path: root/drivers/net/ethernet/cirrus
2018-09-21net: cirrus: fix return type of ndo_start_xmit functionYueHaibing
The method ndo_start_xmit() is defined as returning an 'netdev_tx_t', which is a typedef for an enum type, so make sure the implementation in this driver has returns 'netdev_tx_t' value, and change the function return type to netdev_tx_t. Found by coccinelle. Signed-off-by: YueHaibing <yuehaibing@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-07-22net: prevent ISA drivers from building on PPC32Randy Dunlap
Prevent drivers from building on PPC32 if they use isa_bus_to_virt(), isa_virt_to_bus(), or isa_page_to_bus(), which are not available and thus cause build errors. ../drivers/net/ethernet/3com/3c515.c: In function 'corkscrew_open': ../drivers/net/ethernet/3com/3c515.c:824:9: error: implicit declaration of function 'isa_virt_to_bus'; did you mean 'virt_to_bus'? [-Werror=implicit-function-declaration] ../drivers/net/ethernet/amd/lance.c: In function 'lance_rx': ../drivers/net/ethernet/amd/lance.c:1203:23: error: implicit declaration of function 'isa_bus_to_virt'; did you mean 'bus_to_virt'? [-Werror=implicit-function-declaration] ../drivers/net/ethernet/amd/ni65.c: In function 'ni65_init_lance': ../drivers/net/ethernet/amd/ni65.c:585:20: error: implicit declaration of function 'isa_virt_to_bus'; did you mean 'virt_to_bus'? [-Werror=implicit-function-declaration] ../drivers/net/ethernet/cirrus/cs89x0.c: In function 'net_open': ../drivers/net/ethernet/cirrus/cs89x0.c:897:20: error: implicit declaration of function 'isa_virt_to_bus'; did you mean 'virt_to_bus'? [-Werror=implicit-function-declaration] Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Suggested-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-03-01net/mac89x0: Replace custom debug logging with netif_* callsFinn Thain
Adopt the conventional style of debug logging because it is both shorter and more flexible. Remove the 'version_printed' flag as the version will be printed only once anyway (when the module loads). Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-03-01net/mac89x0: Fix and modernize log messagesFinn Thain
Fix log message fragments that no longer produce the desired output since the behaviour of printk() was changed. Add missing printk severity levels. Drop deprecated "out of memory" message as per checkpatch advice. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-03-01net/mac89x0: Convert to platform_driverFinn Thain
Apparently these Dayna cards don't have a pseudoslot declaration ROM which means they can't be probed like NuBus cards. Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2018-03-01net/mac89x0: Remove redundant codeFinn Thain
2018-01-29Merge tag 'm68k-for-v4.16-tag1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k updates from Geert Uytterhoeven: - first part of an overhaul of the NuBus subsystem, to bring it up to modern driver model standards - a race condition fix for Mac - defconfig updates * tag 'm68k-for-v4.16-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: MAINTAINERS: Add NuBus subsystem entry m68k/mac: Fix race conditions in OSS interrupt dispatch nubus: Add support for the driver model nubus: Add expansion_type values for various Mac models nubus: Adopt standard linked list implementation nubus: Rename struct nubus_dev nubus: Rework /proc/bus/nubus/s/ implementation nubus: Generalize block resource handling nubus: Clean up whitespace nubus: Remove redundant code nubus: Call proc_mkdir() not more than once per slot directory nubus: Validate slot resource IDs nubus: Fix log spam nubus: Use static functions where possible nubus: Fix up header split nubus: Avoid array underflow and overflow m68k/defconfig: Update defconfigs for v4.15-rc1
2018-01-16nubus: Adopt standard linked list implementationFinn Thain
This increases code re-use and improves readability. Cc: "David S. Miller" <davem@davemloft.net> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Tested-by: Stan Johnson <userm57@yahoo.com> Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2018-01-15net: cs89x0: add MODULE_LICENSEArnd Bergmann
This driver lacks a MODULE_LICENSE tag, leading to a Kbuild warning: WARNING: modpost: missing MODULE_LICENSE() in drivers/net/ethernet/cirrus/cs89x0.o This adds license, author, and description according to the comment block at the start of the file. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-16networking: introduce and use skb_put_data()Johannes Berg
A common pattern with skb_put() is to just want to memcpy() some data into the new space, introduce skb_put_data() for this. An spatch similar to the one for skb_put_zero() converts many of the places using it: @@ identifier p, p2; expression len, skb, data; type t, t2; @@ ( -p = skb_put(skb, len); +p = skb_put_data(skb, data, len); | -p = (t)skb_put(skb, len); +p = skb_put_data(skb, data, len); ) ( p2 = (t2)p; -memcpy(p2, data, len); | -memcpy(p, data, len); ) @@ type t, t2; identifier p, p2; expression skb, data; @@ t *p; ... ( -p = skb_put(skb, sizeof(t)); +p = skb_put_data(skb, data, sizeof(t)); | -p = (t *)skb_put(skb, sizeof(t)); +p = skb_put_data(skb, data, sizeof(t)); ) ( p2 = (t2)p; -memcpy(p2, data, sizeof(*p)); | -memcpy(p, data, sizeof(*p)); ) @@ expression skb, len, data; @@ -memcpy(skb_put(skb, len), data, len); +skb_put_data(skb, data, len); (again, manually post-processed to retain some comments) Reviewed-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-05net/{mii, smsc}: Make mii_ethtool_get_link_ksettings and smc_netdev_get_ecmd ↵yuval.shaia@oracle.com
return void Make return value void since functions never returns meaningfull value. Signed-off-by: Yuval Shaia <yuval.shaia@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-05-10Merge tag 'hwparam-20170420' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs Pull hw lockdown support from David Howells: "Annotation of module parameters that configure hardware resources including ioports, iomem addresses, irq lines and dma channels. This allows a future patch to prohibit the use of such module parameters to prevent that hardware from being abused to gain access to the running kernel image as part of locking the kernel down under UEFI secure boot conditions. Annotations are made by changing: module_param(n, t, p) module_param_named(n, v, t, p) module_param_array(n, t, m, p) to: module_param_hw(n, t, hwtype, p) module_param_hw_named(n, v, t, hwtype, p) module_param_hw_array(n, t, hwtype, m, p) where the module parameter refers to a hardware setting hwtype specifies the type of the resource being configured. This can be one of: ioport Module parameter configures an I/O port iomem Module parameter configures an I/O mem address ioport_or_iomem Module parameter could be either (runtime set) irq Module parameter configures an I/O port dma Module parameter configures a DMA channel dma_addr Module parameter configures a DMA buffer address other Module parameter configures some other value Note that the hwtype is compile checked, but not currently stored (the lockdown code probably won't require it). It is, however, there for future use. A bonus is that the hwtype can also be used for grepping. The intention is for the kernel to ignore or reject attempts to set annotated module parameters if lockdown is enabled. This applies to options passed on the boot command line, passed to insmod/modprobe or direct twiddling in /sys/module/ parameter files. The module initialisation then needs to handle the parameter not being set, by (1) giving an error, (2) probing for a value or (3) using a reasonable default. What I can't do is just reject a module out of hand because it may take a hardware setting in the module parameters. Some important modules, some ipmi stuff for instance, both probe for hardware and allow hardware to be manually specified; if the driver is aborts with any error, you don't get any ipmi hardware. Further, trying to do this entirely in the module initialisation code doesn't protect against sysfs twiddling. [!] Note that in and of itself, this series of patches should have no effect on the the size of the kernel or code execution - that is left to a patch in the next series to effect. It does mark annotated kernel parameters with a KERNEL_PARAM_FL_HWPARAM flag in an already existing field" * tag 'hwparam-20170420' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs: (38 commits) Annotate hardware config module parameters in sound/pci/ Annotate hardware config module parameters in sound/oss/ Annotate hardware config module parameters in sound/isa/ Annotate hardware config module parameters in sound/drivers/ Annotate hardware config module parameters in fs/pstore/ Annotate hardware config module parameters in drivers/watchdog/ Annotate hardware config module parameters in drivers/video/ Annotate hardware config module parameters in drivers/tty/ Annotate hardware config module parameters in drivers/staging/vme/ Annotate hardware config module parameters in drivers/staging/speakup/ Annotate hardware config module parameters in drivers/staging/media/ Annotate hardware config module parameters in drivers/scsi/ Annotate hardware config module parameters in drivers/pcmcia/ Annotate hardware config module parameters in drivers/pci/hotplug/ Annotate hardware config module parameters in drivers/parport/ Annotate hardware config module parameters in drivers/net/wireless/ Annotate hardware config module parameters in drivers/net/wan/ Annotate hardware config module parameters in drivers/net/irda/ Annotate hardware config module parameters in drivers/net/hamradio/ Annotate hardware config module parameters in drivers/net/ethernet/ ...
2017-05-08format-security: move static strings to constKees Cook
While examining output from trial builds with -Wformat-security enabled, many strings were found that should be defined as "const", or as a char array instead of char pointer. This makes some static analysis easier, by producing fewer false positives. As these are all trivial changes, it seemed best to put them all in a single patch rather than chopping them up per maintainer. Link: http://lkml.kernel.org/r/20170405214711.GA5711@beast Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Jes Sorensen <jes@trained-monkey.org> [runner.c] Cc: Tony Lindgren <tony@atomide.com> Cc: Russell King <linux@armlinux.org.uk> Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Daniel Vetter <daniel.vetter@intel.com> Cc: Jani Nikula <jani.nikula@linux.intel.com> Cc: Sean Paul <seanpaul@chromium.org> Cc: David Airlie <airlied@linux.ie> Cc: Yisen Zhuang <yisen.zhuang@huawei.com> Cc: Salil Mehta <salil.mehta@huawei.com> Cc: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Jiri Slaby <jslaby@suse.com> Cc: Patrice Chotard <patrice.chotard@st.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Hogan <james.hogan@imgtec.com> Cc: Paul Burton <paul.burton@imgtec.com> Cc: Matt Redfearn <matt.redfearn@imgtec.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Felipe Balbi <felipe.balbi@linux.intel.com> Cc: Jarod Wilson <jarod@redhat.com> Cc: Florian Westphal <fw@strlen.de> Cc: Antonio Quartulli <a@unstable.cc> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Kejian Yan <yankejian@huawei.com> Cc: Daode Huang <huangdaode@hisilicon.com> Cc: Qianqian Xie <xieqianqian@huawei.com> Cc: Philippe Reynes <tremyfr@gmail.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Eric Dumazet <edumazet@google.com> Cc: Christian Gromm <christian.gromm@microchip.com> Cc: Andrey Shvetsov <andrey.shvetsov@k2l.de> Cc: Jason Litzinger <jlitzingerdev@gmail.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-04-20Annotate hardware config module parameters in drivers/net/ethernet/David Howells
When the kernel is running in secure boot mode, we lock down the kernel to prevent userspace from modifying the running kernel image. Whilst this includes prohibiting access to things like /dev/mem, it must also prevent access by means of configuring driver modules in such a way as to cause a device to access or modify the kernel image. To this end, annotate module_param* statements that refer to hardware configuration and indicate for future reference what type of parameter they specify. The parameter parser in the core sees this information and can skip such parameters with an error message if the kernel is locked down. The module initialisation then runs as normal, but just sees whatever the default values for those parameters is. Note that we do still need to do the module initialisation because some drivers have viable defaults set in case parameters aren't specified and some drivers support automatic configuration (e.g. PNP or PCI) in addition to manually coded parameters. This patch annotates drivers in drivers/net/ethernet/. Suggested-by: Alan Cox <gnomes@lxorguk.ukuu.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> cc: Steffen Klassert <steffen.klassert@secunet.com> cc: Jaroslav Kysela <perex@perex.cz> cc: netdev@vger.kernel.org cc: linux-parisc@vger.kernel.org
2017-04-18net: cx89x0: move attribute declaration before struct keywordStefan Agner
The attribute declaration is typically before the definition. Move the __maybe_unused attribute declaration before the struct keyword. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-02-05ep93xx_eth: add GRO supportEric Dumazet
Use napi_complete_done() instead of __napi_complete() to : 1) Get support of gro_flush_timeout if opt-in 2) Not rearm interrupts for busy-polling users. 3) use standard NAPI API. 4) get rid of baroque code and ease maintenance. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-17net: cirrus: ep93xx: use new api ethtool_{get|set}_link_ksettingsPhilippe Reynes
The ethtool api {get|set}_settings is deprecated. We move this driver to new api {get|set}_link_ksettings. Signed-off-by: Philippe Reynes <tremyfr@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2016-12-05net: ep93xx_eth: Do not crash unloading moduleFlorian Fainelli
When we unload the ep93xx_eth, whether we have opened the network interface or not, we will either hit a kernel paging request error, or a simple NULL pointer de-reference because: - if ep93xx_open has been called, we have created a valid DMA mapping for ep->descs, when we call ep93xx_stop, we also call ep93xx_free_buffers, ep->descs now has a stale value - if ep93xx_open has not been called, we have a NULL pointer for ep->descs, so performing any operation against that address just won't work Fix this by adding a NULL pointer check for ep->descs which means that ep93xx_free_buffers() was able to successfully tear down the descriptors and free the DMA cookie as well. Fixes: 1d22e05df818 ("[PATCH] Cirrus Logic ep93xx ethernet driver") Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-10-13net: deprecate eth_change_mtu, remove usageJarod Wilson
With centralized MTU checking, there's nothing productive done by eth_change_mtu that isn't already done in dev_set_mtu, so mark it as deprecated and remove all usage of it in the kernel. All callers have been audited for calls to alloc_etherdev* or ether_setup directly, which means they all have a valid dev->min_mtu and dev->max_mtu. Now eth_change_mtu prints out a netdev_warn about being deprecated, for the benefit of out-of-tree drivers that might be utilizing it. Of note, dvb_net.c actually had dev->mtu = 4096, while using eth_change_mtu, meaning that if you ever tried changing it's mtu, you couldn't set it above 1500 anymore. It's now getting dev->max_mtu also set to 4096 to remedy that. v2: fix up lantiq_etop, missed breakage due to drive not compiling on x86 CC: netdev@vger.kernel.org Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-15net: cx89x0: Add DT supportAlexander Shiyan
Add DT support to the Cirrus Logic CS89x0 driver. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-23drivers/net: remove all references to obsolete Ethernet-HOWTOPaul Gortmaker
This howto made sense in the 1990s when users had to manually configure ISA cards with jumpers or vendor utilities, but with the implementation of PCI it became increasingly less and less relevant, to the point where it has been well over a decade since I last updated it. And there is no value in anyone else taking over updating it either. However the references to it continue to spread as boiler plate text from one Kconfig file into the next. We are not doing end users any favours by pointing them at this old document, so lets kill it with fire, once and for all, to hopefully stop any further spread. No code is changed in this commit, just Kconfig help text. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-08ethernet: codespell comment spelling fixesJoe Perches
To test a checkpatch spelling patch, I ran codespell against drivers/net/ethernet/. $ git ls-files drivers/net/ethernet/ | \ while read file ; do \ codespell -w $file; \ done I removed a false positive in e1000_hw.h Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/vxlan.c drivers/vhost/net.c include/linux/if_vlan.h net/core/dev.c The net/core/dev.c conflict was the overlap of one commit marking an existing function static whilst another was adding a new function. In the include/linux/if_vlan.h case, the type used for a local variable was changed in 'net', whereas the function got rewritten to fix a stacked vlan bug in 'net-next'. In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next' overlapped with an endainness fix for VHOST 1.0 in 'net'. In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter in 'net-next' whereas in 'net' there was a bug fix to pass in the correct network namespace pointer in calls to this function. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05net: ep93xx_eth: Delete unnecessary checks before the function call "kfree"Markus Elfring
The kfree() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-29net: cs89x0: always build platform code if !HAS_IOPORT_MAPArnd Bergmann
The cs89x0 driver can either be built as an ISA driver or a platform driver, the choice is controlled by the CS89x0_PLATFORM Kconfig symbol. Building the ISA driver on a system that does not have a way to map I/O ports fails with this error: drivers/built-in.o: In function `cs89x0_ioport_probe.constprop.1': :(.init.text+0x4794): undefined reference to `ioport_map' :(.init.text+0x4830): undefined reference to `ioport_unmap' This changes the Kconfig logic to take that option away and always force building the platform variant of this driver if CONFIG_HAS_IOPORT_MAP is not set. This is the only correct choice in this case, and it avoids the build error. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-15cirrus: cs89x0: fix time comparisonAsaf Vertz
To be future-proof and for better readability the time comparisons are modified to use time_before, time_after, and time_after_eq instead of plain, error-prone math. Signed-off-by: Asaf Vertz <asaf.vertz@tandemg.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-10-24cirrus/mac89x0: Remove superfluous interrupt disable/restoreGeert Uytterhoeven
As of commit e4dc601bf99ccd1c ("m68k: Disable/restore interrupts in hwreg_present()/hwreg_write()"), this is no longer needed. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-20net: ethernet: cirrus: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-08-02cirrus: cs89x0: Use managed interfacesHimangi Saraogi
This patch introduces the use of managed interfaces like devm_ioremap_resource and does away with the functions to free the allocated memory in the probe and remove functions. Also, many labels are done away with. The field size in no longer needed and is hence removed from the struct net_local. Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-24cs89x0: Call dev_consume_skb_any instead of dev_kfree_skb.Eric W. Biederman
Replace dev_kfree_skb with dev_consume_skb_any in net_send_packet that can be called in hard irq and other contexts. net_send_packet consumes (not drops) the skb of interest. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-01-16drivers/net: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. This covers everything under drivers/net except for wireless, which has been submitted separately. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-30net: ep93xx_eth: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. This is a cosmetic change to make the code simpler and enhance the readability. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-19net: Move MII out from under NET_CORE and hide itBen Hutchings
All drivers that select MII also need to select NET_CORE because MII depends on it. This is a bit ridiculous because NET_CORE is just a menu option that doesn't enable any code by itself. There is also no need for it to be a visible option, since its users all select it. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-27net: ethernet: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Roland Stigge <stigge@antcom.de> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Roland Stigge <stigge@antcom.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-29cirrus: cs89x0: remove two obsolete Kconfig macrosPaul Bolle
The CONFIG_ARCH_IXDP2X01 and CONFIG_MACH_IXDP2351 Kconfig macros are unused since the ixp23xx and ixp2000 platforms were removed in v3.5. So remove the last code still depending on these macros. And since CS89x0_NONISA_IRQ was only set if either of these two macros was defined we can also remove that macro and the code depending on it. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-18net: ep93xx_eth: Use module_platform_driver()Sachin Kamat
module_platform_driver macro removes some boilerplate and makes the code simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-09drivers:net: Remove unnecessary OOM messages after netdev_alloc_skbJoe Perches
Emitting netdev_alloc_skb and netdev_alloc_skb_ip_align OOM messages is unnecessary as there is already a dump_stack after allocation failures. Other trivial changes around these removals: Convert a few comparisons of pointer to 0 to !pointer. Change flow to remove unnecessary label. Remove now unused variable. Hoist assignment from if. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-05net: cs89x0: use module_platform_driver_probe()Jingoo Han
This patch uses module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-06ethtool: fix drvinfo strings set in driversJiri Pirko
Use strlcpy where possible to ensure the string is \0 terminated. Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN and custom defines. Use snprintf instead of sprint. Remove unnecessary inits of ->fw_version Remove unnecessary inits of drvinfo struct. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-31cs89x0 : packet reception not workingJaccon Bastiaansen
The RxCFG register of the CS89x0 could be configured incorrectly (because of misplaced parentheses), resulting in the disabling of packet reception. Signed-off-by: Jaccon Bastiaansen <jaccon.bastiaansen@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-18cirrus: cs89x0: Remove function prototypes and reorder declarationsJoe Perches
Move blocks of code around to avoid function prototypes. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-18cirrus: cs89x0: Neaten debugging and loggingJoe Perches
Introduce and use a debug macro to test and print. Convert printks to pr_<level>. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-18cirrus: cs89x0: Code neateningJoe Perches
Just some stylings. Use #include <linux... not #include <asm... Convert a test and print to a printk_once. Combine an "if (foo) { if (bar) {" to single "if (foo && bar) {" to save an indent level. Convert single line "if (foo) bar;" to multiple lines. Move some braces. Align some long lines a bit better. Long lines and printks with KERN_ checkpatch complaints still exist. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-18cirrus: cs89x0: Convert printks to pr_<level>Joe Perches
Use more current logging styles. Add pr_fmt. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-18cirrus: cs89x0: Code style neateningJoe Perches
Neaten the comments and reflow the code without changing anything other than whitespace. git diff -w shows just comment neatening and a few line removals. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-17CS89x0 : Use ioread16/iowrite16 on all platformsJaccon Bastiaansen
The use of the inw/outw functions by the cs89x0 platform driver results in NULL pointer references on ARM platforms and platforms that do not provide ISA-style programmed I/O accessors. Using inw/outw also accesses the wrong address space on platforms that have a PCI I/O space that is not identity-mapped into the physical address space. Signed-off-by: Jaccon Bastiaansen <jaccon.bastiaansen@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
