path: root/drivers/net/ntb_netdev.c
2018-10-31ntb_netdev: Simplify remove with client device drvdataAaron Sierra
Replace the elaborate private structure global linked-list used in ntb_netdev_probe() and ntb_netdev_remove() by stashing our private data in the NTB transport client device. Signed-off-by: Aaron Sierra <asierra@xes-inc.com> Reviewed-by: Logan Gunthorpe <logang@deltatee.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2018-10-31ntb_netdev: fix sleep time mismatchJon Mason
The tx_time should be in usecs (according to the comment above the variable), but the setting of the timer during the rearming is done in msecs. Change it to match the expected units. Fixes: e74bfeedad08 ("NTB: Add flow control to the ntb_netdev") Suggested-by: Gerd W. Haeussler <gerd.haeussler@cesys-it.com> Signed-off-by: Jon Mason <jdmason@kudzu.us> Acked-by: Dave Jiang <dave.jiang@intel.com>
2018-06-23net: drivers/net: Convert random_ether_addr to eth_random_addrJoe Perches
random_ether_addr is a #define for eth_random_addr which is generally preferred in kernel code by ~3:1 Convert the uses of random_ether_addr to enable removing the #define Miscellanea: o Convert &vfmac[0] to equivalent vfmac and avoid unnecessary line wrap Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-11-01drivers/net: ntb_netdev: Convert timers to use timer_setup()Kees Cook
In preparation for unconditionally passing the struct timer_list pointer to all timer callbacks, switch to using the new timer_setup() and from_timer() to pass the timer pointer explicitly. Cc: Jon Mason <jdmason@kudzu.us> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Allen Hubbe <Allen.Hubbe@emc.com> Cc: linux-ntb@googlegroups.com Cc: netdev@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-07-06ntb_netdev: set the net_device's parentLogan Gunthorpe
At present, ntb_netdev devices end up under /sys/devices/virtual/net completely unconnected to the ntb trees below them. This patch sets the parent of the net_device (using SET_NETDEV_DEV) to the client_dev device. This results in a better connected sysfs path for the network device: /sys/devices/pci0000:00/0000:00:03.0/0000:03:00.1/0000:03:00.1/ntb_netdev0/net/eth2 Signed-off-by: Logan Gunthorpe <logang@deltatee.com> Acked-by: Allen Hubbe <Allen.Hubbe@dell.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2017-03-13net: net_netdev: use new api ethtool_{get|set}_link_ksettingsPhilippe Reynes
The ethtool api {get|set}_settings is deprecated. We move this driver to new api {get|set}_link_ksettings. As I don't have the hardware, I'd be very pleased if someone may test this patch. Signed-off-by: Philippe Reynes <tremyfr@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-10-20net: use core MTU range checking in core net infraJarod Wilson
geneve: - Merge __geneve_change_mtu back into geneve_change_mtu, set max_mtu - This one isn't quite as straight-forward as others, could use some closer inspection and testing macvlan: - set min/max_mtu tun: - set min/max_mtu, remove tun_net_change_mtu vxlan: - Merge __vxlan_change_mtu back into vxlan_change_mtu - Set max_mtu to IP_MAX_MTU and retain dynamic MTU range checks in change_mtu function - This one is also not as straight-forward and could use closer inspection and testing from vxlan folks bridge: - set max_mtu of IP_MAX_MTU and retain dynamic MTU range checks in change_mtu function openvswitch: - set min/max_mtu, remove internal_dev_change_mtu - note: max_mtu wasn't checked previously, it's been set to 65535, which is the largest possible size supported sch_teql: - set min/max_mtu (note: max_mtu previously unchecked, used max of 65535) macsec: - min_mtu = 0, max_mtu = 65535 macvlan: - min_mtu = 0, max_mtu = 65535 ntb_netdev: - min_mtu = 0, max_mtu = 65535 veth: - min_mtu = 68, max_mtu = 65535 8021q: - min_mtu = 0, max_mtu = 65535 CC: netdev@vger.kernel.org CC: Nicolas Dichtel <nicolas.dichtel@6wind.com> CC: Hannes Frederic Sowa <hannes@stressinduktion.org> CC: Tom Herbert <tom@herbertland.com> CC: Daniel Borkmann <daniel@iogearbox.net> CC: Alexander Duyck <alexander.h.duyck@intel.com> CC: Paolo Abeni <pabeni@redhat.com> CC: Jiri Benc <jbenc@redhat.com> CC: WANG Cong <xiyou.wangcong@gmail.com> CC: Roopa Prabhu <roopa@cumulusnetworks.com> CC: Pravin B Shelar <pshelar@ovn.org> CC: Sabrina Dubroca <sd@queasysnail.net> CC: Patrick McHardy <kaber@trash.net> CC: Stephen Hemminger <stephen@networkplumber.org> CC: Pravin Shelar <pshelar@nicira.com> CC: Maxim Krasnyansky <maxk@qti.qualcomm.com> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-07NTB: Add flow control to the ntb_netdevDave Jiang
Right now if we push the NTB really hard, we start dropping packets due to not able to process the packets fast enough. We need to st:qop the upper layer from flooding us when that happens. A timer is necessary in order to restart the queue once the resource has been processed on the receive side. Due to the way NTB is setup, the resources on the tx side are tied to the processing of the rx side and there's no async way to know when the rx side has released those resources. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-08-09NTB: ntb_netdev not covering all receive errorsDave Jiang
ntb_netdev is allowing the link to come up even when -ENOMEM is returned from ntb_transport_rx_enqueue. Fix to cover all possible errors. Signed-off-by: Dave Jiang <dave.jiang@intel.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-08-09NTB: Fix ntb_transport out-of-order RX updateAllen Hubbe
It was possible for a synchronous update of the RX index in the error case to get ahead of the asynchronous RX index update in the normal case. Change the RX processing to preserve an RX completion order. There were two error cases. First, if a buffer is not present to receive data, there would be no queue entry to preserve the RX completion order. Instead of dropping the RX frame, leave the RX frame in the ring. Schedule RX processing when RX entries are enqueued, in case there are RX frames waiting in the ring to be received. Second, if a buffer is too small to receive data, drop the frame in the ring, mark the RX entry as done, and indicate the error in the RX entry length. Check for a negative length in the receive callback in ntb_netdev, and count occurrences as rx_length_errors. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-04NTB: Split ntb_hw_intel and ntb_transport driversAllen Hubbe
Change ntb_hw_intel to use the new NTB hardware abstraction layer. Split ntb_transport into its own driver. Change it to use the new NTB hardware abstraction layer. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2015-07-02NTB: Move files in preparation for NTB abstractionAllen Hubbe
This patch only moves files to their new locations, before applying the next two patches adding the NTB Abstraction layer. Splitting this patch from the next is intended make distinct which code is changed only due to moving the files, versus which are substantial code changes in adding the NTB Abstraction layer. Signed-off-by: Allen Hubbe <Allen.Hubbe@emc.com> Signed-off-by: Jon Mason <jdmason@kudzu.us>
2014-06-06net: use ethtool_cmd_speed_set helper to set ethtool speed valueJiri Pirko
Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-13net: get rid of SET_ETHTOOL_OPSWilfried Klaebe
net: get rid of SET_ETHTOOL_OPS Dave Miller mentioned he'd like to see SET_ETHTOOL_OPS gone. This does that. Mostly done via coccinelle script: @@ struct ethtool_ops *ops; struct net_device *dev; @@ - SET_ETHTOOL_OPS(dev, ops); + dev->ethtool_ops = ops; Compile tested only, but I'd seriously wonder if this broke anything. Suggested-by: Dave Miller <davem@davemloft.net> Signed-off-by: Wilfried Klaebe <w-lkml@lebenslange-mailadresse.de> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-07NTB: Code Style Clean-upJon Mason
Some white space and 80 char overruns corrected. Signed-off-by: Jon Mason <jon.mason@intel.com>
2014-04-07NTB: client event cleanupJon Mason
Provide a better event interface between the client and transport Signed-off-by: Jon Mason <jon.mason@intel.com>
2014-04-07ntb_netdev: Fix skb free issue in openJon Mason
In ntb_netdev_open, when ntb_transport_rx_enqueue fails the skb that was attempting to be enqueued is not freed. Free this skb on the ntb_transport_rx_enqueue error. Signed-off-by: Jon Mason <jon.mason@intel.com>
2014-04-07ntb_netdev: Fix list_for_each_entry exit issueJon Mason
If list_for_each_entry exits without finding the ntb_device, the dev pointer will not be NULL. Thus the check will never be true and the code will not exit when it should. Correct this by adding a bool to determine when the device is found, otherwise exit in good fashion. Signed-off-by: Jon Mason <jon.mason@intel.com>
2013-05-15ntb_netdev: remove from list on exitJon Mason
The ntb_netdev device is not removed from the global list of devices upon device removal. If the device is re-added, the removal code would find the first instance and try to remove an already removed device. Signed-off-by: Jon Mason <jon.mason@intel.com>
2013-01-20ntb_netdev: Update VersionJon Mason
Update NTB netdev version to 0.7 Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-20ntb_netdev: improve loggingJon Mason
Improve driver logging to be more helpful Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-20ntb_netdev: remove tx timeoutJon Mason
There is a race between disabling and enabling the tx queue, resulting in tx timeouts. Since all the tx timeout does is re-enable the tx queue, simple remove the start/stop of the queue and the tx timeout routine. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-20ntb_netdev: correct skb leakJon Mason
If ntb_netdev is unable to pass a new skb to the ntb transport for future rx packets, it should free the newly alloc'ed skb in the error case. Found by Kernel memory leak detector. Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-20ntb_netdev: remove init/exit from probe/removeJon Mason
Remove init/exit from probe/remove routines to correct warnings of "Section mismatch". Signed-off-by: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17ntb: remove __dev* markingsGreg Kroah-Hartman
These are now gone from the kernel, so remove them from the newly-added drivers before they start to cause build errors for people. Cc: Jon Mason <jon.mason@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17net: Add support for NTB virtual ethernet deviceJon Mason
A virtual ethernet device that uses the NTB transport API to send/receive data. Signed-off-by: Jon Mason <jon.mason@intel.com> Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
