path: root/drivers/net/irda/ali-ircc.c
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-09-23Fix typo: configuation => configurationThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24net/irda: remove trailing space in messagesFrans Pop
Includes a minor consistency improvement between two related debug messages. Signed-off-by: Frans Pop <elendil@planet.nl> Cc: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01irda: convert to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: convert remaining non-symbolic return values in ndo_start_xmit() functionsPatrick McHardy
This patch converts the remaining occurences of raw return values to their symbolic counterparts in ndo_start_xmit() functions that were missed by the previous automatic conversion. Additionally code that assumed the symbolic value of NETDEV_TX_OK to be zero is changed to explicitly use NETDEV_TX_OK. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21irda: convert ali driver to net_device_opsStephen Hemminger
2009-01-06irda: convert to internal statsStephen Hemminger
Convert IRDA drivers to use already existing net_device_stats structure in network device. This is a pre-cursor to conversion to net_device ops. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12netdevice: safe convert to netdev_priv() #part-2Wang Chen
We have some reasons to kill netdev->priv: 1. netdev->priv is equal to netdev_priv(). 2. netdev_priv() wraps the calculation of netdev->priv's offset, obviously netdev_priv() is more flexible than netdev->priv. But we cann't kill netdev->priv, because so many drivers reference to it directly. This patch is a safe convert for netdev->priv to netdev_priv(netdev). Since all of the netdev->priv is only for read. But it is too big to be sent in one mail. I split it to 4 parts and make every part smaller than 100,000 bytes, which is max size allowed by vger. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-30irda: replace __FUNCTION__ with __func__Harvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25net drivers: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable network platform drivers, to re-enable auto loading. NOTE: didn't change drivers/net/fs_enet/fs_enet-main.c "old binding" support. That looks problematic in the first place (it even uses the ancient "struct device_driver" binding scheme for platform_bus!) and I suspect it will vanish soonish when arch/powerpc rules the world. Also, drivers/net/ne.c would have needed more thought to sort out. [akpm@linux-foundation.org: fix sgiseeq.c] [dbrownell@users.sourceforge.net: more drivers, registration fixes] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Vitaly Bordug <vitb@kernel.crashing.org> Cc: Dale Farnsworth <dale@farnsworth.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_from_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying from linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2007-04-25[SK_BUFF]: Introduce skb_reset_mac_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->mac.raw = skb->data' operation, so that we can later turn skb->mac.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-06drivers/net: eliminate irq handler impossible checks, needless castsJeff Garzik
- Eliminate check for irq handler 'dev_id==NULL' where the condition never occurs. - Eliminate needless casts to/from void* Signed-off-by: Jeff Garzik <jeff@garzik.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-22[IRDA]: Replace hard-coded dev_self[] array sizes with ARRAY_SIZE()Bjorn Helgaas
Several IR drivers used "for (i = 0; i < 4; i++)" to walk their dev_self[] table. Better to use ARRAY_SIZE(). And fix ali-ircc so it won't run off the end if we find too many adapters. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-08[IRDA]: fix drivers/net/irda/ali-ircc.c:ali_ircc_init()Adrian Bunk
The Coverity checker spotted, that from the changes from commit 898b1d16f8230fb912a0c2248df685735c6ceda3 the if (ret) platform_driver_unregister(&ali_ircc_driver); was dead code. This patch changes this function to what seems to have been the intention. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[IRDA]: ali-ircc: using device model power managementSamuel Ortiz
This patch gets rid of the old power management code and now uses the device model for the ali-ircc driver. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-13[PATCH] move pm_register/etc. to CONFIG_PM_LEGACY, pm_legacy.hJeff Garzik
Since few people need the support anymore, this moves the legacy pm_xxx functions to CONFIG_PM_LEGACY, and include/linux/pm_legacy.h. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
