[ Upstream commit 065fd83e1be2e1ba0d446a257fd86a3cc7bddb51 ]
For the case where the last mvneta_poll did not process all
RX packets, we need to xor the pp->cause_rx_tx or port->cause_rx_tx
before claculating the rx_queue.
Fixes: 2dcf75e2793c ("net: mvneta: Associate RX queues with each CPU")
Signed-off-by: Jisheng Zhang <Jisheng.Zhang@synaptics.com>
[ Upstream commit 5aafeb74b5bb65b34cc87c7623f9fa163a34fa3b ]
Running old skge driver on PowerPC causes checksum errors
because hardware reported 1's complement checksum is in little-endian
byte order.
Reported-by: Benoit <benoit.sansoni@gmail.com>
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 189308d5823a089b56e2299cd96589507dac7319 ]
A similar workaround for the suspend/resume problem is needed for yet
another ASUS machines, P6X models. Like the previous fix, the BIOS
doesn't provide the standard DMI_SYS_* entry, so again DMI_BOARD_*
entries are used instead.
Reported-and-tested-by: SteveM <swm@swm1.com>
[ Upstream commit a261e3797506bd561700be643fe1a85bf81e9661 ]
The onboard sky2 NIC on ASUS P6T WS PRO doesn't work after PM resume
due to the infamous IRQ problem. Disabling MSI works around it, so
let's add it to the blacklist.
Unfortunately the BIOS on the machine doesn't fill the standard
DMI_SYS_* entry, so we pick up DMI_BOARD_* entries instead.
BugLink: https://bugzilla.suse.com/show_bug.cgi?id=1142496
Reported-and-tested-by: Marcus Seyfarth <m.seyfarth@gmail.com>
[ Upstream commit 21808437214637952b61beaba6034d97880fbeb3 ]
MVPP2_TXQ_SCHED_TOKEN_CNTR_REG() expects the logical queue id but
the current code is passing the global tx queue offset, so it ends
up writing to unknown registers (between 0x8280 and 0x82fc, which
seemed to be unused by the hardware). This fixes the issue by using
the logical queue id instead.
Fixes: 3f518509dedc ("ethernet: Add new driver for Marvell Armada 375 network unit")
Signed-off-by: Antoine Tenart <antoine.tenart@bootlin.com>
[ Upstream commit d484e06e25ebb937d841dac02ac1fe76ec7d4ddd ]
Fix below issues in err code path of probe:
1. we don't need to unregister_netdev() because the netdev isn't
registered.
2. when register_netdev() fails, we also need to destroy bm pool for
HWBM case.
Fixes: dc35a10f68d3 ("net: mvneta: bm: add support for hardware buffer management")
[ Upstream commit a8fef9ba58c9966ddb1fec916d8d8137c9d8bc89 ]
Booting 4.20 on SolidRun Clearfog issues this warning with DMA API
debug enabled:
WARNING: CPU: 0 PID: 555 at kernel/dma/debug.c:1230 check_sync+0x514/0x5bc
mvneta f1070000.ethernet: DMA-API: device driver tries to sync DMA memory it has not allocated [device address=0x000000002dd7dc00] [size=240 bytes]
Modules linked in: ahci mv88e6xxx dsa_core xhci_plat_hcd xhci_hcd devlink armada_thermal marvell_cesa des_generic ehci_orion phy_armada38x_comphy mcp3021 spi_orion evbug sfp mdio_i2c ip_tables x_tables
CPU: 0 PID: 555 Comm: bridge-network- Not tainted 4.20.0+ #291
Hardware name: Marvell Armada 380/385 (Device Tree)
[<c0019638>] (unwind_backtrace) from [<c0014888>] (show_stack+0x10/0x14)
[<c0014888>] (show_stack) from [<c07f54e0>] (dump_stack+0x9c/0xd4)
[<c07f54e0>] (dump_stack) from [<c00312bc>] (__warn+0xf8/0x124)
[<c00312bc>] (__warn) from [<c00313b0>] (warn_slowpath_fmt+0x38/0x48)
[<c00313b0>] (warn_slowpath_fmt) from [<c00b0370>] (check_sync+0x514/0x5bc)
[<c00b0370>] (check_sync) from [<c00b04f8>] (debug_dma_sync_single_range_for_cpu+0x6c/0x74)
[<c00b04f8>] (debug_dma_sync_single_range_for_cpu) from [<c051bd14>] (mvneta_poll+0x298/0xf58)
[<c051bd14>] (mvneta_poll) from [<c0656194>] (net_rx_action+0x128/0x424)
[<c0656194>] (net_rx_action) from [<c000a230>] (__do_softirq+0xf0/0x540)
[<c000a230>] (__do_softirq) from [<c00386e0>] (irq_exit+0x124/0x144)
[<c00386e0>] (irq_exit) from [<c009b5e0>] (__handle_domain_irq+0x58/0xb0)
[<c009b5e0>] (__handle_domain_irq) from [<c03a63c4>] (gic_handle_irq+0x48/0x98)
[<c03a63c4>] (gic_handle_irq) from [<c0009a10>] (__irq_svc+0x70/0x98)
This appears to be caused by mvneta_rx_hwbm() calling
dma_sync_single_range_for_cpu() with the wrong struct device pointer,
as the buffer manager device pointer is used to map and unmap the
buffer. Fix this.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit e928b5d6b75e239feb9c6d5488974b6646a0ebc8 ]
If mv643xx_eth_shared_of_probe() fails, mv643xx_eth_shared_probe()
leaves clk enabled.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
[ Upstream commit b33b7cd6fd86478dd2890a9abeb6f036aa01fdf7 ]
Some sky2 chips fire IRQ after S3, before the driver is fully resumed:
[ 686.804877] do_IRQ: 1.37 No irq handler for vector
This is likely a platform bug that device isn't fully quiesced during
S3. Use MSI-X, maskable MSI or INTx can prevent this issue from
happening.
Since MSI-X and maskable MSI are not supported by this device, fallback
to use INTx on affected platforms.
BugLink: https://bugs.launchpad.net/bugs/1807259
BugLink: https://bugs.launchpad.net/bugs/1809843
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
[ Upstream commit 1765f5dcd00963e33f1b8a4e0f34061fbc0e2f7f ]
Another platform requires even longer delay to make the device work
correctly after S3.
So increase the delay to 300ms.
BugLink: https://bugs.launchpad.net/bugs/1798921
[ Upstream commit 294c149a209c6196c2de85f512b52ef50f519949 ]
The "p" buffer is 0x4000 bytes long. B3_RI_WTO_R1 is 0x190. The value
of "regs->len" is in the 1-0x4000 range. The bug here is that
"regs->len - B3_RI_WTO_R1" can be a negative value which would lead to
memory corruption and an abrupt crash.
Fixes: c3f8be961808 ("[PATCH] skge: expand ethtool debug register dump")
[ Upstream commit 35f3625c21852ad839f20c91c7d81c4c1101e207 ]
When offloading the L3 and L4 csum computation on TX, we need to extract
the l3_proto from the ethtype, independently of the presence of a vlan
tag.
The actual driver uses skb->protocol as-is, resulting in packets with
the wrong L4 checksum being sent when there's a vlan tag in the packet
header and checksum offloading is enabled.
This commit makes use of vlan_protocol_get() to get the correct ethtype
regardless the presence of a vlan tag.
Signed-off-by: Maxime Chevallier <maxime.chevallier@bootlin.com>
[ Upstream commit 8466baf788ec3e18836bd9c91ba0b1a07af25878 ]
It is incorrect to enable TX/RX queues (call by mvneta_port_up()) for
port without link. Indeed MTU change for interface without link causes TX
queues to stuck.
Fixes: c5aff18204da ("net: mvneta: driver for Marvell Armada 370/XP
network unit")
Signed-off-by: Yelena Krivosheev <yelena@marvell.com>
[gregory.clement: adding Fixes tags and rewording commit log]
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
[ Upstream commit e81b5e01c14add8395dfba7130f8829206bb507d ]
In mvneta_port_up() we enable relevant RX and TX port queues by write
queues bit map to an appropriate register.
q_map must be ZERO in the beginning of this process.
Acked-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
[ Upstream commit afb133637071be6deeb8b3d0e55593ffbf63c527 ]
The sky2 ethernet stops working after system resume from suspend:
[ 582.852065] sky2 0000:04:00.0: Refused to change power state, currently in D3
The current 150ms delay is not enough, change it to 200ms can solve the
issue.
BugLink: https://bugs.launchpad.net/bugs/1758507
Cc: Stable <stable@vger.kernel.org>
commit 7ac8ff95f48cbfa609a060fd6a1e361dd62feeb3 upstream.
IPv6 doesn't work on the MacchiatoBIN board. It is caused by broken
multicast address filter in the mvpp2 driver.
The driver loads doesn't load any multicast entries if "allmulti" is not
set. This condition should be reversed.
The condition !netdev_mc_empty(dev) is useless (because
netdev_for_each_mc_addr is nop if the list is empty).
This patch also fixes a possible overflow of the multicast list - if
mvpp2_prs_mac_da_accept fails, we set the allmulti flag and retry.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@vger.kernel.org
[ Upstream commit 589bf32f09852041fbd3b7ce1a9e703f95c230ba ]
add appropriate calls to clk_disable_unprepare() by jumping to out_mdio
in case orion_mdio_probe() returns -EPROBE_DEFER.
Fixes: 3d604da1e954 ("net: mvmdio: get and enable optional clock")
Signed-off-by: Tobias Jordan <Tobias.Jordan@elektrobit.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
commit 2eecb2e04abb62ef8ea7b43e1a46bdb5b99d1bf8 upstream.
There are few reasons in mvneta_rx_swbm() function when received packet
is dropped. mvneta_rx_error() should be called only if error bit [16]
is set in rx descriptor.
[gregory.clement@free-electrons.com: add fixes tag]
Tested-by: Dmitri Epshtein <dima@marvell.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit ca5902a6547f662419689ca28b3c29a772446caa upstream.
When adding the RX queue association with each CPU, a typo was made in
the mvneta_cleanup_rxqs() function. This patch fixes it.
[gregory.clement@free-electrons.com: add commit log and fixes tag]
commit 4423c18e466afdfb02a36ee8b9f901d144b3c607 upstream.
When port connect to PHY in polling mode (with poll interval 1 sec),
port and phy link status must be synchronize in order don't loss link
change event.
Fixes: c5aff18204da ("net: mvneta: driver for Marvell Armada 370/XP network unit")
[ Upstream commit 9303ab2b3402b60f6c39abfdbfa4ce00fce8bee4 ]
drivers/net/ethernet/marvell/mvneta.c:2694:26: error: storage size of 'status' isn't known
drivers/net/ethernet/marvell/mvneta.c:2695:26: error: storage size of 'changed' isn't known
drivers/net/ethernet/marvell/mvneta.c:2695:9: error: variable 'changed' has initializer but incomplete type
drivers/net/ethernet/marvell/mvneta.c:2709:2: error: implicit declaration of function 'fixed_phy_update_state' [-Werror=implicit-function-declaration]
Add linux/phy_fixed.h to mvneta.c
Acked-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
[ Upstream commit 36fb7435b6ac4d288a2d4deea8934f9456ab46b6 ]
The mvpp2_txq_bufs_free() function is called upon TX completion to DMA
unmap TX buffers, and free the corresponding SKBs. It gets the
references to the SKB to free and the DMA buffer to unmap from a per-CPU
txq_pcpu data structure.
However, the code currently increments the pointer to the next entry
before doing the DMA unmap and freeing the SKB. It does not cause any
visible problem because for a given SKB the TX completion is guaranteed
to take place on the CPU where the TX was started. However, it is much
more logical to increment the pointer to the next entry once the current
entry has been completely unmapped/released.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
commit 239a3b663647869330955ec59caac0100ef9b60a upstream.
When TX descriptors are filled in, the buffer DMA address is split
between the tx_desc->buf_phys_addr field (high-order bits) and
tx_desc->packet_offset field (5 low-order bits).
However, when we re-calculate the DMA address from the TX descriptor in
mvpp2_txq_inc_put(), we do not take tx_desc->packet_offset into
account. This means that when the DMA address is not aligned on a 32
bytes boundary, we end up calling dma_unmap_single() with a DMA address
that was not the one returned by dma_map_single().
This inconsistency is detected by the kernel when DMA_API_DEBUG is
enabled. We fix this problem by properly calculating the DMA address in
mvpp2_txq_inc_put().
commit 8354491c9d5b06709384cea91d13019bf5e61449 upstream.
Since commit 71ce391dfb784 ("net: mvpp2: enable proper per-CPU TX
buffers unmapping"), we are not correctly DMA unmapping TX buffers for
fragments.
Indeed, the mvpp2_txq_inc_put() function only stores in the
txq_cpu->tx_buffs[] array the physical address of the buffer to be
DMA-unmapped when skb != NULL. In addition, when DMA-unmapping, we use
skb_headlen(skb) to get the size to be unmapped. Both of this works fine
for TX descriptors that are associated directly to a SKB, but not the
ones that are used for fragments, with a NULL pointer as skb:
- We have a NULL physical address when calling DMA unmap
- skb_headlen(skb) crashes because skb is NULL
This causes random crashes when fragments are used.
To solve this problem, we need to:
- Store the physical address of the buffer to be unmapped
unconditionally, regardless of whether it is tied to a SKB or not.
- Store the length of the buffer to be unmapped, which requires a new
field.
Instead of adding a third array to store the length of the buffer to be
unmapped, and as suggested by David Miller, this commit refactors the
tx_buffs[] and tx_skb[] arrays of 'struct mvpp2_txq_pcpu' into a
separate structure 'mvpp2_txq_pcpu_buf', to which a 'size' field is
added. Therefore, instead of having three arrays to allocate/free, we
have a single one, which also improve data locality, reducing the
impact on the CPU cache.
Fixes: 71ce391dfb784 ("net: mvpp2: enable proper per-CPU TX buffers unmapping")
Reported-by: Raphael G <raphael.glon@corp.ovh.com>
Cc: Raphael G <raphael.glon@corp.ovh.com>
Make sure to deregister and free any fixed-link PHY registered using
of_phy_register_fixed_link() on probe errors and on driver unbind.
Fixes: 83895bedeee6 ("net: mvneta: add support for fixed links")
Signed-off-by: Johan Hovold <johan@kernel.org>
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
gcc-7 detects a short memset in mvpp2, introduced in the original
merge of the driver:
drivers/net/ethernet/marvell/mvpp2.c: In function 'mvpp2_cls_init':
drivers/net/ethernet/marvell/mvpp2.c:3296:2: error: 'memset' used with length equal to number of elements without multiplication by element size [-Werror=memset-elt-size]
The result seems to be that we write uninitialized data into the
flow table registers, although we did not get any warning about
that uninitialized data usage.
Using sizeof() lets us initialize then entire array instead.
The mvneta driver advertises it supports IFF_UNICAST_FLT. However, it
actually does not. The hardware probably does support it, but there is
no code to configure the filter. As a quick and simple fix, remove the
flag. This will cause the core to fall back to promiscuous mode.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Fixes: b50b72de2f2f ("net: mvneta: enable features before registering the driver")
The sky2 frequently crashes during machine shutdown with:
sky2_get_stats+0x60/0x3d8 [sky2]
dev_get_stats+0x68/0xd8
rtnl_fill_stats+0x54/0x140
rtnl_fill_ifinfo+0x46c/0xc68
rtmsg_ifinfo_build_skb+0x7c/0xf0
rtmsg_ifinfo.part.22+0x3c/0x70
rtmsg_ifinfo+0x50/0x5c
netdev_state_change+0x4c/0x58
linkwatch_do_dev+0x50/0x88
__linkwatch_run_queue+0x104/0x1a4
linkwatch_event+0x30/0x3c
process_one_work+0x140/0x3e0
worker_thread+0x60/0x44c
kthread+0xdc/0xf0
ret_from_fork+0x10/0x50
This is caused by the sky2 being called after it has been shutdown.
A previous thread about this can be found here:
https://lkml.org/lkml/2016/4/12/410
An alternative fix is to assure that IFF_UP gets cleared by
calling dev_close() during shutdown. This is similar to what the
bnx2/tg3/xgene and maybe others are doing to assure that the driver
isn't being called following _shutdown().
Signed-off-by: Jeremy Linton <jeremy.linton@arm.com>
The coalesce settings behave badly when changing just one value:
... # ethtool -c eth0
rx-usecs: 249
... # ethtool -C eth0 tx-usecs 250
rx-usecs: 248
This occurs due to rounding errors when calculating the microseconds
value - the divisons round down. This causes (eg) the rx-usecs to
decrease by one every time the tx-usecs value is set as per the above.
Fix this by making the divison round-to-nearest.
The MAC is capable of RGMII mode and that is probably a more typical
connection type than GMII today (eg it is used by Marvell Reference
designs for several SOCs). Let DT users specify the standard
phy-connection-type = "rgmii-id";
On a phy node.
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Pull networking updates from David Miller:
1) BBR TCP congestion control, from Neal Cardwell, Yuchung Cheng and
co. at Google. https://lwn.net/Articles/701165/
2) Do TCP Small Queues for retransmits, from Eric Dumazet.
3) Support collect_md mode for all IPV4 and IPV6 tunnels, from Alexei
Starovoitov.
4) Allow cls_flower to classify packets in ip tunnels, from Amir Vadai.
5) Support DSA tagging in older mv88e6xxx switches, from Andrew Lunn.
6) Support GMAC protocol in iwlwifi mwm, from Ayala Beker.
7) Support ndo_poll_controller in mlx5, from Calvin Owens.
8) Move VRF processing to an output hook and allow l3mdev to be
loopback, from David Ahern.
9) Support SOCK_DESTROY for UDP sockets. Also from David Ahern.
10) Congestion control in RXRPC, from David Howells.
11) Support geneve RX offload in ixgbe, from Emil Tantilov.
12) When hitting pressure for new incoming TCP data SKBs, perform a
partial rathern than a full purge of the OFO queue (which could be
huge). From Eric Dumazet.
13) Convert XFRM state and policy lookups to RCU, from Florian Westphal.
14) Support RX network flow classification to igb, from Gangfeng Huang.
15) Hardware offloading of eBPF in nfp driver, from Jakub Kicinski.
16) New skbmod packet action, from Jamal Hadi Salim.
17) Remove some inefficiencies in snmp proc output, from Jia He.
18) Add FIB notifications to properly propagate route changes to
hardware which is doing forwarding offloading. From Jiri Pirko.
19) New dsa driver for qca8xxx chips, from John Crispin.
20) Implement RFC7559 ipv6 router solicitation backoff, from Maciej
Żenczykowski.
21) Add L3 mode to ipvlan, from Mahesh Bandewar.
22) Support 802.1ad in mlx4, from Moshe Shemesh.
23) Support hardware LRO in mediatek driver, from Nelson Chang.
24) Add TC offloading to mlx5, from Or Gerlitz.
25) Convert various drivers to ethtool ksettings interfaces, from
Philippe Reynes.
26) TX max rate limiting for cxgb4, from Rahul Lakkireddy.
27) NAPI support for ath10k, from Rajkumar Manoharan.
28) Support XDP in mlx5, from Rana Shahout and Saeed Mahameed.
29) UDP replicast support in TIPC, from Richard Alpe.
30) Per-queue statistics for qed driver, from Sudarsana Reddy Kalluru.
31) Support BQL in thunderx driver, from Sunil Goutham.
32) TSO support in alx driver, from Tobias Regnery.
33) Add stream parser engine and use it in kcm.
34) Support async DHCP replies in ipconfig module, from Uwe
Kleine-König.
35) DSA port fast aging for mv88e6xxx driver, from Vivien Didelot.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1715 commits)
mlxsw: switchx2: Fix misuse of hard_header_len
mlxsw: spectrum: Fix misuse of hard_header_len
net/faraday: Stop NCSI device on shutdown
net/ncsi: Introduce ncsi_stop_dev()
net/ncsi: Rework the channel monitoring
net/ncsi: Allow to extend NCSI request properties
net/ncsi: Rework request index allocation
net/ncsi: Don't probe on the reserved channel ID (0x1f)
net/ncsi: Introduce NCSI_RESERVED_CHANNEL
net/ncsi: Avoid unused-value build warning from ia64-linux-gcc
net: Add netdev all_adj_list refcnt propagation to fix panic
net: phy: Add Edge-rate driver for Microsemi PHYs.
vmxnet3: Wake queue from reset work
i40e: avoid NULL pointer dereference and recursive errors on early PCI error
qed: Add RoCE ll2 & GSI support
qed: Add support for memory registeration verbs
qed: Add support for QP verbs
qed: PD,PKEY and CQ verb support
qed: Add support for RoCE hw init
qede: Add qedr framework
There is no need to clk_disable_unprepare(dev->clk)
before it was initialized.
We get 2 warnings when building kernel with W=1:
drivers/net/ethernet/marvell/mvneta.c:639:27: warning: no previous prototype for 'mvneta_get_stats64' [-Wmissing-prototypes]
drivers/net/ethernet/marvell/mvneta.c:3529:5: warning: no previous prototype for 'mvneta_ethtool_set_link_ksettings' [-Wmissing-prototypes]
In fact, these two functions are only used in the file in which they are
declared and don't need a declaration, but can be made static.
so this patch marks these functions with 'static'.
Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org>
The IS_ENABLED() macro checks if a Kconfig symbol has been enabled either
built-in or as a module, use that macro instead of open coding the same.
Using the macro makes the code more readable by helping abstract away some
of the Kconfig built-in and module enable details.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Install the callbacks via the state machine and let the core invoke
the callbacks on the already online CPUs.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: netdev@vger.kernel.org
Cc: rt@linutronix.de
Link: http://lkml.kernel.org/r/20160818125731.27256-9-bigeasy@linutronix.de
Update the sky2 driver to pass number of packets done to NAPI.
The driver was never updated when napi_complete_done was added.
The ethtool api {get|set}_settings is deprecated.
We move the mvneta driver to new api {get|set}_link_ksettings.
We use the generic function phy_ethtool_get_link_ksettings,
and update old mvneta_ethtool_set_settings to the new api.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
The private structure contain a pointer to phydev, but the structure
net_device already contain such pointer. So we can remove the pointer
phy_dev in the private structure, and update the driver to use the
one contained in struct net_device.
of_parse_phandle
of_node_put needs to be called when the device node which is got
from of_parse_phandle has finished using.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
of_parse_phandle
Just several instances of overlapping changes.
There are two generics functions phy_ethtool_{get|set}_link_ksettings,
so we can use them instead of defining the same code in the driver.
phydev in the private structure, and update the driver to use the
Commit aebea2ba0f74 ("net: mvneta: fix Tx interrupt delay") intended to
set coalescing threshold to a value guaranteeing interrupt generation
per each sent packet, so that buffers can be released with no delay.
In fact setting threshold to '1' was wrong, because it causes interrupt
every two packets. According to the documentation a reason behind it is
following - interrupt occurs once sent buffers counter reaches a value,
which is higher than one specified in MVNETA_TXQ_SIZE_REG(q). This
behavior was confirmed during tests. Also when testing the SoC working
as a NAS device, better performance was observed with int-per-packet,
as it strongly depends on the fact that all transmitted packets are
released immediately.
This commit enables NETA controller work in interrupt per sent packet mode
by setting coalescing threshold to 0.
Signed-off-by: Dmitri Epshtein <dima@marvell.com>
Signed-off-by: Marcin Wojtas <mw@semihalf.com>
Cc: <stable@vger.kernel.org> # v3.10+
Fixes aebea2ba0f74 ("net: mvneta: fix Tx interrupt delay")
Acked-by: Willy Tarreau <w@1wt.eu>
drivers/net/ethernet/mellanox/mlx5/core/en.h
drivers/net/ethernet/mellanox/mlx5/core/en_main.c
drivers/net/usb/r8152.c
All three conflicts were overlapping changes.
If mvneta_mdio_probe() fails, a kernel warning is triggered due to
missing cleanup in the error path. Add the necessary cleanup.
WARNING: CPU: 1 PID: 281 at kernel/irq/manage.c:1814 __free_percpu_irq+0xfc/0x130
percpu IRQ 38 still enabled on CPU0!
Modules linked in: bnep bluetooth xhci_plat_hcd xhci_hcd marvell_cesa armada_thermal des_generic ehci_orion mcp3021 spi_orion sfp mdio_i2c evbug fuse
CPU: 1 PID: 281 Comm: connmand Not tainted 4.7.0-rc2+ #53
Backtrace:
[<c0013488>] (dump_backtrace) from [<c00137d0>] (show_stack+0x18/0x1c)
r6:60010093 r5:ffffffff r4:00000000 r3:dc8ba500
[<c00137b8>] (show_stack) from [<c02c6fe0>] (dump_stack+0xa4/0xdc)
[<c02c6f3c>] (dump_stack) from [<c002d4ec>] (__warn+0xd8/0x104)
r6:c081e6a0 r5:00000000 r4:edfe5d50 r3:dc8ba500
[<c002d414>] (__warn) from [<c002d5d0>] (warn_slowpath_fmt+0x40/0x48)
r10:a0010013 r8:c09356f8 r7:00000026 r6:ef11a260 r5:edd7b980 r4:ef11a200
[<c002d594>] (warn_slowpath_fmt) from [<c008c8e0>] (__free_percpu_irq+0xfc/0x130)
r3:00000026 r2:c081e7ac
[<c008c7e4>] (__free_percpu_irq) from [<c008c95c>] (free_percpu_irq+0x48/0x74)
r10:00008914 r8:00000000 r7:ffffffed r6:c09356f8 r5:00000026 r4:ef11a200
[<c008c914>] (free_percpu_irq) from [<c043dd70>] (mvneta_open+0x118/0x134)
r6:ffffffed r5:ef01e640 r4:ef01e000 r3:ef01e000
[<c043dc58>] (mvneta_open) from [<c055f5b4>] (__dev_open+0xa4/0x108)
r7:ef01e030 r6:c06ff3d8 r5:ffff9003 r4:ef01e000
[<c055f510>] (__dev_open) from [<c055f844>] (__dev_change_flags+0x94/0x150)
r7:00001002 r6:00000001 r5:ffff9003 r4:ef01e000
[<c055f7b0>] (__dev_change_flags) from [<c055f938>] (dev_change_flags+0x20/0x50)
r8:00000000 r7:c09334c8 r6:00001002 r5:00000148 r4:ef01e000 r3:00008914
[<c055f918>] (dev_change_flags) from [<c05de044>] (devinet_ioctl+0x6f4/0x7e0)
r8:00000000 r7:c09334c8 r6:00000000 r5:ee87200c r4:00000000 r3:00008914
[<c05dd950>] (devinet_ioctl) from [<c05e0168>] (inet_ioctl+0x1b8/0x1c8)
r10:beb4499c r9:edfe4000 r8:ecf13280 r7:c096cf00 r6:beb4499c r5:eef7c240
r4:00008914
[<c05dffb0>] (inet_ioctl) from [<c053c898>] (sock_ioctl+0x78/0x300)
[<c053c820>] (sock_ioctl) from [<c0155ecc>] (do_vfs_ioctl+0x98/0xa60)
r7:00000011 r6:00008914 r5:00000011 r4:c01568d0
[<c0155e34>] (do_vfs_ioctl) from [<c01568d0>] (SyS_ioctl+0x3c/0x60)
r10:00000000 r9:edfe4000 r8:beb4499c r7:00000011 r6:00008914 r5:ecf13280
r4:ecf13280
[<c0156894>] (SyS_ioctl) from [<c000fe60>] (ret_fast_syscall+0x0/0x1c)
r8:c0010004 r7:00000036 r6:00000011 r5:000a2978 r4:00000000 r3:00009003
---[ end trace 711f625d5b04b3a7 ]---
Tested-by: Jon Nettleton <jon@solid-run.com>
The spinlock used by the hwbm functions must be initialized by the
network driver. This commit fixes this lack and the following erros when
lockdep is enabled:
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
[<c010ff80>] (unwind_backtrace) from [<c010bd08>] (show_stack+0x10/0x14)
[<c010bd08>] (show_stack) from [<c032913c>] (dump_stack+0xb4/0xe0)
[<c032913c>] (dump_stack) from [<c01670e4>] (__lock_acquire+0x1f58/0x2060)
[<c01670e4>] (__lock_acquire) from [<c0167dec>] (lock_acquire+0xa4/0xd0)
[<c0167dec>] (lock_acquire) from [<c06f6650>] (_raw_spin_lock_irqsave+0x54/0x68)
[<c06f6650>] (_raw_spin_lock_irqsave) from [<c058e830>] (hwbm_pool_add+0x1c/0xdc)
[<c058e830>] (hwbm_pool_add) from [<c043f4e8>] (mvneta_bm_pool_use+0x338/0x490)
[<c043f4e8>] (mvneta_bm_pool_use) from [<c0443198>] (mvneta_probe+0x654/0x1284)
[<c0443198>] (mvneta_probe) from [<c03b894c>] (platform_drv_probe+0x4c/0xb0)
[<c03b894c>] (platform_drv_probe) from [<c03b7158>] (driver_probe_device+0x214/0x2c0)
[<c03b7158>] (driver_probe_device) from [<c03b72c4>] (__driver_attach+0xc0/0xc4)
[<c03b72c4>] (__driver_attach) from [<c03b5440>] (bus_for_each_dev+0x68/0x9c)
[<c03b5440>] (bus_for_each_dev) from [<c03b65b8>] (bus_add_driver+0x1a0/0x218)
[<c03b65b8>] (bus_add_driver) from [<c03b79cc>] (driver_register+0x78/0xf8)
[<c03b79cc>] (driver_register) from [<c01018f4>] (do_one_initcall+0x90/0x1dc)
[<c01018f4>] (do_one_initcall) from [<c0900de4>] (kernel_init_freeable+0x15c/0x1fc)
[<c0900de4>] (kernel_init_freeable) from [<c06eed90>] (kernel_init+0x8/0x114)
[<c06eed90>] (kernel_init) from [<c0107910>] (ret_from_fork+0x14/0x24)
Fixes: baa11ebc0c76 ("net: mvneta: Use the new hwbm framework")
Reported-by: Russell King <rmk+kernel@armlinux.org.uk>
