path: root/drivers/net/hp.c
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-21drivers/net/*.c: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. Signed-off-by: Joe Perches <joe@perches.com>
2010-08-25drivers/net: Remove address use from assignments of function pointersJoe Perches
"foo = &function" is more commonly written "foo = function" Done with coccinelle script: // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> drivers/net/tehuti.c used a function and struct with the same name, the function was renamed. Compile tested x86 only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25hp: convert to net_device_opsStephen Hemminger
Another old EISA driver converted. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22net 8390p: fix interface usageIngo Molnar
various drivers were using the wrong APIs: drivers/built-in.o: In function `hp_probe1': hp.c:(.init.text+0xa280): undefined reference to `NS8390_init' fixed via: cd drivers/net/; sed -i 's/NS8390_/NS8390p_/g' \ $(grep -l NS8390_ $(grep 8390p.o Makefile | cut -d' ' -f3 | \ sed 's/.o$/.c/g')) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-048390: Split 8390 support into a pausing and a non pausing driver coreAlan Cox
Only a few ISA controllers need the pausing version of the 8390 core while PCMCIA, later ISA and PCI do not. More importantly the ISA delays can break non ISA boxes so we must use a different build of 8390.c for the two sets of controllers. No changes since last time as all the points of concerns raised proved to be invalid Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] trivial missing __init in drivers/net/*Al Viro
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-06-11[PATCH] hp ethernet: fix section mismatchesRandy Dunlap
Priority: not critical; makes init code discardable. Fix section mismatch warnings: WARNING: drivers/net/hp-plus.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x387) and 'cleanup_card' WARNING: drivers/net/hp.o - Section mismatch: reference to .init.data: from .text between 'hp_init_card' (at offset 0x310) and 'init_module' WARNING: drivers/net/hp.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x367) and 'cleanup_card' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-09[PATCH] fix a few "warning: 'cleanup_card' defined but not used"Denis Vlasenko
These warnings are emitted if non-modular network drivers are built. Fixes just move cleanup_card() definitions into #ifdef MODULE region. /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/wd.c:131: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/3c503.c:152: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/ne.c:216: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/hp.c:106: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/hp-plus.c:142: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/smc-ultra.c:172: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/e2100.c:144: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/es3210.c:159: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/lne390.c:149: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/lance.c:313: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/ac3200.c:127: warning: 'cleanup_card' defined but not used Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-05-12[netdrvr] Fix register_netdev() races in older ISA net drivers
