Replace all trans_start updates with netif_trans_update helper.
change was done via spatch:
struct net_device *d;
- d->trans_start = jiffies
+ netif_trans_update(d)
Compile tested only.
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-rdma@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: MPT-FusionLinux.pdl@broadcom.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-can@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: b.a.t.m.a.n@lists.open-mesh.org
Cc: linux-bluetooth@vger.kernel.org
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Antonio Quartulli <a@unstable.cc>
Before the ax25 stack calls dev_queue_xmit it always calls
ax25_type_trans which sets skb->protocol to ETH_P_AX25.
Which means that by looking at the protocol type it is possible to
detect IP packets that have not been munged by the ax25 stack in
ndo_start_xmit and call a function to munge them.
Rename ax25_neigh_xmit to ax25_ip_xmit and tweak the return type and
value to be appropriate for an ndo_start_xmit function.
Update all of the ax25 devices to test the protocol type for ETH_P_IP
and return ax25_ip_xmit as the first thing they do. This preserves
the existing semantics of IP packet processing, but the timing will be
a little different as the IP packets now pass through the qdisc layer
before reaching the ax25 ip packet processing.
Remove the now unnecessary ax25 neighbour table operations.
AX25 already has it's own private arp cache operations to isolate
it's abuse of dev_rebuild_header to transmit packets. Add a function
ax25_neigh_construct that will allow all of the ax25 devices to
force using these operations, so that the generic arp code does
not need to.
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert
all users to pass NET_NAME_UNKNOWN.
Coccinelle patch:
expression sizeof_priv, name, setup, txqs, rxqs, count;
-alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs)
+alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs)
-alloc_netdev_mq(sizeof_priv, name, setup, count)
+alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count)
-alloc_netdev(sizeof_priv, name, setup)
+alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup)
v9: move comments here from the wrong commit
Signed-off-by: Tom Gundersen <teg@jklm.no>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
This patch proposes to remove the use of the IRQF_DISABLED flag
It's a NOOP since 2.6.35 and it will be removed one day.
Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com>
proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Right now, some modules such as bonding use proc_create
to create proc entries under /proc/net/, and other modules
such as ipv4 use proc_net_fops_create.
It looks a little chaos.this patch changes all of
proc_net_fops_create to proc_create. we can remove
proc_net_fops_create after this patch.
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
Indent the branch of an if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
cocci.print_main("branch",p1)
cocci.print_secs("after",p2)
// </smpl>
This patch removes from drivers/net/ all the unnecessary
return; statements that precede the last closing brace of
void functions.
It does not remove the returns that are immediately
preceded by a label as gcc doesn't like that.
It also does not remove null void functions with return.
Done via:
$ grep -rP --include=*.[ch] -l "return;\n}" net/ | \
xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }'
with some cleanups by hand.
Compile tested x86 allmodconfig only.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
Impact: Use 'static const char[]' instead of 'static char[]' and while
being at it fix an issue in 'mkiss_init_driver', where in case of an
error the status code was not passed to printk.
Fix this warnings:
drivers/net/hamradio/6pack.c: In function 'sixpack_init_driver':
drivers/net/hamradio/6pack.c:802: warning: format not a string literal and no format arguments
drivers/net/hamradio/bpqether.c: In function 'bpq_init_driver':
drivers/net/hamradio/bpqether.c:609: warning: format not a string literal and no format arguments
drivers/net/hamradio/mkiss.c: In function 'mkiss_init_driver':
drivers/net/hamradio/mkiss.c:988: warning: format not a string literal and no format arguments
drivers/net/hamradio/mkiss.c:991: warning: format not a string literal and no format arguments
drivers/net/hamradio/scc.c: In function 'scc_init_driver':
drivers/net/hamradio/scc.c:2109: warning: format not a string literal and no format arguments
drivers/net/hamradio/yam.c: In function 'yam_init_driver':
drivers/net/hamradio/yam.c:1094: warning: format not a string literal and no format arguments
Signed-off-by: Hannes Eder <hannes@hanneseder.net>
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Since all the memory, which pointed by netdev->priv, are allocated in
advance instead of by alloc_netdev(). Use netdev->ml_priv to point to
those memory.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
The generic packet receive code takes care of setting
netdev->last_rx when necessary, for the sake of the
bonding ARP monitor.
Drivers need not do it any more.
Some cases had to be skipped over because the drivers
were making use of the ->last_rx value themselves.
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This patch makes /proc/net per network namespace. It modifies the global
variables proc_net and proc_net_stat to be per network namespace.
The proc_net file helpers are modified to take a network namespace argument,
and all of their callers are fixed to pass &init_net for that argument.
This ensures that all of the /proc/net files are only visible and
usable in the initial network namespace until the code behind them
has been updated to be handle multiple network namespaces.
Making /proc/net per namespace is necessary as at least some files
in /proc/net depend upon the set of network devices which is per
network namespace, and even more files in /proc/net have contents
that are relevant to a single network namespace.
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Only the callsign but not the SSID part of an AX.25 address is ASCII
based but Linux by initializes the SSID which should be just a 4-bit
number from ASCII anyway.
Fix that and convert the code to use a shared constant for both default
addresses. While at it, use the same style for null_ax25_address also.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Cc: Jeff Garzik <jeff@garzik.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org>
Rename ax25_encapsulate to ax25_hard_header which these days more
accurately describes what the function is supposed to do.
This is part of the grand scheme to eliminate the qlen
member of skb_queue_head, and subsequently remove the
'list' member of sk_buff.
Most users of skb_queue_len() want to know if the queue is
empty or not, and that's trivially done with skb_queue_empty()
which doesn't use the skb_queue_head->qlen member and instead
uses the queue list emptyness as the test.
Replacing the open coded equivalents and making ax25 look more like
a linux network protocol, i.e. more similar to inet.
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
infrastructure for it.
Let it rip!
