRafael J. Wysocki
After redefining CONFIG_PM to depend on (CONFIG_PM_SLEEP || CONFIG_PM_RUNTIME) the CONFIG_PM_OPS option is redundant and can be replaced with CONFIG_PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-11e1000e: bump version numberBruce Allan
2011-03-11e1000e: do not suggest the driver supports Wake-on-ARPBruce Allan
The driver doesn't support Wake-on-ARP, so don't advertise through ethtool that it does. Cleanup some coding style issues in the same functions. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-11e1000e: disable jumbo frames on 82579 when MACsec enabled in EEPROMBruce Allan
If/when an OEM enables MACsec in the 82579 EEPROM, disable jumbo frames support in the driver due to an interoperability issue in hardware that prevents jumbo packets from being transmitted or received. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-11e1000e: do not toggle LANPHYPC value bit when PHY reset is blockedBruce Allan
When PHY reset is intentionally blocked on 82577/8/9, do not toggle the LANPHYPC value bit (essentially performing a hard power reset of the device) otherwise the PHY can be put into an unknown state. Cleanup whitespace in the same function. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-11e1000e: extend EEE LPI timer to prevent dropped linkBruce Allan
The link can be unexpectedly dropped when the timer for entering EEE low- power-idle quiet state expires too soon. The timer needs to be extended from 196usec to 200usec after every LCD (PHY) reset to prevent this from happening. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-11e1000e: extend timeout for ethtool link test diagnosticBruce Allan
With some PHYs supported by this driver, link establishment can take a little longer when connected to certain switches. Extend the timeout to reduce the number of false diagnostic failures, and cleanup a code style issue in the same function. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-11e1000e: magic number cleanup - ETH_ALENBruce Allan
2011-03-11e1000e: use dev_kfree_skb_irq() instead of dev_kfree_skb()Bruce Allan
Based on a report and patch originally submitted by Prasanna Panchamukhi. Use dev_kfree_skb_irq() in e1000_clean_jumbo_rx_irq() since this latter function is called only in interrupt context. This avoids "Warning: kfree_skb on hard IRQ" messages. Cc: "Prasanna S. Panchamukhi" <prasanna.panchamukhi@riverbed.com> Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-03-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x.h
2011-03-02e1000e: disable broken PHY wakeup for ICH10 LOMs, use MAC wakeup insteadBruce Allan
When support for 82577/82578 was added[1] in 2.6.31, PHY wakeup was in- advertently enabled (even though it does not function properly) on ICH10 LOMs. This patch makes it so that the ICH10 LOMs use MAC wakeup instead as was done with the initial support for those devices (i.e. 82567LM-3, 82567LF-3 and 82567V-4). [1] commit a4f58f5455ba0efda36fb33c37074922d1527a10 Reported-by: Aurelien Jarno <aurelien@aurel32.net> Cc: <stable@kernel.org> Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-02-28net: use pci_dev->revision, againSergei Shtylyov
Several more network drivers that read the device's revision ID from the PCI configuration register were merged after the commit 44c10138fd4bbc4b6d6bff0873c24902f2a9da65 (PCI: Change all drivers to use pci_device->revision), so it's time to do another pass of conversion to using the 'revision' field of 'struct pci_dev'... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-19Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/net/e1000e/netdev.c net/xfrm/xfrm_policy.c
2011-02-17e1000e: flush all writebacks before unloadJesse Brandeburg
The driver was not flushing all writebacks before unloading, possibly causing memory to be written by the hardware after the driver had reinitialized the rings. This adds missing functionality to flush any pending writebacks and is called in all spots where descriptors should be completed before the driver begins processing. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Reviewed-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-02-17e1000e: check down flag in tasksJesse Brandeburg
This change is part of a fix to avoid any tasks running while the driver is exiting and deinitializing resources. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-02-11e1000e: return appropriate errors for 'ethtool -r'Bruce Allan
...when invoked while interface is not up or when auto-negotiation is disabled as done by other drivers. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-02-11e1000e: use correct pointer when memcpy'ing a 2-dimensional arrayBruce Allan
*e1000_gstrings_test is not the same size as e1000_gstrings_test. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-02-11e1000e: replace unbounded sprintf with snprintfBruce Allan
2011-02-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e1000e/netdev.c
2011-02-08e1000e: tx_timeout should not increment for non-hang eventsJesse Brandeburg
Currently the driver increments the tx_timeout counter (an error counter) when simply resetting the part with outstanding transmit work pending. This is an unnecessary count of an error, when all we should be doing is just resetting the part and discarding the transmits. With this change the only increment of tx_timeout is when the stack calls the watchdog reset function due to a true Tx timeout. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Reviewed-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-01-24e1000e: Use kmemdup rather than duplicating its implementationBruce Allan
The semantic patch that makes this output is available in scripts/coccinelle/api/memdup.cocci. More information about semantic patching is available at http://coccinelle.lip6.fr/ Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-01-24e1000e: reduce scope of some variables, remove unnecessary onesBruce Allan
Static analysis of the driver code found some variables for which the scope can be reduced, or remove the variable altogether. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
