[ Upstream commit a288f105a03a7e0e629a8da2b31f34ebf0343ee2 ]
fjes_acpi_add() misses a check for platform_device_register_simple().
Add a check to fix it.
Fixes: 658d439b2292 ("fjes: Introduce FUJITSU Extended Socket Network Device driver")
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
[ Upstream commit 85ac30fa2e24f628e9f4f9344460f4015d33fd7d ]
In the highly unlikely event that we fail to allocate either of the
"/txrx" or "/control" workqueues, we should bail cleanly rather than
blindly march on with NULL queue pointer(s) installed in the
'fjes_adapter' instance.
Reported-by: Nicolas Waisman <nico@semmle.com>
Link: https://lore.kernel.org/lkml/CADJ_3a8WFrs5NouXNqS5WYe7rebFP+_A5CheeqAyD_p7DFJJcg@mail.gmail.com/
Signed-off-by: Will Deacon <will@kernel.org>
[ Upstream commit fe8daf5fa715f7214952f06a387e4b7de818c5be ]
This patch fixes netdev->features for Extended Socket network device.
Currently Extended Socket network device's netdev->feature claims
NETIF_F_HW_CSUM, however this is completely wrong. There's no feature
of checksum offloading.
That causes invalid TCP/UDP checksum and packet rejection when IP
forwarding from Extended Socket network device to other network device.
NETIF_F_HW_CSUM should be omitted.
Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
The field "owner" is set by core. Thus delete an extra initialisation.
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
alloc_workqueue replaces deprecated create_workqueue().
The workqueue adapter->txrx_wq has workitem
&adapter->raise_intr_rxdata_task per adapter. Extended Socket Network
Device is shared memory based, so someone's transmission denotes other's
reception. raise_intr_rxdata_task raises interruption of receivers from
the sender in order to notify receivers.
The workqueue adapter->control_wq has workitem
&adapter->interrupt_watch_task per adapter. interrupt_watch_task is used
to prevent delay of interrupts.
Dedicated workqueues have been used in both cases since the workitems
on the workqueues are involved in normal device operation and require
forward progress under memory pressure.
max_active has been set to 0 since there is no need for throttling
the number of active work items.
Since network devices may be used for memory reclaim,
WQ_MEM_RECLAIM has been set to guarantee forward progress.
Signed-off-by: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
commit-bd5a256 introduces a deadlock bug in fjes_change_mtu().
This spin_lock_irqsave() is obviously unnecessary.
This patch eliminates unnecessary spin_lock_irqsave() in
fjes_change_mtu()
Replace all trans_start updates with netif_trans_update helper.
change was done via spatch:
struct net_device *d;
- d->trans_start = jiffies
+ netif_trans_update(d)
Compile tested only.
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-rdma@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: MPT-FusionLinux.pdl@broadcom.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-can@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: b.a.t.m.a.n@lists.open-mesh.org
Cc: linux-bluetooth@vger.kernel.org
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Antonio Quartulli <a@unstable.cc>
a trans_start struct member exists twice:
- in struct net_device (legacy)
- in struct netdev_queue
Instead of open-coding dev->trans_start usage to obtain the current
trans_start value, use dev_trans_start() instead.
This is not exactly the same, as dev_trans_start also considers
the trans_start values of the netdev queues owned by the device
and provides the most recent one.
For legacy devices this doesn't matter as dev_trans_start can cope
with netdev trans_start values of 0 (they are ignored).
This is a prerequisite to eventual removal of dev->trans_start.
This patch introduces spinlock of rx_status for
proper excusive control.
This patch enhances the fjes_change_mtu() method
by introducing new flag named FJES_RX_MTU_CHANGING_DONE
in rx_status. At the same time, default MTU value is
changed into 65510 bytes.
In fjes_raise_intr_rxdata_task(), there's a bug of bitwise
check because of missing "& FJES_RX_POLL_WORK".
This patch fixes this bug.
There are bugs of acounting statistics in fjes_xmit_frame().
Accounting self stats is wrong. accounting stats of other
EPs to be transmitted is right.
This patch optimizes the following timeout value.
- FJES_DEVICE_RESET_TIMEOUT
- FJES_COMMAND_REQ_TIMEOUT
- FJES_COMMAND_REQ_BUFF_TIMEOUT
Use the function resource_size instead of explicit computation.
Problem found using Coccinelle.
Signed-off-by: Vaishali Thakkar <vaishali.thakkar@oracle.com>
minor change, indenting is one tab out.
The vfree() function performs also input parameter validation.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Many drivers initialize uselessly n_priv_flags, n_stats, testinfo_len,
eedump_len & regdump_len fields in their .get_drvinfo() ethtool op.
It's not necessary as these fields is filled in ethtool_get_drvinfo().
v2: removed unused variable
v3: removed another unused variable
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
Dan Carpenter reported off-by-one error of fjes at
http://www.mail-archive.com/netdev@vger.kernel.org/msg77520.html
Actually this is a bug.
ep_shm_info[epidx].{es_status, zone} should be update
inside for loop.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
This patch adds implementation for ethtool support.
This patch adds implementation of handling IRQ
of other receiver's receive cancellation request.
This patch adds epstop_task.
This task is used to process other receiver's
This patch adds update_zone_task.
Zoning information can be changed by user.
This task is used to monitor if zoning information is
changed or not.
This patch adds unshare_watch_task.
Shared buffer's status can be changed into unshared.
This task is used to monitor shared buffer's status.
This patch adds force_close_task.
This task is used to close network device forcibly.
This patch adds interrupt_watch_task.
This task is used to prevent delay of interrupts.
This patch adds net_device_ops.ndo_vlan_rx_add_vid and
net_device_ops.ndo_vlan_rx_kill_vid callback.
This patch adds net_device_ops.ndo_tx_timeout callback.
This patch adds net_device_ops.ndo_change_mtu.
This patch adds net_device_ops.ndo_get_stats64 callback.
This patch adds NAPI polling function and receive related work.
This patch adds tx_stall_task.
When receiver's buffer is full, sender stops
its tx queue. This task is used to monitor
receiver's status and when receiver's buffer
is avairable, it resumes tx queue.
This patch add raise_intr_rxdata_task.
Extended Socket Network Device is shared memory
reception. In order to notify receivers, sender
has to raise interruption of receivers.
raise_intr_rxdata_task does this work.
This patch adds net_device_ops.ndo_start_xmit callback,
which is called when sending packets.
This patch adds net_device_ops.ndo_open and .ndo_stop
callback. These function is called when network device
activation and deactivation.
This patch adds buffer address regist/unregistration routine.
This function is mainly invoked when network device's
activation (open) and deactivation (close)
in order to retist/unregist shared buffer address.
This patch adds ES information acquisition routine.
ES information can be retrieved issuing information
request command. ES information includes which
receiver is same zone.
This patch implements platform_driver's .probe and .remove
routine, and also adds board specific private data structure.
This driver registers net_device at platform_driver's .probe
routine and unregisters net_device at its .remove routine.
This patch adds hardware cleanup routine to be
invoked at driver's .remove routine.
This patch adds hardware initialization routine to be
invoked at driver's .probe routine.
This patch adds the basic code of FUJITSU Extended Socket
Network Device driver.
When "PNP0C02" is found in ACPI DSDT, it evaluates "_STR"
to check if "PNP0C02" is for Extended Socket device driver
and retrieves ACPI resource information. Then creates
platform_device.
