path: root/drivers/net/ehea/ehea_main.c
2011-05-23ehea: Fix multicast registration on semi-promiscuous modeBreno Leitao
Ehea will not register multicast groups in phyp if the physical interface is in promiscuous mode. But it should register if the logical port is in promiscuous mode, but the physical port is not. Ehea physical promiscuous mode is defined by ehea_port->promisc, while logical port is defined by IFF_PROMISC. So currently, if the user set the interface in promiscuous mode, IGMP will not be registred in PHYP, and PHYP will never pass the multicast packet to the logical port, which is bad So, this patch just fixes it, assuring that we register in phyp if the physical port is not on promiscuous mode. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-20sanitize <linux/prefetch.h> usageLinus Torvalds
Commit e66eed651fd1 ("list: remove prefetching from regular list iterators") removed the include of prefetch.h from list.h, which uncovered several cases that had apparently relied on that rather obscure header file dependency. So this fixes things up a bit, using grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]') grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]') to guide us in finding files that either need <linux/prefetch.h> inclusion, or have it despite not needing it. There are more of them around (mostly network drivers), but this gets many core ones. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/vmxnet3/vmxnet3_ethtool.c net/core/dev.c
2011-05-12ehea: Fix memory hotplug oopsAnton Blanchard
The ehea driver oopses during memory hotplug if the ports are not up. A simple testcase: # ifconfig ethX down # echo offline > /sys/devices/system/memory/memory32/state Oops: Kernel access of bad area, sig: 11 [#1] last sysfs file: /sys/devices/system/memory/memory32/state REGS: c000000709393110 TRAP: 0300 Not tainted (2.6.39-rc2-01385-g7ef73bc-dirty) DAR: 0000000000000000, DSISR: 40000000 ... NIP [c000000000067c98] .__wake_up_common+0x48/0xf0 LR [c00000000006d034] .__wake_up+0x54/0x90 Call Trace: [c00000000006d034] .__wake_up+0x54/0x90 [d000000006bb6270] .ehea_rereg_mrs+0x140/0x730 [ehea] [d000000006bb69c4] .ehea_mem_notifier+0x164/0x170 [ehea] [c0000000006fc8a8] .notifier_call_chain+0x78/0xf0 [c0000000000b3d70] .__blocking_notifier_call_chain+0x70/0xb0 [c000000000458d78] .memory_notify+0x28/0x40 [c0000000001871d8] .remove_memory+0x208/0x6d0 [c000000000458264] .memory_section_action+0x94/0x140 [c0000000004583ec] .memory_block_change_state+0xdc/0x1d0 [c0000000004585cc] .store_mem_state+0xec/0x160 [c00000000044768c] .sysdev_store+0x3c/0x50 [c00000000020b48c] .sysfs_write_file+0xec/0x1f0 [c00000000018f86c] .vfs_write+0xec/0x1e0 [c00000000018fa88] .SyS_write+0x58/0xd0 To fix this, initialise the waitqueues during port probe instead of port open. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable@kernel.org Acked-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Resolved logic conflicts causing a build failure due to drivers/net/r8169.c changes using a patch from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-20ehea: Fix a DLPAR bug on ehea_rereg_mrs().Breno Leitao
We are currently continuing if ehea_restart_qps() fails, when we do a memory DLPAR (remove or add more memory to the system). This patch just let the NAPI disabled if the ehea_restart_qps() fails. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-17net: ehea: convert to hw_featuresMichał Mirosław
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-11ehea: Increase the skb array usageBreno Leitao
Currently the skb array is not fully allocated, and the allocation is done as it's requested, which is not the expected way. This patch just allocate the full skb array at driver initialization. Also, this patch increases ehea version to 107. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-20ehea: Fixing some message levelBreno Leitao
Currently there are some info message that is set as error, and an error message that is set as debug. This patch just fixes it. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-13ehea: Use the standard logging functionsJoe Perches
Remove ehea_error, ehea_info and ehea_debug macros. Use pr_fmt, pr_<level>, netdev_<level> and netif_<level> as appropriate. Fix messages to use trailing "\n", some messages had an extra one as the old ehea_<level> macros added a trailing "\n". Coalesced long format strings. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12ehea: don't use flush_scheduled_work()Tejun Heo
Directly cancel port->reset_task from ehea_shutdown_single_port() instead. As this cancels the work for each port on driver detach, flushing system_wq from ehea_remove() or ehea_module_exit() is no longer necessary. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Breno Leitao <leitao@linux.vnet.ibm.com> Cc: netdev@vger.kernel.org
2010-12-12ehea: kill unused ehea_rereg_mr_taskTejun Heo
ehea_rereg_mr_task is not used. Remove it and drop @work parameter from ehea_rereg_mrs(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Breno Leitao <leitao@linux.vnet.ibm.com> Cc: netdev@vger.kernel.org
2010-12-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath/ath9k/ar9003_eeprom.c net/llc/af_llc.c
2010-12-08ehea: Fixing LRO configurationBreno Leitao
In order to set LRO on ehea, the user must set a module parameter, which is not the standard way to do so. This patch adds a way to set LRO using the ethtool tool. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06Revert "ehea: Use the standard logging functions"David S. Miller
This reverts commit 539995d18649023199986424d140f1d620372ce5. As reported by Stephen Rothwell, this breaks the build. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06ehea: Use the standard logging functionsJoe Perches
Remove ehea_error, ehea_info and ehea_debug macros. Use pr_fmt, pr_<level>, netdev_<level> and netif_<level> as appropriate. Fix messages to use trailing "\n", some messages had an extra one as the old ehea_<level> macros added a trailing "\n". Coalesced long format strings. Uncompiled/untested. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Breno Leitao<leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28ehea: Add some info messages and fix an issueBreno Leitao
This patch adds some debug information about ehea not being able to allocate enough spaces. Also it correctly updates the amount of available skb. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-27drivers/net: use vzalloc()Eric Dumazet
Use vzalloc() and vzalloc_node() in net drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Jon Mason <jon.mason@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-27ehea: Fixing statisticsBreno Leitao
(Applied over Eric's "ehea: fix use after free" patch) Currently ehea stats are broken. The bytes counters are got from the hardware, while the packets counters are got from the device driver. Also, the device driver counters are resetted during the the down process, and the hardware aren't, causing some weird numbers. This patch just consolidates the packets and bytes on the device driver. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-27ehea: fix use after freeEric Dumazet
ehea_start_xmit() dereferences skb after its freeing in ehea_xmit3() to get vlan tags. Move the offending block before the potential ehea_xmit3() call. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/dev.c
2010-10-21vlan: Don't check for vlan group before vlan_tx_tag_present.Jesse Gross
Many (but not all) drivers check to see whether there is a vlan group configured before using a tag stored in the skb. There's not much point in this check since it just throws away data that should only be present in the expected circumstances. However, it will soon be legal and expected to get a vlan tag when no vlan group is configured, so remove this check from all drivers to avoid dropping the tags. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13ehea: Fix a checksum issue on the receive pathBreno Leitao
Currently we set all skbs with CHECKSUM_UNNECESSARY, even those whose protocol we don't know. This patch just add the CHECKSUM_COMPLETE tag for non TCP/UDP packets. Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-09ehea: simplify conditionalNicolas Kaiser
Simplify: ((a && b) || (!a && !b)) => (a == b) Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Acked-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05ehea: converting msleeps to waitqueue on check_sqs() functionBreno Leitao
Removing the msleep() call in check_sqs() function, and replacing by a wait queue. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05ehea: using wait queues instead of msleep on ehea_flush_sqBreno Leitao
This patch just remove a msleep loop and change to wait queue, making the code cleaner. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15ehea: Remove a silly returnBreno Leitao
This patch removes the unconditional return in the end of the function check_sqs() Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25drivers/net: Remove address use from assignments of function pointersJoe Perches
"foo = &function" is more commonly written "foo = function" Done with coccinelle script: // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> drivers/net/tehuti.c used a function and struct with the same name, the function was renamed. Compile tested x86 only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (27 commits) netfilter: fix CONFIG_COMPAT support isdn/avm: fix build when PCMCIA is not enabled header: fix broken headers for user space e1000e: don't check for alternate MAC addr on parts that don't support it e1000e: disable ASPM L1 on 82573 ll_temac: Fix poll implementation netxen: fix a race in netxen_nic_get_stats() qlnic: fix a race in qlcnic_get_stats() irda: fix a race in irlan_eth_xmit() net: sh_eth: remove unused variable netxen: update version 4.0.74 netxen: fix inconsistent lock state vlan: Match underlying dev carrier on vlan add ibmveth: Fix opps during MTU change on an active device ehea: Fix synchronization between HW and SW send queue bnx2x: Update bnx2x version to 1.52.53-4 bnx2x: Fix PHY locking problem rds: fix a leak of kernel memory netlink: fix compat recvmsg netfilter: fix userspace header warning ...
2010-08-21Merge branch 'master' of ↵David S. Miller
2010-08-18ehea: Fix synchronization between HW and SW send queueAndre Detsch
ehea: Fix synchronization between HW and SW send queue When memory is added to / removed from a partition via the Memory DLPAR mechanism, the eHEA driver has to do a couple of things to reflect the memory change in its own IO address translation tables. This involves stopping and restarting the HW queues. During this operation, it is possible that HW and SW pointer into these queues get out of sync. This results in a situation where packets that are attached to a send queue are not transmitted immediately, but delayed until further X packets have been put on the queue. This patch detects such loss of synchronization, and resets the ehea port when needed. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Andre Detsch <adetsch@br.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-17drivers/net: Convert unbounded kzalloc calls to kcallocJoe Perches
These changes may be slightly safer in some instances. There are other kzalloc calls with a multiply, but those calls are typically "small fixed #" * sizeof(some pointer)" and those are not converted. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-07-01ehea: Allocate stats buffer with GFP_KERNELBrian King
Since ehea_get_stats calls ehea_h_query_ehea_port, which can sleep, we can also sleep when allocating a page in this function. This fixes some memory allocation failure warnings seen under low memory conditions. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16ehea: Fix kernel deadlock in DLPAR-mem processingJan-Bernd Themann
Port reset operations and memory add/remove operations need to be serialized to avoid a kernel deadlock. The deadlock is caused by calling the napi_disable() function twice. Therefore we have to employ the dlpar_mem_lock in the ehea_reset_port function as well Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16ehea: fix delayed packet processingJan-Bernd Themann
In the eHEA poll function an rmb() is required. Without that some packets on the receive queue are not seen and thus delayed until the next interrupt is handled for the same receive queue. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-17drivers/net: remove useless semicolonsJoe Perches
switch and while statements don't need semicolons at end of statement [ Fixup minor conflicts with recent wimax merge... -DaveM ] Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21ehea: fix possible DLPAR/mem deadlockThomas Klein
Force serialization of userspace-triggered DLPAR/mem operations Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21ehea: error handling improvementThomas Klein
Reset a port's resources only if they're actually in an error state Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14drivers: net: use skb_headlen()Eric Dumazet
replaces (skb->len - skb->data_len) occurrences by skb_headlen(skb) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part4Jiri Pirko
