[ Upstream commit 56d374624778652d2a999e18c87a25338b127b41 ]
With autoneg enabled, PHY loopback test fails. To disable autoneg,
driver needs to send a valid forced speed to FW. FW is not sending
async event for invalid speeds. To fix this, query forced speeds
and send the correct speed when disabling autoneg mode.
Signed-off-by: Vasundhara Volam <vasundhara-v.volam@broadcom.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 7c675421afef18253a86ffc383f57bc15ef32ea8 ]
Currently firmware specific errors are returned directly in flash_device
and reset ethtool hooks. Modify it to return linux standard errors
to userspace when flashing operations fail.
[ Upstream commit dea521a2b9f96e905fa2bb2f95e23ec00c2ec436 ]
Error code returned by 'bnxt_read_sfp_module_eeprom_info()' is handled a
few lines above when reading the A0 portion of the EEPROM.
The same should be done when reading the A2 portion of the EEPROM.
In order to correctly propagate an error, update 'rc' in this 2nd call as
well, otherwise 0 (success) is returned.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
In bnxt_find_nvram_item(), it is copying firmware response data after
releasing the mutex. This can cause the firmware response data
to be corrupted if the next firmware response overwrites the response
buffer. The rare problem shows up when running ethtool -i repeatedly.
Fix it by calling the new variant _hwrm_send_message_silent() that requires
the caller to take the mutex and to release it after the response data has
been copied.
Fixes: 3ebf6f0a09a2 ("bnxt_en: Add installed-package version reporting via Ethtool GDRVINFO")
Reported-by: Sarveswara Rao Mygapula <sarveswararao.mygapula@broadcom.com>
As a further improvement to the PF/VF link change logic, use a private
mutex instead of the rtnl lock to protect link change logic. With the
new mutex, we don't have to take the rtnl lock in the workqueue when
we have to handle link related functions. If the VF and PF drivers
are running on the same host and both take the rtnl lock and one is
waiting for the other, it will cause timeout. This patch fixes these
timeouts.
Fixes: 90c694bb7181 ("bnxt_en: Fix RTNL lock usage on bnxt_update_link().")
When the number of TX rings is changed (e.g. ethtool -L, enabling XDP TX
rings, etc), the current code tries to reserve the new number of TX rings
before closing and re-opening the NIC. If we are unable to reserve the
new TX rings, we abort the operation and keep the current TX rings.
The problem is that the firmware will disable the current TX rings even
when it cannot reserve the new set of TX rings. We fix it as follows:
1. Instead of reserving the new set of TX rings, just ask the firmware
to check if the new set of TX rings is available. There is a flag in
the firmware message to do that. If not available, abort and the
current TX rings will not be disabled.
2. Do the actual TX ring reservation in the path that opens the NIC.
We keep the number of TX rings currently successfully reserved. If the
number of TX rings is different than the reserved TX rings, we call
firmware and reserve again.
Fixes warning because location is u32 and can never be netative
warning: comparison of unsigned expression < 0 is always false [-Wtype-limits]
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
Acked-by: Michael Chan <michael.chan@broadcom.com>
For debugging purpose, it is sometimes useful to disable periodic
port statistics updates, so that the firmware logs will not be
filled with statistics update messages.
Instead of duplicating the logic multiple times. Also, it is unnecessary
to zero the buffer in .get_ethtool_stats() because it is already zeroed
by the caller.
When changing channels from combined to rx/tx or vice versa, the code
uses the wrong "sh" parameter to determine if we are reserving rings
for shared or non-shared mode. It should be using the ethtool requested
"sh" parameter instead of the current "sh" parameter.
Fix it by passing the "sh" parameter to bnxt_reserve_rings(). For
ethtool, we will pass in the requested "sh" parameter.
Fixes: 391be5c27364 ("bnxt_en: Implement new scheme to reserve tx rings.")
Older chips require the doorbells to be written twice, but newer chips
do not. Add a new common function bnxt_db_write() to write all
doorbells appropriately depending on the chip. Eliminating the extra
doorbell on newer chips has a significant performance improvement
on pktgen.
Added support for 100G link speed reporting for Broadcom BCM57454
ASIC in ethtool command.
Signed-off-by: Deepak Khungar <deepak.khungar@broadcom.com>
Signed-off-by: Ray Jui <ray.jui@broadcom.com>
It is necessary to disable autoneg before enabling PHY loopback,
otherwise link won't come up.
The mac loopback self test operates in polling mode. To support that,
we need to add functions to open and close the NIC half way. The half
open mode allows the rings to operate without IRQ and NAPI. We
use the XDP transmit function to send the loopback packet.
Add the basic infrastructure and only firmware tests initially.
And add functions to set and free magic packet filter.
With commit d1e7925e6d80 ("bnxt_en: Centralize logic to reserve rings."),
ring allocation for combined rings has become stricter. A combined
ring must now have an rx-tx ring pair. The pre-set max. for combined
rings should now be min(rx, tx).
Fixes: d1e7925e6d80 ("bnxt_en: Centralize logic to reserve rings.")
If the HWRM_NVM_INSTALL_UPDATE command fails with the error code
NVM_INSTALL_UPDATE_CMD_ERR_CODE_FRAG_ERR, retry the command with
a new flag to allow defragmentation. Since we are checking the
response for error code, we also need to take the mutex until
we finish reading the response.
Signed-off-by: Kshitij Soni <kshitij.soni@broadcom.com>
Add logic for an extra set of TX rings for XDP. If enabled, this
set of TX rings equals the number of RX rings and shares the same
IRQ as the RX ring set. A new field bp->tx_nr_rings_xdp is added
to keep track of these TX XDP rings. Adjust all other relevant functions
to handle bp->tx_nr_rings_xdp.
Currently, bnxt_setup_tc() and bnxt_set_channels() have similar and
duplicated code to check and reserve rx and tx rings. Add a new
function bnxt_reserve_rings() to centralize the logic. This will
make it easier to add XDP_TX support which requires allocating a
Also, the tx ring checking logic in bnxt_setup_msix() can be removed.
The rings have been reserved before hand.
Add LED blinking code to support ethtool -p on the PF.
In order to properly support TX rate limiting in SRIOV VF functions or
NPAR functions, firmware needs better control over tx ring allocations.
The new scheme requires the driver to reserve the number of tx rings
and to query to see if the requested number of tx rings is reserved.
The driver will use the new scheme when the firmware interface spec is
1.6.1 or newer.
Accept ipv6 flows in .ndo_rx_flow_steer() and support ETHTOOL_GRXCLSRULE
ipv6 flows.
Signed-off-by: Michael Chan <michael.chan@broadocm.com>
The advertising field is closely related to the auto_link_speeds field.
The former is the user setting while the latter is the firmware setting.
Both should be u16. We should use the advertising field in
bnxt_get_link_ksettings because the auto_link_speeds field may not
be updated with the latest from the firmware yet.
Report PFC statistics to ethtool -S and DCBNL.
To display and modify the RSS hash.
Restart autoneg if autoneg is enabled.
The existing code is inconsistent in reporting and accepting the combined
channel count. bnxt_get_channels() reports maximum combined as the
maximum rx count. bnxt_set_channels() accepts combined count that
cannot be bigger than max rx or max tx.
For example, if max rx = 2 and max tx = 1, we report max supported
combined to be 2. But if the user tries to set combined to 2, it will
fail because 2 is bigger than max tx which is 1.
Fix the code to be consistent. Max allowed combined = max(max_rx, max_tx).
We will accept a combined channel count <= max(max_rx, max_tx).
Using Ethtool flashdev command, entire NVM package (*.pkg) files
may now be staged into the "update" area of the NVM and subsequently
verified and installed by the firmware using the newly introduced
command: NVM_INSTALL_UPDATE.
We also introduce use of the new firmware command FW_SET_TIME so that the
NVM-resident package installation log contains valid time-stamps.
Signed-off-by: Rob Swindell <Rob.Swindell@broadcom.com>
Just several instances of overlapping changes.
The hardware is unable to drop rx packets not matching the RX filters. To
workaround it, we create a special VNIC and configure the hardware to
direct all packets not matching the filters to it. We then setup the
driver to drop packets received on this VNIC.
This patch creates the infrastructure for this VNIC, reserves a
completion ring, and rx rings. Only shared completion ring mode is
supported. The next 2 patches add a NAPI to handle packets from this
VNIC and the setup of the VNIC.
Signed-off-by: Prashant Sreedharan <prashant.sreedharan@broadcom.com>
rc is not initialized so it can contain garbage if it is not
set by the call to bnxt_read_sfp_module_eeprom_info. Ensure
garbage is not returned by initializing rc to 0.
The allowable range is 0.25 seconds to 1 second interval. Default is
1 second.
Add support to the Ethtool FLASHDEV command handler for additional
firmware types to cover all the on-chip processors.
Signed-off-by: Rob Swindell <rob.swindell@broadcom.com>
Upon successful mgmt processor firmware update, request a self
reset upon next PCIe reset (e.g. system reboot).
To support Secure Firmware Update, we must be able to allocate
a staging area in the Flash. This patch adds support for the
"update" type to tell firmware to do that.
Returning 0 for doing nothing is confusing to the user.
To fully support 25G and 50G link settings.
Some cards do not support autoneg. The current code does not prevent the
user from enabling autoneg with ethtool on such cards, causing confusion.
Firmware provides the autoneg capability information and we just need to
store it in the support_auto_speeds field in bnxt_link_info struct.
The ethtool set_settings() call will check this field before proceeding
with autoneg.
NPAR type is read from bnxt_hwrm_func_qcfg. Do not allow changing link
parameters if in NPAR mode sinc ethe port is shared among multiple
partitions. The link parameters are set up by firmware.
Signed-off-by: Satish Baddipadige <sbaddipa@broadcom.com>
Add support to fetch the SFP EEPROM settings from the firmware
and display it via the ethtool -m command. We support SFP+ and QSFP
modules.
v2: Fixed a bug in bnxt_get_module_eeprom() found by Ben Hutchings.
Signed-off-by: Ajit Khaparde <ajit.khaparde@broadcom.com>
When there is only 1 MSI-X vector or in INTA mode, tx and rx pre-set
max channel parameters are shown incorrectly in ethtool -l. With only 1
vector, bnxt_get_max_rings() will return -ENOMEM. bnxt_get_channels
should check this return value, and set max_rx/max_tx to 0 if it is
non-zero.
10GBaseT devices must autonegotiate to determine master/slave clocking.
Disallow forced speed in ethtool .set_settings() for these devices.
If autoneg is off, we should always report the speed and duplex settings
even if it is link down so the user knows the current settings. The
unknown speed and duplex should only be used for autoneg when link is
down.
Check that the forced speed is a valid speed supported by firmware.
If not supported, return -EINVAL.
Allow users to get|set EEE parameters.
v2: Added comment for preserving the tx_lpi_timer value in get_eee.
1. Add bnxt_hwrm_set_eee() function to setup EEE firmware parameters based
on the bp->eee settings.
2. The new function bnxt_eee_config_ok() will check if EEE parameters need
to be modified due to autoneg changes.
3. bnxt_hwrm_set_link() has added a new parameter to update EEE. If the
parameter is set, it will call bnxt_hwrm_set_eee().
Get EEE capability and the initial EEE settings from firmware.
Add "EEE is active | not active" to link up dmesg.
