[ Upstream commit b317538c47943f9903860d83cc0060409e12d2ff ]
printk in macro vxge_debug_ll uses __VA_ARGS__ without "##" prefix,
it causes a build error when there is no variable
arguments(e.g. only fmt is specified.).
Signed-off-by: Zheng Wei <wei.zheng@vivo.com>
CONFIG_HOTPLUG is going away as an option. As result the __dev*
markings will be going away.
Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst,
and __devexit.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Jon Mason <jdmason@kudzu.us>
Adding casts of objects to the same type is unnecessary
and confusing for a human reader.
For example, this cast:
int y;
int *p = (int *)&y;
I used the coccinelle script below to find and remove these
unnecessary casts. I manually removed the conversions this
script produces of casts with __force, __iomem and __user.
type T;
T *p;
- (T *)p
+ p
A function in atl1e_main.c was passed a const pointer
when it actually modified elements of the structure.
Change the argument to a non-const pointer.
A function in stmmac needed a __force to avoid a sparse
warning. Added it.
All tables of function pointers should be const.
The pre-existing code has lots of needless indirection...
Inspired by similar change in PAX.
Compile tested only.
Move the Exar drivers into drivers/net/ethernet/neterion/ and make the
necessary Kconfig and Makefile changes.
CC: Jon Mason <jdmason@kudzu.us>
