Additionally, one comment was reformulated by Joe Perches <joe@perches.com>.
callback
Unify the EVENT_CARD_INSERTION and "attach" callbacks to one unified
probe() callback. As all in-kernel drivers are changed to this new
callback, there will be no temporary backwards-compatibility. Inside a
probe() function, each driver _must_ set struct pcmcia_device
*p_dev->instance and instance->handle correctly.
With these patches, the basic driver interface for 16-bit PCMCIA drivers
now has the classic four callbacks known also from other buses:
int (*probe) (struct pcmcia_device *dev);
void (*remove) (struct pcmcia_device *dev);
int (*suspend) (struct pcmcia_device *dev);
int (*resume) (struct pcmcia_device *dev);
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
The linked list of devices managed by each PCMCIA driver is, in very most
cases, unused. Therefore, remove it from many drivers.
Unify the "detach" and REMOVAL_EVENT handlers to one "remove" function.
Old functionality is preserved, for the moment.
Move the suspend and resume methods out of the event handler, and into
special functions. Also use these functions for pre- and post-reset, as
almost all drivers already do, and the remaining ones can easily be
converted.
Bugfix to include/pcmcia/ds.c
If the product-id-string contains the '+' , '&' ,'_', it was not converted
properly from the /etc/pcmcia/config(pcmcia-cs config file).
As a follow-up, remove the inclusion of pcmcia/version.h in many files.
Move the "event handler" to struct pcmcia_driver -- the unified event handler
will disappear really soon, but switching it to struct pcmcia_driver in the
meantime allows for better "step-by-step" patches.
Add pcmcia_device_id table.
infrastructure for it.
Let it rip!
