This change updates the PHY setup code to support 100Mbps capable PHYs
as well as 10G and 1Gbps.
Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com>
Tested-by: Stephen Ko <stephen.s.ko@intel.com>
This patch enables flow control pause parameters auto-negotiation support
to 82599 based 10G Base-T, backplane devices and multi-speed fiber optics
modules at 1G speed
Updating the copyrights for 2011 as well as make the ixgbe_copyright string
a constant.
Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com>
Adds the new x540.c file and Aquantia 1202 PHY for X540 support.
The new MAC type X540 shares much of the same functionality of
some silicon specific functions. To reduce duplicate code,
made these functions generic.
Add support for 1G SFP+ PHY's to 82599.
This adds support for a new copper device for 82599, device id 0x151c.
This 82599 10GBase-T device uses the PHY's internal temperature sensor
to guard against over-temp conditions. In this scenario the PHY will be
put in a low power mode and link will no longer be able to transmit or
receive any data. When this occurs, the over-temp interrupt is latched
and driver logs this error message. A HW reset or power cycle is
required to clear this status.
Signed-off-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com>
This patch adds support of active DA cables. This is
renaming and adding some PHY type enumerations.
Signed-off-by: Shannon Nelson <shannon.nelson@intel.com>
The SFF specification for Direct Attach cable detection has now been
ratified. Previously, DA cable detect was looking at the Twinaxial bit in
byte 9 of the SFP+ EEPROM. The spec now defines active and passive DA
cables in byte 8 of the SFP+ EEPROM. This patch changes the cable
detection for both 82598 and 82599 SFP+ adapters to conform to the new
spec.
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
This patch does two things:
1) On 82599, the PHY is emedded in the MAC. On 82598, the SFP+ NIC has an external PHY. The reset in the SFP+ setup patch for 82598 is unnecessary on 82599, and adds extra dead time to device initialization. This removes that PHY reset for 82599 only.
2) On 82599, the SFP+ modules are multispeed fiber modules (10G/1G). We need to make sure to identify them properly for the remaining init sections to properly set them up.
This patch adds the hardware initialization code specific to 82599. This
is similar to the 82598 hardware initialization code. It also includes all
changes to the existing hardware init code to support 82599.
New year, new copyright date ranges. Also bump the driver version
number to reflect many of the recent changes.
This patch adds support for SFP+ PHY in the following device ID's (10DB,
10F1, 10E1). These SFP+ PHY's are accessed via an I2C interface so the
patch also includes functions to support this.
Another feature of note is that the PHY is pluggable and some
rearchitecting was needed to support this.
Signed-off-by: Donald Skidmore <donald.c.skidmore@intel.com>
Intel is currently shipping support for adapters with a phy
that does 10GBase-T (copper), which is 10 Gigabit ethernet
over standard Category 6 cabling.
Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
This patch cleans up a bit of whitespace issues with the driver, updates
the copyright information, and bumps the version number up.
This is a massive update that includes infrastructure for further patches
where we will add support for more phy types and eeprom types.
This code is shared as much as possible with other drivers, so the code may
seem a little obtuse at times but wherever possible we keep to the linux
style and methods.
While cleaning up the internal API focussing on Fiber and CX4 code
we found that I had broken the copper PHY initialization code. This
patch restores the PHY-specific code. This is mostly uninteresting
since no copper PHY boards are yet available. The changes have been
tested against Fiber only as I do not even have copper PHY versions
of 82598 macs.
This change actually cleans up the API code a bit more and we
lose some initialization code. A few PHY link detection helper
lines of code have been snuck into this patch, as well as a
read flush where it was suspected that this might cause issues.
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
This patch adds support for the Intel 82598 PCI-Express 10GbE
chipset. Devices will be available on the market soon.
This version of the driver is largely the same as the last release:
* Driver uses a single RX and single TX queue, each using 1 MSI-X
irq vector.
* Driver runs in NAPI mode only
* Driver is largely multiqueue-ready (TM)
Changes since 20070803:
* removed wrappers for hardware functions
* incorporated e1000e-style HW api reorganization code
* sparse/checkpatch cleanups, namespace cleanups
* driver prints out extra debugging information at load time
identifying adapter board number, mac, phy types
* removed ixgbe_api.c, ixgbe_api.h, ixgbe_osdep.h
* driver update to 1.1.18
* removed ixgbe.txt which contained no useful info anymore
[ Integrated napi_struct changes from Auke as well... -DaveM ]
Signed-off-by: Ayyappan Veeraiyan <ayyappan.veeraiyan@intel.com>
