path: root/drivers/net/ehea/ehea_qmr.c
2010-12-13ehea: Use the standard logging functionsJoe Perches
Remove ehea_error, ehea_info and ehea_debug macros. Use pr_fmt, pr_<level>, netdev_<level> and netif_<level> as appropriate. Fix messages to use trailing "\n", some messages had an extra one as the old ehea_<level> macros added a trailing "\n". Coalesced long format strings. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06Revert "ehea: Use the standard logging functions"David S. Miller
This reverts commit 539995d18649023199986424d140f1d620372ce5. As reported by Stephen Rothwell, this breaks the build. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06ehea: Use the standard logging functionsJoe Perches
Remove ehea_error, ehea_info and ehea_debug macros. Use pr_fmt, pr_<level>, netdev_<level> and netif_<level> as appropriate. Fix messages to use trailing "\n", some messages had an extra one as the old ehea_<level> macros added a trailing "\n". Coalesced long format strings. Uncompiled/untested. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Breno Leitao<leitao@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21ehea: error handling improvementThomas Klein
Reset a port's resources only if they're actually in an error state Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23walk system ram rangeKAMEZAWA Hiroyuki
Originally, walk_memory_resource() was introduced to traverse all memory of "System RAM" for detecting memory hotplug/unplug range. For doing so, flags of IORESOUCE_MEM|IORESOURCE_BUSY was used and this was enough for memory hotplug. But for using other purpose, /proc/kcore, this may includes some firmware area marked as IORESOURCE_BUSY | IORESOUCE_MEM. This patch makes the check strict to find out busy "System RAM". Note: PPC64 keeps their own walk_memory_resouce(), which walk through ppc64's lmb informaton. Because old kclist_add() is called per lmb, this patch makes no difference in behavior, finally. And this patch removes CONFIG_MEMORY_HOTPLUG check from this function. Because pfn_valid() just show "there is memmap or not* and cannot be used for "there is physical memory or not", this function is useful in generic to scan physical memory range. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-21ehea: Fix mem allocations which require page alignmentThomas Klein
PAGE_SIZE allocations via slab are not guaranteed to be page-aligned. Fixed all memory allocations where page alignment is required by firmware. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-13powerpc: Cleanup from l64 to ll64 change: drivers/netStephen Rothwell
These are powerpc specific drivers. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-25ehea: use get_zeroed_page for alignment-sensitive allocationNathan Lynch
With slub debug enabled, I see the following errors and crash with 2.6.28-rc9: IBM eHEA ethernet device driver (Release EHEA_0095) ehea: Error in ehea_h_register_rpage_mr: not on pageboundary ehea: Error in ehea_reg_mr_section: register_rpage_mr failed ehea: Error in ehea_reg_kernel_mr: registering mr failed ehea: Error in ehea_setup_ports: creating MR failed ehea 23c00100.lhea: setup_ports failed Unable to handle kernel paging request for data at address 0x6b6b6b6b6b6bbdcb Faulting instruction address: 0xd000000000064a24 cpu 0x0: Vector: 300 (Data Access) at [c0000000740e7190] pc: d000000000064a24: .ehea_update_firmware_handles+0x84/0x47c [ehea] lr: d00000000006df34: .ehea_probe_adapter+0x35c/0x39c [ehea] sp: c0000000740e7410 msr: 8000000000009032 dar: 6b6b6b6b6b6bbdcb dsisr: 40000000 current = 0xc000000074233780 paca = 0xc0000000008a3300 pid = 2046, comm = modprobe enter ? for help [c0000000740e74f0] d00000000006df34 .ehea_probe_adapter+0x35c/0x39c [ehea] [c0000000740e75a0] c00000000041d5a4 .of_platform_device_probe+0x78/0xb0 [c0000000740e7630] c0000000002d8b38 .driver_probe_device+0x13c/0x200 [c0000000740e76c0] c0000000002d8c90 .__driver_attach+0x94/0xd8 [c0000000740e7750] c0000000002d7d64 .bus_for_each_dev+0x80/0xd8 [c0000000740e7800] c0000000002d889c .driver_attach+0x28/0x40 [c0000000740e7880] c0000000002d8340 .bus_add_driver+0xd4/0x284 [c0000000740e7920] c0000000002d90a0 .driver_register+0xc4/0x198 [c0000000740e79d0] c00000000041d45c .of_register_driver+0x4c/0x60 [c0000000740e7a50] c000000000020ef8 .ibmebus_register_driver+0x30/0x4c [c0000000740e7ae0] d00000000006e108 .ehea_module_init+0x194/0x208c [ehea] [c0000000740e7b90] c000000000009028 .do_one_initcall+0x90/0x1ac [c0000000740e7d90] c00000000008619c .sys_init_module+0xc4/0x200 [c0000000740e7e30] c0000000000084ac syscall_exit+0x0/0x40 (When slub debug is disabled it works fine.) PAGE_SIZE allocations via slab are not guaranteed to be page-aligned; use get_zeroed_page for the 'pt' buffer (I don't really know what this is, only that it is passed to firmware and that the first error message complains about its alignment). This allows the system to boot. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25drivers/net/ehea: Remove redundant testJulia Lawall
In each case, vpage is checked not to be NULL just after it is initialized at the beginning of each loop iteration. A simplified version of the semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; expression E; position p1,p2; @@ if (x@p1 == NULL || ...) { ... when forall return ...; } ... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\) ( x@p2 == NULL | x@p2 != NULL ) // another path to the test that is not through p1? @s exists@ local idexpression r.x; position r.p1,r.p2; @@ ... when != x@p1 ( x@p2 == NULL | x@p2 != NULL ) @fix depends on !s@ position r.p1,r.p2; expression x,E; statement S1,S2; @@ ( - if ((x@p2 != NULL) || ...) S1 | - if ((x@p2 == NULL) && ...) S1 | - BUG_ON(x@p2 == NULL); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06ehea: Fix some whitespace issuesHannes Hering
This patch removes some trailing whitespaces and spaces before tabs. Signed-off-by: Hannes Hering <hering2@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-27ehea: Detect 16GB hugepages for firmware restrictionThomas Klein
All kernel memory which is used for kernel/hardware data transfer must be registered with firmware using "memory regions". 16GB hugepages may not be part of a memory region due to firmware restrictions. This patch modifies the walk_memory_resource callback fn to filter hugepages and add only standard memory to the busmap which is later on used for MR registration. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-22ehea: Fix memory hotplug supportHannes Hering
This patch implements the memory notifier to update the busmap instantly instead of rebuilding the whole map. This is necessary because walk_memory_resource provides different information than required during memory hotplug. Signed-off-by: Hannes Hering <hering2@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24ehea: Fix DLPAR memory handlingHannes Hering
The ehea busmap must be allocated only once in the first of many calls of the ehea_create_busmap_callback. Signed-off-by: Hannes Hering <hering2@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13ehea: Add DLPAR memory remove supportHannes Hering
The eHEA driver uses the recently modified walk_memory_resource for powerpc functionality to detect the memory layout. It further uses the memory hotplug notifiers to catch memory hotplug events. Signed-off-by: Hannes Hering <hering2@de.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-03ehea: fix qmr checkpatch complaintsDoug Maxey
Cc: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Doug Maxey <dwm@austin.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10ehea: use kernel event queueJan-Bernd Themann
eHEA recovery and DLPAR functions are called seldomly. The eHEA workqueues are replaced by the kernel event queue. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10ehea: DLPAR memory add fixJan-Bernd Themann
Due to stability issues in high load situations the HW queue handling has to be changed. The HW queues are now stopped and restarted again instead of destroying and allocating new HW queues. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-08-25ehea: fix queue destructorJan-Bernd Themann
Includes hcp_epas_dtor in eq/cq/qp destructors to unmap HW register. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-16eHEA: Introducing support vor DLPAR memory addThomas Klein
This patch adds support for DLPAR memory add to the eHEA driver. To detect whether memory was added the driver uses its own memory mapping table and checks for kernel addresses whether they're located in already known memory sections. If not the function ehea_rereg_mrs() is triggered which performs a rebuild of the mapping table and a re-registration of the global memory region. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-08ehea: Whitespace cleanupJan-Bernd Themann
This patch fixes several whitespace issues. Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-28ehea: code cleanupJan-Bernd Themann
This patch includes: - code cleanup related to resource management - extended error data gathering for resource management - removing trailing whitespaces Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-09ehea: Fixed error recoveryJan-Bernd Themann
Error recovery for QP errors: Reset QPs and dump error information Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] severing skbuff.h -> mm.hAl Viro
2006-11-06[PATCH] ehea: 64K page support fixThomas Klein
This patch fixes 64k page support by using PAGE_MASK and appropriate pagesize defines in several places. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-11-06[PATCH] ehea: Nullpointer dereferencation fixThomas Klein
Fix: Must check for nullpointer before dereferencing it - not afterwards. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] ehea: IBM eHEA Ethernet Device DriverJan-Bernd Themann
Hi Jeff, I fixed the __iomem issue and tested the driver with sparse. Looks good so far. Thanks for your effort. Jan-Bernd Themann Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> drivers/net/Kconfig | 9 drivers/net/Makefile | 1 drivers/net/ehea/Makefile | 6 drivers/net/ehea/ehea.h | 447 ++++++ drivers/net/ehea/ehea_ethtool.c | 294 ++++ drivers/net/ehea/ehea_hcall.h | 51 drivers/net/ehea/ehea_hw.h | 287 ++++ drivers/net/ehea/ehea_main.c | 2654 ++++++++++++++++++++++++++++++++++++++++ drivers/net/ehea/ehea_phyp.c | 705 ++++++++++ drivers/net/ehea/ehea_phyp.h | 455 ++++++ drivers/net/ehea/ehea_qmr.c | 582 ++++++++ drivers/net/ehea/ehea_qmr.h | 358 +++++ 12 files changed, 5849 insertions(+) Signed-off-by: Jeff Garzik <jeff@garzik.org>
