path: root/drivers/net/hamradio
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-03hamradio: avoid null deref v3Dan Carpenter
This should address the problems in version 1 (lazy) and version 2 (ugly). Bump the stats on orig_dev not on the newly assigned NULL dev variable. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-03drivers/net: Move && and || to end of previous lineJoe Perches
Only files where David Miller is the primary git-signer. wireless, wimax, ixgbe, etc are not modified. Compile tested x86 allyesconfig only Not all files compiled (not x86 compatible) Added a few > 80 column lines, which I ignored. Existing checkpatch complaints ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-15hamradio/mkiss: fix typo in compat_ioctlArnd Bergmann
My last commit introduced an typo causing the compat_ioctl function to do nothing useful. The obvious way for an ioctl function to work is to look at the command, not the argument first. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06net, compat_ioctl: handle socket ioctl abuses in tty driversArnd Bergmann
Slip and a few other drivers use the same ioctl numbers on tty devices that are normally meant for sockets. This causes problems with our compat_ioctl handling that tries to convert the data structures in a different format. Fortunately, these five drivers all use 32 bit compatible data structures in the ioctl numbers, so we can just add a trivial compat_ioctl conversion function to each of them. SIOCSIFENCAP and SIOCGIFENCAP do not need to live in fs/compat_ioctl.c after this any more, and they are not used on any sockets. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14hamradio: Fix bit test correctly.Thomas Sailer
Signed-off-by: Thomas Sailer <t.sailer@alumni.ethz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net/hamradio: fix test in receive()roel kluin
The negation makes it a bool before the comparison and hence it will never evaluate to true. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-01NET: mkiss: Fix typoRalf Baechle
This typo was introduced by 5793f4be23f0171b4999ca68a39a9157b44139f3 on October 14, 2005 ... Reported-by: Matti Aarnio <matti.aarnio@zmailer.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02NET: Fix possible corruption in bpqether driverRalf Baechle
The bpq ether driver is modifying the data art of the skb by first dropping the KISS byte (a command byte for the radio) then prepending the length + 4 of the remaining AX.25 packet to be transmitted as a little endian 16-bit number. If the high byte of the length has a different value than the dropped KISS byte users of clones of the skb may observe this as corruption. This was observed with by running listen(8) -a which uses a packet socket which clones transmit packets. The corruption will then typically be displayed for as a KISS "TX Delay" command for AX.25 packets in the range of 252..508 bytes or any other KISS command for yet larger packets. Fixed by using skb_cow to create a private copy should the skb be cloned. Using skb_cow also allows us to cleanup the old logic to ensure sufficient headroom in the skb. While at it, replace a return of 0 from bpq_xmit with the proper constant NETDEV_TX_OK which is now being used everywhere else in this function. Affected: all 2.2, 2.4 and 2.6 kernels. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reported-by: Jann Traschewski <jann@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01convert hamradio drivers to netdev_txreturnt_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-07-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwmc3200wifi/netdev.c net/wireless/scan.c
2009-07-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits) sky2: Avoid races in sky2_down drivers/net/mlx4: Adjust constant drivers/net: Move a dereference below a NULL test drivers/net: Move a dereference below a NULL test connector: maintainer/mail update. USB host CDC Phonet network interface driver macsonic, jazzsonic: fix oops on module unload macsonic: move probe function to .devinit.text can: switch carrier on if device was stopped while in bus-off state can: restart device even if dev_alloc_skb() fails can: sja1000: remove duplicated includes New device ID for sc92031 [1088:2031] 3c589_cs: re-initialize the multicast in the tc589_reset Fix error return for setsockopt(SO_TIMESTAMPING) netxen: fix thermal check and shutdown netxen: fix deadlock on dev close netxen: fix context deletion sequence net: Micrel KS8851 SPI network driver tcp: Use correct peer adr when copying MD5 keys tcp: Fix MD5 signature checking on IPv4 mapped sockets ...
2009-07-17Update Andreas Koensgen's email addressRalf Baechle
The kernel has used a stale email address of Andreas for a few years. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-14Revert "NET: Fix locking issues in PPP, 6pack, mkiss and strip line ↵David S. Miller
disciplines." This reverts commit adeab1afb7de89555c69aab5ca21300c14af6369. As Alan Cox explained, the TTY layer changes that went recently to get rid of the tty->low_latency stuff fixes this already, and even for -stable it's the ->low_latency changes that should go in to fix this, rather than this patch. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12NET: Fix locking issues in PPP, 6pack, mkiss and strip line disciplines.Ralf Baechle
Guido Trentalancia reports: I am trying to use the kiss driver in the Linux kernel that is being shipped with Fedora 10 but unfortunately I get the following oops: mkiss: AX.25 Multikiss, Hans Albas PE1AYX mkiss: ax0: crc mode is auto. ADDRCONF(NETDEV_CHANGE): ax0: link becomes ready ------------[ cut here ]------------ WARNING: at kernel/softirq.c:77 __local_bh_disable+0x2f/0x83() (Not tainted) [...] unloaded: microcode] Pid: 0, comm: swapper Not tainted 2.6.27.25-170.2.72.fc10.i686 #1 [<c042ddfb>] warn_on_slowpath+0x65/0x8b [<c06ab62b>] ? _spin_unlock_irqrestore+0x22/0x38 [<c04228b4>] ? __enqueue_entity+0xe3/0xeb [<c042431e>] ? enqueue_entity+0x203/0x20b [<c0424361>] ? enqueue_task_fair+0x3b/0x3f [<c041f88c>] ? resched_task+0x3a/0x6e [<c06ab62b>] ? _spin_unlock_irqrestore+0x22/0x38 [<c06ab4e2>] ? _spin_lock_bh+0xb/0x16 [<c043255b>] __local_bh_disable+0x2f/0x83 [<c04325ba>] local_bh_disable+0xb/0xd [<c06ab4e2>] _spin_lock_bh+0xb/0x16 [<f8b6f600>] mkiss_receive_buf+0x2fb/0x3a6 [mkiss] [<c0572a30>] flush_to_ldisc+0xf7/0x198 [<c0572b12>] tty_flip_buffer_push+0x41/0x51 [<f89477f2>] ftdi_process_read+0x375/0x4ad [ftdi_sio] [<f8947a5a>] ftdi_read_bulk_callback+0x130/0x138 [ftdi_sio] [<c05d4bec>] usb_hcd_giveback_urb+0x63/0x93 [<c05ea290>] uhci_giveback_urb+0xe5/0x15f [<c05eaabf>] uhci_scan_schedule+0x52e/0x767 [<c05f6288>] ? psmouse_handle_byte+0xc/0xe5 [<c054df78>] ? acpi_ev_gpe_detect+0xd6/0xe1 [<c05ec5b0>] uhci_irq+0x110/0x125 [<c05d4834>] usb_hcd_irq+0x40/0xa3 [<c0465313>] handle_IRQ_event+0x2f/0x64 [<c046642b>] handle_level_irq+0x74/0xbe [<c04663b7>] ? handle_level_irq+0x0/0xbe [<c0406e6e>] do_IRQ+0xc7/0xfe [<c0405668>] common_interrupt+0x28/0x30 [<c056821a>] ? acpi_idle_enter_simple+0x162/0x19d [<c0617f52>] cpuidle_idle_call+0x60/0x92 [<c0403c61>] cpu_idle+0x101/0x134 [<c069b1ba>] rest_init+0x4e/0x50 ======================= ---[ end trace b7cc8076093467ad ]--- ------------[ cut here ]------------ WARNING: at kernel/softirq.c:136 _local_bh_enable_ip+0x3d/0xc4() [...] Pid: 0, comm: swapper Tainted: G W 2.6.27.25-170.2.72.fc10.i686 [<c042ddfb>] warn_on_slowpath+0x65/0x8b [<c06ab62b>] ? _spin_unlock_irqrestore+0x22/0x38 [<c04228b4>] ? __enqueue_entity+0xe3/0xeb [<c042431e>] ? enqueue_entity+0x203/0x20b [<c0424361>] ? enqueue_task_fair+0x3b/0x3f [<c041f88c>] ? resched_task+0x3a/0x6e [<c06ab62b>] ? _spin_unlock_irqrestore+0x22/0x38 [<c06ab4e2>] ? _spin_lock_bh+0xb/0x16 [<f8b6f642>] ? mkiss_receive_buf+0x33d/0x3a6 [mkiss] [<c04325f9>] _local_bh_enable_ip+0x3d/0xc4 [<c0432688>] local_bh_enable_ip+0x8/0xa [<c06ab54d>] _spin_unlock_bh+0x11/0x13 [<f8b6f642>] mkiss_receive_buf+0x33d/0x3a6 [mkiss] [<c0572a30>] flush_to_ldisc+0xf7/0x198 [<c0572b12>] tty_flip_buffer_push+0x41/0x51 [<f89477f2>] ftdi_process_read+0x375/0x4ad [ftdi_sio] [<f8947a5a>] ftdi_read_bulk_callback+0x130/0x138 [ftdi_sio] [<c05d4bec>] usb_hcd_giveback_urb+0x63/0x93 [<c05ea290>] uhci_giveback_urb+0xe5/0x15f [<c05eaabf>] uhci_scan_schedule+0x52e/0x767 [<c05f6288>] ? psmouse_handle_byte+0xc/0xe5 [<c054df78>] ? acpi_ev_gpe_detect+0xd6/0xe1 [<c05ec5b0>] uhci_irq+0x110/0x125 [<c05d4834>] usb_hcd_irq+0x40/0xa3 [<c0465313>] handle_IRQ_event+0x2f/0x64 [<c046642b>] handle_level_irq+0x74/0xbe [<c04663b7>] ? handle_level_irq+0x0/0xbe [<c0406e6e>] do_IRQ+0xc7/0xfe [<c0405668>] common_interrupt+0x28/0x30 [<c056821a>] ? acpi_idle_enter_simple+0x162/0x19d [<c0617f52>] cpuidle_idle_call+0x60/0x92 [<c0403c61>] cpu_idle+0x101/0x134 [<c069b1ba>] rest_init+0x4e/0x50 ======================= ---[ end trace b7cc8076093467ad ]--- mkiss: ax0: Trying crc-smack mkiss: ax0: Trying crc-flexnet The issue was, that the locking code in mkiss was assuming it was only ever being called in process or bh context. Fixed by converting the involved locking code to use irq-safe locks. Review of other networking line disciplines shows that 6pack, both sync and async PPP and STRIP have similar issues. The ppp_async one is the most interesting one as it sorts out half of the issue as far back as 2004 in commit http://git.kernel.org/?p=linux/kernel/git/tglx/history.git;a=commitdiff;h=2996d8deaeddd01820691a872550dc0cfba0c37d Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reported-by: Guido Trentalancia <guido@trentalancia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17net: fix network drivers ndo_start_xmit() return valuesPatrick McHardy
Fix up remaining drivers returning a magic or an errno value from their ndo_start_xmit() functions that were missed in the first pass: - isdn_net: missed conversion - bpqether: missed conversion: skb is freed, so return NETDEV_TX_OK - hp100: intention appears to be to resubmit skb once resources are available, but due to no queue handling it is dropped for now. - lapbether: skb is freed, so return NETDEV_TX_OK Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: fix network drivers ndo_start_xmit() return values (part 6)Patrick McHardy
Fix up hamradio drivers that return an errno value to dev_queue_xmit(), causing it to print a warning an free the skb. - bpqether: skb is freed: use after free Compile tested only. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-31Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jaswinder/net-next-2.6
2009-03-30yam: use request_firmwareJaswinder Singh Rajput
Added predef variable in add_mcs() to support predefined mcs data Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-03-28dmascc: fix incomplete conversion to network_device_opsAlexander Beregalov
drivers/net/hamradio/dmascc.c:587: error: 'struct net_device' has no member named 'set_mac_address' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/hamradio: fix sparse warning: symbol shadows an earlier oneHannes Eder
Impact: Rename inner scrope variable. Fix this sparse warning: drivers/net/hamradio/yam.c:856:35: warning: symbol 'dev' shadows an earlier one Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/hamradio: fix sparse warning: context imbalanceHannes Eder
Impact: Attribute functions with __acquires(...) resp. __releases(...). Fix this sparse warnings: drivers/net/hamradio/bpqether.c:387:13: warning: context imbalance in 'bpq_seq_start' - wrong count at exit drivers/net/hamradio/bpqether.c:419:13: warning: context imbalance in 'bpq_seq_stop' - unexpected unlock Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/hamradio: fix warning: format not a string literal and no ...Hannes Eder
Impact: Use 'static const char[]' instead of 'static char[]' and while being at it fix an issue in 'mkiss_init_driver', where in case of an error the status code was not passed to printk. Fix this warnings: drivers/net/hamradio/6pack.c: In function 'sixpack_init_driver': drivers/net/hamradio/6pack.c:802: warning: format not a string literal and no format arguments drivers/net/hamradio/bpqether.c: In function 'bpq_init_driver': drivers/net/hamradio/bpqether.c:609: warning: format not a string literal and no format arguments drivers/net/hamradio/mkiss.c: In function 'mkiss_init_driver': drivers/net/hamradio/mkiss.c:988: warning: format not a string literal and no format arguments drivers/net/hamradio/mkiss.c:991: warning: format not a string literal and no format arguments drivers/net/hamradio/scc.c: In function 'scc_init_driver': drivers/net/hamradio/scc.c:2109: warning: format not a string literal and no format arguments drivers/net/hamradio/yam.c: In function 'yam_init_driver': drivers/net/hamradio/yam.c:1094: warning: format not a string literal and no format arguments Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: constify VFTsJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21dmascc: convert to net_device_opsStephen Hemminger
2009-01-21mkiss: convert to internal network device statsStephen Hemminger
2009-01-21scc: convert to internal net_device_opsStephen Hemminger
2009-01-21yam: convert to net_device_opsStephen Hemminger
2009-01-21yam: convert to internal net_device_statsStephen Hemminger
2009-01-21hdlcdrv: convert to net_device_opsStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Thomas Sailer <t.sailer@alumni.ethz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21hdlcdrv: convert to internal net_device_statsStephen Hemminger
2009-01-21dmascc: convert to network_device_opsStephen Hemminger
2009-01-21dmascc: convert to internal network device statsStephen Hemminger
2009-01-21bpqether: convert to net_device_opsStephen Hemminger
2009-01-21bpqether: convert to internal net_device_statsStephen Hemminger
2009-01-21baycom: convert to net_device_opsStephen Hemminger
2009-01-21baycom: convert to internal net_device_statsStephen Hemminger
2009-01-216pack: convert to net_device_opsStephen Hemminger
2009-01-11drivers/net/hamradio/6pack.c: move a dereference below a NULL testJulia Lawall
In each case, if the NULL test is necessary, then the dereference should be moved below the NULL test. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; expression E; identifier i,fld; statement S; @@ - T i = E->fld; + T i; ... when != E when != i if (E == NULL) S + i = E->fld; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
