path: root/drivers/net/mac8390.c
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-04m68k: Mac DP8390 updateFinn Thain
Fix the support for C/NET nubus ethernet cards etc. Sync up the DP8390 driver with the latest code in the mac68k repo. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-02[PATCH] 8390 fixes - m68k oddballsAl Viro
more 8390 conversions - mac8390, zorro8390 and hydra got the same treatment as arm etherh; one more case in 8390.h ifdef cascade is gone. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-01-12[PATCH] m68k: lvalues abuse in mac8390Al Viro
Cast is not an lvalue Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
