path: root/drivers/net/ks8842.c
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-31Merge branch 'master' of ↵David S. Miller
2011-05-31drivers/net: ks8842 Fix crash on received packet when in PIO mode.Dennis Aberilla
This patch fixes a driver crash during packet reception due to not enough bytes allocated in the skb. Since the loop reads out 4 bytes at a time, we need to allow for up to 3 bytes of slack space. Signed-off-by: Dennis Aberilla <denzzzhome@yahoo.com> Signed-off-by: David S. Miller <davem@zippy.davemloft.net>
2011-05-26mfd: Use mfd cell platform_data for timberdale cells platform bitsSamuel Ortiz
With the addition of a device platform mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: mfd_cell is now implicitly available to timberdale driversAndres Salomon
The cell's platform_data is now accessed with a helper function; change clients to use that, and remove the now-unused data_size. Note that the mfd's platform_data is marked __devinitdata. This is still correct in all cases except for the timbgpio driver, whose remove hook has been changed to no longer reference the pdata. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-07-27ks8842: Fix warnings on 64-bit.David S. Miller
drivers/net/ks8842.c:922:26: warning: cast from pointer to integer of different size drivers/net/ks8842.c:940:17: warning: cast to pointer from integer of different size drivers/net/ks8842.c:963:17: warning: cast to pointer from integer of different size Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-27ks8842: Support DMA when accessed via timberdaleRichard Röjfors
This patch adds support for RX and TX DMA via the DMA API, this is only supported when the KS8842 is accessed via timberdale. There is no support for DMA on the generic bus interface it self, a state machine inside the FPGA is handling RX and TX transfers to/from buffers in the FPGA. The host CPU can do DMA to and from these buffers. The FPGA has to handle the RX interrupts, so these must be enabled in the ks8842 but not in the FPGA. The driver must not disable the RX interrupt that would mean that the data transfers into the FPGA buffers would stop. The host shall not enable TX interrupts since TX is handled by the FPGA, the host is notified by DMA callbacks when transfers are finished. Which DMA channels to use are added as parameters in the platform data struct. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-26ks8842: Support 100Mbps when accessed via timberdaleRichard Röjfors
This patch removes the code which disables 100Mbps advertising when the ks8842 is accessed via timberdale. At higher speed it's good to be nice to the internal state machine of timberdale by acking interrupts. That is done by a write to the interrupt ack register (IAR). Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-19ks8842: Fix ks8842_tx_frame() for 16bit case.David S. Miller
As reported by Andrew: drivers/net/ks8842.c: In function 'ks8842_handle_rx': drivers/net/ks8842.c:428: warning: 'status' may be used uninitialized in this function Just use the 32-bit status for all reads, and delete the useless cast to 'int' when reading a u16 into 'len'. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-13drivers/net: Add Micrel KS8841/42 support to ks8842 driverDavid J. Choi
Body of the explanation: -support 16bit and 32bit bus width. -add device reset for ks8842/8841 Micrel device. -set 100Mbps as a default for Micrel device. -set MAC address in both MAC/Switch layer with different sequence for Micrel device, as mentioned in data sheet. -use private data to set options both 16/32bit bus width and Micrel device/ Timberdale(FPGA). -update Kconfig in order to put more information about ks8842 device. Signed-off-by: David J. Choi <david.choi@micrel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-08ks8842: Remove unnecessary bank select.Richard Röjfors
This patch removes an unnecessary bank select before resetting the controller. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-08ks8842: Do the TX timeout work in workqueue context.Richard Röjfors
Currently all code that needs to be run at TX timeout is done in the calling context, where bottom halves are disabled. Some of the code blocks, so it needs to be done in a different context. This patch adds in a work struct which is scheduled at TX timeout. Then the timeout code is executed within work queue context. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-05ks8842: Replace usage of dev_dbg with netdev_dbgRichard Röjfors
This patch replaces all usage of dev_dbg with netdev_dbg. A side effect is that the pointer to the platform device in the adapter struct can be removed. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-21ks8842: Add platform data for setting mac addressRichard Röjfors
This patch adds platform data to the ks8842 driver. Via the platform data a MAC address, to be used by the controller, can be passed. To ensure this MAC address is used, the MAC address is written after each hardware reset. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16drivers/net/ks*: Use netdev_<level>, netif_<level> and pr_<level>Joe Perches
I'm not sure this is correct. It changes logging macros from: dev_<level>(&ks->spidev->dev, to netdev_<level>(ks->netdev, Comments? Use netdev_<level> Use netif_<level> Use pr_<level> Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Add missing line to message in ks8851_remove Change kmalloc/memset(,0) to kzalloc Remove ks_<level> macros Consolidation code into set_media_state Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13net: Use netdev_alloc_skb_ip_align()Eric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02netdev: drivers should make ethtool_ops constStephen Hemminger
No need to put ethtool_ops in data, they should be const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08netdev: Added KS8842 driverRichard Ršöjfors
This is a driver for the Micrel KS8842 ethernet switch. The supplied code is for driving the KS8842 through the Timberdale FPGA on the Russellville board, a development board for Intel Atom CPU in the automotive area. Signed-off-by: Richard Röjfors <richard.rojfors.ext@mocean-labs.com> Signed-off-by: David S. Miller <davem@davemloft.net>
