path: root/drivers/net/ixgb
2011-05-22Add appropriate <linux/prefetch.h> include for prefetch usersPaul Gortmaker
After discovering that wide use of prefetch on modern CPUs could be a net loss instead of a win, net drivers which were relying on the implicit inclusion of prefetch.h via the list headers showed up in the resulting cleanup fallout. Give them an explicit include via the following $0.02 script. ========================================= #!/bin/bash MANUAL="" for i in `git grep -l 'prefetch(.*)' .` ; do grep -q '<linux/prefetch.h>' $i if [ $? = 0 ] ; then continue fi ( echo '?^#include <linux/?a' echo '#include <linux/prefetch.h>' echo . echo w echo q ) | ed -s $i > /dev/null 2>&1 if [ $? != 0 ]; then echo $i needs manual fixup MANUAL="$i $MANUAL" fi done echo ------------------- 8\<---------------------- echo vi $MANUAL ========================================= Signed-off-by: Paul <paul.gortmaker@windriver.com> [ Fixed up some incorrect #include placements, and added some non-network drivers and the fib_trie.c case - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-04ixgb: convert to set_phys_idJeff Kirsher
Based on the original patch sent by Stephen Hemminger. This version incorporates the ethtool changes that Bruce Allan submitted. CC: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Evan Swanson <evan.swanson@intel.com>
2011-04-29ethtool: cosmetic: Use ethtool ethtool_cmd_speed APIDavid Decotigny
This updates the network drivers so that they don't access the ethtool_cmd::speed field directly, but use ethtool_cmd_speed() instead. For most of the drivers, these changes are purely cosmetic and don't fix any problem, such as for those 1GbE/10GbE drivers that indirectly call their own ethtool get_settings()/mii_ethtool_gset(). The changes are meant to enforce code consistency and provide robustness with future larger throughputs, at the expense of a few CPU cycles for each ethtool operation. All drivers compiled with make allyesconfig ion x86_64 have been updated. Tested: make allyesconfig on x86_64 + e1000e/bnx2x work Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ethtool: Use full 32 bit speed range in ethtool's set_settingsDavid Decotigny
This makes sure the ethtool's set_settings() callback of network drivers don't ignore the 16 most significant bits when ethtool calls their set_settings(). All drivers compiled with make allyesconfig on x86_64 have been updated. Signed-off-by: David Decotigny <decot@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-11ixgb: convert to new VLAN modelEmil Tantilov
Based on a patch from Jesse Gross <jesse@nicira.com> This switches the ixgb driver to use the new VLAN interfaces. In doing this, it completes the work begun in ae54496f9e8d40c89e5668205c181dccfa9ecda1 allowing the use of hardware VLAN insertion without having a VLAN group configured. CC: Jesse Gross <jesse@nicira.com> Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-12-16net: Fix drivers advertising HW_CSUM feature to use csum_startMichał Mirosław
Some drivers are using skb_transport_offset(skb) instead of skb->csum_start for NETIF_F_HW_CSUM offload. This does not matter now, but if someone implements checksumming of encapsulated packets then this will break silently. TSO output paths are left as they are, since they are for IP+TCP only (might be worth converting though). Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12drivers/net: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is on its way out. This patch contains simple conversions to replace flush_scheduled_work() usage with direct cancels and flushes. Directly cancel the used works on driver detach and flush them in other cases. The conversions are mostly straight forward and the only dangers are, * Forgetting to cancel/flush one or more used works. * Cancelling when a work should be flushed (ie. the work must be executed once scheduled whether the driver is detaching or not). I've gone over the changes multiple times but it would be much appreciated if you can review with the above points in mind. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jay Cliburn <jcliburn@gmail.com> Cc: Michael Chan <mchan@broadcom.com> Cc: Divy Le Ray <divy@chelsio.com> Cc: e1000-devel@lists.sourceforge.net Cc: Vasanthy Kolluri <vkolluri@cisco.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Andrew Gallatin <gallatin@myri.com> Cc: Francois Romieu <romieu@fr.zoreil.com> Cc: Ramkrishna Vepa <ramkrishna.vepa@exar.com> Cc: Matt Carlson <mcarlson@broadcom.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Shreyas Bhatewara <sbhatewara@vmware.com> Cc: netdev@vger.kernel.org
2010-12-10ixgb: Don't check for vlan group on transmitEmil Tantilov
Based on a patch from Jesse Gross. Enable vlan tag insertion even when vlan group is not configured. For ixgb HW both CTRL0.VME and VLE bit in the Tx descriptor need to be set in order to enable HW acceleration. Introduced separate functions for enabling/disabling of vlan tag stripping similar to ixgbe. CC: Jesse Gross <jesse@nicira.com> Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2010-12-10Intel Wired LAN drivers: Use static constJeff Kirsher
Based on work by Joe Perches <joe@perches.com> Using static const to decrease data and overall object size. CC: Joe Perches <joe@perches.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com>
2010-11-27drivers/net: use vzalloc()Eric Dumazet
Use vzalloc() and vzalloc_node() in net drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Jon Mason <jon.mason@exar.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-28ixgb: call pci_disable_device in ixgb_removeEmil Tantilov
ixgb fails to work after reload on recent kernels: rmmod ixgb (dev->current_state = PCI_UNKNOWN) modprobe ixgb (pci_enable_device will bail leaving current_state to PCI_UNKNOWN) ifup eth0 do_IRQ: 2.82 No irq handler for vector (irq -1) The issue was exposed by commit fcd097f31a6ee207cc0c3da9cccd2a86d4334785 PCI: MSI: Remove unsafe and unnecessary hardware access which avoids HW writes for power states != PCI_D0 CC: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com> Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21vlan: Rename VLAN_GROUP_ARRAY_LEN to VLAN_N_VID.Jesse Gross
VLAN_GROUP_ARRAY_LEN is simply the number of possible vlan VIDs. Since vlan groups will soon be more of an implementation detail for vlan devices, rename the constant to be descriptive of its actual purpose. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-26drivers/net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-22e1000/e1000e/igb/ixgb/ixgbe: set NETIF_F_HIGHDMA for VLAN feature flagsYi Zou
If the netdev->features is set with NETIF_F_HIGHDMA, we should set the corresponding netdev->vlan_features as well to allow VLAN netdev created on top of the real netdev to be able to also benefit from HIGHDMA on 32bit system, reducing the performance hit that is caused by __skb_linearize(), particularly for large send. This is fixed in this patch for all Intel e1000, e1000e, igb, ixgbe, and ixgbe drivers since this should be beneficial to all devices supported by these drivers. Signed-off-by: Yi Zou <yi.zou@intel.com> Tested-by: Emil Tantilov <emil.s.tantilov@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-02drivers/net: avoid some skb->ip_summed initializationsEric Dumazet
fresh skbs have ip_summed set to CHECKSUM_NONE (0) We can avoid setting again skb->ip_summed to CHECKSUM_NONE in drivers. Introduce skb_checksum_none_assert() helper so that we keep this assertion documented in driver sources. Change most occurrences of : skb->ip_summed = CHECKSUM_NONE; by : skb_checksum_none_assert(skb); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-25drivers/net: Remove address use from assignments of function pointersJoe Perches
"foo = &function" is more commonly written "foo = function" Done with coccinelle script: // <smpl> @r@ identifier f; @@ f(...) { ... } @@ identifier r.f; @@ - &f + f // </smpl> drivers/net/tehuti.c used a function and struct with the same name, the function was renamed. Compile tested x86 only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-08e100/e1000*/igb*/ixgb*: Add missing read memory barrierJeff Kirsher
Based on patches from Sonny Rao and Milton Miller... Combined the patches to fix up clean_tx_irq and clean_rx_irq. The PowerPC architecture does not require loads to independent bytes to be ordered without adding an explicit barrier. In ixgbe_clean_rx_irq we load the status bit then load the packet data. With packet split disabled if these loads go out of order we get a stale packet, but we will notice the bad sequence numbers and drop it. The problem occurs with packet split enabled where the TCP/IP header and data are in different descriptors. If the reads go out of order we may have data that doesn't match the TCP/IP header. Since we use hardware checksumming this bad data is never verified and it makes it all the way to the application. This bug was found during stress testing and adding this barrier has been shown to fix it. The bug can manifest as a data integrity issue (bad payload data) or as a BUG in skb_pull(). This was a nasty bug to hunt down, if people agree with the fix I think it's a candidate for stable. Previously Submitted to e1000-devel only for ixgbe http://marc.info/?l=e1000-devel&m=126593062701537&w=3 We've now seen this problem hit with other device drivers (e1000e mostly) So I'm resubmitting with fixes for other Intel Device Drivers with similar issues. CC: Milton Miller <miltonm@bga.com> CC: Anton Blanchard <anton@samba.org> CC: Sonny Rao <sonnyrao@us.ibm.com> CC: stable <stable@kernel.org> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14ixgb and e1000: Use new function for copybreak testsJoe Perches
There appears to be an off-by-1 defect in the maximum packet size copied when copybreak is speified in these modules. The copybreak module params are specified as: "Maximum size of packet that is copied to a new buffer on receive" The tests are changed from "< copybreak" to "<= copybreak" and moved into new static functions for readability. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgb: use DMA API instead of PCI DMA functionsNick Nunley
Signed-off-by: Nicholas Nunley <nicholasx.d.nunley@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27ixgb: Use pr_<level> and netdev_<level>Joe Perches
Convert DEBUGOUTx to pr_debug Convert DEBUGFUNC to more commonly used ENTER Convert mac address output to %pM Use #define pr_fmt Convert a few printks to pr_<level> Improve ixgb_mc_addr_list_update: use a temporary for current mc address Use etherdevice.h functions for mac address testing Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22net: convert multiple drivers to use netdev_for_each_mc_addr, part4Jiri Pirko
2010-02-16drivers/net/ixgb: Use netif_printk macrosJoe Perches
Convert private DPRINTK macro uses to netif_<level> equivalents Remove #define DPRINTK Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: use netdev_mc_count and netdev_mc_empty when appropriateJiri Pirko
This patch replaces dev->mc_count in all drivers (hopefully I didn't miss anything). Used spatch and did small tweaks and conding style changes when it was suitable. Jirka Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23Merge branch 'master' of ↵David S. Miller
2010-01-20e1000/e1000e/igb/igbvf/ixgb/ixgbe: Fix tests of unsigned in *_tx_map()Roel Kluin
The variable count and i are unsigned so the (<|>=)0 tests do not work. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07drivers/net/: use DEFINE_PCI_DEVICE_TABLE()Alexey Dobriyan
Use DEFINE_PCI_DEVICE_TABLE() so we get place PCI ids table into correct section in every case. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-02ixgb: remove use of skb_dma_map from ixgbAlexander Duyck
skb_dma_map is incompatible with HW iommu due to the fact that multiple mappings can result in different results each time. For this reason it is best to just remove use of these function calls. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18drivers/net: request_irq - Remove unnecessary leading & from second argJoe Perches
Not as fancy as coccinelle. Checkpatch errors ignored. Compile tested allyesconfig x86, not all files compiled. grep -rPl --include=*.[ch] "\brequest_irq\s*\([^,\)]+,\s*\&" drivers/net | while read file ; do \ perl -i -e 'local $/; while (<>) { s@(\brequest_irq\s*\([^,\)]+,\s*)\&@\1@g ; print ; }' $file ;\ done Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13ixgb: Fix erroneous display of stats by ethtool -SAjit Khaparde
Commit 5675f221 overlooked the way offsets for netdev stats were considered. Because of this some of the stats shown by ethtool -S were wrong. This patch fixes it. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
2009-10-07ixgb: Use the instance of net_device_stats from net_device.Ajit Khaparde
Since net_device has an instance of net_device_stats, we can remove the instance of this from the private adapter structure. Signed-off-by: Ajit Khaparde <ajitk@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01intel: convert drivers to netdev_tx_tStephen Hemminger
Get rid of some bogus return wrapping as well. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-01ixgb: return PCI_ERS_RESULT_DISCONNECT on permanent failureDean Nelson
PCI drivers that implement the struct pci_error_handlers' error_detected callback should return PCI_ERS_RESULT_DISCONNECT if the state passed in is pci_channel_io_perm_failure. This patch fixes the issue for ixgb. Signed-off-by: Dean Nelson <dnelson@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08net: skb_shared_info optimizationEric Dumazet
skb_dma_unmap() is quite expensive for small packets, because we use two different cache lines from skb_shared_info. One to access nr_frags, one to access dma_maps[0] Instead of dma_maps being an array of MAX_SKB_FRAGS + 1 elements, let dma_head alone in a new dma_head field, close to nr_frags, to reduce cache lines misses. Tested on my dev machine (bnx2 & tg3 adapters), nice speedup ! Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_start in 10GB driversEric Dumazet
Followup of commits 9d21493b4beb8f918ba248032fefa393074a5e2b and 08baf561083bc27a953aa087dd8a664bb2b88e8e (net: tx scalability works : trans_start) (net: txq_trans_update() helper) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Multi queue drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers (vxge & tehuti) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-07e1000/e1000e/igb/ixgb: don't txhang after link downJesse Brandeburg
after the recent changes to wired drivers to use only netif_carrier_off the driver can have outstanding tx work to complete that will never complete once link is down. Since the intel hardware will hold this tx work forever, the driver notices a tx timeout condition internally and might try to instigate printk and reset of the part with a netif_stop_queue, which doesn't work because link is down. Don't bother arming to tx hang detection when link is down. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-29ixgb: Use generic MDIO definitionsBen Hutchings
Compile-tested only. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-22e1000/e1000e/igb/ixgb: do not use netif_wake_queue un-necessarilyJesse Brandeburg
It was pointed out that the Intel wired ethernet drivers do not need to wake the tx queue since netif_carrier_on/off will take care of the qdisc management in order to guarantee the correct handling of the transmit routine enable state. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-20ixgb: fix link down initial stateJesse Brandeburg
As reported by Andrew Lutomirski <amluto@gmail.com> All the intel wired ethernet drivers were calling netif_carrier_off and netif_stop_queue (or variants) before calling register_netdevice This is incorrect behavior as was pointed out by davem, and causes ifconfig and friends to report a strange state before first link after the driver was loaded, since without a netif_carrier_off, the stack assumes carrier_on, but before register_netdev, netlink messages are not sent out telling link state. This apparently confused *some* versions of networkmanager. in addition this driver appeared to need a netif_start_queue at the end of open. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Reported-by: Andrew Lutomirski <amluto@gmail.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-13drivers/net: replace BUG() with BUG_ON() if possibleAlexander Beregalov
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07dma-mapping: replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64)Yang Hongyang
Replace all DMA_64BIT_MASK macro with DMA_BIT_MASK(64) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-20ixgb: refactor tx path to use skb_dma_map/unmapAlexander Duyck
This code updates ixgb so that it can use the skb_dma_map/unmap functions to map the buffers. In addition it also updates the tx hang logic to use time_stamp instead of dma to determine if it has detected a tx hang. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-26net: Fix warning fallout from recent NAPI interface changes.David S. Miller
When we removed the network device argument from several NAPI interfaces in 908a7a16b852ffd618a9127be8d62432182d81b4 ("net: Remove unused netdev arg from some NAPI interfaces.") several drivers now started getting unused variable warnings. This fixes those up. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-27ixgb: cleanup link up/down messagesJeff Kirsher
The system log messages created on a link status change need to follow a specific format to work with tools some customers use. This also makes the messages consistant with other Intel driver link messages. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
