path: root/drivers/net/myri10ge/myri10ge_mcp_gen_header.h
2011-08-11myri*: Move the Myricom driversJeff Kirsher
Move the Myricom drivers into drivers/net/ethernet/myricom/ and make the necessary Kconfig and Makefile changes. CC: Andrew Gallatin <gallatin@myri.com> CC: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-06-29myri10ge: add support for set_phys_idJon Mason
Add myri10ge driver support for the ethtool identify operation. NOTE: Rather than blinking (which is the normal case), when identify is used, the yellow LED turns solid. Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-24myri10ge: update firmware headers to 1.4.41Brice Goglin
Update myri10ge firmware headers to firmware version 1.4.41. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25myri10ge: update firmware headers to 1.4.37Brice Goglin
Update myri10ge firmware headers to 1.4.37: * Make each member of the error/cmd enum an initialized one, so there is a convenient numerical reference to look for reverse conversion. * Add new MXGEFW_CMD_RELAX_RXBUFFER_ALIGNMENT command. * Add new "features" field to mcp_header. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-23myri10ge: update firmware headersBrice Goglin
Update myri10ge firmware headers. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-07myri10ge: update firmware headersBrice Goglin
Update myri10ge firmware headers. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-13myri10ge: update firmware headersBrice Goglin
Update myri10ge firmware headers. Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew Gallatin <gallatin@myri.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2006-12-04[PATCH] myri10ge annotationsAl Viro
2006-05-24[netdrvr pcnet_cs, myri] trim trailing whitespaceJeff Garzik
2006-05-24[PATCH] Add Myri-10G Ethernet driverBrice Goglin
Signed-off-by: Brice Goglin <brice@myri.com> Signed-off-by: Andrew J. Gallatin <gallatin@myri.com> drivers/net/Kconfig | 17 drivers/net/Makefile | 1 drivers/net/myri10ge/Makefile | 5 drivers/net/myri10ge/myri10ge.c | 2851 +++++++++++++++ drivers/net/myri10ge/myri10ge_mcp.h | 205 + drivers/net/myri10ge/myri10ge_mcp_gen_header.h | 58 include/linux/pci_ids.h | 1 7 files changed, 3138 insertions(+) Signed-off-by: Jeff Garzik <jeff@garzik.org>
