path: root/drivers/net/forcedeth.c
2011-07-27forcedeth: fix vlansJiri Pirko
For some reason, when rxaccel is disabled, NV_RX3_VLAN_TAG_PRESENT is still set and some pseudorandom vids appear. So check for NETIF_F_HW_VLAN_RX as well. Also set correctly hw_features and set vlan mode on probe. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-21forcedeth: do vlan cleanupJiri Pirko
- unify vlan and nonvlan rx path - kill np->vlangrp and nv_vlan_rx_register - allow to turn on/off rx vlan accel via ethtool (set_features) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: Use full 32 bit speed range in ethtool's set_settingsDavid Decotigny
This makes sure the ethtool's set_settings() callback of network drivers don't ignore the 16 most significant bits when ethtool calls their set_settings(). All drivers compiled with make allyesconfig on x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-19net: forcedeth: fix compile warning of not used nv_set_tso functionShan Wei
Fix the below compile warning: drivers/net/forcedeth.c:4266: warning: ‘nv_set_tso’ defined but not used commit 569e146 converts forcedeth driver to use hw_features. So, implement function of .set_tso is abandoned. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-15net: forcedeth: convert to hw_featuresMichał Mirosław
This also fixes a race around np->txrxctl_bits while changing RXCSUM offload. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14drivers/net: fix build warnings with CONFIG_PM_SLEEP disabledMichel Lespinasse
This fixes a couple of build warnings when CONFIG_PM is enabled but CONFIG_PM_SLEEP is disabled. Applies on top of v2.6.38-rc7 - I know it's late, but it would be great if v2.6.38 could compile without warnings! Signed-off-by: Michel Lespinasse <walken@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-17drivers/net: Call netif_carrier_off at the end of the probeIvan Vecera
Without calling of netif_carrier_off at the end of the probe the operstate is unknown when the device is initially opened. By default the carrier is on so when the device is opened and netif_carrier_on is called the link watch event is not fired and operstate remains zero (unknown). This patch fixes this behavior in forcedeth and r8169. Signed-off-by: Ivan Vecera <ivecera@redhat.com> Acked-by: Francois Romieu <romieu@fr.zoreil.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-09forcedeth: Do not use legacy PCI power managementRafael J. Wysocki
The forcedeth driver uses the legacy PCI power management, so it has to do PCI-specific things in its ->suspend() and ->resume() callbacks and some of them are not done correctly. Convert forcedeth to the new PCI power management framework and make it let the PCI subsystem take care of all the PCI-specific aspects of device handling during system power transitions. Tested with nVidia Corporation MCP55 Ethernet (rev a2). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Use netdev_dbg for printk(KERN_DEBUGJoe Perches
Use the normal debugging functions. Print mac address when using random_ether_addr. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Remove netdev_dbg usesJoe Perches
These were probably just for initial driver debugging and have not been enabled in builds in git history. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Convert dev_printk(<level> to dev_<level>(Joe Perches
Use vsprintf extension %pM for a mac address in one instance. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Separate vendor specific initializations into functionsJoe Perches
Neaten the phy_init function by adding and calling vendor specific functions. object size is reduced by ~1kb: $ size drivers/net/forcedeth.o.* text data bss dec hex filename 83475 1848 19304 104627 198b3 drivers/net/forcedeth.o.new 84459 1848 19544 105851 19d7b drivers/net/forcedeth.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Add function init_realtek_8211bJoe Perches
Deduplicate the code use for the init/reset of this device. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Convert pr_<level> to netdev_<level>Joe Perches
Use netdev_<level> when a struct net_device * is available. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Use pr_fmt and pr_<level>Joe Perches
Convert printks to pr_<level>. Remove "forcedeth: " from some calls as it's now added by pr_fmt. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Convert remaining dprintk to netdev_dbgJoe Perches
The remaining dprintk uses are emitted as KERN_INFO. Change these dprintk uses to netdev_dbg. Remove the now unused dprintk macros. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Use print_hex_dumpJoe Perches
Use the standard code to emit hex dumps. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: convert dprintk(KERN_DEBUG to netdev_dbgJoe Perches
Use the more standard macro to preface netdev->name. Fix casting on resource use. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-29forcedeth: Change reg_delay arguments and useJoe Perches
Move the printk out of reg_delay and make the callers emit a message on error. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28forcedeth: use usleep_range not msleep for small sleepsSzymon Janc
Signed-off-by: Szymon Janc <szymon@janc.net.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28forcedeth: do not use assignment in if conditionsSzymon Janc
2010-11-28forcedeth: include <linux/io.h> and <linux/uaccess.h> instead of <asm/io.h> ↵Szymon Janc
and <asm/uaccess.h> as suggested by checkpatch Signed-off-by: Szymon Janc <szymon@janc.net.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28forcedeth: remove unnecessary checks before kfreeSzymon Janc
2010-11-28forcedeth: fix multiple code style issuesSzymon Janc
2010-10-21vlan: Don't check for vlan group before vlan_tx_tag_present.Jesse Gross
Many (but not all) drivers check to see whether there is a vlan group configured before using a tag stored in the skb. There's not much point in this check since it just throws away data that should only be present in the expected circumstances. However, it will soon be legal and expected to get a vlan tag when no vlan group is configured, so remove this check from all drivers to avoid dropping the tags. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25drivers/net: Remove address use from assignments of function pointersJoe Perches
"foo = &function" is more commonly written "foo = function" Done with coccinelle script: // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> drivers/net/tehuti.c used a function and struct with the same name, the function was renamed. Compile tested x86 only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-25forcedeth: Fix different hardware statistics versions.Mike Ditto
The macros for the values of the bit field describing the four different versions of statistics supported by different hardware variants were being misused. Where the code was trying to test if the hardware implements V3, it was actually testing whether it implements any of V1, V2, or V3, causing the driver to report statistics that don't really exist in the hardware, with bogus values. Signed-off-by: Mike Ditto <mditto@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-05forcedeth: correct valid flagJulia Lawall
Elsewhere in the "optimized" functions, the "2" constants are used. NV_TX_VALID and NV_TX2_VALID have the same value. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-10net: trans_start cleanupsEric Dumazet
Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-05forcedeth: Account for consumed budget in napi pollTom Herbert
Repeated calls to nv_rx_process in napi poll routine do not take portion of budget that has been consumed in previous calls. Fix by subtracting the number of packets processed. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-03forcedeth: Kill NAPI config options.David S. Miller
All distributions enable it, therefore no significant body of users are even testing the driver with it disabled. And making NAPI configurable is heavily discouraged anyways. I left the MSI-X interrupt enabling thing in an "#if 0" block so hopefully someone can debug that and it can get re-enabled. Probably it was just one of the NVIDIA chipset MSI erratas that we work handle these days in the PCI quirks (see drivers/pci/quirks.c and stuff like nvenet_msi_disable()). Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-03forcedeth: GRO supportTom Herbert
Add GRO support to forcedeth. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-30forcedeth: Stay in NAPI as long as there's workstephen hemminger
The following does the same thing without the extra overhead of testing all the registers. It also handles the out of memory case. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Tested-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14drivers: net: use skb_headlen()Eric Dumazet
replaces (skb->len - skb->data_len) occurrences by skb_headlen(skb) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/pcmcia/smc91c92_cs.c drivers/net/virtio_net.c
2010-04-13forcedeth: fix tx limit2 flag checkAyaz Abdulla
This is a fix for bug 572201 @ bugs.debian.org This patch fixes the TX_LIMIT feature flag. The previous logic check for TX_LIMIT2 also took into account a device that only had TX_LIMIT set. Reported-by: Stephen Mulcahu <stephen.mulcahy@deri.org> Reported-by: Ben Huchings <ben@decadent.org.uk> Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part4Jiri Pirko
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits) cxgb3: fix premature page unmap ibm_newemac: Fix EMACx_TRTR[TRT] bit shifts vlan: Fix register_vlan_dev() error path gro: Fix illegal merging of trailer trash sungem: Fix Serdes detection. net: fix mdio section mismatch warning ppp: fix BUG on non-linear SKB (multilink receive) ixgbe: Fixing EEH handler to handle more than one error net: Fix the rollback test in dev_change_name() Revert "isdn: isdn_ppp: Use SKB list facilities instead of home-grown implementation." TI Davinci EMAC : Fix Console Hang when bringing the interface down smsc911x: Fix Console Hang when bringing the interface down. mISDN: fix error return in HFCmulti_init() forcedeth: mac address fix r6040: fix version printing Bluetooth: Fix regression with L2CAP configuration in Basic Mode Bluetooth: Select Basic Mode as default for SOCK_SEQPACKET Bluetooth: Set general bonding security for ACL by default r8169: Fix receive buffer length when MTU is between 1515 and 1536 can: add the missing netlink get_xstats_size callback ...
2009-11-15forcedeth: mac address fixStanislav O. Bezzubtsev
Use the existing random_ether_addr() to generate random MAC instead of doing it by-hand. Signed-off-by: Stanislav O. Bezzubtsev <stas@lvk.cs.msu.su> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
