drivers/net/ethernet/marvell/mvneta.c
The mvneta.c conflict is a case of overlapping changes,
a conversion to devm_ioremap_resource() vs. a conversion
to netdev_alloc_pcpu_stats.
The mvneta driver currently uses of_iomap(), which has two drawbacks:
it doesn't request the resource, and it isn't devm-style so some error
handling is needed.
This commit switches to use devm_ioremap_resource() instead, which
automatically requests the resource (so the I/O registers region shows
up properly in /proc/iomem), and also is devm-style, which allows to
get rid of some error handling to unmap the I/O registers region.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
handling is needed.
Commit 5445eaf309ff ('mvneta: Try to fix mvneta when compiled as
module') fixed the mvneta driver to make it work properly when loaded
as a module in SGMII configuration, which was tested successful by the
author on the Armada XP OpenBlocks AX3, which uses SGMII.
However, it turns out that the Armada XP GP, which uses RGMII, is
affected by a similar problem: its SERDES configuration is lost when
mvneta is loaded as a module, because this configuration is set by the
bootloader, and then lost because the clock is gated by the clock
framework until the mvneta driver is loaded again and the clock is
re-enabled.
However, it turns out that for the RGMII case, setting the SERDES
configuration is not sufficient: the PCS enable bit in the
MVNETA_GMAC_CTRL_2 register must also be set, like in the SGMII
configuration.
Therefore, this commit reworks the SGMII/RGMII initialization: the
only difference between the two now is a different SERDES
configuration, all the rest is identical.
In detail, to achieve this, the commit:
* Renames MVNETA_SGMII_SERDES_CFG to MVNETA_SERDES_CFG because it is
not specific to SGMII, but also used on RGMII configurations.
* Adds a MVNETA_RGMII_SERDES_PROTO definition, that must be used as
the MVNETA_SERDES_CFG value in RGMII configurations.
* Removes the mvneta_gmac_rgmii_set() and mvneta_port_sgmii_config()
functions, and instead directly do the SGMII/RGMII configuration in
mvneta_port_up(), from where those functions where called. It is
worth mentioning that mvneta_gmac_rgmii_set() had an 'enable'
parameter that was always passed as '1', so it was pretty useless.
* Reworks the mvneta_port_up() function to set the MVNETA_SERDES_CFG
register to the appropriate value depending on the RGMII vs. SGMII
configuration. It also unconditionally set the PCS_ENABLE bit (was
already done for SGMII, but is now also needed for RGMII), and sets
the PORT_RGMII bit (which was already done for both SGMII and
RGMII).
This commit was successfully tested with mvneta compiled as a module,
on both the OpenBlocks AX3 (SGMII configuration) and the Armada XP GP
(RGMII configuration).
Reported-by: Steve McIntyre <steve@einval.com>
Cc: stable@vger.kernel.org # 3.11.x: 5445eaf309ff mvneta: Try to fix mvneta when compiled as module
Bit 3 of the MVNETA_GMAC_CTRL_2 is actually used to enable the PCS,
not the PSC: there was a typo in the name of the define, which this
commit fixes.
Replace the bh safe variant with the hard irq safe variant.
We need a hard irq safe variant to deal with netpoll transmitting
packets from hard irq context, and we need it in most if not all of
the places using the bh safe variant.
Except on 32bit uni-processor the code is exactly the same so don't
bother with a bh variant, just have a hard irq safe variant that
everyone can use.
There are many drivers calling alloc_percpu() to allocate pcpu stats
and then initializing ->syncp. So just introduce a helper function for them.
The function return parameter is not used in mvneta_tx_done_gbe(),
where the function is called. This patch makes the function return
void.
Reviewed-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
mvneta_tx_done_gbe() return value and third parameter are no more
used. This patch changes the function prototype and removes a useless
variable where the function is called.
calling dma_map_single()/dma_unmap_single() is quite expensive compared
to copying a small packet. So let's copy short frames and keep the buffers
mapped. We set the limit to 256 bytes which seems to give good results both
on the XP-GP board and on the AX3/4.
The Rx small packet rate increased by 16.4% doing this, from 486kpps to
573kpps. It is worth noting that even the call to the function
dma_sync_single_range_for_cpu() is expensive (300 ns) although less
than dma_unmap_single(). Without it, the packet rate raises to 711kpps
(+24% more). Thus on systems where coherency from device to CPU is
guaranteed by a snoop control unit, this patch should provide even more
gains, and probably rx_copybreak could be increased.
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
Tested-by: Arnaud Ebalard <arno@natisbad.org>
Signed-off-by: Willy Tarreau <w@1wt.eu>
Make use of build_skb() to allocate frags on the RX path. When frag size
is lower than a page size, we can use netdev_alloc_frag(), and we fall back
to kmalloc() for larger sizes. The frag size is stored into the mvneta_port
struct. The alloc/free functions check the frag size to decide what alloc/
free method to use. MTU changes are safe because the MTU change function
stops the device and clears the queues before applying the change.
With this patch, I observed a reproducible 2% performance improvement on
HTTP-based benchmarks, and 5% on small packet RX rate.
Currently, the mvneta driver tries to prefetch the current Rx
descriptor during read. Tests have shown that prefetching the
next one instead increases general performance by about 1% on
HTTP traffic.
At several places, we already know the value of the rx status but
we call functions which dereference the pointer again to get it
and don't need the descriptor for anything else. Simplify this
task by replacing the rx desc pointer by the status word itself.
Make mvneta_rxq_fill() use mvneta_rx_refill() instead of using
duplicate code.
Currently, mvneta_txq_bufs_free() calls mvneta_tx_done_policy() with
a non-null cause to retrieve the pointer to the next queue to process.
There are useless tests on the return queue number and on the pointer,
all of which are well defined within a known limited set. This code
path is fast, although not critical. Removing 3 tests here that the
compiler could not optimize (verified) is always desirable.
Right now the mvneta driver doesn't handle Tx IRQ, and relies on two
mechanisms to flush Tx descriptors : a flush at the end of mvneta_tx()
and a timer. If a burst of packets is emitted faster than the device
can send them, then the queue is stopped until next wake-up of the
timer 10ms later. This causes jerky output traffic with bursts and
pauses, making it difficult to reach line rate with very few streams.
A test on UDP traffic shows that it's not possible to go beyond 134
Mbps / 12 kpps of outgoing traffic with 1500-bytes IP packets. Routed
traffic tends to observe pauses as well if the traffic is bursty,
making it even burstier after the wake-up.
It seems that this feature was inherited from the original driver but
nothing there mentions any reason for not using the interrupt instead,
which the chip supports.
Thus, this patch enables Tx interrupts and removes the timer. It does
the two at once because it's not really possible to make the two
mechanisms coexist, so a split patch doesn't make sense.
First tests performed on a Mirabox (Armada 370) show that less CPU
seems to be used when sending traffic. One reason might be that we now
call the mvneta_tx_done_gbe() with a mask indicating which queues have
been done instead of looping over all of them.
The same UDP test above now happily reaches 987 Mbps / 87.7 kpps.
Single-stream TCP traffic can now more easily reach line rate. HTTP
transfers of 1 MB objects over a single connection went from 730 to
840 Mbps. It is even possible to go significantly higher (>900 Mbps)
by tweaking tcp_tso_win_divisor.
Cc: Arnaud Ebalard <arno@natisbad.org>
Marvell has not published the chip's datasheet yet, so it's very hard
to find the relevant bits to manipulate to change the IRQ behaviour.
Fortunately, these bits are described in the proprietary LSP patch set
which is publicly available here :
http://www.plugcomputer.org/downloads/mirabox/
So let's put them back in the driver in order to reduce the burden of
current and future maintenance.
If a queue timeout is reported, we can oops because of some
schedules while the caller is atomic, as shown below :
mvneta d0070000.ethernet eth0: tx timeout
BUG: scheduling while atomic: bash/1528/0x00000100
Modules linked in: slhttp_ethdiv(C) [last unloaded: slhttp_ethdiv]
CPU: 2 PID: 1528 Comm: bash Tainted: G WC 3.13.0-rc4-mvebu-nf #180
[<c0011bd9>] (unwind_backtrace+0x1/0x98) from [<c000f1ab>] (show_stack+0xb/0xc)
[<c000f1ab>] (show_stack+0xb/0xc) from [<c02ad323>] (dump_stack+0x4f/0x64)
[<c02ad323>] (dump_stack+0x4f/0x64) from [<c02abe67>] (__schedule_bug+0x37/0x4c)
[<c02abe67>] (__schedule_bug+0x37/0x4c) from [<c02ae261>] (__schedule+0x325/0x3ec)
[<c02ae261>] (__schedule+0x325/0x3ec) from [<c02adb97>] (schedule_timeout+0xb7/0x118)
[<c02adb97>] (schedule_timeout+0xb7/0x118) from [<c0020a67>] (msleep+0xf/0x14)
[<c0020a67>] (msleep+0xf/0x14) from [<c01dcbe5>] (mvneta_stop_dev+0x21/0x194)
[<c01dcbe5>] (mvneta_stop_dev+0x21/0x194) from [<c01dcfe9>] (mvneta_tx_timeout+0x19/0x24)
[<c01dcfe9>] (mvneta_tx_timeout+0x19/0x24) from [<c024afc7>] (dev_watchdog+0x18b/0x1c4)
[<c024afc7>] (dev_watchdog+0x18b/0x1c4) from [<c0020b53>] (call_timer_fn.isra.27+0x17/0x5c)
[<c0020b53>] (call_timer_fn.isra.27+0x17/0x5c) from [<c0020cad>] (run_timer_softirq+0x115/0x170)
[<c0020cad>] (run_timer_softirq+0x115/0x170) from [<c001ccb9>] (__do_softirq+0xbd/0x1a8)
[<c001ccb9>] (__do_softirq+0xbd/0x1a8) from [<c001cfad>] (irq_exit+0x61/0x98)
[<c001cfad>] (irq_exit+0x61/0x98) from [<c000d4bf>] (handle_IRQ+0x27/0x60)
[<c000d4bf>] (handle_IRQ+0x27/0x60) from [<c000843b>] (armada_370_xp_handle_irq+0x33/0xc8)
[<c000843b>] (armada_370_xp_handle_irq+0x33/0xc8) from [<c000fba9>] (__irq_usr+0x49/0x60)
Ben Hutchings attempted to propose a better fix consisting in using a
scheduled work for this, but while it fixed this panic, it caused other
random freezes and panics proving that the reset sequence in the driver
is unreliable and that additional fixes should be investigated.
When sending multiple streams over a link limited to 100 Mbps, Tx timeouts
happen from time to time, and the driver correctly recovers only when the
function is disabled.
Cc: Ben Hutchings <ben@decadent.org.uk>
Stats writers are mvneta_rx() and mvneta_tx(). They don't lock anything
when they update the stats, and as a result, it randomly happens that
the stats freeze on SMP if two updates happen during stats retrieval.
This is very easily reproducible by starting two HTTP servers and binding
each of them to a different CPU, then consulting /proc/net/dev in loops
during transfers, the interface should immediately lock up. This issue
also randomly happens upon link state changes during transfers, because
the stats are collected in this situation, but it takes more attempts to
reproduce it.
The comments in netdevice.h suggest using per_cpu stats instead to get
rid of this issue.
This patch implements this. It merges both rx_stats and tx_stats into
a single "stats" member with a single syncp. Both mvneta_rx() and
mvneta_rx() now only update the a single CPU's counters.
In turn, mvneta_get_stats64() does the summing by iterating over all CPUs
to get their respective stats.
With this change, stats are still correct and no more lockup is encountered.
Note that this bug was present since the first import of the mvneta
driver. It might make sense to backport it to some stable trees. If
so, it depends on "d33dc73 net: mvneta: increase the 64-bit rx/tx stats
out of the hot path".
Reviewed-by: Eric Dumazet <edumazet@google.com>
Better count packets and bytes in the stack and on 32 bit then
accumulate them at the end for once. This saves two memory writes
and two memory barriers per packet. The incoming packet rate was
increased by 4.7% on the Openblocks AX3 thanks to this.
The current code unmaps the DMA mapping created for rx skb_buff's by
using the data_size as the the mapping size. This is wrong since the
correct size to specify should match the size used to create the mapping.
This commit removes the following DMA_API_DEBUG warning:
WARNING: at lib/dma-debug.c:887 check_unmap+0x3a8/0x860()
mvneta d0070000.ethernet: DMA-API: device driver frees DMA memory with different size [device address=0x000000002eb80000] [map size=1600 bytes] [unmap size=66 bytes]
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.10.21-01444-ga88ae13-dirty #92
[<c0013600>] (unwind_backtrace+0x0/0xf8) from [<c0010fb8>] (show_stack+0x10/0x14)
[<c0010fb8>] (show_stack+0x10/0x14) from [<c001afa0>] (warn_slowpath_common+0x48/0x68)
[<c001afa0>] (warn_slowpath_common+0x48/0x68) from [<c001b01c>] (warn_slowpath_fmt+0x30/0x40)
[<c001b01c>] (warn_slowpath_fmt+0x30/0x40) from [<c018d0fc>] (check_unmap+0x3a8/0x860)
[<c018d0fc>] (check_unmap+0x3a8/0x860) from [<c018d734>] (debug_dma_unmap_page+0x64/0x70)
[<c018d734>] (debug_dma_unmap_page+0x64/0x70) from [<c0233f78>] (mvneta_rx+0xec/0x468)
[<c0233f78>] (mvneta_rx+0xec/0x468) from [<c023436c>] (mvneta_poll+0x78/0x16c)
[<c023436c>] (mvneta_poll+0x78/0x16c) from [<c02db468>] (net_rx_action+0x94/0x160)
[<c02db468>] (net_rx_action+0x94/0x160) from [<c0021e68>] (__do_softirq+0xe8/0x1d0)
[<c0021e68>] (__do_softirq+0xe8/0x1d0) from [<c0021ff8>] (do_softirq+0x4c/0x58)
[<c0021ff8>] (do_softirq+0x4c/0x58) from [<c0022228>] (irq_exit+0x58/0x90)
[<c0022228>] (irq_exit+0x58/0x90) from [<c000e7c8>] (handle_IRQ+0x3c/0x94)
[<c000e7c8>] (handle_IRQ+0x3c/0x94) from [<c0008548>] (armada_370_xp_handle_irq+0x4c/0xb4)
[<c0008548>] (armada_370_xp_handle_irq+0x4c/0xb4) from [<c000dc20>] (__irq_svc+0x40/0x50)
Exception stack(0xc04f1f70 to 0xc04f1fb8)
1f60: c1fe46f8 00000000 00001d92 00001d92
1f80: c04f0000 c04f0000 c04f84a4 c03e081c c05220e7 00000001 c05220e7 c04f0000
1fa0: 00000000 c04f1fb8 c000eaf8 c004c048 60000113 ffffffff
[<c000dc20>] (__irq_svc+0x40/0x50) from [<c004c048>] (cpu_startup_entry+0x54/0x128)
[<c004c048>] (cpu_startup_entry+0x54/0x128) from [<c04c1a14>] (start_kernel+0x29c/0x2f0)
[<c04c1a14>] (start_kernel+0x29c/0x2f0) from [<00008074>] (0x8074)
---[ end trace d4955f6acd178110 ]---
Mapped at:
[<c018d600>] debug_dma_map_page+0x4c/0x11c
[<c0235d6c>] mvneta_setup_rxqs+0x398/0x598
[<c0236084>] mvneta_open+0x40/0x17c
[<c02dbbd4>] __dev_open+0x9c/0x100
[<c02dbe58>] __dev_change_flags+0x7c/0x134
Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Pull core locking changes from Ingo Molnar:
"The biggest changes:
- add lockdep support for seqcount/seqlocks structures, this
unearthed both bugs and required extra annotation.
- move the various kernel locking primitives to the new
kernel/locking/ directory"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
block: Use u64_stats_init() to initialize seqcounts
locking/lockdep: Mark __lockdep_count_forward_deps() as static
lockdep/proc: Fix lock-time avg computation
locking/doc: Update references to kernel/mutex.c
ipv6: Fix possible ipv6 seqlock deadlock
cpuset: Fix potential deadlock w/ set_mems_allowed
seqcount: Add lockdep functionality to seqcount/seqlock structures
net: Explicitly initialize u64_stats_sync structures for lockdep
locking: Move the percpu-rwsem code to kernel/locking/
locking: Move the lglocks code to kernel/locking/
locking: Move the rwsem code to kernel/locking/
locking: Move the rtmutex code to kernel/locking/
locking: Move the semaphore core to kernel/locking/
locking: Move the spinlock code to kernel/locking/
locking: Move the lockdep code to kernel/locking/
locking: Move the mutex code to kernel/locking/
hung_task debugging: Add tracepoint to report the hang
x86/locking/kconfig: Update paravirt spinlock Kconfig description
lockstat: Report avg wait and hold times
lockdep, x86/alternatives: Drop ancient lockdep fixup message
In order to enable lockdep on seqcount/seqlock structures, we
must explicitly initialize any locks.
The u64_stats_sync structure, uses a seqcount, and thus we need
to introduce a u64_stats_init() function and use it to initialize
the structure.
This unfortunately adds a lot of fairly trivial initialization code
to a number of drivers. But the benefit of ensuring correctness makes
this worth while.
Because these changes are required for lockdep to be enabled, and the
changes are quite trivial, I've not yet split this patch out into 30-some
separate patches, as I figured it would be better to get the various
maintainers thoughts on how to best merge this change along with
the seqcount lockdep enablement.
Feedback would be appreciated!
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Jesse Gross <jesse@nicira.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Mirko Lindner <mlindner@marvell.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Roger Luethi <rl@hellgate.ch>
Cc: Simon Horman <horms@verge.net.au>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Wensong Zhang <wensong@linux-vs.org>
Cc: netdev@vger.kernel.org
Link: http://lkml.kernel.org/r/1381186321-4906-2-git-send-email-john.stultz@linaro.org
Checking if MAC address is valid using is_valid_ether_addr() is already done in
of_get_mac_address().
Signed-off-by: Luka Perkov <luka@openwrt.org>
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
CC: David Miller <davem@davemloft.net>
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
net/bridge/br_multicast.c
net/ipv6/sit.c
The conflicts were minor:
1) sit.c changes overlap with change to ip_tunnel_xmit() signature.
2) br_multicast.c had an overlap between computing max_delay using
msecs_to_jiffies and turning MLDV2_MRC() into an inline function
with a name using lowercase instead of uppercase letters.
3) stmmac had two overlapping changes, one which conditionally allocated
and hooked up a dma_cfg based upon the presence of the pbl OF property,
and another one handling store-and-forward DMA made. The latter of
which should not go into the new of_find_property() basic block.
This commit implements the ->ndo_do_ioctl() operation so that the
PHY-related ioctl() calls can work from userspace, which allows
applications like mii-tool or mii-diag to do their job.
Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
This commit fixes a long-standing bug that has been reported by many
users: on some Armada 370 platforms, only the network interface that
has been used in U-Boot to tftp the kernel works properly in
Linux. The other network interfaces can see a 'link up', but are
unable to transmit data. The reports were generally made on the Armada
370-based Mirabox, but have also been given on the Armada 370-RD
board.
The network MAC in the Armada 370/XP (supported by the mvneta driver
in Linux) has a functionality that allows it to continuously poll the
PHY and directly update the MAC configuration accordingly (speed,
duplex, etc.). The very first versions of the driver submitted for
review were using this hardware mechanism, but due to this, the driver
was not integrated with the kernel phylib. Following reviews, the
driver was changed to use the phylib, and therefore a software based
polling. In software based polling, Linux regularly talks to the PHY
over the MDIO bus, and sees if the link status has changed. If it's
the case then the adjust_link() callback of the driver is called to
update the MAC configuration accordingly.
However, it turns out that the adjust_link() callback was not
configuring the hardware in a completely correct way: while it was
setting the speed and duplex bits correctly, it wasn't telling the
hardware to actually take into account those bits rather than what the
hardware-based PHY polling mechanism has concluded. So, in fact the
adjust_link() callback was basically a no-op.
However, the network happened to be working because on the network
interfaces used by U-Boot for tftp on Armada 370 platforms because the
hardware PHY polling was enabled by the bootloader, and left enabled
by Linux. However, the second network interface not used for tftp (or
both network interfaces if the kernel is loaded from USB, NAND or SD
card) didn't had the hardware PHY polling enabled.
This patch fixes this situation by:
(1) Making sure that the hardware PHY polling is disabled by clearing
the MVNETA_PHY_POLLING_ENABLE bit in the MVNETA_UNIT_CONTROL
register in the driver ->probe() function.
(2) Making sure that the duplex and speed selections made by the
adjust_link() callback are taken into account by clearing the
MVNETA_GMAC_AN_SPEED_EN and MVNETA_GMAC_AN_DUPLEX_EN bits in the
MVNETA_GMAC_AUTONEG_CONFIG register.
This patch has been tested on Armada 370 Mirabox, and now both network
interfaces are usable after boot.
[ Problem introduced by commit c5aff18 ("net: mvneta: driver for
Marvell Armada 370/XP network unit") ]
Cc: Willy Tarreau <w@1wt.eu>
Cc: Jochen De Smet <jochen.armkernel@leahnim.org>
Cc: Peter Sanford <psanford@nearbuy.io>
Cc: Ethan Tuttle <ethan@ethantuttle.com>
Cc: Chény Yves-Gael <yves@cheny.fr>
Cc: Ryan Press <ryan@presslab.us>
Cc: Simon Guinot <simon.guinot@sequanux.org>
Cc: vdonnefort@lacie.com
Acked-by: Jason Cooper <jason@lakedaemon.net>
Tested-by: Vincent Donnefort <vdonnefort@gmail.com>
Tested-by: Yves-Gael Cheny <yves@cheny.fr>
Merge net into net-next to setup some infrastructure Eric
Dumazet needs for usbnet changes.
When the mvneta driver is compiled as module, the clock is disabled before
it's loading. This will reset the registers values and all configuration
made by the bootloader.
This patch sets the "sgmii serdes configuration" register to a magical value
found in:
https://github.com/yellowback/ubuntu-precise-armadaxp/blob/master/arch/arm/mach-armadaxp/armada_xp_family/ctrlEnv/mvCtrlEnvLib.c
With this change, the interrupts are working/generated and ethernet is
working.
Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org>
When the mvneta driver is compiled, it'll be loaded with clocks disabled.
This implies that the clocks should be enabled again before any register
access or it'll hang.
To fix it:
- enable clock earlier
- move timer callback after setting timer.data
Use the "swap descriptor" feature of the hardware to properly swap the
descriptors when running in big endian mode. Since the swapping occurs
on 64 bits words, we also need to provide a separate structure layout
for the DMA descriptors between little endian and big endian mode,
like is done in the mv643xx_eth driver.
The macros used for the various fields of the RX and TX descriptions
are currently declared next to those fields within the structure
definitions of the RX and TX descriptors.
However, in order to support big endian, we'll have to use the "swap
descriptors" features of the hardware, which swaps every byte within
each 64 bits word of the descriptors. This requires a separate
definition of the RX and TX descriptor structures for little and big
endian, as is done in the mv643xx_eth. Those macros can therefore no
longer be defined inside those structures.
This patch improves the logic used by the mvneta driver to find a MAC
address for a particular interface. Until now, it was only looking at
the Device Tree, and if no address was found, was falling back to
generating a random MAC address.
This patch adds the intermediate solution of reading the MAC address
from the hardware registers, in case it has been set by the
bootloader. So the order is now:
1) MAC address from the Device Tree
2) MAC address from the hardware registers
3) Random MAC address
This requires moving the MAC address initialization a little bit later
in the ->probe() code, because it now requires the hardware registers
to be remapped.
Cc: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Cc: Joe Perches <joe@perches.com>
The driver core clears the driver data to NULL after device_release
or on probe failure, since commit 0998d0631001288a5974afc0b2a5f568bcdecb4d
(device-core: Ensure drvdata = NULL when no driver is bound).
Thus, it is not needed to manually clear the device driver data to NULL.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Acked-by: Roland Stigge <stigge@antcom.de>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Tested-by: Roland Stigge <stigge@antcom.de>
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
mvneta_tx() was using a static tx queue number causing crashes as
soon as a little bit of traffic was sent via the interface, because
it is normally expected that the same queue should be used as in
dev_queue_xmit().
As suggested by Ben Hutchings, let's use skb_get_queue_mapping() to
get the proper Tx queue number, and use alloc_etherdev_mqs() instead
of alloc_etherdev_mq() to create the queues.
Both my Mirabox and my OpenBlocks AX3 used to crash without this patch
and don't anymore with it. The issue appeared in 3.8 but became more
visible after the fix allowing GSO to be enabled.
Original work was done by Dmitri Epshtein and Thomas Petazzoni. I
just adapted it to take care of Ben's comments.
Cc: Dmitri Epshtein <dima@marvell.com>
Cc: Ben Hutchings <bhutchings@solarflare.com>
It seems that the reason why the dev features were ignored was because
they were enabled after registeration.
I believe these error messages are already logged
on allocation failure by warn_alloc_failed and so
get a dump_stack on OOM.
Remove the unnecessary additional error logging.
Around these deletions:
o Alignment neatening.
o Remove unnecessary casts of dma_alloc_coherent.
o Hoist assigns from ifs.
The file uses nothing from the version.h header, so there is no reason
to include it.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Remove some __dev* markings that snuck in the 3.8-rc1 merge window in
the drivers/net/* directory.
Cc: Bill Pemberton <wfp5p@virginia.edu>
mvneta_deinit() can be called from the ->probe() hook in the error
path, so it shouldn't be marked as __devexit. It fixes the following
section mismatch warning:
WARNING: vmlinux.o(.devinit.text+0x239c): Section mismatch in reference
from the function mvneta_probe() to the function .devexit.text:mvneta_deinit()
The function __devinit mvneta_probe() references
a function __devexit mvneta_deinit().
Now that the Armada 370/XP platform has gained proper integration with
the clock framework, we add clk support in the Marvell Armada 370/XP
Ethernet driver.
Since the existing Device Tree binding that exposes a
'clock-frequency' property has never been exposed in any stable kernel
release, we take the freedom of removing this property to replace it
with the standard 'clocks' clock pointer property.
The Device Tree binding documentation is updated accordingly.
As reported by checkpatch, the multiline comments for net/ and
drivers/net/ have a slightly different format than the one used in the
rest of the kernel, so we adjust our multiline comments accordingly.
This patch contains a new network driver for the network unit of the
ARM Marvell Armada 370 and the Armada XP. Both SoCs use the PJ4B
processor, a Marvell-developed ARM core that implements the ARMv7
instruction set.
Compared to previous ARM Marvell SoCs (Kirkwood, Orion, Discovery),
the network unit in Armada 370 and Armada XP is highly different. This
is the reason why this new 'mvneta' driver is needed, while the older
ARM Marvell SoCs use the 'mv643xx_eth' driver.
Here is an overview of the most important hardware changes that
require a new, specific, driver for the network unit of Armada 370/XP:
- The new network unit has a completely different design and layout
for the RX and TX descriptors. They are now organized as a simple
array (each RX and TX queue has base address and size of this
array) rather than a linked list as in the old SoCs.
- The new network unit has a different RXQ and TXQ management: this
management is done using special read/write counter registers,
while in the Old SocS, it was done using the Ownership bit in RX
and TX descriptors.
- The new network unit has different interrupt registers
- The new network unit way of cleaning of interrupts is not done by
writing to the cause register, but by updating per-queue counters
- The new network unit has different GMAC registers (link, speed,
duplex configuration) and different WRR registers.
- The new network unit has lots of new units like PnC (Parser and
Classifier), PMT, BM (Memory Buffer Management), xPON, and more.
The driver proposed in the current patch only handles the basic
features. Additional hardware features will progressively be supported
as needed.
This code has originally been written by Rami Rosen
<rosenr@marvell.com>, and then reviewed and cleaned up by Thomas
Petazzoni <thomas.petazzoni@free-electrons.com>.
