path: root/drivers/net/ne.c
2010-07-05net/ne: fix memory leak in ne_drv_probe()Kulikov Vasiliy
net_device allocated with alloc_eip_netdev() must be freed. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-14drivers/net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from drivers/net/ all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. It also does not remove null void functions with return. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' with some cleanups by hand. Compile tested x86 allmodconfig only. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-16ne: Do not use slashes in irq name stringAtsushi Nemoto
This patch fixes following warning introduced by commit 12bac0d9f4dbf3445a0319beee848d15fa32775e ("proc: warn on non-existing proc entries"): WARNING: at /work/mips-linux/make/linux/fs/proc/generic.c:316 __xlate_proc_name+0xe0/0xe8() name 'RBHMA4X00/RTL8019' Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-25drivers/net: fix sparse warning: use ANSI-style function declarationHannes Eder
Fix this sparse warning: drivers/net/ne.c:932:24: warning: non-ANSI function declaration of function 'init_module' Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25ne2000: convert to net_device_opsStephen Hemminger
Last driver for today. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-24ne.c: fix rmmod, platform driver improvementsDavid Fries
Removing the module would cause a kernel oops as platform_driver_probe failed to detect a device and unregistered the platform driver on module init, and cleanup_module would unregister the already unregistered driver. The suspend and resume functions weren't being called. platform_driver support was added earlier, but without any platform_device_register* calls I don't think it was being used. Now all devices are registered using platform_device_register_simple and pointers are kept to unregister the ones that the probe failed for or unregister all devices on module shutdown. init_module no longer calls ne_init to reduce confusion (and multiple unregister paths that caused the rmmod oops). With the devices now registered they are added to the platform driver and get suspend and resume events. netif_device_detach(dev) was added before unregister_netdev(dev) when removing the region as occationally I would see a race condition where the device was still being used in unregister_netdev. Signed-off-by: David Fries <david@fries.net> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-09-24[netdrvr] ne: Fix suspend and resume for ISA PnP cards.David Fries
A call to pnp_stop_dev and pnp_start_dev now shuts down and initializes plug and play devices for suspend and resume. Signed-off-by: David Fries <david@fries.net> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-08-14[netdrvr] ne: Use CONFIG_MACH_TX49XXAtsushi Nemoto
After some cleanups in arch/mips area, now MACH_TX49XX is selected for both TOSHIBA_RBTX4927 and TOSHIBA_RBTX4938. Fold these two conditions to one. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-30fix NE2000 linkage errorMikael Pettersson
Trying to build with CONFIG_NE2000=m fails with: scripts/mod/modpost -o /tmp/tmp/linux-2.6.27-rc1/Module.symvers -S -s ERROR: "NS8390_init" [drivers/net/ne.ko] undefined! This is because the split of 8390 into pausing and non-pausing versions was incompletely propagated to ne.c. This fixes it. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-22net 8390p: fix interface usageIngo Molnar
various drivers were using the wrong APIs: drivers/built-in.o: In function `hp_probe1': hp.c:(.init.text+0xa280): undefined reference to `NS8390_init' fixed via: cd drivers/net/; sed -i 's/NS8390_/NS8390p_/g' \ $(grep -l NS8390_ $(grep 8390p.o Makefile | cut -d' ' -f3 | \ sed 's/.o$/.c/g')) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-048390: Split 8390 support into a pausing and a non pausing driver coreAlan Cox
Only a few ISA controllers need the pausing version of the 8390 core while PCMCIA, later ISA and PCI do not. More importantly the ISA delays can break non ISA boxes so we must use a different build of 8390.c for the two sets of controllers. No changes since last time as all the points of concerns raised proved to be invalid Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-10[NET]: Introduce and use print_mac() and DECLARE_MAC_BUF()Joe Perches
This is nicer than the MAC_FMT stuff. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10drivers/net/: all drivers/net/ cleanup with ARRAY_SIZEDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-08ne: MIPS: Use platform_driver for ne on RBTX49XXAtsushi Nemoto
This patch lets RBTX49XX boards use generic platform_driver interface for the ne driver. * Use platform_device to pass ioaddr and irq to the ne driver. * Remove unnecessary ifdefs for RBTX49XX from the ne driver. * Make the ne driver selectable on these boards regardless of CONFIG_ISA Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08ne: Add NEEDS_PORTLIST to control ISA auto-probeAtsushi Nemoto
Add NEEDS_PORTLIST cpp macro to control ISA auto-probe. (I'm not sure M32R needs auto-probe but it is current behavior) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08ne: Misc fixes for platform driver.Atsushi Nemoto
Miscellaneous fixes to make ne platform driver work properly. * Make ioaddr 'unsigned long'. * Move a printk down to show dev->name assigned in register_netdev. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-08ne: Add platform_driverAtsushi Nemoto
Add a platform_driver interface to ne driver. (Existing legacy ports did not covered by this ne_driver for now) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] trivial missing __init in drivers/net/*Al Viro
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-06-11[PATCH] Section mismatch in drivers/net/ne.o during modpostRandy.Dunlap
On Sat, 10 Jun 2006 14:11:42 +0200 (MEST) Mikael Pettersson wrote: > While compiling 2.6.17-rc6 for a 486 with an NE2000 ISA ethernet card, I got: > > WARNING: drivers/net/ne.o - Section mismatch: reference to .init.data:isapnp_clone_list from .text between 'init_module' (at offset 0x158) and 'ne_block_input' > WARNING: drivers/net/ne.o - Section mismatch: reference to .init.data:isapnp_clone_list from .text between 'init_module' (at offset 0x176) and 'ne_block_input' > WARNING: drivers/net/ne.o - Section mismatch: reference to .init.data:isapnp_clone_list from .text between 'init_module' (at offset 0x183) and 'ne_block_input' > WARNING: drivers/net/ne.o - Section mismatch: reference to .init.data:isapnp_clone_list from .text between 'init_module' (at offset 0x1ea) and 'ne_block_input' > WARNING: drivers/net/ne.o - Section mismatch: reference to .init.data:isapnp_clone_list from .text between 'init_module' (at offset 0x251) and 'ne_block_input' > WARNING: drivers/net/ne.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x266) and 'ne_block_input' > WARNING: drivers/net/ne.o - Section mismatch: reference to .init.text: from .text between 'init_module' (at offset 0x29b) and 'ne_block_input' > > Not sure how serious this is; the driver seems to work fine later on. Doesn't look serious. init_module() is not __init, but it calls some __init functions and touches some __initdata. BTW, I would be happy to see some consistent results from modpost section checking. I don't see all of these warnings (I see only 1) when using gcc 3.3.6. What gcc version are you using? Does that matter? (not directed at anyone in particular) Patch below fixes it for me. Please test/report. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-08Fix RTL8019AS init for Toshiba RBTX49xx boardsSergei Shtylyov
Ensure that 8-bit mode is selected for the on-board Realtek RTL8019AS chip on Toshiba RBHMA4x00, get rid of the duplicate #ifdef's when setting ei_status.word16. The chip's datasheet says that the PSTOP register shouldn't exceed 0x60 in 8-bit mode -- ensure this too. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
2006-04-20[PATCH] NEx000: fix RTL8019AS base address for RBTX4938Sergei Shtylyov
Correct the base address of the Realtek RTL8019AS chip on the Toshiba RBTX4938 board -- this should make the driver work at least when CONFIG_PCI is enabled. Signed-off-by: Yuri Shpilevsky <yshpilevsky@ru.mvista.com> Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-01-17[PATCH] drivers/net/*: use time_after() and friendsMarcelo Feitoza Parisi
They deal with wrapping correctly and are nicer to read. Also make jiffies-holding variables unsigned long. Signed-off-by: Marcelo Feitoza Parisi <marcelo@feitoza.com.br> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2006-01-09[PATCH] fix a few "warning: 'cleanup_card' defined but not used"Denis Vlasenko
These warnings are emitted if non-modular network drivers are built. Fixes just move cleanup_card() definitions into #ifdef MODULE region. /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/wd.c:131: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/3c503.c:152: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/ne.c:216: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/hp.c:106: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/hp-plus.c:142: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/smc-ultra.c:172: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/e2100.c:144: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/es3210.c:159: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/lne390.c:149: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/lance.c:313: warning: 'cleanup_card' defined but not used /.1/usr/srcdevel/kernel/linux-2.6.15-rc7.src/drivers/net/ac3200.c:127: warning: 'cleanup_card' defined but not used Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-18[PATCH] ne: Support for RBHMA4500 eval board.Ralf Baechle
Support for Toshiba's RBHMA4500 eval board for the TX4938. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> drivers/net/ne.c | 15 +++++++++++++++ 1 files changed, 15 insertions(+) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-07-27[PATCH] turn many #if $undefined_string into #ifdef $undefined_stringOlaf Hering
turn many #if $undefined_string into #ifdef $undefined_string to fix some warnings after -Wno-def was added to global CFLAGS Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-12[netdrvr] Fix register_netdev() races in older ISA net drivers
