path: root/drivers/net/ksz884x.c
2011-01-03ksz884x: Fix section mismatch derived from pcidev_init()Sedat Dilek
This fixes the following warning: WARNING: drivers/net/ksz884x.o(.data+0x18): Section mismatch in reference from the variable pci_device_driver to the function .init.text:pcidev_init() The variable pci_device_driver references the function __init pcidev_init() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, Tested with linux-next (next-20101231) Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-21drivers/net/*.c: Use static constJoe Perches
Using static const generally increases object text and decreases data size. It also generally decreases overall object size. Signed-off-by: Joe Perches <joe@perches.com>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-07-23drivers: net: use newly introduced hex_to_bin()Andy Shevchenko
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-05ksz884x: Use the instance of net_device_stats from net_device.Kulikov Vasiliy
Since net_device has an instance of net_device_stats, we can remove the instance of this from the adapter structure. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-15bridge: use rx_handler_data pointer to store net_bridge_port pointerJiri Pirko
Register net_bridge_port pointer as rx_handler data pointer. As br_port is removed from struct net_device, another netdev priv_flag is added to indicate the device serves as a bridge port. Also rcuized pointers are now correctly dereferenced in br_fdb.c and in netfilter parts. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01ksz884x: Add missing validate_addr hookDenis Kirjanov
Add missing validate_addr hook Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01ksz884x: convert to netdev_tx_tDenis Kirjanov
Convert TX hook to netdev_tx_t type Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17drivers/net: Use kcalloc or kzallocJulia Lawall
Use kcalloc or kzalloc rather than the combination of kmalloc and memset. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,y,flags; statement S; type T; @@ x = - kmalloc + kcalloc ( - y * sizeof(T), + y, sizeof(T), flags); if (x == NULL) S -memset(x, 0, y * sizeof(T)); @@ expression x,size,flags; statement S; @@ -x = kmalloc(size,flags); +x = kzalloc(size,flags); if (x == NULL) S -memset(x, 0, size); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14drivers: net: use skb_headlen()Eric Dumazet
replaces (skb->len - skb->data_len) occurrences by skb_headlen(skb) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13drivers: net: last_rx eliminationEric Dumazet
Network drivers do not have to update last_rx, unless they need it for their private use. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-03net: convert multicast list to list_headJiri Pirko
Converts the list and the core manipulating with it to be the same as uc_list. +uses two functions for adding/removing mc address (normal and "global" variant) instead of a function parameter. +removes dev_mcast.c completely. +exposes netdev_hw_addr_list_* macros along with __hw_addr_* functions for manipulation with lists on a sandbox (used in bonding and 80211 drivers) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-30net: remove redundant codeEric Dumazet
eth_type_trans(skb, netdev) does the "skb->dev = netdev;" initialization, we can remove it from various network drivers. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-23ksz884x: fix return value of netdev_set_eepromJens Rottmann
ksz884x: fix return value of netdev_set_eeprom netdev_set_eeprom() confused ethtool by just returning 1 on error instead of a proper -EINVAL. Signed-off-by: Jens Rottmann <JRottmann@LiPPERTEmbedded.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-18net: remove unused #include <linux/version.h>Huang Weiyi
Remove unused #include <linux/version.h>('s) in drivers/net/ksz884x.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16drivers/net/ks*: Use netdev_<level>, netif_<level> and pr_<level>Joe Perches
I'm not sure this is correct. It changes logging macros from: dev_<level>(&ks->spidev->dev, to netdev_<level>(ks->netdev, Comments? Use netdev_<level> Use netif_<level> Use pr_<level> Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt Add missing line to message in ks8851_remove Change kmalloc/memset(,0) to kzalloc Remove ks_<level> macros Consolidation code into set_media_state Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16NET: ksz884x, fix lock imbalanceJiri Slaby
Stanse found that one error path (when alloc_skb fails) in netdev_tx omits to unlock hw_priv->hwlock. Fix that. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Tristram Ha <Tristram.Ha@micrel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-26net: convert multiple drivers to use netdev_for_each_mc_addr, part5 V2Jiri Pirko
removed some needless checks and also corrected bug in lp486e (dmi was passed instead of dmi->dmi_addr) Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-12net: Micrel KSZ8841/2 PCI Ethernet driverTristram Ha
This is a new network driver for Micrel KSZ8841/KSZ8842 PCI Ethernet chips. The same driver can run both chips at the same time. It supports IPv4 TCP hardware checksumming and so can use scatter/gather transmission. The KSZ8842 switch has 2 ports. Some users like to take direct control of those ports. So KSZ8842 has a multiple devices mode in which the driver creates another network device so that users can specify which port to send packets. This mode is enabled by passing the "multi_dev=1" parameter to the driver during loading. The KSZ884X can receive huge frames with size up to 1916 bytes. To use this feature change the network device MTU from 1500 to 1898. The KSZ884X driver has 3 packet receive processing functions for the normal mode, multiple devices mode, and huge frame mode. Those functions are identical except for more checking for the new features. In normal programming point of view the huge frame version is the one to use because it covers all the cases, but this is done for performance consideration because the target clients for the KSZ884X chips are embedded systems, which unlike desktop PC may not have powerful CPU. Signed-off-by: Tristram Ha <Tristram.Ha@micrel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
