[ Upstream commit 9f051db566da1e8110659ab4ab188af1c2510bb4 ]
macvlan and multicast handling is now mixed up.
The explicit issue is that macvlan interface gets broken (no traffic)
after clearing MULTICAST flag on the real interface.
We now do separate logic and consider both ALLMULTI and MULTICAST
flags on the device.
Fixes: 11ba961c9161 ("net: aquantia: Fix IFF_ALLMULTI flag functionality")
Signed-off-by: Dmitry Bogdanov <dmitry.bogdanov@aquantia.com>
Signed-off-by: Igor Russkikh <igor.russkikh@aquantia.com>
[ Upstream commit d08b9a0a3ebdf71b0aabe576c7dd48e57e80e0f0 ]
Individual descriptors on LRO TCP session should be checked
for CRC errors. It was discovered that HW recalculates
L4 checksums on LRO session and does not break it up on bad L4
csum.
Thus, driver should aggregate HW LRO L4 statuses from all individual
buffers of LRO session and drop packet if one of the buffers has bad
L4 checksum.
Fixes: f38f1ee8aeb2 ("net: aquantia: check rx csum for all packets in LRO session")
[ Upstream commit ed4d81c4b3f28ccf624f11fd66f67aec5b58859c ]
>From HW specification to correctly reset HW caches (this is a required
workaround when stopping the device), register bit should actually
be toggled.
It was previosly always just set. Due to the way driver stops HW this
never actually caused any issues, but it still may, so cleaning this up.
Fixes: 7a1bb49461b1 ("net: aquantia: fix potential IOMMU fault after driver unbind")
[ Upstream commit 06b0d7fe7e5ff3ba4c7e265ef41135e8bcc232bb ]
Chip temperature is a two byte word, colocated internally with cable
length data. We do all readouts from HW memory by dwords, thus
we should clear extra high bytes, otherwise temperature output
gets weird as soon as we attach a cable to the NIC.
Fixes: 8f8940118654 ("net: aquantia: add infrastructure to readout chip temperature")
Tested-by: Holger Hoffstätte <holger@applied-asynchrony.com>
On embedded environments with hard memory limits it is a normal although
rare case when skb can't be allocated on rx part under high traffic.
In such OOM cases napi_complete_done() was not called.
So the napi object became in an invalid state like it is "scheduled".
Kernel do not re-schedules the poll of that napi object.
Consequently, kernel can not remove that object the system hangs on
`ifconfig down` waiting for a poll.
We are fixing this by gracefully closing napi poll routine with correct
invocation of napi_complete_done.
This was reproduced with artificially failing the allocation of skb to
simulate an "out of memory" error case and check that traffic does
not get stuck.
Fixes: 970a2e9864b0 ("net: ethernet: aquantia: Vector operations")
Declaring threaded irq handler should also indicate the irq is
oneshot. It is oneshot indeed, because HW implements irq automasking
on trigger.
Not declaring this causes some kernel configurations to fail
on interface up, because request_threaded_irq returned an err code.
The issue was originally hidden on normal x86_64 configuration with
latest kernel, because depending on interrupt controller, irq driver
added ONESHOT flag on its own.
Issue was observed on older kernels (4.14) where no such logic exists.
Fixes: 4c83f170b3ac ("net: aquantia: link status irq handling")
Reported-by: Michael Symolkin <Michael.Symolkin@aquantia.com>
In case of device reconfiguration the driver may reset the device invisible
for other modules, vlan module in particular. So vlans will not be
removed&created and vlan filters will not be configured in the device.
The patch reapplies the vlan filters at device start.
Fixes: 7975d2aff5afb ("net: aquantia: add support of rx-vlan-filter offload")
Fix a limit condition of vlans on the interface before setting vlan
promiscuous mode
Fixes: 48dd73d08d4dd ("net: aquantia: fix vlans not working over bridged network")
Due to absence of checking against the rx flow rule when vlan 0 is being
removed, the other rule could be removed instead of the rule with vlan 0
The new route handling in ip_mc_finish_output() from 'net' overlapped
with the new support for returning congestion notifications from BPF
programs.
In order to handle this I had to take the dev_loopback_xmit() calls
out of the switch statement.
The aquantia driver conflicts were simple overlapping changes.
set_features should update flags and reinit hardware if
vlan offload settings were changed.
Tested-by: Nikita Danilov <ndanilov@aquantia.com>
Update datapath by adding logic related to hardware assisted
vlan strip/insert behaviour.
Updating features and vlan_features with vlan HW offload.
Added vlan_tag fields to rx/tx ring_buff to track vlan related data.
Register declaration macros required to work with vlan offload mode.
It was noticed some files had -or-later, however overall driver has
-only license. Clean this up.
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
As it was discussed some time previously, driver is better to
report kernel version string, as it in a best way identifies
the codebase.
In configuration of vlan over bridge over aquantia device
it was found that vlan tagged traffic is dropped on chip.
The reason is that bridge device enables promisc mode,
but in atlantic chip vlan filters will still apply.
So we have to corellate promisc settings with vlan configuration.
The solution is to track in a separate state variable the
need of vlan forced promisc. And also consider generic
promisc configuration when doing vlan filter config.
Fixes: 7975d2aff5af ("net: aquantia: add support of rx-vlan-filter offload")
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull yet more SPDX updates from Greg KH:
"Another round of SPDX header file fixes for 5.2-rc4
These are all more "GPL-2.0-or-later" or "GPL-2.0-only" tags being
added, based on the text in the files. We are slowly chipping away at
the 700+ different ways people tried to write the license text. All of
these were reviewed on the spdx mailing list by a number of different
people.
We now have over 60% of the kernel files covered with SPDX tags:
$ ./scripts/spdxcheck.py -v 2>&1 | grep Files
Files checked: 64533
Files with SPDX: 40392
Files with errors: 0
I think the majority of the "easy" fixups are now done, it's now the
start of the longer-tail of crazy variants to wade through"
* tag 'spdx-5.2-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (159 commits)
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 450
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 449
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 448
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 446
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 445
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 444
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 443
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 442
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 441
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 440
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 438
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 437
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 436
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 435
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 434
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 433
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 432
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 431
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 430
treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 429
WoL magic packet configuration sometimes does not work due to
couple of leakages found.
Mainly there was a regression introduced during readx_poll refactoring.
Next, fw request waiting time was too small. Sometimes that
caused sleep proxy config function to return with an error
and to skip WoL configuration.
At last, WoL data were passed to FW from not clean buffer.
That could cause FW to accept garbage as a random configuration data.
Fixes: 6a7f2277313b ("net: aquantia: replace AQ_HW_WAIT_FOR with readx_poll_timeout_atomic")
Signed-off-by: Nikita Danilov <nikita.danilov@aquantia.com>
Based on 1 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms and conditions of the gnu general public license
version 2 as published by the free software foundation
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 101 file(s).
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190531190113.822954939@linutronix.de
version 2 as published by the free software foundation this program
is distributed in the hope it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with this program if not see http www gnu org
licenses the full gnu general public license is included in this
distribution in the file called copying
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 12 file(s).
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Link: https://lkml.kernel.org/r/20190530000434.160381502@linutronix.de
Thats a known quirk in windows tcp stack it can produce 0xffff checksum.
Thats incorrect but it is.
Atlantic HW with LRO enabled handles that incorrectly and changes csum to
0xfffe - but indicates that csum is invalid. This causes driver to pass
packet to linux networking stack with CSUM_NONE, stack eventually drops
the packet.
There is a quirk in atlantic HW to enable correct processing of
0xffff incorrect csum. Enable it.
The visible bug is that windows link partner with software generated csums
caused TCP connection to be unstable since all packets that csum value
are dropped.
Reported-by: Dmitry Bezrukov <dmitry.bezrukov@aquantia.com>
Signed-off-by: Nikita Danilov <ndanilov@aquantia.com>
Driver stops producing skbs on ring if a packet with FCS error
was coalesced into LRO session. Ring gets hang forever.
Thats a logical error in driver processing descriptors:
When rx_stat indicates MAC Error, next pointer and eop flags
are not filled. This confuses driver so it waits for descriptor 0
to be filled by HW.
Solution is fill next pointer and eop flag even for packets with FCS error.
Fixes: bab6de8fd180b ("net: ethernet: aquantia: Atlantic A0 and B0 specific functions.")
Atlantic hardware does not aggregate nor breaks LRO sessions
with bad csum packets. This means driver should take care of that.
If in LRO session there is a non-first descriptor with invalid
checksum (L2/L3/L4), the driver must account this information
in csum application logic.
Fixes: 018423e90bee8 ("net: ethernet: aquantia: Add ring support code")
In case no other traffic happening on the ring, full tx cleanup
may not be completed. That may cause socket buffer to overflow
and tx traffic to stuck until next activity on the ring happens.
This is due to logic error in budget variable decrementor.
Variable is compared with zero, and then post decremented,
causing it to become MAX_INT. Solution is remove decrementor
from the `for` statement and rewrite it in a clear way.
Fixes: b647d3980948e ("net: aquantia: Add tx clean budget and valid budget handling logic")
drivers/net/ethernet/aquantia/atlantic/aq_drvinfo.o: In function `aq_drvinfo_init':
aq_drvinfo.c:(.text+0xe8): undefined reference to `devm_hwmon_device_register_with_info'
Fix it by using #if IS_REACHABLE(CONFIG_HWMON).
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Fix sparse warning:
drivers/net/ethernet/aquantia/atlantic/aq_main.c:26:12:
warning: symbol 'aq_ndev_driver_name' was not declared. Should it be static?
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Some device ids were never released and does not exist.
Cleanup these.
DMA counters are 64 bit and we can fetch that to reduce
counter overflow, espesially on byte counters.
aq_nic_update_ndev_stats pushes statistics to ndev->stats from
system interface. This is not always good because it counts packets/bytes
before any of rx filters (including mac filter).
Its better to report the packet/bytes statistics from DMA
counters which gives actual values of data transferred over pci.
System level stats is still available via ethtool.
This improves ethtool -S usage, where stats are now actual
on each request. Before that stats only were updated at service
timer period.
Service timer callback fetches statistics from FW and that may cause
a long delay in error cases. We also now need to use fw mutex
to prevent concurrent access to FW, thus - extract that logic
from timer callback into the job in the separate work queue.
Some of FW operations could be invoked simultaneously,
from f.e. ethtool context and from service service activity work.
Here we introduce a fw mutex to secure and serialize access
to FW logic.
Typo in msi code. No much impact though.
Improve for better readability
Original code detected link only after 1 sec is passed after up.
Here we replace this with direct service callback which updates
link status immediately
Here we define and request an extra interrupt line,
assign it on link isr handler and restructure abit aq_pci code
to better support that.
We also remove logic for using different timer intervals
depending on link state, since thats now useless.
We need this to schedule link interrupt handling and
various service tasks.
Define link interrupt handler
Declare macroes and nic fields to support link interrupt
handling
Added support for hwmon api to fetch out chip temperature
Signed-off-by: Yana Esina <yana.esina@aquantia.com>
Ability to read the chip temperature from memory
via hwmon interface
Update all users of eth_get_headlen to pass network device, fetch
network namespace from it and pass it down to the flow dissector.
This commit is a noop until administrator inserts BPF flow dissector
program.
Cc: Maxim Krasnyansky <maxk@qti.qualcomm.com>
Cc: Saeed Mahameed <saeedm@mellanox.com>
Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Cc: intel-wired-lan@lists.osuosl.org
Cc: Yisen Zhuang <yisen.zhuang@huawei.com>
Cc: Salil Mehta <salil.mehta@huawei.com>
Cc: Michael Chan <michael.chan@broadcom.com>
Cc: Igor Russkikh <igor.russkikh@aquantia.com>
Signed-off-by: Stanislav Fomichev <sdf@google.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Default LRO HW configuration was very conservative.
Low Number of Descriptors per LRO Sequence, small session
timeout, inefficient settings in interrupt generation logic.
Change max number of LRO descriptors from 2 to 16 to
increase performance. Increase maximum coalescing interval
in HW to 250uS. Tune up HW LRO interrupt generation setting
to prevent hw issues with long LRO sessions.
For multigig rates 1K ring size is often not enough and causes extra
packet drops in hardware.
This correlates with default internet MTU. This also allows page
flip/reuse to be activated, since each allocated RX page now serves for
two frags/packets.
Before that, we've refilled ring even on single descriptor move.
Under high packet load that caused page allocation logic to be triggered
too often. That made overall ring processing slower.
Moreover, with page buffer reuse implemented, we should give a chance
higher networking levels to process received packets faster, release
the pages they consumed and therefore give a higher chance for these
pages to be reused.
RX ring is now refilled only when AQ_CFG_RX_REFILL_THRES or more
descriptors were processed (32 by default). Under regular traffic this
gives quite enough time for packet to be consumed and page to be reused.
We introduce internal aq_rxpage wrapper over regular page
where extra field is tracked: rxpage offset inside of allocated page.
This offset allows to reuse one page for multiple packets.
When needed (for example with large frames processing), allocated
pageorder could be customized. This gives even larger page reuse
efficiency.
page_ref_count is used to track page users. If during rx refill
underlying page has users, we increase pg_off by rx frame size
thus the top half of the page is reused.
Atlantic driver used 14 bytes preallocated skb size. That made L3 protocol
processing inefficient because pskb_pull had to fetch all the L3/L4 headers
from extra fragments.
Specially on UDP flows that caused extra packet drops because CPU was
overloaded with pskb_pull.
This patch uses eth_get_headlen for skb preallocation.
TCP/UDP checksum validity was propagated to skb
only if IP checksum is valid.
But for IPv6 there is no validity as there is no checksum in IPv6.
This patch propagates TCP/UDP checksum validity regardless of IP checksum.
Fixes: 018423e90bee ("net: ethernet: aquantia: Add ring support code")
