path: root/drivers/net/ethernet/faraday
2016-10-04net/faraday: Stop NCSI device on shutdownGavin Shan
This stops NCSI device when closing the network device so that the NCSI device can be reenabled later. Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Reviewed-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-22net/faraday: Mask out PHYSTS_CHG interruptJoel Stanley
The PHYSTS_CHG (the ftgmac100's PHY IRQ) is telling the system to go look at the PHY registers for a link status change. The interrupt was causing issues on Aspeed SoC where some board designs had an active high configuration, some active low, and in some cases repurposed for other functions. When misconfigured Linux would chew 100% of CPU cycles servicing interrupts: [ 20.280000] ftgmac100 1e660000.ethernet eth0: [ISR] = 0x200: PHYSTS_CHG [ 20.280000] ftgmac100 1e660000.ethernet eth0: [ISR] = 0x200: PHYSTS_CHG [ 20.280000] ftgmac100 1e660000.ethernet eth0: [ISR] = 0x200: PHYSTS_CHG [ 20.300000] ftgmac100 1e660000.ethernet eth0: [ISR] = 0x200: PHYSTS_CHG While in the ftgmac100 IP can be configured for high, low and edge sensitivity the current driver always polls the PHY, so we chose to mask out the interrupt. See https://patchwork.ozlabs.org/patch/672099/ for more discussion. Signed-off-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-22net/faraday: Configure old MDIO interface on Aspeed SoCsJoel Stanley
The Aspeed SoCs have a new MDIO interface as an option in the G4 and G5 SoCs. The old one is still available, so select it in order to remain compatible with the ftgmac100 driver. Signed-off-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-22net/faraday: Clear stale interruptsGavin Shan
There is stale interrupt (PHYSTS_CHG in ISR, bit#6 in 0x0) from the bootloader (uboot) when enabling the MAC. The stale interrupts aren't part of kernel and should be cleared. This clears the stale interrupts in ISR (0x0) when enabling the MAC. Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-22net/faraday: Adapt for Aspeed SoCsJoel Stanley
The RXDES and TXDES registers bits in the ftgmac100 indicates EDO{R,T}R at bit position 15 for the Faraday Tech IP. However, the version of this IP present in the Aspeed SoCs has these bits at position 30 in the registers. It appers that ast2400 SoCs support both positions, with the 15th bit marked as reserved but still functional. In the ast2500 this bit is reused for another function, so we need a work around. This was confirmed with engineers from Aspeed that using bit 30 is correct for both the ast2400 and ast2500 SoCs. Signed-off-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-22net/faraday: Make EDO{R,T}R bits configurableAndrew Jeffery
These bits are #defined at a fixed location. In order to support future hardware that has chosen to move these bits around move the bits into a member of the struct ftgmac100. Signed-off-by: Andrew Jeffery <andrew@aj.id.au> Signed-off-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-09-22net/faraday: Separate rx page storage from rxdescAndrew Jeffery
The ftgmac100 hardware revision in e.g. the Aspeed AST2500 no longer reserves all bits in RXDES#2 but instead uses the bottom 16 bits to store MAC frame metadata. Avoid corruption by shifting struct page pointers out to their own member in struct ftgmac100. Signed-off-by: Andrew Jeffery <andrew@aj.id.au> Signed-off-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-20net/faraday: Disallow using reversed MAC address from hardwareGavin Shan
The initial MAC address is retrieved from hardware if it's not provided by device-tree. The reserved MAC address from hardware will be used if non-reserved MAC address is invalid. It will cause mismatched MAC address seen by hardware and software. This disallows using the reserved hardware MAC address to avoid the mismatched MAC address seen by hardware and software. Fixes: 113ce107afe9 ("net/faraday: Read MAC address from chip") Suggested-by: David Laight <David.Laight@ACULAB.COM> Suggested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-19net/faraday: Mask PHY interrupt with NCSI modeGavin Shan
Bogus PHY interrupts are observed. This masks the PHY interrupt when the interface works in NCSI mode as there is no attached PHY under the circumstance. Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Acked-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-19net/faraday: Match driver according to compatible propertyGavin Shan
This matches the driver with devices compatible with "faraday,ftgmac100" declared in the device tree. Originally, device's name from device tree for it. Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Acked-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-19net/faraday: Support NCSI modeGavin Shan
This makes ftgmac100 driver support NCSI mode. The NCSI is enabled on the interface if property "use-nc-si" or "use-ncsi" is found from the device node in device tree. * No PHY device is used when NCSI mode is enabled. * The NCSI device (struct ncsi_dev) is created when probing the device while it's enabled/started when the interface is brought up. * Hardware IP checksum dosn't work when NCSI mode is enabled. It is disabled on enabled NCSI. Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Acked-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-19net/faraday: Read MAC address from chipGavin Shan
The device is assigned with random MAC address. It isn't reasonable. An valid MAC address might have been provided by (uboot) firmware by device-tree or in chip. It's reasonable to use it to maintain consistency. This uses the MAC address from device-tree or that in the chip if it's valid. Otherwise, a random MAC address is given as before. Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Acked-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-07-19net/faraday: Helper functions to create or destroy MDIO interfaceGavin Shan
This introduces two helper functions to create or destroy MDIO interface. No logical changes introduced except the proper MDIO names are given when having more than one MDIO bus. Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Acked-by: Joel Stanley <joel@jms.id.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-16net: ethernet: ftgmac100: use phy_ethtool_{get|set}_link_ksettingsPhilippe Reynes
There are two generics functions phy_ethtool_{get|set}_link_ksettings, so we can use them instead of defining the same code in the driver. Signed-off-by: Philippe Reynes <tremyfr@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-16net: ethernet: ftgmac100: use phydev from struct net_devicePhilippe Reynes
The private structure contain a pointer to phydev, but the structure net_device already contain such pointer. So we can remove the pointer phydev in the private structure, and update the driver to use the one contained in struct net_device. Signed-off-by: Philippe Reynes <tremyfr@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-10net: ethernet: faraday: Use phy_find_first() instead of open coding itGuenter Roeck
Use phy_find_first() to find the first phy device instead of open coding it. Cc: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-07phy: Add API for {un}registering an mdio device to a bus.Andrew Lunn
Rather than have drivers directly manipulate the mii_bus structure, provide and API for registering and unregistering devices on an MDIO bus, and performing lookups. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-07mdio: Move allocation of interrupts into coreAndrew Lunn
Have mdio_alloc() create the array of interrupt numbers, and initialize it to POLLING. This is what most MDIO drivers want, so allowing code to be removed from the drivers. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Reviewed-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-01-07phy: add phydev_name() wrapperAndrew Lunn
Add a phydev_name() function, to help with moving some structure members from phy_device. Signed-off-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-23drivers/net: remove all references to obsolete Ethernet-HOWTOPaul Gortmaker
This howto made sense in the 1990s when users had to manually configure ISA cards with jumpers or vendor utilities, but with the implementation of PCI it became increasingly less and less relevant, to the point where it has been well over a decade since I last updated it. And there is no value in anyone else taking over updating it either. However the references to it continue to spread as boiler plate text from one Kconfig file into the next. We are not doing end users any favours by pointing them at this old document, so lets kill it with fire, once and for all, to hopefully stop any further spread. No code is changed in this commit, just Kconfig help text. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-20net: ethernet: faraday: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-05-13net: get rid of SET_ETHTOOL_OPSWilfried Klaebe
net: get rid of SET_ETHTOOL_OPS Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone. This does that. Mostly done via coccinelle script: @@ struct ethtool_ops *ops; struct net_device *dev; @@ - SET_ETHTOOL_OPS(dev, ops); + dev->ethtool_ops = ops; Compile tested only, but I'd seriously wonder if this broke anything. Suggested-by: Dave Miller <davem@davemloft.net> Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28net: ftgmac100: remove empty MDIO bus reset functionFlorian Fainelli
ftgmac100_mdiobus_reset() does nothing useful and is optional for the MDIO bus code, so let's just remove it. Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-17net: ftgmac100: use kfree_skb() where appropriateEric Dumazet
In order to get correct drop monitor notifications for dropped packets, we should call kfree_skb() instead of dev_kfree_skb() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-16drivers/net: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. This covers everything under drivers/net except for wireless, which has been submitted separately. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-29drivers:net: Convert dma_alloc_coherent(...__GFP_ZERO) to dma_zalloc_coherentJoe Perches
__GFP_ZERO is an uncommon flag and perhaps is better not used. static inline dma_zalloc_coherent exists so convert the uses of dma_alloc_coherent with __GFP_ZERO to the more common kernel style with zalloc. Remove memset from the static inline dma_zalloc_coherent and add just one use of __GFP_ZERO instead. Trivially reduces the size of the existing uses of dma_zalloc_coherent. Realign arguments as appropriate. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-19net: Move MII out from under NET_CORE and hide itBen Hutchings
All drivers that select MII also need to select NET_CORE because MII depends on it. This is a bit ridiculous because NET_CORE is just a menu option that doesn't enable any code by itself. There is also no need for it to be a visible option, since its users all select it. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-27net: ethernet: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d (device-core: Ensure drvdata = NULL when no driver is bound). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Roland Stigge <stigge@antcom.de> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Tested-by: Roland Stigge <stigge@antcom.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-18net: ftgmac100: Use module_platform_driver()Sachin Kamat
module_platform_driver macro removes some boilerplate and makes the code simpler. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-17drivers:net: dma_alloc_coherent: use __GFP_ZERO instead of memset(, 0)Joe Perches
Reduce the number of calls required to alloc a zeroed block of memory. Trivially reduces overall object size. Other changes around these removals o Neaten call argument alignment o Remove an unnecessary OOM message after dma_alloc_coherent failure o Remove unnecessary gfp_t stack variable Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-14net: phy: remove flags argument from phy_{attach, connect, connect_direct}Florian Fainelli
The flags argument of the phy_{attach,connect,connect_direct} functions is then used to assign a struct phy_device dev_flags with its value. All callers but the tg3 driver pass the flag 0, which results in the underlying PHY drivers in drivers/net/phy/ not being able to actually use any of the flags they would set in dev_flags. This patch gets rid of the flags argument, and passes phydev->dev_flags to the internal PHY library call phy_attach_direct() such that drivers which actually modify a phy device dev_flags get the value preserved for use by the underlying phy driver. Acked-by: Kosta Zertsekel <konszert@marvell.com> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-06ethtool: fix drvinfo strings set in driversJiri Pirko
Use strlcpy where possible to ensure the string is \0 terminated. Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN and custom defines. Use snprintf instead of sprint. Remove unnecessary inits of ->fw_version Remove unnecessary inits of drvinfo struct. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-18net: ftgmac100/ftmac100: dont pull too much dataEric Dumazet
Drivers should pull only ethernet header from page frag to skb->head. Pulling 64 bytes is too much for TCP (without options) on IPv4. However, it makes sense to pull all the frame if it fits the 128 bytes bloc allocated for skb->head, to free one page per small incoming frame. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Po-Yu Chuang <ratbert@faraday-tech.com> Acked-by: Yan-Pai Chen <yanpai.chen@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-15net: replace random_ether_addr() with eth_hw_addr_random()Danny Kukawka
Replace usage of random_ether_addr() with eth_hw_addr_random() to set addr_assign_type correctly to NET_ADDR_RANDOM. Change the trivial cases. v2: adapt to renamed eth_hw_addr_random() Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-18net: ftgmac100/ftmac100: add missing interrupt.h includeThomas Faber
Fixes compilation failure of these modules due to missing irqreturn_t type for the ft(g)mac100_interrupt definition. Signed-off-by: Thomas Faber <thfabba@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-13ftmac100: fix skb truesize underestimationEric Dumazet
ftmac100 allocates a page per skb fragment. We must account PAGE_SIZE increments on skb->truesize, not the actual frag length. If frame is under 64 bytes, page is freed, so increase truesize only for bigger frames. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-13ftgmac100: fix skb truesize underestimationEric Dumazet
ftgmac100 allocates a page per skb fragment. We must account PAGE_SIZE increments on skb->truesize, not the actual frag length. If frame is under 64 bytes, page is freed, and truesize adjusted. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Po-Yu Chuang <ratbert@faraday-tech.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-15MII: fix Kconfig dependencies for MIIJeff Kirsher
MII Kconfig option is apart of the core networking drivers and by default NET_CORE is enabled so drivers selecting MII will have MII enabled as well. It was found using the randconfig option during testing, MII would be selected but NET_CORE could be disabled. This caused a dependency error. Resolved the dependency by selecting NET_CORE when MII is selected. Reported-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-27drivers/net/ethernet/*: Enabled vendor Kconfig optionsJeff Kirsher
Based on finds for Stephen Rothwell, where current defconfig's enable a ethernet driver and it is not compiled due to the newly added NET_VENDOR_* component of Kconfig. This patch enables all the "new" Kconfig options so that current defconfig's will continue to compile the expected drivers. In addition, by enabling all the new Kconfig options does not add any un-expected options. CC: Stephen Rothwll <sfc@canb.auug.org.au> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-08-11ftgmac100/ftmac100: Move the Faraday driversJeff Kirsher
Move the Faraday driver into drivers/net/ethernet/faraday/ and make the necessary Kconfig and Makefile changes. CC: "Po-Yu Chuang" <ratbert@faraday-tech.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Acked-by: Po-Yu Chuang <ratbert@faraday-tech.com>
