Pull networking updates from David Miller:
"Highlights:
1) Support SPI based w5100 devices, from Akinobu Mita.
2) Partial Segmentation Offload, from Alexander Duyck.
3) Add GMAC4 support to stmmac driver, from Alexandre TORGUE.
4) Allow cls_flower stats offload, from Amir Vadai.
5) Implement bpf blinding, from Daniel Borkmann.
6) Optimize _ASYNC_ bit twiddling on sockets, unless the socket is
actually using FASYNC these atomics are superfluous. From Eric
Dumazet.
7) Run TCP more preemptibly, also from Eric Dumazet.
8) Support LED blinking, EEPROM dumps, and rxvlan offloading in mlx5e
driver, from Gal Pressman.
9) Allow creating ppp devices via rtnetlink, from Guillaume Nault.
10) Improve BPF usage documentation, from Jesper Dangaard Brouer.
11) Support tunneling offloads in qed, from Manish Chopra.
12) aRFS offloading in mlx5e, from Maor Gottlieb.
13) Add RFS and RPS support to SCTP protocol, from Marcelo Ricardo
Leitner.
14) Add MSG_EOR support to TCP, this allows controlling packet
coalescing on application record boundaries for more accurate
socket timestamp sampling. From Martin KaFai Lau.
15) Fix alignment of 64-bit netlink attributes across the board, from
Nicolas Dichtel.
16) Per-vlan stats in bridging, from Nikolay Aleksandrov.
17) Several conversions of drivers to ethtool ksettings, from Philippe
Reynes.
18) Checksum neutral ILA in ipv6, from Tom Herbert.
19) Factorize all of the various marvell dsa drivers into one, from
Vivien Didelot
20) Add VF support to qed driver, from Yuval Mintz"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1649 commits)
Revert "phy dp83867: Fix compilation with CONFIG_OF_MDIO=m"
Revert "phy dp83867: Make rgmii parameters optional"
r8169: default to 64-bit DMA on recent PCIe chips
bpf: arm64: remove callee-save registers use for tmp registers
asix: Fix offset calculation in asix_rx_fixup() causing slow transmissions
switchdev: pass pointer to fib_info instead of copy
net_sched: close another race condition in tcf_mirred_release()
tipc: fix nametable publication field in nl compat
drivers: net: Don't print unpopulated net_device name
qed: add support for dcbx.
ravb: Add missing free_irq() calls to ravb_close()
qed: Remove a stray tab
net: ethernet: fec-mpc52xx: use phy_ethtool_{get|set}_link_ksettings
net: ethernet: fec-mpc52xx: use phydev from struct net_device
bpf, doc: fix typo on bpf_asm descriptions
stmmac: hardware TX COE doesn't work when force_thresh_dma_mode is set
net: ethernet: fs-enet: use phy_ethtool_{get|set}_link_ksettings
net: ethernet: fs-enet: use phydev from struct net_device
These drivers already call netif_stop_queue() so we should not be called
unless tx space is available. Just free the skb and return TX_OK.
Followup patch will remove NETDEV_TX_LOCKED from the kernel.
Cc: linux-parisc@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: Thomas Sailer <t.sailer@alumni.ethz.ch>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Link: http://lkml.kernel.org/r/1459801503-15600-7-git-send-email-bp@alien8.de
Now that there is no paravirt TSC, the "native" is
inappropriate. The function does RDTSC, so give it the obvious
Suggested-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Huang Rui <ray.huang@amd.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Len Brown <lenb@kernel.org>
Cc: kvm ML <kvm@vger.kernel.org>
Link: http://lkml.kernel.org/r/fd43e16281991f096c1e4d21574d9e1402c62d39.1434501121.git.luto@kernel.org
[ Ported it to v4.2-rc1. ]
native_read_tsc()
This is only used if BAYCOM_DEBUG is defined.
Acked-by: Thomas Sailer <t.sailer@alumni.ethz.ch
Acked-by: Walter Harms <wharms@bfs.de>
Link: http://lkml.kernel.org/r/1195ce0c7f34169ff3006341b77806184a46b9bf.1434501121.git.luto@kernel.org
Before the ax25 stack calls dev_queue_xmit it always calls
ax25_type_trans which sets skb->protocol to ETH_P_AX25.
Which means that by looking at the protocol type it is possible to
detect IP packets that have not been munged by the ax25 stack in
ndo_start_xmit and call a function to munge them.
Rename ax25_neigh_xmit to ax25_ip_xmit and tweak the return type and
value to be appropriate for an ndo_start_xmit function.
Update all of the ax25 devices to test the protocol type for ETH_P_IP
and return ax25_ip_xmit as the first thing they do. This preserves
the existing semantics of IP packet processing, but the timing will be
a little different as the IP packets now pass through the qdisc layer
before reaching the ax25 ip packet processing.
Remove the now unnecessary ax25 neighbour table operations.
AX25 already has it's own private arp cache operations to isolate
it's abuse of dev_rebuild_header to transmit packets. Add a function
ax25_neigh_construct that will allow all of the ax25 devices to
force using these operations, so that the generic arp code does
not need to.
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Use preferable function name which implies using a pseudo-random number
generator.
[akpm@linux-foundation.org: convert team_mode_random.c]
Acked-by: Thomas Sailer <t.sailer@alumni.ethz.ch>
Acked-by: Bing Zhao <bzhao@marvell.com> [mwifiex]
Cc: Michael Chan <mchan@broadcom.com>
Cc: Jean-Paul Roubelat <jpr@f6fbb.org>
Cc: Bing Zhao <bzhao@marvell.com>
Cc: Brett Rudley <brudley@broadcom.com>
Cc: Arend van Spriel <arend@broadcom.com>
Cc: "Franky (Zhenhui) Lin" <frankyl@broadcom.com>
Cc: Hante Meuleman <meuleman@broadcom.com>
Fixed 'warning: return from incompatible pointer type' related
to module parameters.
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
The kernel already prints its build timestamp during boot, no need to
repeat it in random drivers and produce different object files each
time.
Cc: netdev@vger.kernel.org
drivers/net/sfc/sfe4001.c
drivers/net/wireless/libertas/cmd.c
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/rtl8187se/Kconfig
drivers/staging/rtl8192e/Kconfig
Signed-off-by: Thomas Sailer <t.sailer@alumni.ethz.ch>
The negation makes it a bool before the comparison and hence it
will never evaluate to true.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
arch/microblaze/include/asm/socket.h
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up
handling of log-levels and newlines") changed printk semantics. printk
lines with multiple KERN_<level> prefixes are no longer emitted as
before the patch.
<level> is now included in the output on each additional use.
Remove all uses of multiple KERN_<level>s in formats.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively.
0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases
where its in direct proximity to one of the other values.
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Drivers need not do it any more.
Some cases had to be skipped over because the drivers
were making use of the ->last_rx value themselves.
If the RTNL is held when we invoke flush_scheduled_work() we could
deadlock. One such case is linkwatch, it is a work struct which tries
to grab the RTNL semaphore.
The most common case are net driver ->stop() methods. The
simplest conversion is to instead use cancel_{delayed_}work_sync()
explicitly on the various work struct the driver uses.
This is an OK transformation because these work structs are doing
things like resetting the chip, restarting link negotiation, and so
forth. And if we're bringing down the device, we're about to turn the
chip off and reset it anways. So if we cancel a pending work event,
that's fine here.
Some drivers were working around this deadlock by using a msleep()
polling loop of some sort, and those cases are converted to instead
use cancel_{delayed_}work_sync() as well.
None of the drivers with a struct pardevice's ->irq_func() hook ever
used the 'irq' argument passed to it, so remove it.
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Rather than using a tri-state integer for the wait flag in
call_usermodehelper_exec, define a proper enum, and use that. I've
preserved the integer values so that any callers I've missed should
still work OK.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Andi Kleen <ak@suse.de>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Fix foobar in 15b1c0e822f578306332d4f4c449250db5c5dceb and
e8cc49bb0fdb9e18a99e6780073d1400ba2b0d1f patch series.
Only the callsign but not the SSID part of an AX.25 address is ASCII
based but Linux by initializes the SSID which should be just a 4-bit
number from ASCII anyway.
Fix that and convert the code to use a shared constant for both default
addresses. While at it, use the same style for null_ax25_address also.
Fix up for make allyesconfig.
Signed-Off-By: David Howells <dhowells@redhat.com>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
They deal with wrapping correctly and are nicer to read. Also make
jiffies-holding variables unsigned long.
Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br>
Cc: Jeff Garzik <jgarzik@pobox.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
Rename ax25_encapsulate to ax25_hard_header which these days more
accurately describes what the function is supposed to do.
Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org>
Misc related cleanups in hamradio drivers:
o Use symbolic constants instead of magic numbers
o Don't try to handle the case where AX.25 isn't configured - the kernel
configuration doesn't permit that.
o Remove useless headers
Use of time_before() macro, defined at linux/jiffies.h, which deal with
Signed-off-by: Domen Puncer <domen@coderock.org>
baycom_epp.c | 3 ++-
baycom_par.c | 3 ++-
baycom_ser_fdx.c | 3 ++-
baycom_ser_hdx.c | 3 ++-
mkiss.c | 3 ++-
5 files changed, 10 insertions(+), 5 deletions(-)
The times when tricky goto's produced better codes are long gone.
This patch should express the same in a better way.
(Also fixes the final gcc-4.0 x86 compile error)
Replacing the open coded equivalents and making ax25 look more like
a linux network protocol, i.e. more similar to inet.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
infrastructure for it.
Let it rip!
