Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com>
win0_lock was being used un-initialized, resulting in warning traces
being seen when lock debugging is enabled (and just wrong)
Fixes : fc5ab0209650 ('cxgb4: Replaced the backdoor mechanism to access the HW
memory with PCIe Window method')
Signed-off-by: Anish Bhatt <anish@chelsio.com>
Signed-off-by: Casey Leedom <leedom@chelsio.com>
Disabling DCBx in firmware automatically enables DCBx for control via host
lldp agents. Wait for an explicit setstate call from an lldp agents to enable
DCBx instead.
Fixes: 76bcb31efc06 ("cxgb4 : Add DCBx support codebase and dcbnl_ops")
cxgb4 ipv6 does not guard against ipv6 being disabled, or the standard
ipv6 module vs inbuilt tri-state issue. This was fixed for cxgb4i & iw_cxgb4
but missed for cxgb4.
cxgb4 already handles CLIP updates from a previous changeset for iw_cxgb4,
there is no need to have this functionality in cxgb4i. Remove duplicated code
Use t4_fw_upgrade instead of t4_load_fw to write firmware into FLASH, since
t4_load_fw doesn't co-ordinate with the firmware and the adapter can get hosed
enough to require a power cycle of the system.
Based on original work by Casey Leedom <leedom@chelsio.com>
Call t4_wait_dev_ready() before attempting to read the PL_WHOAMI register
(to determine which function we have been attached to). This prevents us from
failing on that read if it comes right after a RESET.
Based on original work by Kumar Sanghvi <kumaras@chelsio.com>
arch/mips/net/bpf_jit.c
drivers/net/can/flexcan.c
Both the flexcan and MIPS bpf_jit conflicts were cases of simple
overlapping changes.
commit 35b1de557970 ("rdma/cxgb4: Fixes cxgb4 probe failure in VM when PF is
exposed through PCI Passthrough") moved the code to check for SR-IOV PF[0..3]
much further down in init_one() past the point where we allocate a (struct
adapter) for PF[0..3]. As a result, we left four of these on ever module remove.
Fix: Allocate adapter structure only for PF4
RTNL should be already held in the notifier call so the slave list can
be traversed without a problem, remove the unnecessary bond->lock.
CC: Hariprasad S <hariprasad@chelsio.com>
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
A couple of RDMA-related called to t4_query_params() were issuing mbox commands
on mbox0 instead of mbox4.
Avoid dumping MPS_RPLC_MAP_CTL for reg dumps; this is a Write-Only register.
Reading this register may cause MPS TCAM corruption.
Fixes few register access for both T4 and T5.
PCIE_CORE_UTL_SYSTEM_BUS_AGENT_STATUS & PCIE_CORE_UTL_PCI_EXPRESS_PORT_STATUS
is T4 only register don't let T5 access them. For T5 MA_PARITY_ERROR_STATUS2
is additionally read. MPS_TRC_RSS_CONTROL is T4 only register, for T5 use
MPS_T5_TRC_RSS_CONTROL.
There is a possible race condition when we unregister the PCI Driver and then
flush/destroy the global "workq". This could lead to situations where there
are tasks on the Work Queue with references to now deleted adapter data
structures. Instead, have per-adapter Work Queues which were instantiated and
torn down in init_one() and remove_one(), respectively.
v2: Remove unnecessary call to flush_workqueue() before destroy_workqueue()
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull DEFINE_PCI_DEVICE_TABLE removal from Bjorn Helgaas:
"Part two of the PCI changes for v3.17:
- Remove DEFINE_PCI_DEVICE_TABLE macro use (Benoit Taine)
It's a mechanical change that removes uses of the
DEFINE_PCI_DEVICE_TABLE macro. I waited until later in the merge
window to reduce conflicts, but it's possible you'll still see a few"
* tag 'pci-v3.17-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Remove DEFINE_PCI_DEVICE_TABLE macro use
We should prefer `struct pci_device_id` over `DEFINE_PCI_DEVICE_TABLE` to
meet kernel coding style guidelines. This issue was reported by checkpatch.
A simplified version of the semantic patch that makes this change is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
identifier i;
declarer name DEFINE_PCI_DEVICE_TABLE;
initializer z;
- DEFINE_PCI_DEVICE_TABLE(i)
+ const struct pci_device_id i[]
= z;
// </smpl>
[bhelgaas: add semantic patch]
Signed-off-by: Benoit Taine <benoit.taine@lip6.fr>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
* Changes required due to 16eecd9be4b05 ("dcbnl : Fix misleading
dcb_app->priority explanation")
* Driver was previously not aware of what DCBx version was negotiated by
firmware, this could lead to DCB app table in kernel or in firmware being
populated wrong since IEEE/CEE used different formats made clear by above
mentioned commit
* Driver was missing a couple of state transitions that could be caused
by other drivers that use chelsio hardware, resulting in incorrect behaviour
(the change that addresses this also flips the state machine to switch on
state instead of transition, hope this is okay in current window)
* Prio queue info & tsa is no longer thrown away
v2: Print DCBx state transition messages only when debug is enabled
Commit 35b1de5 ("rdma/cxgb4: Fixes cxgb4 probe failure in VM when PF is exposed
through PCI Passthrough") introduced a regression, where VF failed to
initialize for Physical function 0 to Physical Function 3. In the above
commit, we removed the code which used to enable sriov for PF0 to PF3. Now
adding it back to get sriov working.
V2:
Removed SRIOV loop for PF[0..3] to instantiate the VF's as per David Miller's
comment
Enabling a Virtual Interface can result in an interrupt during the processing
of the VI Enable command and, in some paths, result in an attempt to issue
another command in the interrupt context, eventually crashing the system. Thus,
we disable interrupts during the course of the VI Enable command and ensure
enable doesn't sleep.
This commit enhances the iwarp driver to optionally keep a log of rdma
work request timining data for kernel mode QPs. If iw_cxgb4 module option
c4iw_wr_log is set to non-zero, each work request is tracked and timing
data maintained in a rolling log that is 4096 entries deep by default.
Module option c4iw_wr_log_size_order allows specifing a log2 size to use
instead of the default order of 12 (4096 entries). Both module options
are read-only and must be passed in at module load time to set them. IE:
modprobe iw_cxgb4 c4iw_wr_log=1 c4iw_wr_log_size_order=10
The timing data is viewable via the iw_cxgb4 debugfs file "wr_log".
Writing anything to this file will clear all the timing data.
Data tracked includes:
- The host time when the work request was posted, just before ringing
the doorbell. The host time when the completion was polled by the
application. This is also the time the log entry is created. The delta
of these two times is the amount of time took processing the work request.
- The qid of the EQ used to post the work request.
- The work request opcode.
- The cqe wr_id field. For sq completions requests this is the swsqe
index. For recv completions this is the MSN of the ingress SEND.
This value can be used to match log entries from this log with firmware
flowc event entries.
- The sge timestamp value just before ringing the doorbell when
posting, the sge timestamp value just after polling the completion,
and CQE.timestamp field from the completion itself. With these three
timestamps we can track the latency from post to poll, and the amount
of time the completion resided in the CQ before being reaped by the
application. With debug firmware, the sge timestamp is also logged by
firmware in its flowc history so that we can compute the latency from
posting the work request until the firmware sees it.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
With ingress WRITE or READ RESPONSE errors, HW provides the offending
stag from the packet. This patch adds logic to log the parsed TPTE
in this case. cxgb4 now exports a function to read a TPTE entry
from adapter memory.
Advertise a larger max read queue depth for qps, and gather the resource limits
from fw and use them to avoid exhaustinq all the resources.
Design:
cxgb4:
Obtain the max_ordird_qp and max_ird_adapter device params from FW
at init time and pass them up to the ULDs when they attach. If these
parameters are not available, due to older firmware, then hard-code
the values based on the known values for older firmware.
iw_cxgb4:
Fix the c4iw_query_device() to report these correct values based on
adapter parameters. ibv_query_device() will always return:
max_qp_rd_atom = max_qp_init_rd_atom = min(module_max, max_ordird_qp)
max_res_rd_atom = max_ird_adapter
Bump up the per qp max module option to 32, allowing it to be increased
by the user up to the device max of max_ordird_qp. 32 seems to be
sufficient to maximize throughput for streaming read benchmarks.
Fail connection setup if the negotiated IRD exhausts the available
adapter ird resources. So the driver will track the amount of ird
resource in use and not send an RI_WR/INIT to FW that would reduce the
available ird resources below zero.
Updates iw_cxgb4 to determine the Ingress Padding Boundary from
cxgb4_lld_info, and take subsequent actions.
test before debugfs_remove_recursive
Fix checkpatch warning:
"WARNING: debugfs_remove_recursive(NULL) is safe this check is probably not required"
Cc: Hariprasad S <hariprasad@chelsio.com>
Cc: netdev@vger.kernel.org
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Window method
Rip out a bunch of redundant PCI-E Memory Window Read/Write routines,
collapse the more general purpose routines into a single routine
thereby eliminating the need for a large stack frame (and extra data
copying) in the outer routine, change everything to use the improved
routine t4_memory_rw.
Based on origninal work by Casey Leedom <leedom@chelsio.com> and
Use the firmware interface to get the BAR0 value since we really don't want
to use the PCI-E Configuration Space Backdoor access which is owned by the
firmware.
Set up PCI-E Memory Window registers using the true values programmed into
BAR registers. When the PF4 "Master Function" is exported to a Virtual
Machine, the values returned by pci_resource_start() will be for the
synthetic PCI-E Configuration Space and not the real addresses. But we need
to program the PCI-E Memory Window address decoders with the real addresses
that we're going to be using in order to have accesses through the Memory
Windows work.
Passthrough
Change logic which determines our Physical Function at PCI Probe time.
Now we read the PL_WHOAMI register and get the Physical Function.
Pass Physical Function to Upper Layer Drivers in lld_info structure in the
new field "pf" added to lld_info. This is useful for the cases where the
PF, say PF4, is attached to a Virtual Machine via some form of "PCI
Pass Through" technology and the PCI Function shows up as PF0 in the VM.
cxgb4_netdev maybe lead to dead lock, since it uses a spin lock, and be called
in both thread and softirq context, but not disable BH, the lockdep report is
below; In fact, cxgb4_netdev only reads adap_rcu_list with RCU protection, so
not need to hold spin lock again.
[ INFO: inconsistent lock state ]
3.14.7+ #24 Tainted: G C O
inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
radvd/3794 [HC0[0]:SC1[1]:HE1:SE0] takes:
(adap_rcu_lock){+.?...}, at: [<ffffffffa09989ea>] clip_add+0x2c/0x116 [cxgb4]
{SOFTIRQ-ON-W} state was registered at:
[<ffffffff810fca81>] __lock_acquire+0x34a/0xe48
[<ffffffff810fd98b>] lock_acquire+0x82/0x9d
[<ffffffff815d6ff8>] _raw_spin_lock+0x34/0x43
[<ffffffffa0998beb>] cxgb4_inet6addr_handler+0x117/0x12c [cxgb4]
[<ffffffff815da98b>] notifier_call_chain+0x32/0x5c
[<ffffffff815da9f9>] __atomic_notifier_call_chain+0x44/0x6e
[<ffffffff815daa32>] atomic_notifier_call_chain+0xf/0x11
[<ffffffff815b1356>] inet6addr_notifier_call_chain+0x16/0x18
[<ffffffffa01f72e5>] ipv6_add_addr+0x404/0x46e [ipv6]
[<ffffffffa01f8df0>] addrconf_add_linklocal+0x5f/0x95 [ipv6]
[<ffffffffa01fc3e9>] addrconf_notify+0x632/0x841 [ipv6]
[<ffffffff810e09a1>] __raw_notifier_call_chain+0x9/0xb
[<ffffffff810e09b2>] raw_notifier_call_chain+0xf/0x11
[<ffffffff8151b3b7>] call_netdevice_notifiers_info+0x4e/0x56
[<ffffffff8151b3d0>] call_netdevice_notifiers+0x11/0x13
[<ffffffff8151c0a6>] netdev_state_change+0x1f/0x38
[<ffffffff8152f004>] linkwatch_do_dev+0x3b/0x49
[<ffffffff8152f184>] __linkwatch_run_queue+0x10b/0x144
[<ffffffff8152f1dd>] linkwatch_event+0x20/0x27
[<ffffffff810d7bc0>] process_one_work+0x1cb/0x2ee
[<ffffffff810d7e3b>] worker_thread+0x12e/0x1fc
[<ffffffff810dd391>] kthread+0xc4/0xcc
[<ffffffff815dc48c>] ret_from_fork+0x7c/0xb0
irq event stamp: 3388
hardirqs last enabled at (3388): [<ffffffff810c6c85>]
__local_bh_enable_ip+0xaa/0xd9
hardirqs last disabled at (3387): [<ffffffff810c6c2d>]
__local_bh_enable_ip+0x52/0xd9
softirqs last enabled at (3288): [<ffffffffa01f1d5b>]
rcu_read_unlock_bh+0x0/0x2f [ipv6]
softirqs last disabled at (3289): [<ffffffff815ddafc>]
do_softirq_own_stack+0x1c/0x30
Possible unsafe locking scenario:
CPU0
lock(adap_rcu_lock);
<Interrupt>
*** DEADLOCK ***
5 locks held by radvd/3794:
#0: (sk_lock-AF_INET6){+.+.+.}, at: [<ffffffffa020b85a>]
rawv6_sendmsg+0x74b/0xa4d [ipv6]
#1: (rcu_read_lock){.+.+..}, at: [<ffffffff8151ac6b>]
rcu_lock_acquire+0x0/0x29
#2: (rcu_read_lock){.+.+..}, at: [<ffffffffa01f4cca>]
rcu_lock_acquire.constprop.16+0x0/0x30 [ipv6]
#3: (rcu_read_lock){.+.+..}, at: [<ffffffff810e09b4>]
#4: (rcu_read_lock){.+.+..}, at: [<ffffffffa0998782>]
rcu_lock_acquire.constprop.40+0x0/0x30 [cxgb4]
stack backtrace:
CPU: 7 PID: 3794 Comm: radvd Tainted: G C O 3.14.7+ #24
Hardware name: Supermicro X7DBU/X7DBU, BIOS 6.00 12/03/2007
ffffffff81f15990 ffff88012fdc36a8 ffffffff815d0016 0000000000000006
ffff8800c80dc2a0 ffff88012fdc3708 ffffffff815cc727 0000000000000001
0000000000000001 ffff880100000000 ffffffff81015b02 ffff8800c80dcb58
Call Trace:
<IRQ> [<ffffffff815d0016>] dump_stack+0x4e/0x71
[<ffffffff815cc727>] print_usage_bug+0x1ec/0x1fd
[<ffffffff81015b02>] ? save_stack_trace+0x27/0x44
[<ffffffff810fbfaa>] ? check_usage_backwards+0xa0/0xa0
[<ffffffff810fc640>] mark_lock+0x11b/0x212
[<ffffffff810fca0b>] __lock_acquire+0x2d4/0xe48
[<ffffffff810fbff6>] ? check_usage_forwards+0x4c/0xa6
[<ffffffff810c6c8a>] ? __local_bh_enable_ip+0xaf/0xd9
[<ffffffffa09989ea>] ? clip_add+0x2c/0x116 [cxgb4]
[<ffffffffa0998782>] ? rcu_read_unlock+0x23/0x23 [cxgb4]
[<ffffffffa09987b0>] ? rcu_lock_acquire.constprop.40+0x2e/0x30 [cxgb4]
[<ffffffff810fd99d>] ? lock_acquire+0x94/0x9d
[<ffffffff810e09b4>] ? raw_notifier_call_chain+0x11/0x11
[<ffffffff810fde6a>] ? trace_hardirqs_on+0xd/0xf
[<ffffffffa01fb634>] addrconf_prefix_rcv+0x385/0x6ea [ipv6]
[<ffffffffa0207950>] ndisc_rcv+0x9d3/0xd76 [ipv6]
[<ffffffffa020d536>] icmpv6_rcv+0x592/0x67b [ipv6]
[<ffffffff810c6c85>] ? __local_bh_enable_ip+0xaa/0xd9
[<ffffffff810fd8dc>] ? lock_release+0x14e/0x17b
[<ffffffffa020df97>] ? rcu_read_unlock+0x21/0x23 [ipv6]
[<ffffffff8150df52>] ? rcu_read_unlock+0x23/0x23
[<ffffffffa01f4ede>] ip6_input_finish+0x1e4/0x2fc [ipv6]
[<ffffffffa01f540b>] ip6_input+0x33/0x38 [ipv6]
[<ffffffffa01f5557>] ip6_mc_input+0x147/0x160 [ipv6]
[<ffffffffa01f4ba3>] ip6_rcv_finish+0x7c/0x81 [ipv6]
[<ffffffffa01f5397>] ipv6_rcv+0x3a1/0x3e2 [ipv6]
[<ffffffff8151ef96>] __netif_receive_skb_core+0x4ab/0x511
[<ffffffff810fdc94>] ? mark_held_locks+0x71/0x99
[<ffffffff8151f0c0>] ? process_backlog+0x69/0x15e
[<ffffffff8151f045>] __netif_receive_skb+0x49/0x5b
[<ffffffff8151f0cf>] process_backlog+0x78/0x15e
[<ffffffff8151f571>] ? net_rx_action+0x1a2/0x1cc
[<ffffffff8151f47b>] net_rx_action+0xac/0x1cc
[<ffffffff810c69b7>] ? __do_softirq+0xad/0x218
[<ffffffff810c69ff>] __do_softirq+0xf5/0x218
[<ffffffff815ddafc>] do_softirq_own_stack+0x1c/0x30
<EOI> [<ffffffff810c6bb6>] do_softirq+0x38/0x5d
[<ffffffffa01f1d5b>] ? ip6_copy_metadata+0x156/0x156 [ipv6]
[<ffffffff810c6c78>] __local_bh_enable_ip+0x9d/0xd9
[<ffffffffa01f1d88>] rcu_read_unlock_bh+0x2d/0x2f [ipv6]
[<ffffffffa01f28b4>] ip6_finish_output2+0x381/0x3d8 [ipv6]
[<ffffffffa01f49ef>] ip6_finish_output+0x6e/0x73 [ipv6]
[<ffffffffa01f4a70>] ip6_output+0x7c/0xa8 [ipv6]
[<ffffffff815b1bfa>] dst_output+0x18/0x1c
[<ffffffff815b1c9e>] ip6_local_out+0x1c/0x21
[<ffffffffa01f2489>] ip6_push_pending_frames+0x37d/0x427 [ipv6]
[<ffffffff81558af8>] ? skb_orphan+0x39/0x39
[<ffffffffa020b85a>] ? rawv6_sendmsg+0x74b/0xa4d [ipv6]
[<ffffffffa020ba51>] rawv6_sendmsg+0x942/0xa4d [ipv6]
[<ffffffff81584cd2>] inet_sendmsg+0x3d/0x66
[<ffffffff81508930>] __sock_sendmsg_nosec+0x25/0x27
[<ffffffff8150b0d7>] sock_sendmsg+0x5a/0x7b
[<ffffffff8116d756>] ? might_fault+0x9e/0xa5
[<ffffffff8116d70d>] ? might_fault+0x55/0xa5
[<ffffffff81508cb1>] ? copy_from_user+0x2a/0x2c
[<ffffffff8150b70c>] ___sys_sendmsg+0x226/0x2d9
[<ffffffff810fcd25>] ? __lock_acquire+0x5ee/0xe48
[<ffffffff810fde01>] ? trace_hardirqs_on_caller+0x145/0x1a1
[<ffffffff8118efcb>] ? slab_free_hook.isra.71+0x50/0x59
[<ffffffff8115c81f>] ? release_pages+0xbc/0x181
[<ffffffff81115e97>] ? read_seqcount_begin.constprop.25+0x73/0x90
[<ffffffff8150c408>] __sys_sendmsg+0x3d/0x5b
[<ffffffff8150c433>] SyS_sendmsg+0xd/0x19
[<ffffffff815dc53d>] system_call_fastpath+0x1a/0x1f
Reported-by: Ben Greear <greearb@candelatech.com>
Cc: Casey Leedom <leedom@chelsio.com>
Cc: Hariprasad Shenai <hariprasad@chelsio.com>
Signed-off-by: Li RongQing <roy.qing.li@gmail.com>
Acked-by: Casey Leedom <leedom@chelsio.com>
access to DCBx functions
Select the appropriate hw mtu index and initial sequence number to optimize
hw memory performance.
Add new cxgb4_best_aligned_mtu() which allows callers to provide enough
information to be used to [possibly] select an MTU which will result in the
TCP Data Segment Size (AKA Maximum Segment Size) to be an aligned value.
If an RTR message exhange is required, then align the ISS to 8B - 1 + 4, so
that after the SYN the send seqno will align on a 4B boundary. The RTR
message exchange will leave the send seqno aligned on an 8B boundary.
If an RTR is not required, then align the ISS to 8B - 1. The goal is
to have the send seqno be 8B aligned when we send the first FPDU.
Based on original work by Casey Leedom <leeedom@chelsio.com> and
Currently indirect interrupts for RDMA CQs funnel through the LLD's RDMA
RXQs, which also handle direct interrupts for offload CPLs during RDMA
connection setup/teardown. The intended T4 usage model, however, is to
have indirect interrupts flow through dedicated IQs. IE not to mix
indirect interrupts with CPL messages in an IQ. This patch adds the
concept of RDMA concentrator IQs, or CIQs, setup and maintained by the
LLD and exported to iw_cxgb4 for use when creating CQs. RDMA CPLs will
flow through the LLD's RDMA RXQs, and CQ interrupts flow through the
CIQs.
Design:
cxgb4 creates and exports an array of CIQs for the RDMA ULD. These IQs
are sized according to the max available CQs available at adapter init.
In addition, these IQs don't need FL buffers since they only service
indirect interrupts. One CIQ is setup per RX channel similar to the
RDMA RXQs.
iw_cxgb4 will utilize these CIQs based on the vector value passed into
create_cq(). The num_comp_vectors advertised by iw_cxgb4 will be the
number of CIQs configured, and thus the vector value will be the index
into the array of CIQs.
Based on original work by Steve Wise <swise@opengridcomputing.com>
ETHTOOL_{G,S}RXFHINDIR and ETHTOOL_{G,S}RSSH should work for drivers
regardless of whether they expose the hash key, unless you try to
set a hash key for a driver that doesn't expose it.
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
net: get rid of SET_ETHTOOL_OPS
Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone.
This does that.
Mostly done via coccinelle script:
struct ethtool_ops *ops;
struct net_device *dev;
- SET_ETHTOOL_OPS(dev, ops);
+ dev->ethtool_ops = ops;
Compile tested only, but I'd seriously wonder if this broke anything.
Suggested-by: Dave Miller <davem@davemloft.net>
Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de>
Acked-by: Felipe Balbi <balbi@ti.com>
The __vlan_find_dev_deep should always called in RCU, according
David's suggestion, rename to __vlan_find_dev_deep_rcu looks more
reasonable.
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
drivers/net/ethernet/altera/altera_sgdma.c
net/netlink/af_netlink.c
net/sched/cls_api.c
net/sched/sch_api.c
The netlink conflict dealt with moving to netlink_capable() and
netlink_ns_capable() in the 'net' tree vs. supporting 'tc' operations
in non-init namespaces. These were simple transformations from
netlink_capable to netlink_ns_capable.
The Altera driver conflict was simply code removal overlapping some
void pointer cast cleanups in net-next.
Add handling for " 8 GT/s" in print_port_info().
Signed-off-by: Roland Dreier <roland@purestorage.com>
Using addressof then casting to the original type is pointless,
so remove these unnecessary casts.
Done via coccinelle script:
$ cat typecast.cocci
type T;
T foo;
- (T *)&foo
+ &foo
The current logic suffers from a slow response time to disable user DB
usage, and also fails to avoid DB FIFO drops under heavy load. This commit
fixes these deficiencies and makes the avoidance logic more optimal.
This is done by more efficiently notifying the ULDs of potential DB
problems, and implements a smoother flow control algorithm in iw_cxgb4,
which is the ULD that puts the most load on the DB fifo.
Design:
cxgb4:
Direct ULD callback from the DB FULL/DROP interrupt handler. This allows
the ULD to stop doing user DB writes as quickly as possible.
While user DB usage is disabled, the LLD will accumulate DB write events
for its queues. Then once DB usage is reenabled, a single DB write is
done for each queue with its accumulated write count. This reduces the
load put on the DB fifo when reenabling.
iw_cxgb4:
Instead of marking each qp to indicate DB writes are disabled, we create
a device-global status page that each user process maps. This allows
iw_cxgb4 to only set this single bit to disable all DB writes for all
user QPs vs traversing the idr of all the active QPs. If the libcxgb4
doesn't support this, then we fall back to the old approach of marking
each QP. Thus we allow the new driver to work with an older libcxgb4.
When the LLD upcalls iw_cxgb4 indicating DB FULL, we disable all DB writes
via the status page and transition the DB state to STOPPED. As user
processes see that DB writes are disabled, they call into iw_cxgb4
to submit their DB write events. Since the DB state is in STOPPED,
the QP trying to write gets enqueued on a new DB "flow control" list.
As subsequent DB writes are submitted for this flow controlled QP, the
amount of writes are accumulated for each QP on the flow control list.
So all the user QPs that are actively ringing the DB get put on this
list and the number of writes they request are accumulated.
When the LLD upcalls iw_cxgb4 indicating DB EMPTY, which is in a workq
context, we change the DB state to FLOW_CONTROL, and begin resuming all
the QPs that are on the flow control list. This logic runs on until
the flow control list is empty or we exit FLOW_CONTROL mode (due to
a DB DROP upcall, for example). QPs are removed from this list, and
their accumulated DB write counts written to the DB FIFO. Sets of QPs,
called chunks in the code, are removed at one time. The chunk size is 64.
So 64 QPs are resumed at a time, and before the next chunk is resumed, the
logic waits (blocks) for the DB FIFO to drain. This prevents resuming to
quickly and overflowing the FIFO. Once the flow control list is empty,
the db state transitions back to NORMAL and user QPs are again allowed
to write directly to the user DB register.
The algorithm is designed such that if the DB write load is high enough,
then all the DB writes get submitted by the kernel using this flow
controlled approach to avoid DB drops. As the load lightens though, we
resume to normal DB writes directly by user applications.
drivers/net/wireless/ath/ath9k/recv.c
drivers/net/wireless/mwifiex/pcie.c
net/ipv6/sit.c
The SIT driver conflict consists of a bug fix being done by hand
in 'net' (missing u64_stats_init()) whilst in 'net-next' a helper
was created (netdev_alloc_pcpu_stats()) which takes care of this.
The two wireless conflicts were overlapping changes.
Without a shutdown handler, T4 cards behave very badly after a kexec.
Some firmware calls return errors indicating allocation failures, for
example. This is probably because thouse resources were not released by
a BYE message to the firmware, for example.
Using the remove handler guarantees we will use a well tested path.
With this patch I applied, I managed to use kexec multiple times and
probe and iSCSI login worked every time.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com>
