path: root/drivers/net/enc28j60.c
2011-08-12enc28j60: Move the Microchip driverJeff Kirsher
Move the Microchip driver into drivers/net/ethernet/microchip/ and make the necessary Kconfig and Makefile changes. CC: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: Use full 32 bit speed range in ethtool's set_settingsDavid Decotigny
This makes sure the ethtool's set_settings() callback of network drivers don't ignore the 16 most significant bits when ethtool calls their set_settings(). All drivers compiled with make allyesconfig on x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-31enc28j60: Fix reading of transmit status vectorStefan Weil
This error was reported by cppcheck: drivers/net/enc28j60.c:815: error: Using sizeof for array given as function argument returns the size of pointer. The original code reads 4 or 8 bytes instead of TSV_SIZE (= 100) bytes. I just fixed the code, but did not run any tests. Signed-off-by: Stefan Weil <weil@mail.berlios.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-07enc28j60: update to net_device_opsStephen Hemminger
2009-01-04enc28j60: fix RX buffer overflowBaruch Siach
The enc28j60 driver doesn't check whether the length of the packet as reported by the hardware fits into the preallocated buffer. When stressed, the hardware may report insanely large packets even tough the "Receive OK" bit is set. Fix this. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-18enc28j60: reduce the number of spi transfers in enc28j60_set_bank()Baruch Siach
A major source of overhead in the enc28j60 driver is the SPI transfers. Each SPI transfer entails two kernel thread context switches. One major source of SPI transfers is the enc28j60_set_bank() functions which runs before every register access. This patch reduces the number of SPI transfers that enc28j60_set_bank() performs in two ways: 1. removes unnecessary bank switch for the registers that are present in all banks 2. when switching from banks 0 or 3 to banks 1 or 2 (i.e. only one bit changes) enc28j60_set_bank() does only one SPI transfer instead of two According to my tests these changes reduce the number of SPI transfers in about 25%. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/enc28j60.c
2008-12-16enc28j60: use netif_rx_ni() to deliver RX packetsBaruch Siach
The enc28j60 driver reads incoming packets in the process (workqueue) context, not in a tasklet or the interrupt context. Thus, we should use netif_rx_ni() to deliver those packets to the networking layer, instead of netif_rx(). This way incoming packets don't wait in the incoming queue for the next IRQ to be serviced. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-core.c drivers/net/wireless/iwlwifi/iwl-sta.c
2008-12-03enc28j60: Fix sporadic packet loss (corrected again)Baruch Siach
Packet data read from the RX buffer the when the RSV is at the end of the RX buffer does not warp around. This causes packet loss, as the actual data is never read. Fix this by calculating the right packet data location. Thanks to Shachar Shemesh for suggesting the fix. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-10net: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24drivers/net: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-29enc28j60: don't specify (wrong) IRQ typeDavid Brownell
Recent changes to the IRQ framework have made passing the wrong trigger type to request_irq() become a fatal error. In the case of the enc28j60 driver, it stopped working in my test harness. (Specifically: the signal detects "pin change" events, both edges, not just falling edges. Similarly, other boards might route it through an inverter. Trigger type are board-specific.) This fixes that problem by the usual fix of expecting board setup code to have set up the correct IRQ trigger type. The best known example of that being x86 setup. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17net/enc28j60: low power modeDavid Brownell
Keep enc28j60 chips in low-power mode when they're not in use. At typically 120 mA, these chips run hot even when idle; this low power mode cuts that power usage by a factor of around 100. This version provides a generic routine to poll a register until its masked value equals some value ... e.g. bit set or cleared. It's basically what the previous wait_phy_ready() did, but this version is generalized to support the handshaking needed to enter and exit low power mode. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-17net/enc28j60: section fixDavid Brownell
Minor bugfixes to the enc28j60 driver ... wrong section marking, indentation, and bogus use of spi_bus_type. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-03-05net/enc28j60: oops fixDavid Brownell
Prevent oops on enc28j60 packet RX: make sure buffers are aligned. Not all architectures support unaligned accesses in kernel space. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28add driver for enc28j60 ethernet chipClaudio Lanconelli
Signed-off-by: Claudio Lanconelli <lanconelli.claudio@eptar.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
