Declaring threaded irq handler should also indicate the irq is
oneshot. It is oneshot indeed, because HW implements irq automasking
on trigger.
Not declaring this causes some kernel configurations to fail
on interface up, because request_threaded_irq returned an err code.
The issue was originally hidden on normal x86_64 configuration with
latest kernel, because depending on interrupt controller, irq driver
added ONESHOT flag on its own.
Issue was observed on older kernels (4.14) where no such logic exists.
Fixes: 4c83f170b3ac ("net: aquantia: link status irq handling")
Signed-off-by: Igor Russkikh <igor.russkikh@aquantia.com>
Reported-by: Michael Symolkin <Michael.Symolkin@aquantia.com>
The new route handling in ip_mc_finish_output() from 'net' overlapped
with the new support for returning congestion notifications from BPF
programs.
In order to handle this I had to take the dev_loopback_xmit() calls
out of the switch statement.
The aquantia driver conflicts were simple overlapping changes.
Update datapath by adding logic related to hardware assisted
vlan strip/insert behaviour.
Tested-by: Nikita Danilov <ndanilov@aquantia.com>
Updating features and vlan_features with vlan HW offload.
Added vlan_tag fields to rx/tx ring_buff to track vlan related data.
In configuration of vlan over bridge over aquantia device
it was found that vlan tagged traffic is dropped on chip.
The reason is that bridge device enables promisc mode,
but in atlantic chip vlan filters will still apply.
So we have to corellate promisc settings with vlan configuration.
The solution is to track in a separate state variable the
need of vlan forced promisc. And also consider generic
promisc configuration when doing vlan filter config.
Fixes: 7975d2aff5af ("net: aquantia: add support of rx-vlan-filter offload")
Signed-off-by: Dmitry Bogdanov <dmitry.bogdanov@aquantia.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms and conditions of the gnu general public license
version 2 as published by the free software foundation
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 101 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190531190113.822954939@linutronix.de
aq_nic_update_ndev_stats pushes statistics to ndev->stats from
system interface. This is not always good because it counts packets/bytes
before any of rx filters (including mac filter).
Its better to report the packet/bytes statistics from DMA
counters which gives actual values of data transferred over pci.
System level stats is still available via ethtool.
Signed-off-by: Nikita Danilov <ndanilov@aquantia.com>
This improves ethtool -S usage, where stats are now actual
on each request. Before that stats only were updated at service
timer period.
Service timer callback fetches statistics from FW and that may cause
a long delay in error cases. We also now need to use fw mutex
to prevent concurrent access to FW, thus - extract that logic
from timer callback into the job in the separate work queue.
Some of FW operations could be invoked simultaneously,
from f.e. ethtool context and from service service activity work.
Here we introduce a fw mutex to secure and serialize access
to FW logic.
Original code detected link only after 1 sec is passed after up.
Here we replace this with direct service callback which updates
link status immediately
Here we define and request an extra interrupt line,
assign it on link isr handler and restructure abit aq_pci code
to better support that.
We also remove logic for using different timer intervals
depending on link state, since thats now useless.
Define link interrupt handler
We introduce internal aq_rxpage wrapper over regular page
where extra field is tracked: rxpage offset inside of allocated page.
This offset allows to reuse one page for multiple packets.
When needed (for example with large frames processing), allocated
pageorder could be customized. This gives even larger page reuse
efficiency.
page_ref_count is used to track page users. If during rx refill
underlying page has users, we increase pg_off by rx frame size
thus the top half of the page is reused.
drivers/net/ethernet/aquantia/atlantic/aq_nic.c: 991:1:
warning: no newline at end of file
Signed-off-by: Nikita Danilov <nikita.danilov@aquantia.com>
Now RSS indirection table is initialized before setting up the number of
hw queues, consequently the table may be filled by non existing queues.
This patch moves the initialization when the number of hw queues is
known.
Set RSS indirection table and RSS hash key sizes to their real size.
Since it uses the same NIC table as rx flow vlan filter therefore
rx-flow vlan filter accepts only vlans that present on the interface
in case of rx-vlan-filter is on.
RX Checksum offloads could not be configured and ignored netdev features
flag for checksumming.
Fixed a condition mistake due to which macvlans unicast
item number 32 was not added in the unicast filter.
The consequence is that when exactly 32 macvlans are created
on NIC, the last created macvlan receives no traffic because
its MAC was not registered in HW.
Fixes: 94b3b542303f ("net: aquantia: vlan unicast address list correct handling")
Tested-by: Nikita Danilov <nikita.danilov@aquantia.com>
Flow control statuses were not synchronized between blocks,
that caused packets/link drop on some corner cases, when
MAC sent PFC although Phy was not expecting these to come.
Driver should readout the negotiated FC from phy and
configure RX block accordigly.
This is done on each link change event with information from FW.
Fixes: 288551de45aa ("net: aquantia: Implement rx/tx flow control ethtools callback")
Removed extra spaces, corrected alignment.
Add WOL support. Currently only magic packet
(ethtool -s <ethX> wol g) feature is implemented.
Remove hw_set_power and move that to FW_OPS set_power:
because WOL configuration behaves differently on 1x and 2x
firmwares
Signed-off-by: Yana Esina <yana.esina@aquantia.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
All conflicts were trivial overlapping changes, so reasonably
easy to resolve.
Setting up macvlan/macvtap networks over atlantic NIC results
in no traffic over these networks because ndo_set_rx_mode did
not listed UC MACs as registered in unicast filter.
Here we fix that taking into account maximum number of UC
filters supported by hardware. If more than MAX addresses were
registered, we just enable promisc and/or allmulti to pass
the traffic in.
We also remove MULTICAST_ADDRESS_MAX constant from aq_cfg since
thats not a configurable parameter at all.
Fixes: b21f502 ("net:ethernet:aquantia: Fix for multicast filter handling.")
Runtime change of pause frame configuration (rx/tx flow control)
via ethtool.
We now pass link drop status to FW on init/deinit. This is required
to inform FW that driver took/released a control on link.
FW then will manage its own state and device power profile based
on this information. To improve management we remove mpi_set
function which ambiguously took both state and speed parameters.
Deinit callback is now a part of FW ops, as it actually manages the FW.
Implemented ring size setup, min/max validation and reconfiguration in
runtime.
Signed-off-by: Anton Mikaev <amikaev@aquantia.com>
Driver should use pci_alloc_irq_vectors return value to correct number
of allocated vectors and napi instances. Otherwise it'll panic later
in pci_irq_vector.
Driver also should allow more than one MSI vectors to be allocated.
Error return path from pci_alloc_irq_vectors is also fixed to revert
resources in a correct sequence when error happens.
Reported-by: Long, Nicholas <nicholas.a.long@baesystems.com>
Fixes: 23ee07a ("net: aquantia: Cleanup pci functions module")
In particular, not reporting SG forced skbs to be linear for vlan
interfaces over atlantic NIC.
With this fix it is possible to enable SG feature on device and
therefore optimize performance.
Reported-by: Ma Yuying <yuma@redhat.com>
In case netdev is closed at the moment of pci shutdown, aq_nic_stop
gets called second time. napi_disable in that case hangs indefinitely.
In other case, if device was never opened at all, we get oops because
of null pointer access.
We should invoke aq_nic_stop conditionally, only if device is running
at the moment of shutdown.
Reported-by: David Arcari <darcari@redhat.com>
Fixes: 90869ddfefeb ("net: aquantia: Implement pci shutdown callback")
We should close link and all NIC operations during shutdown.
On some systems graceful reboot never closes NIC interface on its own,
but only indicates pci device shutdown. Without explicit handler, NIC
rx rings continued to transfer DMA data into prepared buffers while CPU
rebooted already. That caused memory corruptions on soft reboot.
There is nothing prevents us from changing MAC on the running interface.
Allow this with ndev priv flag.
For devices with known capabilities of Fibre media type we now report that
to ethtool.
New AQC cards will have an updated firmware with new binary interface.
This patch extracts firmware specific operations into a separate table
and prepares for the introduction of new fw 2.x and 3.x
Driver contained a dead code of maintaining multiple pci port instances.
That will never be used since for each pci function a separate NIC
instance is created.
Simplify this, making pci module only responsible for pci resource
management.
NIC initialization is also simplified accordingly.
This removes unnecessary structure copying, and prepares the driver for
separate firmware ops table introduction.
We also remove extra copy of capabilities structure (which is const actually)
and also replace it with a const pointer in aq_nic_cfg.
A number of new AQC devices is going to be released. To support more
flexible capabilities management a number of static caps instances is now
declared. Devices now are mainly differs by supported speeds, but in future
more parameters will be customized. A set of AQC100 devices have
fibre media, not twisted pair - this is also reflected in
new capabilities definitions.
HW level also now directly exports hw_ops for each of A0/B0 hardware.
PCI configuration now uses a device configuration table where each
device ID is explicitly mapped with hardware OPs and capabilities
structures.
aq_nic_s was hidden in aq_nic_internal.h, that made it difficult to access
nic fields and structures from other modules.
This change moves aq_nic_s struct into aq_nic.h and thus makes it available
to other driver modules, mainly pci module and hw related module.
Eliminate useless passing of net_device_ops and ethtools_ops through
deep chain of calls.
Move all pci related code into aq_pci_func module.
Hardware operations and capabilities tables are constants and
never changed. Declare these as constants.
Use direct aq_hw_s *self reference where possible
Eliminate useless abstraction PHAL, duplicated structures definitions,
Simplify nic config structure creation and management.
Usage of aq_obj_s structure is noop, here we remove it
replacing access to flags filed directly.
Reduce timeout from 2 secs to 1 sec. If link is down,
reduce it to 500msec. This speeds up link detection.
This metric comes from HW and is also diff-calculated, like other counters
Originally they were filled from ring sw counters.
These sometimes incorrectly calculate byte and packet amounts
when using LRO/LSO and jumboframes. Filling ndev counters from
hardware makes them precise.
Device hardware provides only 32bit counters. Using these directly
causes byte counters to overflow soon. A separate nic level structure
with 64 bit counters is now used to collect incrementally all the stats
and report these counters to ethtool stats and ndev stats.
Different hardware device Ids correspond to different maximum speed
available. Extra checks were added for devices D108 and D109 to
remove unsupported speeds from these device capabilities list.
This converts all remaining cases of the old setup_timer() API into using
timer_setup(), where the callback argument is the structure already
holding the struct timer_list. These should have no behavioral changes,
since they just change which pointer is passed into the callback with
the same available pointers after conversion. It handles the following
examples, in addition to some other variations.
Casting from unsigned long:
void my_callback(unsigned long data)
struct something *ptr = (struct something *)data;
setup_timer(&ptr->my_timer, my_callback, ptr);
and forced object casts:
void my_callback(struct something *ptr)
setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr);
become:
void my_callback(struct timer_list *t)
struct something *ptr = from_timer(ptr, t, my_timer);
timer_setup(&ptr->my_timer, my_callback, 0);
Direct function assignments:
ptr->my_timer.function = my_callback;
have a temporary cast added, along with converting the args:
ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback;
And finally, callbacks without a data assignment:
setup_timer(&ptr->my_timer, my_callback, 0);
have their argument renamed to verify they're unused during conversion:
void my_callback(struct timer_list *unused)
The conversion is done with the following Coccinelle script:
spatch --very-quiet --all-includes --include-headers \
-I ./arch/x86/include -I ./arch/x86/include/generated \
-I ./include -I ./arch/x86/include/uapi \
-I ./arch/x86/include/generated/uapi -I ./include/uapi \
-I ./include/generated/uapi --include ./include/linux/kconfig.h \
--dir . \
--cocci-file ~/src/data/timer_setup.cocci
@fix_address_of@
expression e;
setup_timer(
-&(e)
+&e
// Update any raw setup_timer() usages that have a NULL callback, but
// would otherwise match change_timer_function_usage, since the latter
// will update all function assignments done in the face of a NULL
// function initialization in setup_timer().
@change_timer_function_usage_NULL@
expression _E;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_timer, NULL, _E);
+timer_setup(&_E->_timer, NULL, 0);
-setup_timer(&_E->_timer, NULL, (_cast_data)_E);
-setup_timer(&_E._timer, NULL, &_E);
+timer_setup(&_E._timer, NULL, 0);
-setup_timer(&_E._timer, NULL, (_cast_data)&_E);
@change_timer_function_usage@
expression _E;
identifier _timer;
struct timer_list _stl;
identifier _callback;
type _cast_func, _cast_data;
-setup_timer(&_E->_timer, _callback, _E);
+timer_setup(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, &_callback, _E);
-setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_timer@_stl.function = _callback;
_E->_timer@_stl.function = &_callback;
_E->_timer@_stl.function = (_cast_func)_callback;
_E->_timer@_stl.function = (_cast_func)&_callback;
_E._timer@_stl.function = _callback;
_E._timer@_stl.function = &_callback;
_E._timer@_stl.function = (_cast_func)_callback;
_E._timer@_stl.function = (_cast_func)&_callback;
// callback(unsigned long arg)
@change_callback_handle_cast
depends on change_timer_function_usage@
identifier change_timer_function_usage._callback;
identifier change_timer_function_usage._timer;
type _origtype;
identifier _origarg;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+struct timer_list *t
... when != _origarg
_handletype *_handle =
-(_handletype *)_origarg;
+from_timer(_handle, t, _timer);
-(void *)_origarg;
_handletype *_handle;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
// callback(unsigned long arg) without existing variable
@change_callback_handle_cast_no_arg
depends on change_timer_function_usage &&
!change_callback_handle_cast@
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _timer);
- (_handletype *)_origarg
+ _origarg
// Avoid already converted callbacks.
@match_callback_converted
!change_callback_handle_cast &&
!change_callback_handle_cast_no_arg@
identifier t;
void _callback(struct timer_list *t)
// callback(struct something *handle)
@change_callback_handle_arg
!match_callback_converted &&
type _handletype;
identifier _handle;
void _callback(
-_handletype *_handle
+ _handletype *_handle = from_timer(_handle, t, _timer);
// If change_callback_handle_arg ran on an empty function, remove
// the added handler.
@unchange_callback_handle_arg
change_callback_handle_arg@
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _timer);
// We only want to refactor the setup_timer() data argument if we've found
// the matching callback. This undoes changes in change_timer_function_usage.
@unchange_timer_function_usage
!change_callback_handle_cast_no_arg &&
!change_callback_handle_arg@
expression change_timer_function_usage._E;
type change_timer_function_usage._cast_data;
-timer_setup(&_E->_timer, _callback, 0);
+setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-timer_setup(&_E._timer, _callback, 0);
+setup_timer(&_E._timer, _callback, (_cast_data)&_E);
// If we fixed a callback from a .function assignment, fix the
// assignment cast now.
@change_timer_function_assignment
(change_callback_handle_cast ||
change_callback_handle_cast_no_arg ||
change_callback_handle_arg)@
type _cast_func;
typedef TIMER_FUNC_TYPE;
_E->_timer.function =
-_callback
+(TIMER_FUNC_TYPE)_callback
-&_callback
-(_cast_func)_callback;
-(_cast_func)&_callback
_E._timer.function =
-_callback
-&_callback;
// Sometimes timer functions are called directly. Replace matched args.
@change_timer_function_calls
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_timer
-(_cast_data)&_E
+&_E._timer
-_E
+&_E->_timer
// If a timer has been configured without a data argument, it can be
// converted without regard to the callback argument, since it is unused.
@match_timer_function_unused_data@
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, _callback, 0L);
-setup_timer(&_E->_timer, _callback, 0UL);
-setup_timer(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, 0L);
-setup_timer(&_E._timer, _callback, 0UL);
-setup_timer(&_timer, _callback, 0);
+timer_setup(&_timer, _callback, 0);
-setup_timer(&_timer, _callback, 0L);
-setup_timer(&_timer, _callback, 0UL);
-setup_timer(_timer, _callback, 0);
+timer_setup(_timer, _callback, 0);
-setup_timer(_timer, _callback, 0L);
-setup_timer(_timer, _callback, 0UL);
@change_callback_unused_data
depends on match_timer_function_unused_data@
identifier match_timer_function_unused_data._callback;
type _origtype;
void _callback(
-_origtype _origarg
+struct timer_list *unused
