There are more memory leaks in the !PPC_CPM_NEW_BINDING case, but that code
will disappear soon along with arch/ppc.
Reported by Daniel Marjamki <danielm77@spray.se> at
http://bugzilla.kernel.org/show_bug.cgi?id=10591
Having the id field be an int was making more complex bus topologies
excessively difficult. For now, just convert it to a string, and
change all instances of "bus->id = val" to
snprintf(id, MII_BUS_ID_LEN, "%x", val).
Signed-off-by: Andy Fleming <afleming@freescale.com>
Mostly a bunch of __iomem annotations.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
The existing OF glue code was crufty and broken. Rather than fix it, it
will be removed, and the ethernet driver now talks to the device tree
directly.
The old, non-CONFIG_PPC_CPM_NEW_BINDING code can go away once CPM
platforms are dropped from arch/ppc (which will hopefully be soon), and
existing arch/powerpc boards that I wasn't able to test on for this
patchset get converted (which should be even sooner).
I noticed that many source files include <linux/pci.h> while they do
not appear to need it. Here is an attempt to clean it all up.
In order to find all possibly affected files, I searched for all
files including <linux/pci.h> but without any other occurence of "pci"
or "PCI". I removed the include statement from all of these, then I
compiled an allmodconfig kernel on both i386 and x86_64 and fixed the
false positives manually.
My tests covered 66% of the affected files, so there could be false
positives remaining. Untested files are:
arch/alpha/kernel/err_common.c
arch/alpha/kernel/err_ev6.c
arch/alpha/kernel/err_ev7.c
arch/ia64/sn/kernel/huberror.c
arch/ia64/sn/kernel/xpnet.c
arch/m68knommu/kernel/dma.c
arch/mips/lib/iomap.c
arch/powerpc/platforms/pseries/ras.c
arch/ppc/8260_io/enet.c
arch/ppc/8260_io/fcc_enet.c
arch/ppc/8xx_io/enet.c
arch/ppc/syslib/ppc4xx_sgdma.c
arch/sh64/mach-cayman/iomap.c
arch/xtensa/kernel/xtensa_ksyms.c
arch/xtensa/platform-iss/setup.c
drivers/i2c/busses/i2c-at91.c
drivers/i2c/busses/i2c-mpc.c
drivers/media/video/saa711x.c
drivers/misc/hdpuftrs/hdpu_cpustate.c
drivers/misc/hdpuftrs/hdpu_nexus.c
drivers/net/au1000_eth.c
drivers/net/fec_8xx/fec_main.c
drivers/net/fec_8xx/fec_mii.c
drivers/net/fs_enet/fs_enet-main.c
drivers/net/fs_enet/mac-fcc.c
drivers/net/fs_enet/mac-fec.c
drivers/net/fs_enet/mac-scc.c
drivers/net/fs_enet/mii-bitbang.c
drivers/net/fs_enet/mii-fec.c
drivers/net/ibm_emac/ibm_emac_core.c
drivers/net/lasi_82596.c
drivers/parisc/hppb.c
drivers/sbus/sbus.c
drivers/video/g364fb.c
drivers/video/platinumfb.c
drivers/video/stifb.c
drivers/video/valkyriefb.c
include/asm-arm/arch-ixp4xx/dma.h
sound/oss/au1550_ac97.c
I would welcome test reports for these files. I am fine with removing
the untested files from the patch if the general opinion is that these
changes aren't safe. The tested part would still be nice to have.
Note that this patch depends on another header fixup patch I submitted
to LKML yesterday:
[PATCH] scatterlist.h needs types.h
http://lkml.org/lkml/2007/3/01/141
Cc: Badari Pulavarty <pbadari@us.ibm.com>
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
kbuild explicitly includes this at build time.
Signed-off-by: Dave Jones <davej@redhat.com>
This patch should update the fs_enet infrastructure to utilize Phy Abstraction
Layer subsystem. Along with the above, there are apparent bugfixes, overhaul
and improvements.
Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com>
