path: root/drivers/net/nlmon.c
2017-06-26net: add netlink_ext_ack argument to rtnl_link_ops.validateMatthias Schiffer
Add support for extended error reporting. Signed-off-by: Matthias Schiffer <mschiffer@universe-factory.net> Acked-by: David Ahern <dsahern@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-06-07net: Fix inconsistent teardown and release of private netdev state.David S. Miller
Network devices can allocate reasources and private memory using netdev_ops->ndo_init(). However, the release of these resources can occur in one of two different places. Either netdev_ops->ndo_uninit() or netdev->destructor(). The decision of which operation frees the resources depends upon whether it is necessary for all netdev refs to be released before it is safe to perform the freeing. netdev_ops->ndo_uninit() presumably can occur right after the NETDEV_UNREGISTER notifier completes and the unicast and multicast address lists are flushed. netdev->destructor(), on the other hand, does not run until the netdev references all go away. Further complicating the situation is that netdev->destructor() almost universally does also a free_netdev(). This creates a problem for the logic in register_netdevice(). Because all callers of register_netdevice() manage the freeing of the netdev, and invoke free_netdev(dev) if register_netdevice() fails. If netdev_ops->ndo_init() succeeds, but something else fails inside of register_netdevice(), it does call ndo_ops->ndo_uninit(). But it is not able to invoke netdev->destructor(). This is because netdev->destructor() will do a free_netdev() and then the caller of register_netdevice() will do the same. However, this means that the resources that would normally be released by netdev->destructor() will not be. Over the years drivers have added local hacks to deal with this, by invoking their destructor parts by hand when register_netdevice() fails. Many drivers do not try to deal with this, and instead we have leaks. Let's close this hole by formalizing the distinction between what private things need to be freed up by netdev->destructor() and whether the driver needs unregister_netdevice() to perform the free_netdev(). netdev->priv_destructor() performs all actions to free up the private resources that used to be freed by netdev->destructor(), except for free_netdev(). netdev->needs_free_netdev is a boolean that indicates whether free_netdev() should be done at the end of unregister_netdevice(). Now, register_netdevice() can sanely release all resources after ndo_ops->ndo_init() succeeds, by invoking both ndo_ops->ndo_uninit() and netdev->priv_destructor(). And at the end of unregister_netdevice(), we invoke netdev->priv_destructor() and optionally call free_netdev(). Signed-off-by: David S. Miller <davem@davemloft.net>
2017-01-08net: make ndo_get_stats64 a void functionstephen hemminger
The network device operation for reading statistics is only called in one place, and it ignores the return value. Having a structure return value is potentially confusing because some future driver could incorrectly assume that the return value was used. Fix all drivers with ndo_get_stats64 to have a void function. Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-12-07nlmon: use core MTU range checking in nlmon driverZhang Shengju
Since commit 61e84623ace3 ("net: centralize net_device min/max MTU checking"), mtu range is checked at dev_set_mtu(). This patch adds min_mtu for nlmon device and remove unnecessary ndo_change_mtu() function. Signed-off-by: Zhang Shengju <zhangshengju@cmss.chinamobile.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-18net: nlmon: convert to using IFF_NO_QUEUEPhil Sutter
Signed-off-by: Phil Sutter <phil@nwl.cc> Cc: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-28net: nlmon: flag nlmon devs with LLTX/SGDaniel Borkmann
As in xmit path we merely update statistics and free the skb, we can mark the device with LLTX feature, so that upper layers can avoid taking the single txq lock on xmit. While at it, also add missing NETIF_F_SG. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14net: Replace u64_stats_fetch_begin_bh to u64_stats_fetch_begin_irqEric W. Biederman
Replace the bh safe variant with the hard irq safe variant. We need a hard irq safe variant to deal with netpoll transmitting packets from hard irq context, and we need it in most if not all of the places using the bh safe variant. Except on 32bit uni-processor the code is exactly the same so don't bother with a bh variant, just have a hard irq safe variant that everyone can use. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-02-14net: introduce netdev_alloc_pcpu_stats() for driversWANG Cong
There are many drivers calling alloc_percpu() to allocate pcpu stats and then initializing ->syncp. So just introduce a helper function for them. Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-06net: Explicitly initialize u64_stats_sync structures for lockdepJohn Stultz
In order to enable lockdep on seqcount/seqlock structures, we must explicitly initialize any locks. The u64_stats_sync structure, uses a seqcount, and thus we need to introduce a u64_stats_init() function and use it to initialize the structure. This unfortunately adds a lot of fairly trivial initialization code to a number of drivers. But the benefit of ensuring correctness makes this worth while. Because these changes are required for lockdep to be enabled, and the changes are quite trivial, I've not yet split this patch out into 30-some separate patches, as I figured it would be better to get the various maintainers thoughts on how to best merge this change along with the seqcount lockdep enablement. Feedback would be appreciated! Signed-off-by: John Stultz <john.stultz@linaro.org> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: James Morris <jmorris@namei.org> Cc: Jesse Gross <jesse@nicira.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: Mirko Lindner <mlindner@marvell.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Roger Luethi <rl@hellgate.ch> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Simon Horman <horms@verge.net.au> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Wensong Zhang <wensong@linux-vs.org> Cc: netdev@vger.kernel.org Link: http://lkml.kernel.org/r/1381186321-4906-2-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-07-02nlmon: use standard rtnetlink link api for add/del devicesJiri Pirko
It is not nice when netdev is created right after module load and with some implicit name. So rather change nlmon to use standard rtnl link API. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-28nlmon: fix comparison in nlmon_is_valid_mtuDaniel Borkmann
This patch fixes the following warning introduced in e4fc408e0e99 ("packet: nlmon: virtual netlink monitoring device for packet sockets") reported by Dan Carpenter: warning: "drivers/net/nlmon.c:31 nlmon_is_valid_mtu() warn: always true condition '(new_mtu <= ((~0 >> 1))) => (s32min-s32max <= s32max)'" Thus, we should simply remove the test against INT_MAX. Next to that we also need to explicitly cast the sizeof() case as the comparison is type promoted to unsigned long so negative values are then valid instead of invalid. While at it, this also adds a comment about Netlink and MTUs. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-24packet: nlmon: virtual netlink monitoring device for packet socketsDaniel Borkmann
Currently, there is no good possibility to debug netlink traffic that is being exchanged between kernel and user space. Therefore, this patch implements a netlink virtual device, so that netlink messages will be made visible to PF_PACKET sockets. Once there was an approach with a similar idea [1], but it got forgotten somehow. I think it makes most sense to accept the "overhead" of an extra netlink net device over implementing the same functionality from PF_PACKET sockets once again into netlink sockets. We have BPF filters that can already be easily applied which even have netlink extensions, we have RX_RING zero-copy between kernel- and user space that can be reused, and much more features. So instead of re-implementing all of this, we simply pass the skb to a given PF_PACKET socket for further analysis. Another nice benefit that comes from that is that no code needs to be changed in user space packet analyzers (maybe adding a dissector, but not more), thus out of the box, we can already capture pcap files of netlink traffic to debug/troubleshoot netlink problems. Also thanks goes to Thomas Graf, Flavio Leitner, Jesper Dangaard Brouer. [1] http://marc.info/?l=linux-netdev&m=113813401516110 Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
