There are two generics functions phy_ethtool_{get|set}_link_ksettings,
so we can use them instead of defining the same code in the driver.
Signed-off-by: Philippe Reynes <tremyfr@gmail.com>
The private structure contain a pointer to phydev, but the structure
net_device already contain such pointer. So we can remove the pointer
phydev in the private structure, and update the driver to use the
one contained in struct net_device.
We need to use post-decrement to ensure that irq_dispose_mapping is
also called on priv->rxq[0]->irq_no; moreover, if one of the above for
loops failed already at i==0 (so we reach one of these labels with
that value of i), we'll enter an essentially infinite loop of
out-of-bounds accesses.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Reviewed-by: Francois Romieu <romieu@fr.zoreil.com>
Remove the unused code of sxgbe_xpcs.
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Suggested-by: David S. Miller <davem@davemloft.net>
Signed-off-by: Jean Sacren <sakiwit@gmail.com>
Cc: Byungho An <bh74.an@samsung.com>
Cc: Girish K S <ks.giri@samsung.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1601191918470.2531@hadrien
Rather than have drivers directly manipulate the mii_bus structure,
provide and API for registering and unregistering devices on an MDIO
bus, and performing lookups.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Add a phydev_name() function, to help with moving some structure members
from phy_device.
To test a checkpatch spelling patch, I ran codespell against
drivers/net/ethernet/.
$ git ls-files drivers/net/ethernet/ | \
while read file ; do \
codespell -w $file; \
done
I removed a false positive in e1000_hw.h
There are a couple bugs with the error handling in this function.
1) If we can't allocate "rx_ring->rx_skbuff" then we should call
dma_free_coherent() but we don't.
2) free_rx_ring() frees "rx_ring->rx_skbuff_dma" and "rx_ring->rx_skbuff"
so calling it in a loop causes a double free.
Also it was a bit confusing how we sometimes freed things before doing
the goto. I've cleaned it up so it does error handling in normal kernel
style.
arch/arm/boot/dts/imx6sx-sdb.dts
net/sched/cls_bpf.c
Two simple sets of overlapping changes.
This patch fixes double kfree() calls at init_rx_ring() because
it causes static checker warning.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Byungho An <bh74.an@samsung.com>
Signed-off-by: Kukjin Kim <kgene@kernel.org>
When the MAC address is provided in the device tree file, the
condition is true and kernel crashes due to NULL dereference.
Signed-off-by: Girish K.S <ks.giri@samsung.com>
The same macros are used for rx as well. So rename it.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
A simplified version of the semantic match that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.function = f;
-t.data = d;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
devm_ioremap_resource checks platform_get_resource() return value.
We can remove the duplicate check here.
Signed-off-by: Varka Bhadram <varkab@cdac.in>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The SXGBE_CORE_L34_ADDCTL_REG define is cut and pasted twice so we can
delete the second instance.
net: get rid of SET_ETHTOOL_OPS
Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone.
This does that.
Mostly done via coccinelle script:
struct ethtool_ops *ops;
struct net_device *dev;
- SET_ETHTOOL_OPS(dev, ops);
+ dev->ethtool_ops = ops;
Compile tested only, but I'd seriously wonder if this broke anything.
Suggested-by: Dave Miller <davem@davemloft.net>
Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de>
Acked-by: Felipe Balbi <balbi@ti.com>
drivers/net/ethernet/altera/altera_sgdma.c
net/netlink/af_netlink.c
net/sched/cls_api.c
net/sched/sch_api.c
The netlink conflict dealt with moving to netlink_capable() and
netlink_ns_capable() in the 'net' tree vs. supporting 'tc' operations
in non-init namespaces. These were simple transformations from
netlink_capable to netlink_ns_capable.
The Altera driver conflict was simply code removal overlapping some
void pointer cast cleanups in net-next.
This patch adds set_rx_int_on_com function for interrupt when
dma is completed.
This patch adds rxqueue enable function according to number of rxqueue
and adds rxqueue disable function for removing.
This patch moves sw reset to probe function because
sw reset is needed early stage before open function.
Signed-off-by: Byungho An <bh74.an@samsung.net>
drivers/net/ethernet/intel/igb/e1000_mac.c
net/core/filter.c
Both conflicts were simple overlapping changes.
This patch adds phy_found error path when there is no phy device
and changes bus_name.
This patch moves cksum_ctl to tx_rd_des23 from cksum_pktlen for correct checksum
offloading and modifies size for Tx/Rx descriptor.
sxgbe_config() denies changing the base address and interrupt, and
ignores all other 'struct ifmap' members, which means that it is useless
as is, so let's remove it.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
Make local functions static, because these are used only in this
file.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Byungho An <bh74.an@samsung.com>
The commit 1edb9ca69e8a ("net: sxgbe: add basic framework for
Samsung 10Gb ethernet driver") added support for Samsung 10Gb
ethernet driver(sxgbe) with a minor issue of including linux/io.h
header twice in sxgbe_dma.c file. Fix the duplicate #include by
deleting the top one so that all the rest good #include headers
would be preserved in the alphabetical order.
Cc: Siva Reddy Kallam <siva.kallam@samsung.com>
Cc: Vipul Pandya <vipul.pandya@samsung.com>
sxgbe_drv_probe: mdio and priv->hw leaks
sxgbe_drv_remove: clk and priv->hw leaks
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Acked-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
The "core_ops" variable isn't referenced outside this file and Sparse
complains about it:
drivers/net/ethernet/samsung/sxgbe/sxgbe_core.c:239:29: warning:
symbol 'core_ops' was not declared. Should it be static?
Bitwise '|' was intended here instead of logical '||'.
Fixes: 1edb9ca69e8a ('net: sxgbe: add basic framework for Samsung 10Gb ethernet driver')
"err" is always zero at this point so we always unregister and free the
mdio_bus before returning success. This seems like left over code and
I have deleted it.
This fixes following:
drivers/net/ethernet/samsung/sxgbe/sxgbe_main.c:1828 sxgbe_hw_init()
error: potential null dereference 'priv->hw'. (kmalloc returns null)
Reported-by: kbuild test robot <fengguang.wu@intel.com>
This fixes followings:
sparse warnings: (new ones prefixed by >>)
>> drivers/net/ethernet/samsung/sxgbe/sxgbe_platform.c:197:5:
sparse: symbol 'sxgbe_platform_freeze' was not declared. Should it be static?
>> drivers/net/ethernet/samsung/sxgbe/sxgbe_platform.c:204:5:
sparse: symbol 'sxgbe_platform_restore' was not declared. Should it be static?
>> drivers/net/ethernet/samsung/sxgbe/sxgbe_platform.c:228:24:
sparse: symbol 'sxgbe_platform_driver' was not declared. Should it be static?
>> drivers/net/ethernet/samsung/sxgbe/sxgbe_main.c:1795:6:
sparse: symbol 'sxgbe_get_ops' was not declared. Should it be static?
This patch adds ethtool related functions.
Signed-off-by: Vipul Pandya <vipul.pandya@samsung.com>
Neatening-by: Joe Perches <joe@perches.com>
This patch adds TX and RX checksum offload support.
Enable TSO during initialization for each DMA channels
Added support for the EEE(Energy Efficient Ethernet) in 10G ethernet driver.
Signed-off-by: Girish K S <ks.giri@samsung.com>
This patch adds support for Samsung 10Gb ethernet driver(sxgbe).
- sxgbe core initialization
- Tx and Rx support
- MDIO support
- ISRs for Tx and Rx
- ifconfig support to driver
Signed-off-by: Siva Reddy Kallam <siva.kallam@samsung.com>
