[ Upstream commit 4b14cc313f076c37b646cee06a85f0db59cf216c ]
When PVID is removed from a bridge port, the Linux bridge drops both
untagged and prio-tagged packets. Align mlxsw with this behavior.
Fixes: 148f472da5db ("mlxsw: reg: Add the Switch Port Acceptable Frame Types register")
Acked-by: Jiri Pirko <jiri@mellanox.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
The ASIC has the ability to generate events whenever a sensor indicates
the temperature goes above or below its high or low thresholds,
respectively.
In new firmware versions the firmware enforces a minimum of 5
degrees Celsius difference between both thresholds. Make the driver
conform to this requirement.
Note that this is required even when the events are disabled, as in
certain systems interrupts are generated via GPIO based on these
thresholds.
Fixes: 85926f877040 ("mlxsw: reg: Add definition of temperature management registers")
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
The TIGCR register is used for setting up the IPinIP Tunnel
configuration.
Fixes: ee954d1a91b2 ("mlxsw: spectrum_router: Support GRE tunnels")
Signed-off-by: Petr Machata <petrm@mellanox.com>
Reviewed-by: Ido Schimmel <idosch@mellanox.com>
To support IPIP, the driver needs to be able to construct an IPIP
adjacency. Change mlxsw_reg_ratr_pack to take an adjacency type as an
argument. Adjust the one existing caller.
Unlike other interface types, loopback RIFs do not have MAC address. So
drop the corresponding argument from mlxsw_reg_ritr_pack() and move it
to a new function. Call that from callers of mlxsw_reg_ritr_pack.
The RTDP register is used for configuring the tunnel decap properties of
NVE and IPinIP.
To implement IP-in-IP decapsulation, Spectrum uses LPM entries of type
IP2ME with tunnel validity bit and tunnel pointer set. The necessary
register fields are already available, so add a function to pack the
RALUE as appropriate.
This enum is used with reg_ratr_trap_id, so move it next to the register
definition.
While at it, drop the enumerator initializers.
So far, adjacencies have always been of type Ethernet (with value of 0),
and thus there was no need to explicitly support RATR type. However to
support IP-in-IP adjacencies, this type and a suite of IP-in-IP-specific
attributes need to be added.
Update the register so that loopback RIFs can be created and loopback
properties specified.
Add support for setting counters on neighbors based on dpipe's host table
counter status. This patch also adds the ability for getting the counter
value, which will be used by the dpipe host table implementation in the
next patches.
Signed-off-by: Arkadi Sharshevsky <arkadis@mellanox.com>
This is done as a preparation before introducing support for neighbor
counters. The flow counter's type enum is used by many registers, yet,
until now it was used only by mgpc and thus it was private. This patch
updates the namespace for more generic usage.
This renames IP2ME-specific registers reg_ralue_v and
reg_ralue_tunnel_ptr to reg_ralue_ip2me_*.
The comments really belong to the individual enumerators. The comment
at the register should instead reference the enum.
Update the register so that IPv6 LPM entries could be programmed to the
device's table.
Update the register so that the active IPv6 neighbours could be dumped
from the device's neighbour table.
Update the register, so the IPv6 neighbours could be programmed to the
Before we can start using IPv6, we need to trap certain control packets
to the CPU. Among others, these include Neighbour Discovery, DHCP and
neighbour misses.
Enable IPv6 and IPv6 forwarding on router interfaces (RIFs), so that
they will be able to receive and forward IPv6 traffic.
Before we add IPv6 constructs like traps and router interfaces, we first
need to enable IPv6 routing in the device.
Add support for IPv6 MLDv1/2 packet trapping.
The MCIA register is used to access the SFP+ and QSFP connector's
EPROM. It will be used to query the cable info.
Reviewed-by: Petr Machata <petrm@mellanox.com>
The MCDA register allows reading and writing a firmware component.
Signed-off-by: Yotam Gigi <yotamg@mellanox.com>
The MCC register allows controlling and querying the firmware flash state
machine (FSM).
The MCQI register queries information about firmware components. It will
be needed by the mlxfw module to query various options about the
components, such as their max size, alignment and max write size.
The RICNT register retrieves per port performance counter. It will be
used to query the router interfaces statistics.
Update RITR for counter support. This allows adding counters for
ASIC's router ports.
drivers/net/ethernet/broadcom/genet/bcmgenet.c
net/core/sock.c
Conflicts were overlapping changes in bcmgenet and the
lockdep handling of sockets.
The num_rec field is 8 bit, so the maximal count number is 255.
This fixes vlans learning not being enabled for wider ranges than 255.
Fixes: a4feea74cd7a ("mlxsw: reg: Add Switch Port VLAN MAC Learning register definition")
The num_rec field is 8 bit, so the maximal count number is 255. This
fixes vlans not being enabled for wider ranges than 255.
Fixes: b2e345f9a454 ("mlxsw: reg: Add Switch Port VID and Switch Port VLAN Membership registers definitions")
The MGPC register retrieves generic flow counter value. It will be
used to query ACL counters.
Up until now we implicitly associated all the router interfaces (RIFs)
with the first virtual router (VR). This must be changed in order to
enable VRF offload. Otherwise, a packet received via a VRF slave would
do a FIB lookup in the same table used by other VRFs.
Instead, bind the RIF to a VR according to the table where FIB lookup
should be performed for packets received via the RIF.
Currently, we only care about the MAIN and LOCAL tables (which we squash
together).
HTGT register length is limited to 32 bytes and not 256 bytes.
Signed-off-by: Elad Raz <eladr@mellanox.com>
PEFA register is used for accessing an extended flexible action entry
in the central KVD Linear Database.
The PPBS register retrieves and sets Policy Based Switching Table entries.
The PRCR register is used for accessing rules within a TCAM region.
The PPBT is used for configuration of the Port Binding Table.
The PTCE-V2 register is used for accessing rules within a TCAM region.
It is a new version of PTCE in order to support wider key, mask and
action within a TCAM region.
The PTAR register is used for allocation of regions in the TCAM.
The PAGT register is used for configuration of the ACL Group Table.
The PACL register is used for configuration of the ACL.
The MPSC register allows to configure ingress packet sampling on specific
port of the mlxsw device. The sampled packets are then trapped via
PKT_SAMPLE trap.
The QPCR register is used to create and control policers.
A policer can discard or change the color of packets that are
trapped by a specific trap.
Signed-off-by: Nogah Frankel <nogahf@mellanox.com>
Trap groups can be used to control traps priority, both in terms of
which trap "wins" if a packet matches two traps (priority) and in terms
of packets from which trap group will be scheduled to the cpu first (tc).
They can also be used to set rate limiters (policers) on them (will be
added in the next patches).
Currently, we support two trap groups. In Spectrum we want a better
resolution, so every protocol / flow will have a different trap group,
so we can control its parameters separately. Once the policers will be
implemented, it will also allow us limit the rate of each protocol by
itself.
This patch change the trap group list to include:
* the emad trap group, which is shared for all the devices.
* Switchx2's trap groups, which are a copy of the current trap groups.
* Spectrum's new trap groups, in order to match the above guidelines.
(Switchib is using only the emad trap group, so it require no changes).
This patch also includes new configuration for Spectrum's trap groups,
with primary priority order within them.
Trap groups have many options which we currently set to default values.
In the next patches we will use many of them with non-default values.
Some of these options have no default value, so this patch sets them as
params for the trap group set function. Others almost always use the same
values, so the set function will use this default values. In the rare cases
when they will need to be with other values, these values can be set
directly (using the macros for fields in registers).
Parameters without default value:
TC - the traffic class for packets that hit this trap group.
(old default is the max tc)
priority - if one packet hits multiple trap groups, the group with the
higher priority will "catch" it. (old default is 0)
policer - limit rate policer (old default is disabled)
Default parameters:
swid - switch id, relevant for the emad trap only, ignored on Spectrum.
(new default is 0)
rdq - CPU receive descriptor queue (new default is identical to trap
group id)
Change trap setting function so instead of determining the trap group by
trap id, it gets it as a parameter (so later we can have different trap
groups for Spectrum and Switchx2).
Add "is_ctrl" parameter to the trap setting function. It control whether
the trapped packets wait in a designated control buffer or in their
default one. This parameter is ignored by Switchx2 and Switchib.
Add these parameters to the traps array in Spectrum, Switchx2 and
Switchib.
The MFSL register is used to configure the fan speed event / interrupt
notification mechanism. Fan speed threshold are defined for both
under-speed and over-speed.
The field is 7bit long. Fix it.
