[ Upstream commit 580a05f9d4ada3bfb689140d0efec1efdb8a48da ]
Currently, the num_msi_left means the vector numbers of NIC,
but if the PF supported RoCE, it contains the vector numbers
of NIC and RoCE(Not expected).
This may cause interrupts lost in some case, because of the
NIC module used the vector resources which belongs to RoCE.
This patch adds a new variable num_nic_msi to store the vector
numbers of NIC, and adjust the default TQP numbers and rss_size
according to the value of num_nic_msi.
Fixes: 46a3df9f9718 ("net: hns3: Add HNS3 Acceleration Engine & Compatibility Layer Support")
Signed-off-by: Yonglong Liu <liuyonglong@huawei.com>
Signed-off-by: Huazhong Tan <tanhuazhong@huawei.com>
When loading or unloading module, it should wait for the reset task
done before it un-initializes the client, otherwise the reset task
may cause a NULL pointer reference.
Signed-off-by: Peng Li <lipeng321@huawei.com>
When HW is resetting, firmware is unable to handle commands
from driver. So if remove VLAN device from stack at this time,
it will fail to remove the VLAN ID from HW VLAN filter, then
the VLAN filter status is unsynced with stack.
This patch fixes it by recording the VLAN ID delete failed,
and removes them again when reset complete.
Fixes: 44e626f720c3 ("net: hns3: fix VLAN offload handle for VLAN inserted by port")
Signed-off-by: Jian Shen <shenjian15@huawei.com>
This patch does following things:
1. add the keyword const before some variables which won't be modified
in functions.
2. changes some variables from signed to unsigned to avoid bitwise
operation on signed variables.
3. adds or removes initialization of some variables.
4. defines a new structure to help parsing mailbox messages instead of
using an array which is harder to get the meaning of each element.
Signed-off-by: Weihang Li <liweihang@hisilicon.com>
Signed-off-by: Yunsheng Lin <linyunsheng@huawei.com>
Signed-off-by: Yufeng Mo <moyufeng@huawei.com>
This patch adds some macros instead of magic numbers in serval places
In order to improve readability, this patch uses macros to
replace some magic numbers, and adds some comments for some
others.
VF VLAN table can only support no more than 256 VLANs. When user
adds too many VLANs, the VF VLAN table will be full, and firmware
will close the VF VLAN table for the function. When VF VLAN table
is full, and user keeps adding new VLANs, it's unnecessary to
configure the VF VLAN table, because it will always fail, and print
warning message. The worst case is adding 4K VLANs, and doing reset,
it will take much time to restore these VLANs, which may cause VF
reset fail by timeout.
Fixes: 6c251711b37f ("net: hns3: Disable vf vlan filter when vf vlan table is full")
registered
When PF ROCE client's init_instance() succeeds, it means this client
has been registered successfully, so we use HCLGE_STATE_ROCE_REGISTERED
to indicate that. And before calling PF ROCE client's uninit_instance(),
we clear this state.
So any operation of the ROCE client from HCLGE is not allowed if this
state is not set.
registered
When PF NIC client's init_instance() succeeds, it means this client
has been registered successfully, so we use HCLGE_STATE_NIC_REGISTERED
to indicate that. And before calling PF NIC client's uninit_instance(),
So any operation of PF NIC client from HCLGE is not allowed if this
state is not set.
This patch adds aRFS support for PF. The aRFS rules are also
stored in the hardware flow director table, Use the existing
filter management functions to insert TCPv4/UDPv4/TCPv6/UDPv6
flow director filters. To avoid rule conflict, once user adds
flow director rules with ethtool, the aRFS will be disabled,
and clear exist aRFS rules. Once all user configure rules were
removed, aRFS can work again.
In order to be compatible with aRFS rules, this patch adds
spin_lock for flow director rule adding, deleting, querying,
and packages the rule configuration.
This patch adds support for FEC encoding control, user can change
FEC mode by command ethtool --set-fec, and get FEC mode by command
ethtool --show-fec. The fec capability is changed follow the port
speed. If autoneg on, the user configure fec mode will be overwritten
by autoneg result.
Previously, we can only identify copper and fiber type, the
supported link modes of port information are always showing
SR type. This patch adds support for multiple media types,
include SR, LR CR, KR. Driver needs to query the media type
from firmware periodicly, and updates the port information.
The new port information looks like this:
Settings for eth0:
Supported ports: [ FIBRE ]
Supported link modes: 25000baseCR/Full
25000baseSR/Full
1000baseX/Full
10000baseCR/Full
10000baseSR/Full
10000baseLR/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Supported FEC modes: None BaseR
Advertised link modes: Not reported
Advertised pause frame use: No
Advertised auto-negotiation: No
Advertised FEC modes: Not reported
Speed: 10000Mb/s
Duplex: Full
Port: FIBRE
PHYAD: 0
Transceiver: internal
Auto-negotiation: off
Current message level: 0x00000036 (54)
probe link ifdown ifup
Link detected: yes
In order to be compatible with old firmware which only support
sfp speed, we remained using the same query command, and kept
the former logic.
MAC tnl interruptions are different from other type of RAS and MSI-X
errors, because some bits, such as OVF/LR/RF will occur during link up
and down.
The drivers should clear status of all MAC tnl interruption bits but
shouldn't print any message that would mislead the users.
In case that link down and re-up in a short time because of some reasons,
we record when they occurred, and users can query them by debugfs.
This patch adds statistics for PF's reset information,
also, provides a debugfs command to dump these statistics.
When setting vport->bw_limit to hdev->tm_info.pg_info[0].bw_limit
in hclge_tm_vport_tc_info_update, vport->bw_limit can be as big as
HCLGE_ETHER_MAX_RATE (100000), which can not fit into u16 (65535).
So this patch fixes it by using u32 for vport->bw_limit.
Fixes: 848440544b41 ("net: hns3: Add support of TX Scheduler & Shaper to HNS3 driver")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
In original codes, ndo_set_vf_vlan() in hns3 driver was implemented
wrong. It adds or removes VLAN into VLAN filter for VF, but VF is
unaware of it.
This patch fixes it. When VF loads up, it firstly queries the port
based VLAN state from PF. When user change port based VLAN state
from PF, PF firstly checks whether the VF is alive. If the VF is
alive, then PF notifies the VF the modification; otherwise PF
configure the port based VLAN state directly.
unaware of it.
Indeed, ndo_set_vf_vlan() is expected to enable or disable port based
VLAN (hardware inserts a specified VLAN tag to all TX packets for a
specified VF) . When enable port based VLAN, we use port based VLAN id
as VLAN filter entry. When disable port based VLAN, we use VLAN id of
VLAN device.
This patch fixes it for PF, enable/disable port based VLAN when calls
ndo_set_vf_vlan().
Our hardware supports inserting a specified VLAN header for each
function when sending packets. User can enable it with command
"ip link set <devname> vf <vfid> vlan <vlan id>".
For this VLAN header is inserted by hardware, not from stack,
hardware also needs to strip it from received packets before
sending to stack. In this case, driver needs to tell
hardware which VLAN to insert or strip.
The current VLAN initialization doesn't allow inserting
VLAN header by hardware, this patch modifies it, in order be
compatible with VLAN inserted base on port.
This patch adds support to config depth for tx|rx ring separately
by ethtool command "-G".
Record the vlan tables that the VF sends to the chip.
After the VF exception, the PF actively clears the VF to chip config.
Signed-off-by: liuzhongzhu <liuzhongzhu@huawei.com>
Record the unicast and multicast tables that the VF sends to the chip.
In original codes, for copper port which doesn't connect to phy,
it always returns -EOPNOTSUPP when query port information. This
patch fixes it by return the port information of MAC.
Fixes: 5f373b158523 ("net: hns3: Fix speed/duplex information loss problem when executing ethtool ethx cmd of VF")
In orginal codes, driver always enables flow director when
intializing. When user disable flow director with command
ethtool -K, the flow director will be enabled again after
resetting.
This patch fixes it by only enabling it when first initialzing.
Fixes: 6871af29b3ab ("net: hns3: Add reset handle for flow director")
The PFC enabling is based on user priority, currently it is
based on TC, which may cause PFC not setting correctly when pri
to TC mapping is not one to one relation.
This patch adds pfc_en in tm_info to fix it.
Fixes: cacde272dd00 ("net: hns3: Add hclge_dcb module for the support of DCB feature")
In the old firmware version, statistics acquisition of
PFC frames and MAC control frames is not supported.
Add command retrieves statistics for PFC frames and
MAC control frames from the firmware.
When the ETS information is changed, the network device needs to be
re-initialized, otherwise the information such as the receiving queue
will be incorrect.
This patch adds support of getting tx and dv buffer size through
firmware, because different version of hardware requires different
size of tx and dv buffer.
This patch also add dv_buf_size to tc' private buffer size even if
pfc is not enable for the tc.
This patch prints queue map information.
debugfs command:
echo dump queue map > cmd
Sample Command:
root@(none)# echo queue map > cmd
local queue id | global queue id | vector id
0 32 769
1 33 770
2 34 771
3 35 772
4 36 773
5 37 774
6 38 775
7 39 776
8 40 777
9 41 778
10 42 779
11 43 780
12 44 781
13 45 782
14 46 783
15 47 784
root@(none)#
Signed-off-by: Salil Mehta <salil.mehta@huawei.com>
This patch adds handling for HNS3 hardware errors(non-standard)
which are reported through MSIX interrupts and not through
PCIe AER channel.
These MSIX reported hardware errors are handled using common
misc. interrupt handler. Hardware error related registers
cannot be cleared in context to the interrupt received as
they require *heavy* access to hardware using IMP(Integrated
Mangement Processor) commands. Hence, we defer the clearing
of such error events till later time.
Since, we have defered exact identification of errors we
will have to defer the level of receovery/reset which
might be required. Hence, a new reset type UNKNOWN reset
has been introduced which effectively defers the assertion
of the reset till we get hold of kind of errors at later
time.
Signed-off-by: Shiju Jose <shiju.jose@huawei.com>
This patch adds support to dump PF PCIe registers using ethtool -d
for HNS3 PF Driver.
Port 0/1 of HiP08 supports 10G and 25G. This patch adds a
change to configure NIC port speed same as that of optical
module(SFP/QFSP). Driver gets the optical module speed and
sets NIC port speed accordingly.
All the Flow Director rules are stored in tcam blocks.
For each bit of tcam entry, the match value
depends on two input value(x, y).
debugfs command:
echo dump fd tcam > cmd
Sample output:
root@(none)# echo dump fd tcam > cmd
hns3 0000:7d:00.0: read result tcam key x(31):
hns3 0000:7d:00.0: 00000000
hns3 0000:7d:00.0: 08000000
hns3 0000:7d:00.0: 00000600
hns3 0000:7d:00.0: read result tcam key y(31):
hns3 0000:7d:00.0: f7ff0000
hns3 0000:7d:00.0: 0000f900
hns3 0000:7d:00.0: 0000fff8
root@(none)#
The patch adds mtu setting support for vf, currently
vf and pf share the same hardware mtu setting. Mtu set
by vf must be less than or equal to pf' mtu, and mtu
set by pf must be greater than or equal to vf' mtu.
Currently there is no way for pf to know if a vf device is
alive or not, so PF does not know which vf to notify when
reset happens, or which vf's mtu is invalid when vf and pf
This patch adds vport alive state checking support, in order
to support the above scenario.
This patch adds supports for two vlan header when setting mtu.
This patch implements the .reset_prepare and .reset_done
ops from pci framework to support the PF FLR.
The current code only print the prompt message after receiving
the IMP reset interrupt and does not perform the corresponding driver
reset operation. This patch implements the missing IMP reset handling
in the driver.
1. The driver sets the HCLGE_STATE_CMD_DISABLE to stop sending command
after receiving the IMP reset interrupt.
2. The driver needs to notify the hardware to reload the IMP firmware.
3. The IMP firmware reloading makes the reset time of hardware longer,
so it is necessary to extend the driver's waiting time to wait for
the hardware reset to complete.
4. In hclge_check_event_cause, IMP reset event should have higher
priority than other events.
Also, after clearing HCLGE_STATE_CMD_DISABLE in the hclge_cmd_init(),
it needs to check whether there is a pending reset, if so, just set
the HCLGE_STATE_CMD_DISABLE back and return.
When PF performs a function reset, the hardware will reset both PF
and all the VF belong to this PF. Hence, both PF's driver and VF's
driver need to perform corresponding reset operations.
Before PF driver asserting function reset to hardware, it firstly
set up VF's hardware reset status, and inform the VF driver with
HNAE3_VF_PF_FUNC_RESET, then VF driver sets this reset type to
reset_pending and shechule reset task to stop IO and waits for the
hardware reset status to clear. When PF driver has reinitialized the
hardware and is ready to process mailbox from VF, PF driver clears
VF's hardware reset status for VF to continue its reset process.
Also, this patch uses readl_poll_timeout to simplify the hardware reset
status waitting.
Currently when VF need to reset itself, it will send a cmd to PF,
after receiving the VF reset requset, PF sends a cmd to inform
VF to enter the reset process and send a cmd to firmware to do the
actual reset for the VF, it is possible that firmware has resetted
the VF, but VF has not entered the reset process, which may cause
IO not stopped problem when firmware is resetting VF.
This patch fixes it by adjusting the VF reset process, when VF
need to reset itself, it will enter the reset process first, and
it will tell the PF to send cmd to firmware to reset itself.
Add member reset_pending to struct hclgevf_dev, which indicates that
there is reset event need to be processed by the VF's reset task, and
the VF's reset task chooses the highest-level one and clears other
low-level one when it processes reset_pending.
hclge_inform_reset_assert_to_vf function is unused now, but it will
be used to support the PF reset with VF working, so declare it in
the header file.
When hclge_reset() is called, it may fail for several reasons.
For example, an higher-level reset event occurs, memory allocation
failure, hardware reset timeout, etc. Therefore, it is necessary
to add corresponding error handling for these situations.
1. A high-level reset is required due to a high-level reset failure.
2. For memory allocation failure, a high-level reset is initiated by
the timer to recover. The reason for using the timer is to prevent this
new high-level reset to interrupt the reset process of other pf/vf;
3. For the case of hardware reset timeout, reschedule the reset task
to wait for the hardware to complete the reset.
For memory allocation failure and reset timeouts, in order to prevent
an infinite number of scheduled reset tasks, the number of error
recovery needs to be limited.
This patch also add some reset related debug log printing.
hclge_dev/hclgevf_dev
Saving reset related information in the hclge_dev/hclgevf_dev
structure is more suitable than the hnae3_handle, since hardware
related information is kept in these two structure.
The client needs to know if the hardware is resetting when
loading or unloading itself, because client may abort the loading
process or wait for the reset process to finish when unloading
if hardware is resetting.
So this patch provides these interfaces to do it.
1. get_hw_reset_stat, the reset status of hardware.
2. ae_dev_resetting, whether reset task is scheduling.
3. ae_dev_reset_cnt, how many reset has been done.
Also, the RoCE client needs some field in the hnae3_roce_private_info
to save its state, and process_hw_error interface in the
hnae3_client_ops to process hardware errors.
Currently, when reset_event is called because of tx timeout, it will
upgrade the reset level (For PF, HNAE3_FUNC_RESET -> HNAE3_CORE_RESET
-> HNAE3_GLOBAL_RESET) if the time between the new reset and last reset
is within 20 secs, or restore the reset level to HNAE3_FUNC_RESET if
the time between the new reset and last reset is over 20 secs.
There is requirement that the caller needs to decide the reset level
when triggering a reset, for example, RAS recovery. So this patch
adds the set_default_reset_request to meet this requirement.
There are some functions that, when they fail to send the command,
need to return the corresponding error value to its caller.
Fixes: 681ec3999b3d ("net: hns3: fix for vlan table lost problem when resetting")
For mta table support has been dropped, remove the code for mta table.
Signed-off-by: Zhongzhu Liu <liuzhongzhu@huawei.com>
In previously implement for unicast mac vlan table, the space is
shared by all the functions, driver does nothing when the space is
exhausted. This patch preallocates the space of unicast mac vlan
table for each function by software. Each function can only use its
private space and available shared space, avoiding single function
exhausts too much space, and other functions are unable to add
unicast mac address.
This patch adds support for add and delete rule by ethtool commands.
HNS3 driver supports several flow types, include ETHER_FLOW,
IP_USER_FLOW, TCP_V4_FLOW, UDP_V4_FLOW, SCTP_V4_FLOW, IPV6_USER_FLOW,
TCP_V6_FLOW, UDP_V6_FLOW and SCTP_V6_FLOW.
Each flow director rule consists of input key and action. The input key
is the condition for matching, includes tuples of L2/L3/L4 header.
Action is the behaviour when a packet matches with the input key, such
as drop the packet, or forward to a specified queue.
The input key is stored in the tcam blocks, Each bit of input key can
be masked.
Flow director is a new feature supported by hardware with revision 0x21.
This patch adds flow direcor initialization for each PF. It queries flow
director mode and tcam resource from firmware, selects tuples used for
input key.
