path: root/drivers/net/niu.c
2009-10-21niu: VLAN_ETH_HLEN should be used to make sure that the whole MAC header was ↵Joyce Yu
copied to the head buffer in the Vlan packets case Signed-off-by: Joyce Yu <joyce.yu@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23BUILD_BUG_ON(): fix it and a couple of bogus uses of itJan Beulich
gcc permitting variable length arrays makes the current construct used for BUILD_BUG_ON() useless, as that doesn't produce any diagnostic if the controlling expression isn't really constant. Instead, this patch makes it so that a bit field gets used here. Consequently, those uses where the condition isn't really constant now also need fixing. Note that in the gfp.h, kmemcheck.h, and virtio_config.h cases MAYBE_BUILD_BUG_ON() really just serves documentation purposes - even if the expression is compile time constant (__builtin_constant_p() yields true), the array is still deemed of variable length by gcc, and hence the whole expression doesn't have the intended effect. [akpm@linux-foundation.org: make arch/sparc/include/asm/vio.h compile] [akpm@linux-foundation.org: more nonsensical assertions in tpm.c..] Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Cc: Mimi Zohar <zohar@us.ibm.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-09niu: Use resource_size instead of private functionTobias Klauser
The function res_size in drivers/net/niu.c is a copy of resource_size in linux/ioport.h. Remove the function and use resource_size instead. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01netdev: convert bulk of drivers to netdev_tx_tStephen Hemminger
In a couple of cases collapse some extra code like: int retval = NETDEV_TX_OK; ... return retval; into return NETDEV_TX_OK; Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12drivres/net: Change constant nameJulia Lawall
In this series of tests the constants have the form XRXMAC_STATUS, except in this one case. The values of XRXMAC_STAT_MSK_RXOCTET_CNT_EXP and XRXMAC_STATUS_RXOCTET_CNT_EXP are furthermore the same. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: group address list and its countJiri Pirko
This patch is inspired by patch recently posted by Johannes Berg. Basically what my patch does is to group list and a count of addresses into newly introduced structure netdev_hw_addr_list. This brings us two benefits: 1) struct net_device becames a bit nicer. 2) in the future there will be a possibility to operate with lists independently on netdevices (with exporting right functions). I wanted to introduce this patch before I'll post a multicast lists conversion. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 4 +- drivers/net/e1000/e1000_main.c | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/mv643xx_eth.c | 2 +- drivers/net/niu.c | 4 +- drivers/net/virtio_net.c | 10 ++-- drivers/s390/net/qeth_l2_main.c | 2 +- include/linux/netdevice.h | 17 +++-- net/core/dev.c | 130 ++++++++++++++++++-------------------- 9 files changed, 89 insertions(+), 90 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: convert unicast addr listJiri Pirko
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. It also relaxes the locking. Original spinlock (still used for multicast addresses) is not needed and is no longer used for a protection of this list. All reading and writing takes place under rtnl (with no changes). I also removed a possibility to specify the length of the address while adding or deleting unicast address. It's always dev->addr_len. The convertion touched especially e1000 and ixgbe codes when the change is not so trivial. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 13 +-- drivers/net/e1000/e1000_main.c | 24 +++-- drivers/net/ixgbe/ixgbe_common.c | 14 ++-- drivers/net/ixgbe/ixgbe_common.h | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/ixgbe/ixgbe_type.h | 4 +- drivers/net/macvlan.c | 11 +- drivers/net/mv643xx_eth.c | 11 +- drivers/net/niu.c | 7 +- drivers/net/virtio_net.c | 7 +- drivers/s390/net/qeth_l2_main.c | 6 +- drivers/scsi/fcoe/fcoe.c | 16 ++-- include/linux/netdevice.h | 18 ++-- net/8021q/vlan.c | 4 +- net/8021q/vlan_dev.c | 10 +- net/core/dev.c | 195 +++++++++++++++++++++++++++----------- net/dsa/slave.c | 10 +- net/packet/af_packet.c | 4 +- 18 files changed, 227 insertions(+), 137 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: dont update dev->trans_startEric Dumazet
Second round of drivers for Gb cards (and NIU one I forgot in the 10GB round) Now that core network takes care of trans_start updates, dont do it in drivers themselves, if possible. Drivers can avoid one cache miss (on dev->trans_start) in their start_xmit() handler. Exceptions are NETIF_F_LLTX drivers Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-26niu: Add support for C10NEMTanli Chang
This patch is for supporting C10NEM. C10NEM is a switch module, which has back-to-back XAUI link connected to blades. Signed-off-by: Tanli Chang <tanli.chang@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08niu: Fix unused variable warning.David S. Miller
Don't strain gcc's tiny mind. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-08niu: Fix error handlingDan Carpenter
platform_device_register_simple() returns ERR_PTR(), not NULL, if an error occurs. Found by smatch (http://repo.or.cz/w/smatch.git). Compile tested. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-29niu: Add GRO support.David S. Miller
2009-02-20niu: Add TCAM classification configurationSantwona Behera
Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18niu: improve ethtool support for gigabit copper cardsConstantin Baranov
Introduced support for link speed and duplex setting (ethtool -s), link advertising parameters and autonegotiation (ethtool -r): - struct niu_link_config: split advertising and autoneg fields into active and target values (similar to speed and duplex fields) - mii_init_common(): rewrite function to actually apply requested niu_link_config parameters instead of providing default initialization - link_status_1g(): move parsing of MII registers into new link_status_mii() function (link_status_1g_rgmii() could possibly use this new implementation too) - introduce simple nway_reset method - fix incorrect XMAC_CONFIG_MODE selection for 10Mbps case Signed-off-by: Constantin Baranov <baranov@mercdev.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-18niu: fix PHY template choice for 10G copperConstantin Baranov
Fixed a typo in niu_determine_phy_disposition() which resulted in phy_template_1g_copper being selected for 10G/copper configuration. Signed-off-by: Constantin Baranov <baranov@mercdev.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-17drivers/net/niu.c: fix sparse warning: symbol shadows an earlier oneHannes Eder
Impact: Move variable declaration to a more inner scope. Fix this sparse warning: drivers/net/niu.c:2399:21: warning: symbol 'err' shadows an earlier one drivers/net/niu.c:2287:13: originally declared here Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-27net: Add skb_record_rx_queue() calls to multiqueue capable drivers.David S. Miller
2009-01-21net: Remove redundant NAPI functionsBen Hutchings
Following the removal of the unused struct net_device * parameter from the NAPI functions named *netif_rx_* in commit 908a7a1, they are exactly equivalent to the corresponding *napi_* functions and are therefore redundant. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-25drivers/net: fix sparse warning: returning void-valued expressionHannes Eder
Fix this sparse warning: drivers/net/niu.c:8850:2: warning: returning void-valued expression Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-22net: Remove unused netdev arg from some NAPI interfaces.Neil Horman
When the napi api was changed to separate its 1:1 binding to the net_device struct, the netif_rx_[prep|schedule|complete] api failed to remove the now vestigual net_device structure parameter. This patch cleans up that api by properly removing it.. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-18NIU: Implement discard counters, optimizeJesper Dangaard Brouer
Optimize the lightly loaded case, by only synchronizing discards stats when qlen > 10 indicate potential for drops. Notice Robert Olsson might disagree with this patch. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-18NIU: Implement discard counters, info/debug statements.Jesper Dangaard Brouer
Discard packet counter debug statements that can be turned on at runtime by users to assist debugging of the driver code. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-18NIU: Implement discard countersJesper Dangaard Brouer
Implementing discard counters for the NIU driver turned out to be more complicated than first assumed. The discard counters for the NIU neptune chip are only 16-bit (even though this is a 64-bit chip). These 16-bit counters can overflow quickly, especially considering this is a 10Gbit/s ethernet card. The overflow indication bit is, unfortunatly, not usable as the counter value does not wrap, but remains at max value 0xFFFF. Resulting in lost counts until the counter is reset. The read and reset scheme also poses a problem. Both in theory and in practice counters can be lost in between reading nr64() and clearing the counter nw64(). For this reason, the number of counter clearings nw64() is limited/reduced. On the fast-path the counters are only syncronized once it exceeds 0x7FFF. When read by userspace, its syncronized fully. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-28niu: use net_device_stats nowadays available in net_deviceIlpo Järvinen
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25niu: fix another warning in drivers/net/niu.cIngo Molnar
this warning: drivers/net/niu.c: In function ‘esr_reset’: drivers/net/niu.c:741: warning: ‘reset’ may be used uninitialized in this function triggers because GCC does not recognize the (correct) error flow between: - esr_read_reset() and 'reset' Annotate it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25niu: fix warnings in drivers/net/niu.cIngo Molnar
these warnings: drivers/net/niu.c: In function ‘serdes_init_niu_1g_serdes’: drivers/net/niu.c:451: warning: ‘sig’ may be used uninitialized in this function drivers/net/niu.c: In function ‘serdes_init_niu_10g_serdes’: drivers/net/niu.c:550: warning: ‘sig’ may be used uninitialized in this function triggers because GCC does not recognize that the max_retry loop always initializes 'sig', due to max_retry != 0. Annotate them. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25niu: Naming interrupt vectors.Robert Olsson
A patch to put names on the niu interrupt vectors according the syntax below. This is needed to assign correct affinity. > So on a multiqueue card with 2 RX queues and 2 TX queues we'd > have names like: > > eth0-rx-0 > eth0-rx-1 > eth0-tx-0 > eth0-tx-1 Signed-off-by: Robert Olsson <robert.olsson@its.uu.se> Tested-by: Jesper Dangaard Brouer <jdb@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20netdev: add more functions to netdevice opsStephen Hemminger
This patch moves neigh_setup and hard_start_xmit into the network device ops structure. For bisection, fix all the previously converted drivers as well. Bonding driver took the biggest hit on this. Added a prefetch of the hard_start_xmit in the fast path to try and reduce any impact this would have. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19niu: convert to net_device_opsStephen Hemminger
Convert this driver to network device ops. Compile tested only (give me hw!) Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/isdn/i4l/isdn_net.c fs/cifs/connect.c
2008-11-14niu: Bump driver version and release date.David S. Miller
This driver is pretty mature, and the worst of the known problems has been fixed (the 32-bit failures due to readq implementation). So let's finally give it a version of 1.0 Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-14NIU: Add Sun CP3260 ATCA blade supportSantwona Behera
This patch adds support for the Sun CP3260 ATCA blade which is a N2 based ATCA blade with 2 NIU ports. The NIU ports do not have on-board PHY. Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-12niu: Fix readq implementation when architecture does not provide one.David S. Miller
This fixes a TX hang reported by Jesper Dangaard Brouer. When an architecutre cannot provide a fully functional 64-bit atomic readq/writeq, the driver must implement it's own. This is because only the driver can say whether doing something like using two 32-bit reads to implement the full 64-bit read will actually work properly. In particular one of the issues is whether the top 32-bits or the bottom 32-bits of the 64-bit register should be read first. There could be side effects, and in fact that is exactly the problem here. The TX_CS register has counters in the upper 32-bits and state bits in the lower 32-bits. A read clears the state bits. We would read the counter half before the state bit half. That first read would clear the state bits, and then the driver thinks that no interrupts are pending because the interrupt indication state bits are seen clear every time. Fix this by reading the bottom half before the upper half. Tested-by: Jesper Dangaard Brouer <jdb@comx.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath5k/base.c net/8021q/vlan_core.c
2008-11-03drivers/net: Kill now superfluous ->last_rx stores.David S. Miller
The generic packet receive code takes care of setting netdev->last_rx when necessary, for the sake of the bonding ARP monitor. Drivers need not do it any more. Some cases had to be skipped over because the drivers were making use of the ->last_rx value themselves. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-03niu: Use pci_ioremap_bar().David S. Miller
2008-10-27net: convert print_mac to %pMJohannes Berg
This converts pretty much everything to print_mac. There were a few things that had conflicts which I have just dropped for now, no harm done. I've built an allyesconfig with this and looked at the files that weren't built very carefully, but it's a huge patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6 Conflicts: arch/sparc64/kernel/pci_psycho.c
2008-09-12niu: panic on resetSantwona Behera
The reset_task function in the niu driver does not reset the tx and rx buffers properly. This leads to panic on reset. This patch is a modified implementation of the previously posted fix. Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-31sparc: Annotate of_device_id arrays with const or __initdata.David S. Miller
As suggested by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-29niu: Fix error checking in niu_ethflow_to_class.Andreas Schwab
The callers of niu_ethflow_to_class expect zero as error, but it returns -1 instead. Signed-off-by: Andreas Schwab <schwab@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17niu: Add TX multiqueue support.David S. Miller
2008-07-02niu: Add support for rx flow hash configuration.Santwona Behera
Implemented ethtool callback functions for configuring receive flow hashing in the niu driver. Signed-off-by: Santwona Behera <santwona.behera@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12niu: Determine the # of ports from the card's VPD dataMatheos Worku
Determine the number of physical ports from the card's VPD data. Previous fix failed on Maramba platform which doesn't have the "board-model" property. This fix uses the "model" property which exists on all cards and Neptune based motherboards. cstyle cleanup included. Signed-off-by: Matheos Worku <matheos.worku@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-04niu: Fix probing regression for maramba on-board chips.David S. Miller
Changeset 7f7c4072ea552f97a0898331322f71986a97299c ("niu: Determine the # of ports from the card's VPD data") caused maramba on-board NIU ports to stop probing properly. The old code had a fallback that would use a num_ports value of 4 if all the probing methods failed, but that was removed. This restores the fallback of 4 ports, to get things working again. Bump driver version and release date. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24niu: Add support for Neptune FEM/NEM cards for C10 server bladesMatheos Worku
[ Minor coding style and whitespace corrections, also bump driver version and release date. -DaveM ] Signed-off-by: Matheos Worku <matheos.worku@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24niu: Determine the # of ports from the card's VPD dataMatheos Worku
[ Fix minor whitespace and coding style stuff... -DaveM ] Signed-off-by: Matheos Worku <matheos.worku@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NIU]: Add Support for Sun ATCA Blade Server.Matheos Worku
Ports 0 and 1 of the NIU device are connected to extended fabric through SERDES. Ports 2 and 3 are connected using RGMII Fiber mode. [ Coding style cleanups... -DaveM ] Signed-off-by: Matheos Worku <matheos.worku@sun.com> Signed-off-by: David S. Miller <davem@davemloft.net>
