vnic_dev_register(), vnic_rq_alloc_bufs() and vnic_wq_alloc_bufs()
are never called in atomic context.
They call kzalloc() with GFP_ATOMIC, which is not necessary.
GFP_ATOMIC can be replaced with GFP_KERNEL.
This is found by a static analysis tool named DCNS written by myself.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Acked-by: Govindarajulu Varadarajan <gvaradar@cisco.com>
In commit ab123fe071c9 ("enic: handle mtu change for vf properly")
ASSERT_RTNL() is added to _enic_change_mtu() to prevent it from being
called without rtnl held. enic_probe() calls enic_change_mtu()
without rtnl held. At this point netdev is not registered yet.
Remove call to enic_change_mtu and assign the mtu to netdev->mtu.
Fixes: ab123fe071c9 ("enic: handle mtu change for vf properly")
Signed-off-by: Govindarajulu Varadarajan <gvaradar@cisco.com>
When driver gets notification for mtu change, driver does not handle it for
all RQs. It handles only RQ[0].
Fix is to use enic_change_mtu() interface to change mtu for vf.
In failure path, we overwrite err to what vnic_rq_disable() returns. In
case it returns 0, enic_open() returns success in case of error.
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Fixes: e8588e268509 ("enic: enable rq before updating rq descriptors")
lockdep spotted that we are using rfs_h.lock in enic_get_rxnfc() without
initializing. rfs_h.lock is initialized in enic_open(). But ethtool_ops
can be called when interface is down.
Move enic_rfs_flw_tbl_init to enic_probe.
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 18 PID: 1189 Comm: ethtool Not tainted 4.17.0-rc7-devel+ #27
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.11.0-20171110_100015-anatol 04/01/2014
Call Trace:
dump_stack+0x85/0xc0
register_lock_class+0x550/0x560
? __handle_mm_fault+0xa8b/0x1100
__lock_acquire+0x81/0x670
lock_acquire+0xb9/0x1e0
? enic_get_rxnfc+0x139/0x2b0 [enic]
_raw_spin_lock_bh+0x38/0x80
ethtool_get_rxnfc+0x8d/0x1c0
dev_ethtool+0x16c8/0x2400
? __mutex_lock+0x64d/0xa00
? dev_load+0x6a/0x150
dev_ioctl+0x253/0x4b0
sock_do_ioctl+0x9a/0x130
sock_ioctl+0x1af/0x350
do_vfs_ioctl+0x8e/0x670
? syscall_trace_enter+0x1e2/0x380
ksys_ioctl+0x60/0x90
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x5a/0x170
entry_SYSCALL_64_after_hwframe+0x49/0xbe
In commit 48398b6e7065 ("enic: set UDP rss flag") driver needed to set a
single bit to enable UDP rss. This is changed to two bit. One for UDP
IPv4 and other bit for UDP IPv6. The hardware which supports this is not
released yet. When released, driver should set 2 bit to enable UDP rss for
both IPv4 and IPv6.
Also add spinlock around vnic_dev_capable_rss_hash_type().
In commit 624dbf55a359b ("driver/net: enic: Try DMA 64 first, then
failover to DMA") DMA mask was changed from 40 bits to 64 bits.
Hardware actually supports only 47 bits.
Fixes: 624dbf55a359b ("driver/net: enic: Try DMA 64 first, then failover to DMA")
Commit d11790941dd3 ("enic: Add vxlan offload support for IPv6 pkts")
added vxlan offload support for IPv6 pkts. Required change in
enic_udp_tunnel_del was not made. This creates a bug where once user
adds IPv6 tunnel, hw offload for that cannot be deleted.
This patch removes check for IP proto in tunnel delete path. Driver need
not check for IP proto since same UDP port cannot be used to create two
tunnels.
Fixes: d11790941dd3 ("enic: Add vxlan offload support for IPv6 pkts")
drivers/net/ethernet/cisco/enic/vnic_dev.c:1294:9-10: WARNING: return of 0/1 in function 'vnic_dev_capable_udp_rss' with return type bool
Return statements in functions returning bool should use
true/false instead of 1/0.
Generated by: scripts/coccinelle/misc/boolreturn.cocci
Fixes: 48398b6e7065 ("enic: set UDP rss flag")
CC: Govindarajulu Varadarajan <gvaradar@cisco.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
New adapter needs CMD_OPENF_IG_DESCCACHE flag to be set. If this flag is
not set, fw flushes the global IG desc cache. This flag is nop in older
adapter.
Also increment driver version
rq should be enabled before posting the buffers to rq desc. If not hw sees
stale value and casuses DMAR errors.
New hardware needs UDP flag set to enable UDP L4 rss hash. Add ethtool
get option to display supported rss flow hash.
Some adaptors do not support vxlan offload when multi wq is configured.
If hw supports multi wq, BIT(2) is set in a1.
New adaptors supports vxlan offload for inner IPv6 and outer IPv6 vxlan
pkts.
Fw sets BIT(0) & BIT(1) in a1 if hw supports ipv6 inner & outer pkt
offload.
To compute pseudo IP header csum, we need to check the inner header for
encap pkt, not outer IP header.
Also add pseudo csum for IPv6 inner pkt.
In case of tx clean up, we set '-1' as budget. This means clean up until
wq is empty or till (1 << 32) pkts are cleaned. Under heavy load this
will run for long time and cause
"watchdog: BUG: soft lockup - CPU#25 stuck for 21s!" warning.
This patch sets wq clean up budget to 256.
Add ethtool ops to advertise sw timestamping.
Call skb_tx_timestamp() just before ringing the wq doorbell.
This converts all remaining setup_timer() calls that use a nested field
to reach a struct timer_list. Coccinelle does not have an easy way to
match multiple fields, so a new script is needed to change the matches of
"&_E->_timer" into "&_E->_field1._timer" in all the rules.
spatch --very-quiet --all-includes --include-headers \
-I ./arch/x86/include -I ./arch/x86/include/generated \
-I ./include -I ./arch/x86/include/uapi \
-I ./arch/x86/include/generated/uapi -I ./include/uapi \
-I ./include/generated/uapi --include ./include/linux/kconfig.h \
--dir . \
--cocci-file ~/src/data/timer_setup-2fields.cocci
@fix_address_of depends@
expression e;
setup_timer(
-&(e)
+&e
// Update any raw setup_timer() usages that have a NULL callback, but
// would otherwise match change_timer_function_usage, since the latter
// will update all function assignments done in the face of a NULL
// function initialization in setup_timer().
@change_timer_function_usage_NULL@
expression _E;
identifier _field1;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_field1._timer, NULL, _E);
+timer_setup(&_E->_field1._timer, NULL, 0);
-setup_timer(&_E->_field1._timer, NULL, (_cast_data)_E);
-setup_timer(&_E._field1._timer, NULL, &_E);
+timer_setup(&_E._field1._timer, NULL, 0);
-setup_timer(&_E._field1._timer, NULL, (_cast_data)&_E);
@change_timer_function_usage@
expression _E;
identifier _field1;
identifier _timer;
struct timer_list _stl;
identifier _callback;
type _cast_func, _cast_data;
-setup_timer(&_E->_field1._timer, _callback, _E);
+timer_setup(&_E->_field1._timer, _callback, 0);
-setup_timer(&_E->_field1._timer, &_callback, _E);
-setup_timer(&_E->_field1._timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_field1._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_field1._timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_field1._timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_field1._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_field1._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._field1._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._field1._timer, _callback, 0);
-setup_timer(&_E._field1._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._field1._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._field1._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._field1._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._field1._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._field1._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._field1._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_field1._timer@_stl.function = _callback;
_E->_field1._timer@_stl.function = &_callback;
_E->_field1._timer@_stl.function = (_cast_func)_callback;
_E->_field1._timer@_stl.function = (_cast_func)&_callback;
_E._field1._timer@_stl.function = _callback;
_E._field1._timer@_stl.function = &_callback;
_E._field1._timer@_stl.function = (_cast_func)_callback;
_E._field1._timer@_stl.function = (_cast_func)&_callback;
// callback(unsigned long arg)
@change_callback_handle_cast
depends on change_timer_function_usage@
identifier change_timer_function_usage._callback;
identifier change_timer_function_usage._field1;
identifier change_timer_function_usage._timer;
type _origtype;
identifier _origarg;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+struct timer_list *t
... when != _origarg
_handletype *_handle =
-(_handletype *)_origarg;
+from_timer(_handle, t, _field1._timer);
-(void *)_origarg;
_handletype *_handle;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
// callback(unsigned long arg) without existing variable
@change_callback_handle_cast_no_arg
depends on change_timer_function_usage &&
!change_callback_handle_cast@
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _field1._timer);
- (_handletype *)_origarg
+ _origarg
// Avoid already converted callbacks.
@match_callback_converted
!change_callback_handle_cast &&
!change_callback_handle_cast_no_arg@
identifier t;
void _callback(struct timer_list *t)
// callback(struct something *handle)
@change_callback_handle_arg
!match_callback_converted &&
type _handletype;
identifier _handle;
void _callback(
-_handletype *_handle
+ _handletype *_handle = from_timer(_handle, t, _field1._timer);
// If change_callback_handle_arg ran on an empty function, remove
// the added handler.
@unchange_callback_handle_arg
change_callback_handle_arg@
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _field1._timer);
// We only want to refactor the setup_timer() data argument if we've found
// the matching callback. This undoes changes in change_timer_function_usage.
@unchange_timer_function_usage
!change_callback_handle_cast_no_arg &&
!change_callback_handle_arg@
expression change_timer_function_usage._E;
type change_timer_function_usage._cast_data;
-timer_setup(&_E->_field1._timer, _callback, 0);
+setup_timer(&_E->_field1._timer, _callback, (_cast_data)_E);
-timer_setup(&_E._field1._timer, _callback, 0);
+setup_timer(&_E._field1._timer, _callback, (_cast_data)&_E);
// If we fixed a callback from a .function assignment, fix the
// assignment cast now.
@change_timer_function_assignment
(change_callback_handle_cast ||
change_callback_handle_cast_no_arg ||
change_callback_handle_arg)@
type _cast_func;
typedef TIMER_FUNC_TYPE;
_E->_field1._timer.function =
-_callback
+(TIMER_FUNC_TYPE)_callback
-&_callback
-(_cast_func)_callback;
-(_cast_func)&_callback
_E._field1._timer.function =
-_callback
-&_callback;
// Sometimes timer functions are called directly. Replace matched args.
@change_timer_function_calls
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_field1._timer
-(_cast_data)&_E
+&_E._field1._timer
-_E
// If a timer has been configured without a data argument, it can be
// converted without regard to the callback argument, since it is unused.
@match_timer_function_unused_data@
expression _E;
identifier _field1;
identifier _timer;
-setup_timer(&_E->_field1._timer, _callback, 0);
-setup_timer(&_E->_field1._timer, _callback, 0L);
-setup_timer(&_E->_field1._timer, _callback, 0UL);
-setup_timer(&_E._field1._timer, _callback, 0);
-setup_timer(&_E._field1._timer, _callback, 0L);
-setup_timer(&_E._field1._timer, _callback, 0UL);
-setup_timer(&_field1._timer, _callback, 0);
+timer_setup(&_field1._timer, _callback, 0);
-setup_timer(&_field1._timer, _callback, 0L);
-setup_timer(&_field1._timer, _callback, 0UL);
-setup_timer(_field1._timer, _callback, 0);
+timer_setup(_field1._timer, _callback, 0);
-setup_timer(_field1._timer, _callback, 0L);
-setup_timer(_field1._timer, _callback, 0UL);
@change_callback_unused_data
depends on match_timer_function_unused_data@
identifier match_timer_function_unused_data._callback;
type _origtype;
void _callback(
-_origtype _origarg
+struct timer_list *unused
This converts all remaining cases of the old setup_timer() API into using
timer_setup(), where the callback argument is the structure already
holding the struct timer_list. These should have no behavioral changes,
since they just change which pointer is passed into the callback with
the same available pointers after conversion. It handles the following
examples, in addition to some other variations.
Casting from unsigned long:
void my_callback(unsigned long data)
struct something *ptr = (struct something *)data;
setup_timer(&ptr->my_timer, my_callback, ptr);
and forced object casts:
void my_callback(struct something *ptr)
setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr);
become:
void my_callback(struct timer_list *t)
struct something *ptr = from_timer(ptr, t, my_timer);
timer_setup(&ptr->my_timer, my_callback, 0);
Direct function assignments:
ptr->my_timer.function = my_callback;
have a temporary cast added, along with converting the args:
ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback;
And finally, callbacks without a data assignment:
setup_timer(&ptr->my_timer, my_callback, 0);
have their argument renamed to verify they're unused during conversion:
void my_callback(struct timer_list *unused)
The conversion is done with the following Coccinelle script:
--dir . \
--cocci-file ~/src/data/timer_setup.cocci
@fix_address_of@
expression e;
setup_timer(
-&(e)
+&e
expression _E;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_timer, NULL, _E);
+timer_setup(&_E->_timer, NULL, 0);
-setup_timer(&_E->_timer, NULL, (_cast_data)_E);
-setup_timer(&_E._timer, NULL, &_E);
+timer_setup(&_E._timer, NULL, 0);
-setup_timer(&_E._timer, NULL, (_cast_data)&_E);
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, _E);
+timer_setup(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, &_callback, _E);
-setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_timer@_stl.function = _callback;
_E->_timer@_stl.function = &_callback;
_E->_timer@_stl.function = (_cast_func)_callback;
_E->_timer@_stl.function = (_cast_func)&_callback;
_E._timer@_stl.function = _callback;
_E._timer@_stl.function = &_callback;
_E._timer@_stl.function = (_cast_func)_callback;
_E._timer@_stl.function = (_cast_func)&_callback;
type _origtype;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+from_timer(_handle, t, _timer);
-(void *)_origarg;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _timer);
+ _origarg
identifier t;
type _handletype;
identifier _handle;
void _callback(
+ _handletype *_handle = from_timer(_handle, t, _timer);
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _timer);
-timer_setup(&_E->_timer, _callback, 0);
+setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-timer_setup(&_E._timer, _callback, 0);
+setup_timer(&_E._timer, _callback, (_cast_data)&_E);
type _cast_func;
_E->_timer.function =
-_callback
-&_callback
_E._timer.function =
-_callback
-&_callback;
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_timer
-(_cast_data)&_E
+&_E._timer
-_E
+&_E->_timer
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, _callback, 0L);
-setup_timer(&_E->_timer, _callback, 0UL);
-setup_timer(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, 0L);
-setup_timer(&_E._timer, _callback, 0UL);
-setup_timer(&_timer, _callback, 0);
+timer_setup(&_timer, _callback, 0);
-setup_timer(&_timer, _callback, 0L);
-setup_timer(&_timer, _callback, 0UL);
-setup_timer(_timer, _callback, 0);
+timer_setup(_timer, _callback, 0);
-setup_timer(_timer, _callback, 0L);
-setup_timer(_timer, _callback, 0UL);
type _origtype;
void _callback(
-_origtype _origarg
Files removed in 'net-next' had their license header updated
in 'net'. We take the remove from 'net-next'.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Add support for displaying and modifying rx and tx ring sizes using
ethtool.
Also, increasing version to 2.3.0.45
Signed-off-by: Parvi Kaustubhi <pkaustub@cisco.com>
Since we are allowing rx ring size modification, reset fetch index
everytime. Otherwise it could have a stale value that can lead to a null
pointer dereference.
Use setup_timer function instead of initializing timer with the
function and data fields.
Signed-off-by: Allen Pais <allen.lkml@gmail.com>
if 'ioread32()' returns 0xFFFFFFF, we have to go through the error
handling path as done everywhere else in this function.
Move the 'err_free_wq' label to better match its name and its location
and add a new label 'err_disable_wq'.
Update the code accordingly.
Fixes: 373fb0873d43 ("enic: add devcmd2")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
With -Wformat-truncation, gcc throws the following warning.
Fix this by increasing the size of devname to accommodate 15 character
netdev interface name and description.
Remove length format precision for %s. We can fit entire name.
Also increment the version.
drivers/net/ethernet/cisco/enic/enic_main.c: In function ‘enic_open’:
drivers/net/ethernet/cisco/enic/enic_main.c:1740:15: warning: ‘%u’ directive output may be truncated writing between 1 and 2 bytes into a region of size between 1 and 12 [-Wformat-truncation=]
"%.11s-rx-%u", netdev->name, i);
drivers/net/ethernet/cisco/enic/enic_main.c:1740:5: note: directive argument in the range [0, 16]
drivers/net/ethernet/cisco/enic/enic_main.c:1738:4: note: ‘snprintf’ output between 6 and 18 bytes into a destination of size 16
snprintf(enic->msix[intr].devname,
sizeof(enic->msix[intr].devname),
In case of busy poll, napi_complete_done returns false and does not
dequeue napi. In this case do not unmask the intr. We are guaranteed
napi is called again. This reduces unnecessary iowrites.
Define ndo_features_check. Hw supports offload only for ipv4 inner and
ipv4 outer pkt.
Code refactor for setting inner tcp pseudo csum.
Defines enic_udp_tunnel_add/del for configuring vxlan tunnel offload.
enic supports offload of only one ipv4/udp port.
There are two modes that fw supports for vxlan offload.
mode 0: fcoe bit is set for encapsulated packet. fcoe_fc_crc_ok is set
if checksum of csum is ok. This bit is or of ip_csum_ok and
tcp_udp_csum_ok
mode 2: BIT(0) in rss_hash is set if it is encapsulated packet.
BIT(1) is set if outer_ip_csum_ok/
BIT(2) is set if outer_tcp_csum_ok
tcp_udp_csum_ok/ipv4_csum_ok is set if inner csum is OK.
This patch adds devcmds needed for vxlan offload. Implement 3 new devcmd
overlay_offload_ctrl: enable/disable offload
overlay_offload_cfg: update offload udp port number
get_supported_feature_ver: get hw supported offload version. Each
version has different bitmap for csum_ok/encap
We do polling generically these days.
napi_complete_done() allows to opt-in for gro_flush_timeout,
added back in linux-3.19, commit 3b47d30396ba
("net: gro: add a per device gro flush timer")
This allows for more efficient GRO aggregation without
sacrifying latencies.
The network device operation for reading statistics is only called
in one place, and it ignores the return value. Having a structure
return value is potentially confusing because some future driver could
incorrectly assume that the return value was used.
Fix all drivers with ndo_get_stats64 to have a void function.
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
Driver sets the skb l4/l3 hash based on NIC_CFG_RSS_HASH_TYPE_*,
which is bit mask. This is wrong. Hw actually provides us enum.
Use CQ_ENET_RQ_DESC_RSS_TYPE_* to set l3 and l4 hash type.
Fixes: bf751ba802fe ("driver/net: enic: record q_number and rss_hash for skb")
Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com>
Mostly simple overlapping changes.
For example, David Ahern's adjacency list revamp in 'net-next'
conflicted with an adjacency list traversal bug fix in 'net'.
When MTU is changed from 9000 to 1500 while there is burst of inbound 9000
bytes packets, adaptor sometimes delivers 9000 bytes packets to 1500 bytes
buffers. This causes memory corruption and sometimes crash.
This is because of a race condition in adaptor between "RQ disable"
clearing descriptor mini-cache and mini-cache valid bit being set by
completion of descriptor fetch. This can result in stale RQ desc being
cached and used when packets arrive. In this case, the stale descriptor
have old MTU value.
Solution is to write RQ->disable twice. The first write will stop any
further desc fetches, allowing the second disable to clear the mini-cache
valid bit without danger of a race.
Also, the check for rq->running becoming 0 after writing rq->enable to 0
is not done properly. When incoming packets are flooding the interface,
rq->running will pulse high for each dropped packet. Since the driver was
waiting for 10us between each poll, it is possible to see rq->running = 1
1000 times in a row, even though it is not actually stuck running.
This results in false failure of vnic_rq_disable(). Fix is to try more
than 1000 time without delay between polls to ensure we do not miss when
running goes low.
In old adaptors rq->enable needs to be re-written to 0 when posted_index
is reset in vnic_rq_clean() in order to keep rq->prefetch_index in sync.
et131x: min_mtu 64, max_mtu 9216
altera_tse: min_mtu 64, max_mtu 1500
amd8111e: min_mtu 60, max_mtu 9000
bnad: min_mtu 46, max_mtu 9000
macb: min_mtu 68, max_mtu 1500 or 10240 depending on hardware capability
xgmac: min_mtu 46, max_mtu 9000
cxgb2: min_mtu 68, max_mtu 9582 (pm3393) or 9600 (vsc7326)
enic: min_mtu 68, max_mtu 9000
gianfar: min_mtu 50, max_mu 9586
hns_enet: min_mtu 68, max_mtu 9578 (v1) or 9706 (v2)
ksz884x: min_mtu 60, max_mtu 1894
myri10ge: min_mtu 68, max_mtu 9000
natsemi: min_mtu 64, max_mtu 2024
nfp: min_mtu 68, max_mtu hardware-specific
forcedeth: min_mtu 64, max_mtu 1500 or 9100, depending on hardware
pch_gbe: min_mtu 46, max_mtu 10300
pasemi_mac: min_mtu 64, max_mtu 9000
qcaspi: min_mtu 46, max_mtu 1500
- remove qcaspi_netdev_change_mtu as it is now redundant
rocker: min_mtu 68, max_mtu 9000
sxgbe: min_mtu 68, max_mtu 9000
stmmac: min_mtu 46, max_mtu depends on hardware
tehuti: min_mtu 60, max_mtu 16384
- driver had no max mtu checking, but product docs say 16k jumbo packets
are supported by the hardware
netcp: min_mtu 68, max_mtu 9486
- remove netcp_ndo_change_mtu as it is now redundant
via-velocity: min_mtu 64, max_mtu 9000
octeon: min_mtu 46, max_mtu 65370
CC: netdev@vger.kernel.org
CC: Mark Einon <mark.einon@gmail.com>
CC: Vince Bridgers <vbridger@opensource.altera.com>
CC: Rasesh Mody <rasesh.mody@qlogic.com>
CC: Nicolas Ferre <nicolas.ferre@atmel.com>
CC: Santosh Raspatur <santosh@chelsio.com>
CC: Hariprasad S <hariprasad@chelsio.com>
CC: Christian Benvenuti <benve@cisco.com>
CC: Sujith Sankar <ssujith@cisco.com>
CC: Govindarajulu Varadarajan <_govind@gmx.com>
CC: Neel Patel <neepatel@cisco.com>
CC: Claudiu Manoil <claudiu.manoil@freescale.com>
CC: Yisen Zhuang <yisen.zhuang@huawei.com>
CC: Salil Mehta <salil.mehta@huawei.com>
CC: Hyong-Youb Kim <hykim@myri.com>
CC: Jakub Kicinski <jakub.kicinski@netronome.com>
CC: Olof Johansson <olof@lixom.net>
CC: Jiri Pirko <jiri@resnulli.us>
CC: Byungho An <bh74.an@samsung.com>
CC: Girish K S <ks.giri@samsung.com>
CC: Vipul Pandya <vipul.pandya@samsung.com>
CC: Giuseppe Cavallaro <peppe.cavallaro@st.com>
CC: Alexandre Torgue <alexandre.torgue@st.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Wingman Kwok <w-kwok2@ti.com>
CC: Murali Karicheri <m-karicheri2@ti.com>
CC: Francois Romieu <romieu@fr.zoreil.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
i is defined as unsigned.
So print it with %u.
The ethtool api {get|set}_settings is deprecated.
We move the enic driver to new api {get|set}_link_ksettings.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
Driver sets vlan_feature to netdev->features as hardware supports all of
them on vlan interface.
Don't hide varibles used by the logging macros.
Miscellanea:
o Use the more common ##__VA_ARGS__ extension
o Add missing newlines to formats
o Realign arguments
Firmware posts the devcmd result in result ring. In case of timeout, driver
does not increment the current result pointer and firmware could post the
result after timeout has occurred. During next devcmd, driver would be
reading the result of previous devcmd.
Fix this by incrementing result even in case of timeout.
Signed-off-by: Sandeep Pillai <sanpilla@cisco.com>
NAPI drivers no longer need to observe a particular protocol
to benefit from busy polling (CONFIG_NET_RX_BUSY_POLL=y)
napi_hash_add() and napi_hash_del() are automatically called
from core networking stack, respectively from
netif_napi_add() and netif_napi_del()
This patch depends on free_netdev() and netif_napi_del() being
called from process context, which seems to be the norm.
Drivers might still prefer to call napi_hash_del() on their
own, since they might combine all the rcu grace periods into
a single one, knowing their NAPI structures lifetime, while
core networking stack has no idea of a possible combining.
Once this patch proves to not bring serious regressions,
we will cleanup drivers to either remove napi_hash_del()
or provide appropriate rcu grace periods combining.
The affinity hint is used by the user space daemon, irqbalancer, to
indicate a preferred CPU mask for irqs. This patch sets the irq affinity
hint to local numa core first, when exausted we try non-local numa cores.
Also set tx xps cpus mask bassed on affinity hint.
v2: remove the global affinity policy.
The current code invokes hang reset in case of error interrupt. We should
hang reset only in case of tx timeout. This because of the way hang reset
is implemented in firmware. Hang reset takes more firmware resources than
soft reset. Adaptor does not generate error interrupt in case of tx
timeout.
Hang reset only in case of tx timeout, in .ndo_tx_timeout. Do soft reset
otherwise. Introduce deferred work, enic_tx_hang_reset, to do hang reset.
Some of the enic adaptors are know to generate spurious interrupts. When
error interrupt is generated, driver just resets the device. This patch
resets the device only when an error is occurred.
The flags argument will allow control of the dissection process (for
instance whether to parse beyond L3).
Signed-off-by: Tom Herbert <tom@herbertland.com>
posted_index is RO in firmware. We need not do ioread everytime to get
posted index. Store posted index locally.
err_out_vnic_unregister is used regardless of whether
SRIOV is enabled or not.
Reported-by: Jesse Brandeburg <jesse.brangeburg@intel.com>
