[ Upstream commit 18a3ed59d09cf81a6447aadf6931bf0c9ffec5e0 ]
Remove Rx overflow log messages as in an environment where logging results
in network traffic logging may cause further overflows.
Fixes: c156633f1353 ("Renesas Ethernet AVB driver proper")
Signed-off-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
[simon: reworked changelog]
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 79514ef670e9e575a1fe36922268c439d0f0ca8a ]
Commit a47b70ea86bd ("ravb: unmap descriptors when freeing rings") has
introduced the issue seen in [1] reproduced on H3ULCB board.
Fix this by relocating the RX skb ringbuffer free operation, so that
swiotlb page unmapping can be done first. Freeing of aligned TX buffers
is not relevant to the issue seen in [1]. Still, reposition TX free
calls as well, to have all kfree() operations performed consistently
_after_ dma_unmap_*()/dma_free_*().
[1] Console screenshot with the problem reproduced:
salvator-x login: root
root@salvator-x:~# ifconfig eth0 up
Micrel KSZ9031 Gigabit PHY e6800000.ethernet-ffffffff:00: \
attached PHY driver [Micrel KSZ9031 Gigabit PHY] \
(mii_bus:phy_addr=e6800000.ethernet-ffffffff:00, irq=235)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
root@salvator-x:~#
root@salvator-x:~# ifconfig eth0 down
BUG: KASAN: use-after-free in swiotlb_tbl_unmap_single+0xc4/0x35c
Write of size 1538 at addr ffff8006d884f780 by task ifconfig/1649
CPU: 0 PID: 1649 Comm: ifconfig Not tainted 4.12.0-rc4-00004-g112eb07287d1 #32
Hardware name: Renesas H3ULCB board based on r8a7795 (DT)
Call trace:
[<ffff20000808f11c>] dump_backtrace+0x0/0x3a4
[<ffff20000808f4d4>] show_stack+0x14/0x1c
[<ffff20000865970c>] dump_stack+0xf8/0x150
[<ffff20000831f8b0>] print_address_description+0x7c/0x330
[<ffff200008320010>] kasan_report+0x2e0/0x2f4
[<ffff20000831eac0>] check_memory_region+0x20/0x14c
[<ffff20000831f054>] memcpy+0x48/0x68
[<ffff20000869ed50>] swiotlb_tbl_unmap_single+0xc4/0x35c
[<ffff20000869fcf4>] unmap_single+0x90/0xa4
[<ffff20000869fd14>] swiotlb_unmap_page+0xc/0x14
[<ffff2000080a2974>] __swiotlb_unmap_page+0xcc/0xe4
[<ffff2000088acdb8>] ravb_ring_free+0x514/0x870
[<ffff2000088b25dc>] ravb_close+0x288/0x36c
[<ffff200008aaf8c4>] __dev_close_many+0x14c/0x174
[<ffff200008aaf9b4>] __dev_close+0xc8/0x144
[<ffff200008ac2100>] __dev_change_flags+0xd8/0x194
[<ffff200008ac221c>] dev_change_flags+0x60/0xb0
[<ffff200008ba2dec>] devinet_ioctl+0x484/0x9d4
[<ffff200008ba7b78>] inet_ioctl+0x190/0x194
[<ffff200008a78c44>] sock_do_ioctl+0x78/0xa8
[<ffff200008a7a128>] sock_ioctl+0x110/0x3c4
[<ffff200008365a70>] vfs_ioctl+0x90/0xa0
[<ffff200008365dbc>] do_vfs_ioctl+0x148/0xc38
[<ffff2000083668f0>] SyS_ioctl+0x44/0x74
[<ffff200008083770>] el0_svc_naked+0x24/0x28
The buggy address belongs to the page:
page:ffff7e001b6213c0 count:0 mapcount:0 mapping: (null) index:0x0
flags: 0x4000000000000000()
raw: 4000000000000000 0000000000000000 0000000000000000 00000000ffffffff
raw: 0000000000000000 ffff7e001b6213e0 0000000000000000 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8006d884f680: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff8006d884f700: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
>ffff8006d884f780: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff8006d884f800: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff8006d884f880: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Disabling lock debugging due to kernel taint
root@salvator-x:~#
Fixes: a47b70ea86bd ("ravb: unmap descriptors when freeing rings")
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
[ Upstream commit a47b70ea86bdeb3091341f5ae3ef580f1a1ad822 ]
"swiotlb buffer is full" errors occur after repeated initialisation of a
device - f.e. suspend/resume or ip link set up/down. This is because memory
mapped using dma_map_single() in ravb_ring_format() and ravb_start_xmit()
is not released. Resolve this problem by unmapping descriptors when
freeing rings.
[simon: reworked]
[ Upstream commit 8ec3e8a192ba6f13be4522ee81227c792c86fb1a ]
Due to alignment requirements of the hardware transmissions are split into
two DMA descriptors, a small padding descriptor of 0 - 3 bytes in length
followed by a descriptor for rest of the packet.
In the case of IP packets the first descriptor will never be zero due to
the way that the stack aligns buffers for IP packets. However, for non-IP
packets it may be zero.
In that case it has been reported that timeouts occur, presumably because
transmission stops at the first zero-length DMA descriptor and thus the
packet is not transmitted. However, in my environment a BUG is triggered as
follows:
[ 20.381417] ------------[ cut here ]------------
[ 20.386054] kernel BUG at lib/swiotlb.c:495!
[ 20.390324] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP
[ 20.395805] Modules linked in:
[ 20.398862] CPU: 0 PID: 2089 Comm: mz Not tainted 4.10.0-rc3-00001-gf13ad2db193f #162
[ 20.406689] Hardware name: Renesas Salvator-X board based on r8a7796 (DT)
[ 20.413474] task: ffff80063b1f1900 task.stack: ffff80063a71c000
[ 20.419404] PC is at swiotlb_tbl_map_single+0x178/0x2ec
[ 20.424625] LR is at map_single+0x4c/0x98
[ 20.428629] pc : [<ffff00000839c4c0>] lr : [<ffff00000839c680>] pstate: 800001c5
[ 20.436019] sp : ffff80063a71f9b0
[ 20.439327] x29: ffff80063a71f9b0 x28: ffff80063a20d500
[ 20.444636] x27: ffff000008ed5000 x26: 0000000000000000
[ 20.449944] x25: 000000067abe2adc x24: 0000000000000000
[ 20.455252] x23: 0000000000200000 x22: 0000000000000001
[ 20.460559] x21: 0000000000175ffe x20: ffff80063b2a0010
[ 20.465866] x19: 0000000000000000 x18: 0000ffffcae6fb20
[ 20.471173] x17: 0000ffffa09ba018 x16: ffff0000087c8b70
[ 20.476480] x15: 0000ffffa084f588 x14: 0000ffffa09cfa14
[ 20.481787] x13: 0000ffffcae87ff0 x12: 000000000063abe2
[ 20.487098] x11: ffff000008096360 x10: ffff80063abe2adc
[ 20.492407] x9 : 0000000000000000 x8 : 0000000000000000
[ 20.497718] x7 : 0000000000000000 x6 : ffff000008ed50d0
[ 20.503028] x5 : 0000000000000000 x4 : 0000000000000001
[ 20.508338] x3 : 0000000000000000 x2 : 000000067abe2adc
[ 20.513648] x1 : 00000000bafff000 x0 : 0000000000000000
[ 20.518958]
[ 20.520446] Process mz (pid: 2089, stack limit = 0xffff80063a71c000)
[ 20.526798] Stack: (0xffff80063a71f9b0 to 0xffff80063a720000)
[ 20.532543] f9a0: ffff80063a71fa30 ffff00000839c680
[ 20.540374] f9c0: ffff80063b2a0010 ffff80063b2a0010 0000000000000001 0000000000000000
[ 20.548204] f9e0: 000000000000006e ffff80063b23c000 ffff80063b23c000 0000000000000000
[ 20.556034] fa00: ffff80063b23c000 ffff80063a20d500 000000013b1f1900 0000000000000000
[ 20.563864] fa20: ffff80063ffd18e0 ffff80063b2a0010 ffff80063a71fa60 ffff00000839cd10
[ 20.571694] fa40: ffff80063b2a0010 0000000000000000 ffff80063ffd18e0 000000067abe2adc
[ 20.579524] fa60: ffff80063a71fa90 ffff000008096380 ffff80063b2a0010 0000000000000000
[ 20.587353] fa80: 0000000000000000 0000000000000001 ffff80063a71fac0 ffff00000864f770
[ 20.595184] faa0: ffff80063b23caf0 0000000000000000 0000000000000000 0000000000000140
[ 20.603014] fac0: ffff80063a71fb60 ffff0000087e6498 ffff80063a20d500 ffff80063b23c000
[ 20.610843] fae0: 0000000000000000 ffff000008daeaf0 0000000000000000 ffff000008daeb00
[ 20.618673] fb00: ffff80063a71fc0c ffff000008da7000 ffff80063b23c090 ffff80063a44f000
[ 20.626503] fb20: 0000000000000000 ffff000008daeb00 ffff80063a71fc0c ffff000008da7000
[ 20.634333] fb40: ffff80063b23c090 0000000000000000 ffff800600000037 ffff0000087e63d8
[ 20.642163] fb60: ffff80063a71fbc0 ffff000008807510 ffff80063a692400 ffff80063a20d500
[ 20.649993] fb80: ffff80063a44f000 ffff80063b23c000 ffff80063a69249c 0000000000000000
[ 20.657823] fba0: 0000000000000000 ffff80063a087800 ffff80063b23c000 ffff80063a20d500
[ 20.665653] fbc0: ffff80063a71fc10 ffff0000087e67dc ffff80063a20d500 ffff80063a692400
[ 20.673483] fbe0: ffff80063b23c000 0000000000000000 ffff80063a44f000 ffff80063a69249c
[ 20.681312] fc00: ffff80063a5f1a10 000000103a087800 ffff80063a71fc70 ffff0000087e6b24
[ 20.689142] fc20: ffff80063a5f1a80 ffff80063a71fde8 000000000000000f 00000000000005ea
[ 20.696972] fc40: ffff80063a5f1a10 0000000000000000 000000000000000f ffff00000887fbd0
[ 20.704802] fc60: fffffff43a5f1a80 0000000000000000 ffff80063a71fc80 ffff000008880240
[ 20.712632] fc80: ffff80063a71fd90 ffff0000087c7a34 ffff80063afc7180 0000000000000000
[ 20.720462] fca0: 0000ffffcae6fe18 0000000000000014 0000000060000000 0000000000000015
[ 20.728292] fcc0: 0000000000000123 00000000000000ce ffff0000088d2000 ffff80063b1f1900
[ 20.736122] fce0: 0000000000008933 ffff000008e7cb80 ffff80063a71fd80 ffff0000087c50a4
[ 20.743951] fd00: 0000000000008933 ffff000008e7cb80 ffff000008e7cb80 000000100000000e
[ 20.751781] fd20: ffff80063a71fe4c 0000ffff00000300 0000000000000123 0000000000000000
[ 20.759611] fd40: 0000000000000000 ffff80063b1f0000 000000000000000e 0000000000000300
[ 20.767441] fd60: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 20.775271] fd80: 0000000000000000 0000000000000000 ffff80063a71fda0 ffff0000087c8c20
[ 20.783100] fda0: 0000000000000000 ffff000008082f30 0000000000000000 0000800637260000
[ 20.790930] fdc0: ffffffffffffffff 0000ffffa0903078 0000000000000000 000000001ea87232
[ 20.798760] fde0: 000000000000000f ffff80063a71fe40 ffff800600000014 ffff000000000001
[ 20.806590] fe00: 0000000000000000 0000000000000000 ffff80063a71fde8 0000000000000000
[ 20.814420] fe20: 0000000000000000 0000000000000000 0000000000000000 0000000000000001
[ 20.822249] fe40: 0000000203000011 0000000000000000 0000000000000000 ffff80063a68aa00
[ 20.830079] fe60: ffff80063a68aa00 0000000000000003 0000000000008933 ffff0000081f1b9c
[ 20.837909] fe80: 0000000000000000 ffff000008082f30 0000000000000000 0000800637260000
[ 20.845739] fea0: ffffffffffffffff 0000ffffa07ca81c 0000000060000000 0000000000000015
[ 20.853569] fec0: 0000000000000003 000000001ea87232 000000000000000f 0000000000000000
[ 20.861399] fee0: 0000ffffcae6fe18 0000000000000014 0000000000000300 0000000000000000
[ 20.869228] ff00: 00000000000000ce 0000000000000000 00000000ffffffff 0000000000000000
[ 20.877059] ff20: 0000000000000002 0000ffffcae87ff0 0000ffffa09cfa14 0000ffffa084f588
[ 20.884888] ff40: 0000000000000000 0000ffffa09ba018 0000ffffcae6fb20 000000001ea87010
[ 20.892718] ff60: 0000ffffa09b9000 0000ffffcae6fe30 0000ffffcae6fe18 000000000000000f
[ 20.900548] ff80: 0000000000000003 000000001ea87232 0000000000000000 0000000000000000
[ 20.908378] ffa0: 0000000000000000 0000ffffcae6fdc0 0000ffffa09a7824 0000ffffcae6fdc0
[ 20.916208] ffc0: 0000ffffa0903078 0000000060000000 0000000000000003 00000000000000ce
[ 20.924038] ffe0: 0000000000000000 0000000000000000 ffffffffffffffff ffffffffffffffff
[ 20.931867] Call trace:
[ 20.934312] Exception stack(0xffff80063a71f7e0 to 0xffff80063a71f910)
[ 20.940750] f7e0: 0000000000000000 0001000000000000 ffff80063a71f9b0 ffff00000839c4c0
[ 20.948580] f800: ffff80063a71f840 ffff00000888a6e4 ffff80063a24c418 ffff80063a24c448
[ 20.956410] f820: 0000000000000000 ffff00000811cd54 ffff80063a71f860 ffff80063a24c458
[ 20.964240] f840: ffff80063a71f870 ffff00000888b258 ffff80063a24c418 0000000000000001
[ 20.972070] f860: ffff80063a71f910 ffff80063a7b7028 ffff80063a71f890 ffff0000088825e4
[ 20.979899] f880: 0000000000000000 00000000bafff000 000000067abe2adc 0000000000000000
[ 20.987729] f8a0: 0000000000000001 0000000000000000 ffff000008ed50d0 0000000000000000
[ 20.995560] f8c0: 0000000000000000 0000000000000000 ffff80063abe2adc ffff000008096360
[ 21.003390] f8e0: 000000000063abe2 0000ffffcae87ff0 0000ffffa09cfa14 0000ffffa084f588
[ 21.011219] f900: ffff0000087c8b70 0000ffffa09ba018
[ 21.016097] [<ffff00000839c4c0>] swiotlb_tbl_map_single+0x178/0x2ec
[ 21.022362] [<ffff00000839c680>] map_single+0x4c/0x98
[ 21.027411] [<ffff00000839cd10>] swiotlb_map_page+0xa4/0x138
[ 21.033072] [<ffff000008096380>] __swiotlb_map_page+0x20/0x7c
[ 21.038821] [<ffff00000864f770>] ravb_start_xmit+0x174/0x668
[ 21.044484] [<ffff0000087e6498>] dev_hard_start_xmit+0x8c/0x120
[ 21.050407] [<ffff000008807510>] sch_direct_xmit+0x108/0x1a0
[ 21.056064] [<ffff0000087e67dc>] __dev_queue_xmit+0x194/0x4cc
[ 21.061807] [<ffff0000087e6b24>] dev_queue_xmit+0x10/0x18
[ 21.067214] [<ffff000008880240>] packet_sendmsg+0xf40/0x1220
[ 21.072873] [<ffff0000087c7a34>] sock_sendmsg+0x18/0x2c
[ 21.078097] [<ffff0000087c8c20>] SyS_sendto+0xb0/0xf0
[ 21.083150] [<ffff000008082f30>] el0_svc_naked+0x24/0x28
[ 21.088462] Code: d34bfef7 2a1803f3 1a9f86d6 35fff878 (d4210000)
[ 21.094611] ---[ end trace 5bc544ad491f3814 ]---
[ 21.099234] Kernel panic - not syncing: Fatal exception in interrupt
[ 21.105587] Kernel Offset: disabled
[ 21.109073] Memory Limit: none
[ 21.112126] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
Fixes: 2f45d1902acf ("ravb: minimize TX data copying")
Signed-off-by: Masaru Nagai <masaru.nagai.vx@renesas.com
We want to set the other "err" variable here so that we can return it
later. My version of GCC misses this issue but I caught it with a
static checker.
Fixes: 9f70eb339f52 ("net: ethernet: renesas: ravb: fix fixed-link phydev leaks")
Reviewed-by: Johan Hovold <johan@kernel.org>
Make sure to deregister and free any fixed-link PHY registered using
of_phy_register_fixed_link() on initialisation errors and on device
close after having disconnected the PHY.
Fixes: b4bc88a868ed ("ravb: Add fixed-link support")
Signed-off-by: Johan Hovold <johan@kernel.org>
When CONFIG_PM_SLEEP is disabled, we get a couple of harmless warnings:
drivers/net/ethernet/renesas/ravb_main.c:2117:12: error: 'ravb_resume' defined but not used [-Werror=unused-function]
drivers/net/ethernet/renesas/ravb_main.c:2104:12: error: 'ravb_suspend' defined but not used [-Werror=unused-function]
The simplest solution here is to replace the #ifdef with __maybe_unused
annotations, which lets the compiler do the right thing by itself.
Fixes: 0184165b2f42 ("ravb: add sleep PM suspend/resume support")
The ethtool api {get|set}_settings is deprecated.
We move this driver to new api {get|set}_link_ksettings.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
The private structure contain a pointer to phydev, but the structure
net_device already contain such pointer. So we can remove the pointer
phy_dev in the private structure, and update the driver to use the
one contained in struct net_device.
The patch 'ravb: add sleep PM suspend/resume support' used incorrect
function names containing 'runtime' for the suspend and resume
functions.
Reported-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Signed-off-by: Niklas Söderlund <niklas.soderlund+renesas@ragnatech.se>
The interface would not function after the system had been woken up
after have been suspended (echo mem > /sys/power/state) cycle. The
reason for this is that all device registers have been reset to its
default values. This patch adds sleep suspend and resume functions that
detached the interface at suspend and restore the registers and reattach
the interface at resume.
Only the registers that are only configured at probe time needs to be
explicitly restored by the resume handler. All other registers are
reconfigured by either reopening the device in the resume handler (if
the device was running when the system was suspended) or when the
interface is opened by a user at a later time.
of_parse_phandle
of_node_put needs to be called when the device node which is got
from of_parse_phandle has finished using.
Signed-off-by: Peter Chen <peter.chen@nxp.com>
Currently 'ifconfig' for the Ethernet devices handled by this driver shows
"DMA chan: ff" while the driver doesn't use any DMA channels. Not assigning
a value to 'net_device::dma' causes 'ifconfig' to correctly not report a
DMA channel.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Writing a non-zero value to the manual PAUSE frame register (MPR) starts
the transmission of a PAUSE frame.
A PAUSE frame is sent in ravb_emac_init(), but it is not expected behavior.
Signed-off-by: Masaru Nagai <masaru.nagai.vx@renesas.com>
Signed-off-by: Yoshihiro Kaneko <ykaneko0929@gmail.com>
Use SET_RUNTIME_PM_OPS macro instead of assigning a member of
dev_pm_ops directly.
The H/W manual recommends B'10 or B'11 in a value of the separation
filtering select bits in the receive configuration register (RCR.ESF).
When B'10 is set, frames from non-matching streams are discarded.
When B'11 is set, frames from non-matching streams are processed in
reception queue 0 (best effort).
This patch sets B'11 in ESF.
[ykaneko0929@gmail.com: revised this commit message]
When reopening the network device on ra7795/salvator-x, e.g. after a
DHCP timeout:
IP-Config: Reopening network devices...
genirq: Flags mismatch irq 139. 00000000 (eth0:ch0:rx_be) vs. 00000000 (ravb e6800000.ethernet eth0: cannot request IRQ eth0:ch0:rx_be
IP-Config: Failed to open eth0
IP-Config: No network devices available
The "mismatch" is due to requesting an IRQ that is already in use,
while IRQF_PROBE_SHARED wasn't set.
However, the real cause is that ravb_close() doesn't release any of the
R-Car Gen3-specific secondary IRQs.
Add the missing free_irq() calls to fix this.
Fixes: f51bdc236b6c5835 ("ravb: Add dma queue interrupt support")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
The nf_conntrack_core.c fix in 'net' is not relevant in 'net-next'
because we no longer have a per-netns conntrack hash.
The ip_gre.c conflict as well as the iwlwifi ones were cases of
overlapping changes.
drivers/net/wireless/intel/iwlwifi/mvm/tx.c
net/ipv4/ip_gre.c
net/netfilter/nf_conntrack_core.c
DHCP timeout:
genirq: Flags mismatch irq 139. 00000000 (eth0:ch24:emac) vs. 00000000 (eth0:ch24:emac)
ravb e6800000.ethernet eth0: cannot request IRQ eth0:ch24:emac
However, the real cause is that ravb_close() doesn't release the R-Car
Gen3-specific secondary IRQ.
Add the missing free_irq() call to fix this.
Fixes: 22d4df8ff3a3cc72 ("ravb: Add support for r8a7795 SoC")
Aligning the reception data size is not required.
Tested-by: Simon Horman <horms+renesas@verge.net.au>
Conflicts were two cases of simple overlapping changes,
nothing serious.
In the UDP case, we need to add a hlist_add_tail_rcu()
to linux/rculist.h, because we've moved UDP socket handling
away from using nulls lists.
When we have the ISS.CGIS bit set, we already know that gPTP interrupt has
happened, so an extra GIS register check at the end of ravb_ptp_interrupt()
seems superfluous. We can model the gPTP interrupt handler like all other
dedicated interrupt handlers in the driver and make it *void*.
The clk API may return 0 on clk_get_rate, so we should check the result before
using it as a divisor.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
This patch supports the following interrupts.
- One interrupt for multiple (timestamp, error, gPTP)
- One interrupt for emac
- Four interrupts for dma queue (best effort rx/tx, network control rx/tx)
This patch improve efficiency of the interrupt handler by adding the
interrupt handler corresponding to each interrupt source described
above. Additionally, it reduces the number of times of the access to
EthernetAVB IF.
Also this patch prevent this driver depends on the whim of a boot loader.
[ykaneko0929@gmail.com: define bit names of registers]
[ykaneko0929@gmail.com: add comment for gen3 only registers]
[ykaneko0929@gmail.com: fix coding style]
[ykaneko0929@gmail.com: update changelog]
[ykaneko0929@gmail.com: gen3: fix initialization of interrupts]
[ykaneko0929@gmail.com: gen3: fix clearing interrupts]
[ykaneko0929@gmail.com: gen3: add helper function for request_irq()]
[ykaneko0929@gmail.com: gen3: remove IRQF_SHARED flag for request_irq()]
[ykaneko0929@gmail.com: revert ravb_close() and ravb_ptp_stop()]
[ykaneko0929@gmail.com: avoid calling free_irq() to non-hooked interrupts]
[ykaneko0929@gmail.com: make NC/BE interrupt handler a function]
[ykaneko0929@gmail.com: make timestamp interrupt handler a function]
[ykaneko0929@gmail.com: timestamp interrupt is handled in multiple
interrupt handler instead of dma queue interrupt handler]
In ravb_start_xmit dont call skb_tx_timestamp only when hardware
timestamping is requested: in the latter case software timestamps are
suppressed and thus the call of skb_tx_timestamp does not have any effect.
Instead call skb_tx_timestamp unconditionally in ravb_start_xmit, since
the function checks itself if software timestamping is required or should
be skipped due to hardware timestamping.
Signed-off-by: Lino Sanfilippo <LinoSanfilippo@gmx.de>
The result value is overwritten by a return value of
ravb_ptp_interrupt().
Several cases of overlapping changes, as well as one instance
(vxlan) of a bug fix in 'net' overlapping with code movement
in 'net-next'.
This change will also make Coverity happy by avoiding a theoretical NULL
pointer dereference; yet another reason is to use the above helper function
to tighten the code and make it more readable.
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Geert Uytterhoeven <geert+renesas@glider.be>
drivers/net/phy/bcm7xxx.c
drivers/net/phy/marvell.c
drivers/net/vxlan.c
All three conflicts were cases of simple overlapping changes.
The driver has the *default* case doing nothing in the *switch* statement
with an integer expression -- remove it.
When adding support for the R-Car gen3 gPTP active in configuration mode,
some call sites of ravb_ptp_{init|stop}() were missed due to an oversight.
Add checks for the R-Car gen2 SoCs around these...
Fixes: f5d7837f96e5 ("ravb: ptp: Add CONFIG mode support")
the code setting the CCC.CSEL field was duplicated due to an oversight.
For R-Car gen 2 it's just redundant and for R-Car gen3 the write at this
time is probably ignored due to CCC.GAC bit being already set...
The driver has often repeated pattern of reading a register, AND'ing and/or
OR'ing some bits and writing the value back. Factor the pattern out into
ravb_modify() -- this saves 260 bytes of code with ARM gcc 4.7.3.
While at it, update Cogent Embedded's copyrights.
drivers/net/bonding/bond_main.c
drivers/net/ethernet/mellanox/mlxsw/spectrum.h
drivers/net/ethernet/mellanox/mlxsw/spectrum_switchdev.c
The bond_main.c and mellanox switch conflicts were cases of
The code in ravb_emac_init() twiddling the ECMR bits always looked a bit
strange to me: if one intends to respect 'priv->duplex', why save old value
of the ECMR.DM bit? As all the other bits are zeroed anyway, we don't
really need to read ECMR before writing to it.
Many Ethernet drivers contain the same netdev_info() print statement
about the attached phy. Move it into the phy device code. Additionally
add a varargs function which can be used to append additional
information.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Add a phydev_name() function, to help with moving some structure members
from phy_device.
drivers/net/geneve.c
Here we had an overlapping change, where in 'net' the extraneous stats
bump was being removed whilst in 'net-next' the final argument to
udp_tunnel6_xmit_skb() was being changed.
This patch adds support of the fixed PHY.
This patch is based on commit 87009814cdbb ("ucc_geth: use the new fixed
PHY helpers").
Ethernet AVB does not support 10 Mbps transfer speed.
AVB-DMAC Receive FIFO Warning interrupt is not enabled, so it is not
necessary to disable the interrupt in ravb_close().
On the other hand, this patch disables the interrupt in ravb_dmac_init() to
prevent the possibility that the interrupt is issued by the state that
a boot loader left.
The code reading the MAHR/MALR registers in ravb_read_mac_address() is
terribly ineffective -- it reads MAHR 4 times and MALR 2 times, while
it's enough to read each register only once. Use the local variables to
achieve that, somewhat beautifying the code while at it...
The Rx queue #1 frame error counter name contains trailing underscore,
probably due to a typo...
kernel/bpf/syscall.c
net/ipv4/ipmr.c
All three conflicts were cases of overlapping changes.
Add fallback compatibility strings for R-Car Gen 2 & 3 SoC Families.
This is in keeping with the fallback scheme being adopted wherever appropriate
for drivers for Renesas SoCs.
Acked-by: Rob Herring <robh@kernel.org>
This patch makes PTP support active in CONFIG mode on R-Car Gen3.
The GTI.TIV may be set to 2GHz^2 / rate, where rate is
that of the clock of the device. Rather than assuming a
rate of 130MHz use the actual rate of the clock.
The motivation for this is to use the correct rate on
the r8a7795/Salvator-X which is advertised as 133MHz but
may differ depending on the extal present on the Salvator-X.
When the R8A7795 support was added to the driver, little attention was paid
to the ravb_open() error path: free_irq() for the EMAC interrupt was called
uncoditionally, unlike request_irq(), and in a wrong order as well...
As a result, on the R-Car gen2 SoCs I started getting the following in case
of a device opening error:
WARNING: CPU: 0 PID: 1 at kernel/irq/manage.c:1448 __free_irq+0x8c/0x228()
Trying to free already-free IRQ 0
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.0-rc1-dirty #1005
Hardware name: Generic R8A7791 (Flattened Device Tree)
Backtrace:
[<c0013818>] (dump_backtrace) from [<c00139b4>] (show_stack+0x18/0x1c)
r6:c063cdd6 r5:00000009 r4:00000000 r3:00204140
[<c001399c>] (show_stack) from [<c022a578>] (dump_stack+0x74/0x90)
[<c022a504>] (dump_stack) from [<c0025f04>] (warn_slowpath_common+0x8c/0xb8)
r4:ef04fd38 r3:c0714770
[<c0025e78>] (warn_slowpath_common) from [<c0025fd4>] (warn_slowpath_fmt+0x38/0x40)
r8:ee8ad800 r7:ef0030a0 r6:00000000 r5:00000000 r4:ef003040
[<c0025fa0>] (warn_slowpath_fmt) from [<c0064cc0>] (__free_irq+0x8c/0x228)
r3:00000000 r2:c063ce9f
[<c0064c34>] (__free_irq) from [<c0064ecc>] (free_irq+0x70/0xa4)
r10:0000016b r8:00000000 r7:00000000 r6:ee8ad800 r5:00000000 r4:ef003040
[<c0064e5c>] (free_irq) from [<c033472c>] (ravb_open+0x224/0x274)
r7:fffffffe r6:00000000 r5:fffffffe r4:ee8ad800
[<c0334508>] (ravb_open) from [<c041ac78>] (__dev_open+0x84/0x104)
r7:ee8ad830 r6:c0566334 r5:00000000 r4:ee8ad800
[<c041abf4>] (__dev_open) from [<c041af08>] (__dev_change_flags+0x94/0x13c)
r7:00001002 r6:00000001 r5:00001003 r4:ee8ad800
[<c041ae74>] (__dev_change_flags) from [<c041afe8>] (dev_change_flags+0x20/0x50)
r7:c072e6e0 r6:00000138 r5:00001002 r4:ee8ad800
[<c041afc8>] (dev_change_flags) from [<c06ec06c>] (ip_auto_config+0x174/0xfb8)
r8:00001002 r7:c072e6e0 r6:c0703344 r5:00000001 r4:ee8ad800 r3:00000101
[<c06ebef8>] (ip_auto_config) from [<c000a810>] (do_one_initcall+0x100/0x1cc)
r10:c06fb83c r9:00000000 r8:c06ebef8 r7:c0736000 r6:c0710918 r5:c0710918
r4:ef2f8f80
[<c000a710>] (do_one_initcall) from [<c06ccddc>] (kernel_init_freeable+0x11c/0x1
ec)
r10:c06fb83c r9:00000000 r8:0000009a r7:c0736000 r6:c0706bf0 r5:c06fb834
r4:00000007
[<c06cccc0>] (kernel_init_freeable) from [<c0514c54>] (kernel_init+0x14/0xec)
r10:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0514c40 r4:c0736000
[<c0514c40>] (kernel_init) from [<c0010458>] (ret_from_fork+0x14/0x3c)
r4:00000000 r3:ef04e000
Fix up the free_irq() call order and add a new label on the error path.
Fixes: 22d4df8ff3a3 ("ravb: Add support for r8a7795 SoC")
Acked-by: Simon Horman <horms+renesas@verge.net.au>
This driver does not handle the AVB-DMAC Receive FIFO Warning interrupt
now, so the interrupt should not be enabled.
When RX/TX interrupt for Network Control queue and Best Effort queue
is issued at the same time, the interrupt mask of Network Control
queue will be reset when the mask of Best Effort queue is set.
This patch fixes this problem.
