This patch removes old and unsupported CLPS711X IrDA driver.
Support for IrDA for CLPS711X serial port now provided by commit
4a33f1f59abd (serial: clps711x: Add support for N_IRDA line
discipline), so IrDA-mode can be turned ON with "irattach" tool
through "irtty" driver.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
SH_SIR is not Dongle
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial patches from Greg Kroah-Hartman:
"Here's the big tty/serial driver patches for 3.9-rc1.
More tty port rework and fixes from Jiri here, as well as lots of
individual serial driver updates and fixes.
All of these have been in the linux-next tree for a while."
* tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits)
tty: mxser: improve error handling in mxser_probe() and mxser_module_init()
serial: imx: fix uninitialized variable warning
serial: tegra: assume CONFIG_OF
TTY: do not update atime/mtime on read/write
lguest: select CONFIG_TTY to build properly.
ARM defconfigs: add missing inclusions of linux/platform_device.h
fb/exynos: include platform_device.h
ARM: sa1100/assabet: include platform_device.h directly
serial: imx: Fix recursive locking bug
pps: Fix build breakage from decoupling pps from tty
tty: Remove ancient hardpps()
pps: Additional cleanups in uart_handle_dcd_change
pps: Move timestamp read into PPS code proper
pps: Don't crash the machine when exiting will do
pps: Fix a use-after free bug when unregistering a source.
pps: Use pps_lookup_dev to reduce ldisc coupling
pps: Add pps_lookup_dev() function
tty: serial: uartlite: Support uartlite on big and little endian systems
tty: serial: uartlite: Fix sparse and checkpatch warnings
serial/arc-uart: Miscll DT related updates (Grant's review comments)
Fix up trivial conflicts, mostly just due to the TTY config option
clashing with the EXPERIMENTAL removal.
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
CC: Samuel Ortiz <samuel@sortiz.org>
The option allows you to remove TTY and compile without errors. This
saves space on systems that won't support TTY interfaces anyway.
bloat-o-meter output is below.
The bulk of this patch consists of Kconfig changes adding "depends on
TTY" to various serial devices and similar drivers that require the TTY
layer. Ideally, these dependencies would occur on a common intermediate
symbol such as SERIO, but most drivers "select SERIO" rather than
"depends on SERIO", and "select" does not respect dependencies.
bloat-o-meter output comparing our previous minimal to new minimal by
removing TTY. The list is filtered to not show removed entries with awk
'$3 != "-"' as the list was very long.
add/remove: 0/226 grow/shrink: 2/14 up/down: 6/-35356 (-35350)
function old new delta
chr_dev_init 166 170 +4
allow_signal 80 82 +2
static.__warned 143 142 -1
disallow_signal 63 62 -1
__set_special_pids 95 94 -1
unregister_console 126 121 -5
start_kernel 546 541 -5
register_console 593 588 -5
copy_from_user 45 40 -5
sys_setsid 128 120 -8
sys_vhangup 32 19 -13
do_exit 1543 1526 -17
bitmap_zero 60 40 -20
arch_local_irq_save 137 117 -20
release_task 674 652 -22
static.spin_unlock_irqrestore 308 260 -48
Signed-off-by: Joe Millenbach <jmillenbach@gmail.com>
Reviewed-by: Jamey Sharp <jamey@minilop.net>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Pull trivial updates from Jiri Kosina:
"As usual, it's mostly typo fixes, redundant code elimination and some
documentation updates."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits)
edac, mips: don't change code that has been removed in edac/mips tree
xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer
lib: Change mail address of Oskar Schirmer
net: Change mail address of Oskar Schirmer
arm/m68k: Change mail address of Sebastian Hess
i2c: Change mail address of Oskar Schirmer
net: Fix tcp_build_and_update_options comment in struct tcp_sock
atomic64_32.h: fix parameter naming mismatch
Kconfig: replace "--- help ---" with "---help---"
c2port: fix bogus Kconfig "default no"
edac: Fix spelling errors.
qla1280: Remove redundant NULL check before release_firmware() call
remoteproc: remove redundant NULL check before release_firmware()
qla2xxx: Remove redundant NULL check before release_firmware() call.
aic94xx: Get rid of redundant NULL check before release_firmware() call
tehuti: delete redundant NULL check before release_firmware()
qlogic: get rid of a redundant test for NULL before call to release_firmware()
bna: remove redundant NULL test before release_firmware()
tg3: remove redundant NULL test before release_firmware() call
typhoon: get rid of redundant conditional before all to release_firmware()
Pull first batch of arm-soc cleanups from Olof Johansson:
"These cleanups are basically all over the place. The idea is to
collect changes with minimal impact but large number of changes so we
can avoid them from distracting in the diffstat in the other series.
A significant number of lines get removed here, in particular because
the ixp2000 and ixp23xx platforms get removed. These have never been
extremely popular and have fallen into disuse over time with no active
maintainer taking care of them. The u5500 soc never made it into a
product, so we are removing it from the ux500 platform.
Many good cleanups also went into the at91 and omap platforms, as has
been the case for a number of releases."
Trivial modify-delete conflicts in arch/arm/mach-{ixp2000,ixp23xx}
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (152 commits)
ARM: clps711x: Cleanup IRQ handling
ARM clps711x: Removed unused header mach/time.h
ARM: clps711x: Added note about support EP731x CPU to Kconfig
ARM: clps711x: Added missing register definitions
ARM: clps711x: Used own subarch directory for store header file
Dove: Fix Section mismatch warnings
ARM: orion5x: ts78xx debugging changes
ARM: orion5x: remove PM dependency from ts78xx
ARM: orion5x: ts78xx fix NAND resource off by one
ARM: orion5x: ts78xx whitespace cleanups
Orion5x: Fix Section mismatch warnings
Orion5x: Fix warning: struct pci_dev declared inside paramter list
ARM: clps711x: Combine header files into one for clps711x-targets
ARM: S3C24XX: Use common macro to define resources on mach-qt2410.c
ARM: S3C24XX: Use common macro to define resources on mach-osiris.c
ARM: EXYNOS: Adapt to cpuidle core time keeping and irq enable
ARM: S5PV210: Use common macro to define resources on mach-smdkv210.c
ARM: S5PV210: Use common macro to define resources on dev-audio.c
ARM: S5PC100: Use common macro to define resources on dev-audio.c
ARM: S5P64X0: Use common macro to define resources on dev-audio.c
Current ARM7 Cirrus Logic product line contains only 3 cpu.
EP7312 - Fully functional.
EP7309 - Missing SDRAM interface.
EP7311 - Missing DAI.
It makes no sense to separate the header files to identify these differences,
it is only necessary to keep in mind the presence or lack of any features of
a specific CPU when writing code.
This has been used by me and others for ages, let's stop calling it
experimental.
Fix typo "the the" in various Kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Convert the sa11x0 IrDA driver to use the sa11x0 DMA engine driver
rather than our own platform specific DMA API.
Moderate driver cleanup:
convert to platform driver, get rid of board-specific code.
Driver loads and runs on a DB1100 board. But since I have no other
IrDA hardware to exchange data with I can't say whether it really sends
and receives.
Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: netdev@vger.kernel.org
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/2877/
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits)
MIPS: O32: Provide definition of registers ta0 .. ta3.
MIPS: perf: Add Octeon support for hardware perf.
MIPS: perf: Add support for 64-bit perf counters.
MIPS: perf: Reorganize contents of perf support files.
MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c
MIPS: Add accessor macros for 64-bit performance counter registers.
MIPS: Add probes for more Octeon II CPUs.
MIPS: Add more CPU identifiers for Octeon II CPUs.
MIPS: XLR, XLS: Add comment for smp setup
MIPS: JZ4740: GPIO: Check correct IRQ in demux handler
MIPS: JZ4740: GPIO: Simplify IRQ demuxer
MIPS: JZ4740: Use generic irq chip
MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines
MIPS: Alchemy: kill au1xxx.h header
MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines
MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep
MIPS: Alchemy: Redo PCI as platform driver
MIPS: Alchemy: more base address cleanup
MIPS: Alchemy: rewrite USB platform setup.
MIPS: Alchemy: abstract USB block control register access
Fix up trivial conflicts in:
arch/mips/alchemy/devboards/db1x00/platform.c
drivers/ide/Kconfig
drivers/mmc/host/au1xmmc.c
drivers/video/Kconfig
sound/mips/Kconfig
Now that no driver any longer depends on the CONFIG_SOC_AU1??? symbols,
it's time to get rid of them: Move some of the platform devices to the
boards which can use them, Rename a few (unused) constants in the header,
Replace them with MIPS_ALCHEMY in the various Kconfig files. Finally
delete them altogether from the Alchemy Kconfig file.
To: Linux-MIPS <linux-mips@linux-mips.org>
Patchwork: https://patchwork.linux-mips.org/patch/2707/
This patch fixes file references to moved or deleted files
outside of Documentation/.
Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net>
This is very simple driver for SuperH Mobile IrDA
which support SIR/MIR/FIR.
This patch add only SIR support for now.
This is very simple IrDA SIR driver for SuperH.
This driver was tested by irdaping/ircp on SH7724 EcoVec24 board
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Signed-off-by: Graff Yang <graff.yang@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Bryan Wu <bryan.wu@analog.com>
Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
-tip testing found the following build error:
drivers/built-in.o: In function `mcs_receive_irq':
mcs7780.c:(.text+0x4e429): undefined reference to `crc32_le'
drivers/built-in.o: In function `mcs_hard_xmit':
mcs7780.c:(.text+0x4e9af): undefined reference to `crc32_le'
with:
http://redhat.com/~mingo/misc/config-Sun_Jun__8_22_56_14_CEST_2008.bad
the reason is a missing enablement of the CRC32 library in the Kconfig.
This patch removes IrPORT and the old dongle drivers (all off them
have replacement drivers).
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This dongle does not follow the usb-irda specification, so it needs its own
special driver. First, it uses control URBs for data transfer, instead of
bulk or interrupt transfers; the only interrupt endpoint exposed seems to
be a dummy to prevent the interface from being rejected. Second, it uses
obfuscation and padding at the USB traffic level, for no apparent reason
other than to make reverse engineering harder (full details on obfuscation
in comments at beginning of source). Although it is advertised as a "4 Mbps
FIR dongle", it apparently loses packets at speeds greater than 57600 bps.
On plugin, this dongle reports vendor and device IDs: 0x07d0:0x4959 .
The Windows driver that is used normally to control this dongle has a
filename of KS-959.SYS .
Signed-off-by: Alex Villacís Lasso <a_villacis@palosanto.com>
special driver. Just like the Kingsun/Donshine dongle, it exposes two
interrupt endpoints. Reception is performed through direct reads from the
input endpoint. Transmission requires splitting the IrDA frames into 8-byte
segments, in which the first byte encodes how many of the remaining 7 bytes
are used as data. Speed change is made with a control URB just like the one
in cypress_m8, and it seems to support up to 115200 bps.
On plugin, this dongle reports vendor and device IDs: 0x07d0:0x4100
The EP7211 SIR driver was the only one left without a new SIR API port.
own special driver. In addition, it uses interrupt endpoints instead of
bulk ones as the rest of USB IrDA dongles supported by Linux (just to be
different?) and data reads need to be parsed to extract the valid bytes
before being unwrapped (details in the comment at the start of the
source). No speed commands have been discovered for this dongle, and I
suspect it does not have any at all.
On plugin, this dongle reports vendor and device IDs: 0x07c0:0x4200 .
filename of DSIR620.SYS .
Signed-off-by: Alex Villac�s Lasso <a_villacis@palosanto.com>
With the inclusion of the stir421x code, we now need to select FW_LOADER
whenever we try to build the irda-usb code.
AU1000 FIR is broken, it should depend on SOC_AU1000.
Spotted by Jean-Luc Leger.
The MosChip MCS7780 chipset is an IrDA USB bridge that
doesn't conform with the IrDA-USB standard and thus needs
its separate driver.
Tested on an actual MCS7780 based dongle.
Original implementation by Brian Pugh <bpugh@cs.pdx.edu>
If a SIR dongle is built in the kernel while IRTTY_SIR is built
as a module, kernel compilation will fail.
Thus, the SIR dongle config should depend on the IRTTY_SIR.
Closes kernel bug# 6512
(http://bugzilla.kernel.org/show_bug.cgi?id=6512)
Here goes a patch for supporting TOIM3232 based serial IrDA dongles.
The code is based on the tekram dongle code.
It's been tested with a TOIM3232 based IRWave 320S dongle. It may work
for TOIM4232 dongles, although it's not been tested.
Signed-off-by: David Basden <davidb-irda@rcpt.to>
Signed-off-by: Samuel Ortiz <samuel.ortiz@nokia.com>
This patch corrects a few spelling and grammar errors found in
drivers/net
Signed-off-by: Jon Mason <jdmason@us.ibm.com>
Jean-Luc Leger <reiga@dspnet.fr.eu.org> reported this alternative
dependency on a non-existing symbol.
Patch from Nicolas Pitre
This is the PXA2xx common IRDA driver, plus platform support
for Lubbock and Mainstone.
Signed-off-by: Nicolas Pitre <nico@cam.org>
Acked-by: Jean Tourrilhes <jt@hpl.hp.com>
* net/irda/irda_device.c::irda_setup_dma() made conditional on
ISA_DMA_API (it uses helpers in question and irda is usable on
platforms that don't have them at all - think of USB IRDA, for
example).
* irda drivers that depend on ISA DMA marked as dependent on
ISA_DMA_API
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
CONFIG_ISA
This allows to use them on x86-64
Signed-off-by: Andi Kleen <ak@suse.de>
infrastructure for it.
Let it rip!
