The arch/ppc sub-tree has been removed in the powerpc git tree. The old
ibm_emac driver is no longer used by anything as a result of this. This
removes it, leaving the ibm_newemac driver as the proper driver to use for
PowerPC boards with the EMAC hardware.
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Signed-off-by: Denis Cheng <crquan@gmail.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
This patch replaces current PowerPC 4xx EMAC driver with
new, re-written from the scratch version. This patch is quite big
(~234K) because there is virtualy 0% of common code between old and
new version.
New driver uses NAPI, it solves stability problems under heavy packet
load and low memory, corrects chip register access and fixes numerous
small bugs I don't even remember now.
This patch has been tested on all supported in 2.6 PPC 4xx boards.
It's been used in production for almost a year now on custom
4xx hardware. PPC32 specific parts are already upstream.
Patch was acked by the current EMAC driver maintainer (Matt Porter). I
will be maintaining this new version.
Signed-off-by: Eugene Surovegin <ebs@ebshome.net>
Kconfig | 72
ibm_emac/Makefile | 13
ibm_emac/ibm_emac.h | 418 +++--
ibm_emac/ibm_emac_core.c | 3414 ++++++++++++++++++++++++----------------------
ibm_emac/ibm_emac_core.h | 313 ++--
ibm_emac/ibm_emac_debug.c | 377 ++---
ibm_emac/ibm_emac_debug.h | 63
ibm_emac/ibm_emac_mal.c | 674 +++++----
ibm_emac/ibm_emac_mal.h | 336 +++-
ibm_emac/ibm_emac_phy.c | 335 ++--
ibm_emac/ibm_emac_phy.h | 105 -
ibm_emac/ibm_emac_rgmii.c | 201 ++
ibm_emac/ibm_emac_rgmii.h | 68
ibm_emac/ibm_emac_tah.c | 111 +
ibm_emac/ibm_emac_tah.h | 96 -
ibm_emac/ibm_emac_zmii.c | 255 +++
ibm_emac/ibm_emac_zmii.h | 114 -
17 files changed, 4114 insertions(+), 2851 deletions(-)
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
infrastructure for it.
Let it rip!
