path: root/drivers/net/hyperv
2017-03-26hv_netvsc: use skb_get_hash() instead of a homegrown implementationVitaly Kuznetsov
commit 757647e10e55c01fb7a9c4356529442e316a7c72 upstream. Recent changes to 'struct flow_keys' (e.g commit d34af823ff40 ("net: Add VLAN ID to flow_keys")) introduced a performance regression in netvsc driver. Is problem is, however, not the above mentioned commit but the fact that netvsc_set_hash() function did some assumptions on the struct flow_keys data layout and this is wrong. Get rid of netvsc_set_hash() by switching to skb_get_hash(). This change will also imply switching to Jenkins hash from the currently used Toeplitz but it seems there is no good excuse for Toeplitz to stay. Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Sumit Semwal <sumit.semwal@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14netvsc: Set maximum GSO size in the right placeBen Hutchings
Commit a50af86dd49e "netvsc: reduce maximum GSO size" was wrongly backported to 4.4-stable. The maximum size needs to be set before the net device is registered, in netvsc_probe(). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Stephen Hemminger <sthemmin@microsoft.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-15netvsc: reduce maximum GSO sizestephen hemminger
[ Upstream commit a50af86dd49ee1851d1ccf06dd0019c05b95e297 ] Hyper-V (and Azure) support using NVGRE which requires some extra space for encapsulation headers. Because of this the largest allowed TSO packet is reduced. For older releases, hard code a fixed reduced value. For next release, there is a better solution which uses result of host offload negotiation. Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-01flow_dissector: Add flags argument to skb_flow_dissector functionsTom Herbert
The flags argument will allow control of the dissection process (for instance whether to parse beyond L3). Signed-off-by: Tom Herbert <tom@herbertland.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-18hv_netvsc: Fix dereference of nvdev before checkAndrew Schwartzmeyer
Passes static analysis by Smatch. Signed-off-by: Andrew Schwartzmeyer <andschwa@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-12hv_netvsc: Implement set_channels ethtool opAndrew Schwartzmeyer
This enables the use of ethtool --set-channels devname combined N to change the number of vRSS queues. Separate rx, tx, and other parameters are not supported. The maximum is rsscap.num_recv_que. It passes the given value to rndis_filter_device_add through the device_info->num_chn field. If the procedure fails, it attempts to recover to the prior state. If the recovery fails, it logs an error and aborts. Current num_chn is saved and restored when changing the MTU. Signed-off-by: Andrew Schwartzmeyer <andschwa@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-12hv_netvsc: Set vRSS with num_chn in RNDIS filterAndrew Schwartzmeyer
Uses device_info->num_chn to pass user provided number of vRSS queues (from ethtool --set-channels) to rndis_filter_device_add. If nonzero and less than the maximum, set net_device->num_chn to the given value; else default to prior algorithm. Always initialize struct device_info to 0, otherwise not all its fields are guaranteed to be 0, which is necessary when checking if num_chn has been purposefully set. Signed-off-by: Andrew Schwartzmeyer <andschwa@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-27hv_netvsc: Add structs and handlers for VF messagesHaiyang Zhang
This patch adds data structures and handlers for messages related to SRIOV Virtual Function. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-26hv_netvsc: Wait for sub-channels to be processed during probeKY Srinivasan
The current code returns from probe without waiting for the proper handling of subchannels that may be requested. If the netvsc driver were to be rapidly loaded/unloaded, we can trigger a panic as the unload will be tearing down state that may not have been fully setup yet. We fix this issue by making sure that we return from the probe call only after ensuring that the sub-channel offers in flight are properly handled. Reviewed-and-tested-by: Haiyang Zhang <haiyangz@microsoft.com Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-15hv_netvsc: Add close of RNDIS filter into change mtu callHaiyang Zhang
The current change mtu call only stops tx before removing RNDIS filter. In case ringbufer is not empty, the rndis_filter_device_remove() may hang on removing the buffers. This patch adds close of RNDIS filter before removing it, also a gradual waiting loop until the ring is empty. The change_mtu hang issue under heavy traffic is solved by this patch. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-08hv_netvsc: Add support to set MTU reservation from guest sideHaiyang Zhang
When packet encapsulation is in use, the MTU needs to be reduced for headroom reservation. The existing code takes the updated MTU value only from the host side. But vSwitch extensions, such as Open vSwitch, require the flexibility to change the MTU to different values from within a guest during the lifecycle of a vNIC, when the encapsulation protocol is changed. The patch supports this kind of MTU changes. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Add TX fast path in mac80211, from Johannes Berg. 2) Add TSO/GRO support to ibmveth, from Thomas Falcon 3) Move away from cached routes in ipv6, just like ipv4, from Martin KaFai Lau. 4) Lots of new rhashtable tests, from Thomas Graf. 5) Run ingress qdisc lockless, from Alexei Starovoitov. 6) Allow servers to fetch TCP packet headers for SYN packets of new connections, for fingerprinting. From Eric Dumazet. 7) Add mode parameter to pktgen, for testing receive. From Alexei Starovoitov. 8) Cache access optimizations via simplifications of build_skb(), from Alexander Duyck. 9) Move page frag allocator under mm/, also from Alexander. 10) Add xmit_more support to hv_netvsc, from KY Srinivasan. 11) Add a counter guard in case we try to perform endless reclassify loops in the packet scheduler. 12) Extern flow dissector to be programmable and use it in new "Flower" classifier. From Jiri Pirko. 13) AF_PACKET fanout rollover fixes, performance improvements, and new statistics. From Willem de Bruijn. 14) Add netdev driver for GENEVE tunnels, from John W Linville. 15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso. 16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet. 17) Add an ECN retry fallback for the initial TCP handshake, from Daniel Borkmann. 18) Add tail call support to BPF, from Alexei Starovoitov. 19) Add several pktgen helper scripts, from Jesper Dangaard Brouer. 20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa. 21) Favor even port numbers for allocation to connect() requests, and odd port numbers for bind(0), in an effort to help avoid ip_local_port_range exhaustion. From Eric Dumazet. 22) Add Cavium ThunderX driver, from Sunil Goutham. 23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata, from Alexei Starovoitov. 24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai. 25) Double TCP Small Queues default to 256K to accomodate situations like the XEN driver and wireless aggregation. From Wei Liu. 26) Add more entropy inputs to flow dissector, from Tom Herbert. 27) Add CDG congestion control algorithm to TCP, from Kenneth Klette Jonassen. 28) Convert ipset over to RCU locking, from Jozsef Kadlecsik. 29) Track and act upon link status of ipv4 route nexthops, from Andy Gospodarek. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits) bridge: vlan: flush the dynamically learned entries on port vlan delete bridge: multicast: add a comment to br_port_state_selection about blocking state net: inet_diag: export IPV6_V6ONLY sockopt stmmac: troubleshoot unexpected bits in des0 & des1 net: ipv4 sysctl option to ignore routes when nexthop link is down net: track link-status of ipv4 nexthops net: switchdev: ignore unsupported bridge flags net: Cavium: Fix MAC address setting in shutdown state drivers: net: xgene: fix for ACPI support without ACPI ip: report the original address of ICMP messages net/mlx5e: Prefetch skb data on RX net/mlx5e: Pop cq outside mlx5e_get_cqe net/mlx5e: Remove mlx5e_cq.sqrq back-pointer net/mlx5e: Remove extra spaces net/mlx5e: Avoid TX CQE generation if more xmit packets expected net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq() net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device ...
2015-06-03x86/mm: Decouple <linux/vmalloc.h> from <asm/io.h>Stephen Rothwell
Nothing in <asm/io.h> uses anything from <linux/vmalloc.h>, so remove it from there and fix up the resulting build problems triggered on x86 {64|32}-bit {def|allmod|allno}configs. The breakages were triggering in places where x86 builds relied on vmalloc() facilities but did not include <linux/vmalloc.h> explicitly and relied on the implicit inclusion via <asm/io.h>. Also add: - <linux/init.h> to <linux/io.h> - <asm/pgtable_types> to <asm/io.h> ... which were two other implicit header file dependencies. Suggested-by: David Miller <davem@davemloft.net> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> [ Tidied up the changelog. ] Acked-by: David Miller <davem@davemloft.net> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Vinod Koul <vinod.koul@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Vorontsov <anton@enomsg.org> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Colin Cross <ccross@android.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Haiyang Zhang <haiyangz@microsoft.com> Cc: James E.J. Bottomley <JBottomley@odin.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: K. Y. Srinivasan <kys@microsoft.com> Cc: Kees Cook <keescook@chromium.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Kristen Carlson Accardi <kristen@linux.intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Suma Ramars <sramars@cisco.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-31hv_netvsc: Allocate the sendbuf in a NUMA aware wayK. Y. Srinivasan
Allocate the send buffer in a NUMA aware way. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31hv_netvsc: Allocate the receive buffer from the correct NUMA nodeK. Y. Srinivasan
Allocate the receive bufer from the NUMA node assigned to the primary channel. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-30hv_netvsc: Properly size the vrss queuesKY Srinivasan
The current algorithm for deciding on the number of VRSS channels is not optimal since we open up the min of number of CPUs online and the number of VRSS channels the host is offering. So on a 32 VCPU guest we could potentially open 32 VRSS subchannels. Experimentation has shown that it is best to limit the number of VRSS channels to the number of CPUs within a NUMA node. Here is the new algorithm for deciding on the number of sub-channels we would open up: 1) Pick the minimum of what the host is offering and what the driver in the guest is specifying as the default value. 2) Pick the minimum of (1) and the numbers of CPUs in the NUMA node the primary channel is bound to. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-17hv_netvsc: change member name of struct netvsc_statssixiao@microsoft.com
Currently the struct netvsc_stats has a member s_sync of type u64_stats_sync. This definition will break kernel build as the macro netdev_alloc_pcpu_stats requires this member name to be syncp. (see netdev_alloc_pcpu_stats definition in ./include/linux/netdevice.h) This patch changes netvsc_stats's member name from s_sync to syncp to fix the build break. Signed-off-by: Simon Xiao <sixiao@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14hv_netvsc: use per_cpu stats to calculate TX/RX datasixiao@microsoft.com
Current code does not lock anything when calculating the TX and RX stats. As a result, the RX and TX data reported by ifconfig are not accuracy in a system with high network throughput and multiple CPUs (in my test, RX/TX = 83% between 2 HyperV VM nodes which have 8 vCPUs and 40G Ethernet). This patch fixed the above issue by using per_cpu stats. netvsc_get_stats64() summarizes TX and RX data by iterating over all CPUs to get their respective stats. This v2 patch addressed David's comments on the cleanup path when netdev_alloc_pcpu_stats() failed. Signed-off-by: Simon Xiao <sixiao@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-13flow_dissect: use programable dissector in skb_flow_dissect and friendsJiri Pirko
Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Four minor merge conflicts: 1) qca_spi.c renamed the local variable used for the SPI device from spi_device to spi, meanwhile the spi_set_drvdata() call got moved further up in the probe function. 2) Two changes were both adding new members to codel params structure, and thus we had overlapping changes to the initializer function. 3) 'net' was making a fix to sk_release_kernel() which is completely removed in 'net-next'. 4) In net_namespace.c, the rtnl_net_fill() call for GET operations had the command value fixed, meanwhile 'net-next' adjusted the argument signature a bit. This also matches example merge resolutions posted by Stephen Rothwell over the past two days. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-12hv_netvsc: Use the xmit_more skb flag to optimize signaling the hostKY Srinivasan
Based on the information given to this driver (via the xmit_more skb flag), we can defer signaling the host if more packets are on the way. This will help make the host more efficient since it can potentially process a larger batch of packets. Implement this optimization. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-05hv_netvsc: remove unused variable in netvsc_send()Jerry Snitselaar
With commit b56fc3c53654 ("hv_netvsc: Fix a bug in netvsc_start_xmit()"), skb variable is no longer used in netvsc_send. Remove variable and dead code that depended on it. Cc: Haiyang Zhang <haiyangz@microsoft.com> Cc: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Jerry Snitselaar <jsnitsel@redhat.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-29hv_netvsc: Fix a bug in netvsc_start_xmit()KY Srinivasan
Commit b08cc79155fc26d0d112b1470d1ece5034651a4b eliminated memory allocation in the packet send path: "hv_netvsc: Eliminate memory allocation in the packet send path The network protocol used to communicate with the host is the remote ndis (rndis) protocol. We need to decorate each outgoing packet with a rndis header and additional rndis state (rndis per-packet state). To manage this state, we currently allocate memory in the transmit path. Eliminate this allocation by requesting additional head room in the skb." This commit introduced a bug since it did not account for the case if the skb was cloned. Fix this bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Tested-by: Dexuan Cui <decui@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-29hv_netvsc: introduce netif-msg into netvsc moduleSimon Xiao
1. Introduce netif-msg to netvsc to control debug logging output and keep msg_enable in netvsc_device_context so that it is kept persistently. 2. Only call dump_rndis_message() when NETIF_MSG_RX_ERR or above is specified in netvsc module debug param. In non-debug mode, in current code, dump_rndis_message() will not dump anything but it still initialize some local variables and process the switch logic which is unnecessary, especially in high network throughput situation. Signed-off-by: Simon Xiao <sixiao@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-14hv_netvsc: Implement partial copy into send bufferHaiyang Zhang
If remaining space in a send buffer slot is too small for the whole message, we only copy the RNDIS header and PPI data into send buffer, so we can batch one more packet each time. It reduces the vmbus per-message overhead. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-08hv_netvsc: try linearizing big SKBs before dropping themVitaly Kuznetsov
In netvsc_start_xmit() we can handle packets which are scattered around not more than MAX_PAGE_BUFFER_COUNT-2 pages. It is, however, easy to create a packet which is not big in size but occupies more pages (e.g. if it uses frags on compound pages boundaries). When we drop such packet it cases sender to try resending it but in most cases it will try resending the same packet which will also get dropped, this will cause the particular connection to stick. To solve the issue we can try linearizing skb. Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-08hv_netvsc: use single existing drop path in netvsc_start_xmitVitaly Kuznetsov
... which validly uses dev_kfree_skb_any() instead of dev_kfree_skb(). Setting ret to -EFAULT and -ENOMEM have no real meaning here (we need to set it to anything but -EAGAIN) as we drop the packet and return NETDEV_TX_OK anyway. Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-07hv_netvsc: Fix the packet free when it is in skb headroomHaiyang Zhang
In the two places changed, we now use netvsc_xmit_completion() which properly frees hv_netvsc_packet in or not in skb headroom. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-07hv_netvsc: Define a macro RNDIS_AND_PPI_SIZEHaiyang Zhang
The sum of RNDIS msg and PPI struct sizes is used in multiple places, so we define a macro for them. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-07hv_netvsc: Clean up two unused variablesHaiyang Zhang
2015-03-31hv_netvsc: Eliminate memory allocation in the packet send pathKY Srinivasan
The network protocol used to communicate with the host is the remote ndis (rndis) protocol. We need to decorate each outgoing packet with a rndis header and additional rndis state (rndis per-packet state). To manage this state, we currently allocate memory in the transmit path. Eliminate this allocation by requesting additional head room in the skb. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-31hv_netvsc: Cleanup the test for freeing skb when we use sendbuf mechanismKY Srinivasan
In preparation for embedding the rndis state and other packet state into the skb, cleanup the test for freeing the skb. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29hv_netvsc: remove vmbus_are_subchannels_present() in rndis_filter_device_add()Haiyang Zhang
The vmbus_are_subchannels_present() also involves opening the channels, which may be too early at this point. Checking for subchannels is not necessary here. So this patch removes it. Subchannels will be opened when offer messages arrive. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-29hv_netvsc: Implement batching in send bufferHaiyang Zhang
With this patch, we can send out multiple RNDIS data packets in one send buffer slot and one VMBus message. It reduces the overhead associated with VMBus messages. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-28hyperv: Implement netvsc_get_channels() ethool opAndrew Schwartzmeyer
This adds support for reporting the actual and maximum combined channels count of the hv_netvsc driver via 'ethtool --show-channels'. This required adding 'max_chn' to 'struct netvsc_device', and assigning it 'rsscap.num_recv_que' in 'rndis_filter_device_add'. Now we can access the combined maximum channel count via 'struct netvsc_device' in the ethtool callback. Signed-off-by: Andrew Schwartzmeyer <andrew@schwartzmeyer.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05hyperv: fix sparse warningsLad, Prabhakar
this patch fixes following sparse warnings: netvsc.c:688:5: warning: symbol 'netvsc_copy_to_send_buf' was not declared. Should it be static? rndis_filter.c:627:5: warning: symbol 'rndis_filter_set_offload_params' was not declared. Should it be static? rndis_filter.c:702:5: warning: symbol 'rndis_filter_set_rss_param' was not declared. Should it be static? Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/vxlan.c drivers/vhost/net.c include/linux/if_vlan.h net/core/dev.c The net/core/dev.c conflict was the overlap of one commit marking an existing function static whilst another was adding a new function. In the include/linux/if_vlan.h case, the type used for a local variable was changed in 'net', whereas the function got rewritten to fix a stacked vlan bug in 'net-next'. In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next' overlapped with an endainness fix for VHOST 1.0 in 'net'. In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter in 'net-next' whereas in 'net' there was a bug fix to pass in the correct network namespace pointer in calls to this function. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-31hyperv: Fix the error processing in netvsc_send()Haiyang Zhang
The existing code frees the skb in EAGAIN case, in which the skb will be retried from upper layer and used again. Also, the existing code doesn't free send buffer slot in error case, because there is no completion message for unsent packets. This patch fixes these problems. (Please also include this patch for stable trees. Thanks!) Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27hyperv: match wait_for_completion_timeout return typeNicholas Mc Guire
return type of wait_for_completion_timeout is unsigned long not int, this patch just fixes up the declarations. Signed-off-by: Nicholas Mc Guire <der.herr@hofr.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-01-27hyperv: netvsc.c: match wait_for_completion_timeout return typeNicholas Mc Guire
2014-12-22hyperv: Fix some variable name typos in send-buffer init/revokeHaiyang Zhang
The changed names are union fields with the same size, so the existing code still works. But, we now update these variables to the correct names. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-08hyperv: Add support for vNIC hot removalHaiyang Zhang
This patch adds proper handling of the vNIC hot removal event, which includes a rescind-channel-offer message from the host side that triggers vNIC close and removal. In this case, the notices to the host during close and removal is not necessary because the channel is rescinded. This patch blocks these unnecessary messages, and lets vNIC removal process complete normally. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-25net: Hyper-V: Deletion of an unnecessary check before the function call "vfree"Markus Elfring
The vfree() function performs also input parameter validation. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-12hyperv: Add processing of MTU reduced by the hostHaiyang Zhang
If the host uses packet encapsulation feature, the MTU may be reduced by the host due to headroom reservation for encapsulation. This patch handles this new MTU value. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-30hyperv: Add IPv6 into the hash computation for vRSSHaiyang Zhang
This will allow the workload spreading via vRSS for IPv6. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-22hyperv: Fix the total_data_buflen in send pathHaiyang Zhang
total_data_buflen is used by netvsc_send() to decide if a packet can be put into send buffer. It should also include the size of RNDIS message before the Ethernet frame. Otherwise, a messge with total size bigger than send_section_size may be copied into the send buffer, and cause data corruption. [Request to include this patch to the Stable branches] Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-17hyperv: Add handling of IP header with option field in netvsc_set_hash()Haiyang Zhang
In case that the IP header has optional field at the end, this patch will get the port numbers after that field, and compute the hash. The general parser skb_flow_dissect() is used here. Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com> Reviewed-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2014-10-05hyperv: Fix a bug in netvsc_send()KY Srinivasan
After the packet is successfully sent, we should not touch the packet as it may have been freed. This patch is based on the work done by Long Li <longli@microsoft.com>. David, please queue this up for stable. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Reported-by: Sitsofe Wheeler <sitsofe@yahoo.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/r8152.c net/netfilter/nfnetlink.c Both r8152 and nfnetlink conflicts were simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
