[ Upstream commit 7dbbcf496f2a4b6d82cfc7810a0746e160b79762 ]
Fix build error by selecting MDIO_DEVRES for MDIO_THUNDER.
Fixes this build error:
ld: drivers/net/phy/mdio-thunder.o: in function `thunder_mdiobus_pci_probe':
drivers/net/phy/mdio-thunder.c:78: undefined reference to `devm_mdiobus_alloc_size'
Fixes: 379d7ac7ca31 ("phy: mdio-thunder: Add driver for Cavium Thunder SoC MDIO buses.")
Reported-by: kernel test robot <lkp@intel.com>
Cc: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Heiner Kallweit <hkallweit1@gmail.com>
Cc: netdev@vger.kernel.org
Cc: David Daney <david.daney@cavium.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Adjust indentation from spaces to tab (+optional two spaces) as in
coding style with command like:
$ sed -e 's/^ /\t/' -i */Kconfig
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Kalle Valo <kvalo@codeaurora.org>
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
This change adds support for Analog Devices Industrial Ethernet PHYs.
Particularly the PHYs this driver adds support for:
* ADIN1200 - Robust, Industrial, Low Power 10/100 Ethernet PHY
* ADIN1300 - Robust, Industrial, Low Latency 10/100/1000 Gigabit
Ethernet PHY
The 2 chips are register compatible with one another. The main difference
being that ADIN1200 doesn't operate in gigabit mode.
The chips can be operated by the Generic PHY driver as well via the
standard IEEE PHY registers (0x0000 - 0x000F) which are supported by the
kernel as well. This assumes that configuration of the PHY has been done
completely in HW, according to spec.
Configuration can also be done via registers, which will be supported by
this driver.
Datasheets:
https://www.analog.com/media/en/technical-documentation/data-sheets/ADIN1300.pdf
https://www.analog.com/media/en/technical-documentation/data-sheets/ADIN1200.pdf
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
After commit 171a9bae68c7 ("staging/octeon: Allow test build on
!MIPS"), the following combination of configs cause a few Kconfig
warnings and build errors (distilled from arm allyesconfig and Randy's
randconfig builds):
CONFIG_NETDEVICES=y
CONFIG_STAGING=y
CONFIG_COMPILE_TEST=y
and CONFIG_OCTEON_ETHERNET as either a module or built-in.
WARNING: unmet direct dependencies detected for MDIO_OCTEON
Depends on [n]: NETDEVICES [=y] && MDIO_DEVICE [=y] && MDIO_BUS [=y]
&& 64BIT [=n] && HAS_IOMEM [=y] && OF_MDIO [=n]
Selected by [y]:
- OCTEON_ETHERNET [=y] && STAGING [=y] && (CAVIUM_OCTEON_SOC ||
COMPILE_TEST [=y]) && NETDEVICES [=y]
In file included from ../drivers/net/phy/mdio-octeon.c:14:
../drivers/net/phy/mdio-cavium.h:111:36: error: implicit declaration of
function ‘writeq’; did you mean ‘writel’?
[-Werror=implicit-function-declaration]
111 | #define oct_mdio_writeq(val, addr) writeq(val, (void *)addr)
CONFIG_64BIT is not strictly necessary if the proper readq/writeq
definitions are included from io-64-nonatomic-lo-hi.h.
CONFIG_OF_MDIO is not needed when CONFIG_COMPILE_TEST is enabled because
of commit f9dc9ac51610 ("of/mdio: Add dummy functions in of_mdio.h.").
Fixes: 171a9bae68c7 ("staging/octeon: Allow test build on !MIPS")
Reported-by: kbuild test robot <lkp@intel.com>
Reported-by: Mark Brown <broonie@kernel.org>
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org> # build-tested
The AST2600 design separates the MDIO controllers from the MAC, which is
where they were placed in the AST2400 and AST2500. Further, the register
interface is reworked again, so now we have three possible different
interface implementations, however this driver only supports the
interface provided by the AST2600. The AST2400 and AST2500 will continue
to be supported by the MDIO support embedded in the FTGMAC100 driver.
The hardware supports both C22 and C45 mode, but for the moment only C22
support is implemented.
Signed-off-by: Andrew Jeffery <andrew@aj.id.au>
Honestly all the conflicts were simple overlapping changes,
nothing really interesting to report.
[Resent to net instead of net-next - may clash with Anders Roxell's patch
series addressing duplicate module names]
Commit 31dd83b96641 ("net-next: phy: new Asix Electronics PHY driver")
introduced a new PHY driver drivers/net/phy/asix.c that causes a module
name conflict with a pre-existiting driver (drivers/net/usb/asix.c).
The PHY driver is used by the X-Surf 100 ethernet card driver, and loaded
by that driver via its PHY ID. A rename of the driver looks unproblematic.
Rename PHY driver to ax88796b.c in order to resolve name conflict.
Signed-off-by: Michael Schmitz <schmitzmic@gmail.com>
Tested-by: Michael Schmitz <schmitzmic@gmail.com>
Fixes: 31dd83b96641 ("net-next: phy: new Asix Electronics PHY driver")
Add driver for the NXP TJA1100 and TJA1101 PHYs. These PHYs are special
BroadRReach 100BaseT1 PHYs used in automotive.
Cc: Florian Fainelli <f.fainelli@gmail.com>
Cc: Jean Delvare <jdelvare@suse.com>
Cc: linux-hwmon@vger.kernel.org
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
The VSC8514 PHY is a 4-ports PHY that is 10/100/1000BASE-T, 100BASE-FX,
1000BASE-X, can communicate with the MAC via QSGMII.
The MAC interface protocol for each port within QSGMII can
be either 1000BASE-X or SGMII, if the QSGMII MAC that the VSC8514 is
connecting to supports this functionality.
VSC8514 also supports SGMII MAC-side autonegotiation on each individual
port, downshifting, can set the blinking pattern of each of its 4 LEDs,
SyncE, 1000BASE-T Ring Resiliency as well as HP Auto-MDIX detection.
This adds support for 10BASE-T, 100BASE-TX, and 1000BASE-T,
QSGMII link with the MAC, downshifting, HP Auto-MDIX detection
and blinking pattern for its 4 LEDs.
The GPIO register bank is a set of registers that are common to all PHYs
in the package. So any modification in any register of this bank affects
all PHYs of the package.
If the PHYs haven't been reset before booting the Linux kernel and were
configured to use interrupts for e.g. link status updates, it is
required to clear the interrupts mask register of all PHYs before being
able to use interrupts with any PHY. The first PHY of the package that
will be init will take care of clearing all PHYs interrupts mask
registers. Thus, we need to keep track of the init sequence in the
package, if it's already been done or if it's to be done.
Most of the init sequence of a PHY of the package is common to all PHYs
in the package, thus we use the SMI broadcast feature which enables us
to propagate a write in one register of one PHY to all PHYs in the same
package.
Signed-off-by: Kavya Sree Kotagiri <kavyasree.kotagiri@microchip.com>
Signed-off-by: Quentin Schulz <quentin.schulz@bootlin.com>
Co-developed-by: Quentin Schulz <quentin.schulz@bootlin.com>
Add support for the mdio mux and internal phy glue of the g12a SoC family
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com> # clk parts
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
After 90eff9096c01 ("net: phy: Allow splitting MDIO bus/device support
from PHYs") the various MDIO bus drivers were no longer parented with
config PHYLIB but with config MDIO_BUS which is not a menuconfig, fix
this by depending on MDIO_DEVICE which is a menuconfig.
This is visually nicer and less confusing for users.
Fixes: 90eff9096c01 ("net: phy: Allow splitting MDIO bus/device support from PHYs")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
The tristate prompt should have been replaced rather than defined a few
lines below, rebase mistake.
Fixes: 17cc9821766c ("net: phy: Move Omega PHY entry to Cygnus PHY driver")
Cygnus and Omega are part of the same business unit and product line, it
makes sense to group PHY entries by products such that a platform can
select only the drivers that it needs. Bring all the functionality that
the BCM7XXX_28NM_GPHY() macro hides for us and remove the Omega PHY
entry from bcm7xxx.c.
As an added bonus, we now have a proper mdio_device_id entry to permit
auto-loading.
Reviewed-by: Scott Branden <scott.branden@broadcom.com>
MDIO_BUS_MUX can only be selected if OF_MDIO is already turned on:
WARNING: unmet direct dependencies detected for MDIO_BUS_MUX
Depends on [n]: NETDEVICES [=y] && MDIO_BUS [=m] && OF_MDIO [=n]
Selected by [m]:
- MDIO_BUS_MUX_MULTIPLEXER [=m] && NETDEVICES [=y] && MDIO_BUS [=m] && OF [=y]
Fixes: 7865ad6551c9 ("drivers: net: phy: mdio-mux: Add support for Generic Mux controls")
Add support for Generic Mux controls, when Mdio mux node is a consumer
of mux produced by some other device.
Signed-off-by: Pankaj Bansal <pankaj.bansal@nxp.com>
There is nothing in this driver which prevents it to be compiled for
other architectures. Add COMPILE_TEST so we get better compile test
coverage.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
"imply HWMON" was supposed to ensure that the SFP phy code can be built
with HWMON enabled or disabled while at the same time ensuring that
HWMON is not built as module if SFP is built into the kernel.
Unfortunately, that does not work as intended. With "allmodconfig", it
results in several unrelated HWMON drivers to be disabled instead of
being built as module as expected.
Let's use the old "depends on HWMON || HWMON=n" instead. This is slightly
different (it enforces SFP to be built as module if HWMON is built as
module), but it is better than the alternative of using "IS_REACHABLE()"
in the driver since that would disable sensor support if HWMON is built
as module and SFP is built into the kernel.
Fixes: 1323061a018a ("net: phy: sfp: Add HWMON support for module sensors")
The driver builds fine even with CONFIG_OF=n since we now have stubs that are
provided.
SFP modules can contain a number of sensors. The EEPROM also contains
recommended alarm and critical values for each sensor, and indications
of if these have been exceeded. Export this information via
HWMON. Currently temperature, VCC, bias current, transmit power, and
possibly receiver power is supported.
The sensors in the modules can either return calibrate or uncalibrated
values. Uncalibrated values need to be manipulated, using coefficients
provided in the SFP EEPROM. Uncalibrated receive power values require
floating point maths in order to calibrate them. Performing this in
the kernel is hard. So if the SFP module indicates it uses
uncalibrated values, RX power is not made available.
With this hwmon device, it is possible to view the sensor values using
lm-sensors programs:
in0: +3.29 V (crit min = +2.90 V, min = +3.00 V)
(max = +3.60 V, crit max = +3.70 V)
temp1: +33.0°C (low = -5.0°C, high = +80.0°C)
(crit low = -10.0°C, crit = +85.0°C)
power1: 1000.00 nW (max = 794.00 uW, min = 50.00 uW) ALARM (LCRIT)
(lcrit = 40.00 uW, crit = 1000.00 uW)
curr1: +0.00 A (crit min = +0.00 A, min = +0.00 A) ALARM (LCRIT, MIN)
(max = +0.01 A, crit max = +0.01 A)
The scaling sensors performs on the bias current is not particularly
good. The raw values are more useful:
curr1:
curr1_input: 0.000
curr1_min: 0.002
curr1_max: 0.010
curr1_lcrit: 0.000
curr1_crit: 0.011
curr1_min_alarm: 1.000
curr1_max_alarm: 0.000
curr1_lcrit_alarm: 1.000
curr1_crit_alarm: 0.000
In order to keep the I2C overhead to a minimum, the constant values,
such as limits and calibration coefficients are read once at module
insertion time. Thus only reading *_input and *_alarm properties
requires i2c read operations.
Acked-by: Guenter Roeck <linux@roeck-us.net>
The GPIO subsystem provides dummy GPIO consumer functions if GPIOLIB is
not enabled. Hence drivers that depend on GPIOLIB, but use GPIO consumer
functionality only, can still be compiled if GPIOLIB is not enabled.
Relax the dependency on GPIOLIB if COMPILE_TEST is enabled, where
appropriate.
Those drivers build just fine with COMPILE_TEST, so make that possible.
Add a driver for the Microsemi MII Management controller (MIIM) found on
Microsemi SoCs.
On Ocelot, there are two controllers, one is connected to the internal
PHYs, the other one can communicate with external PHYs.
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Add support for the DP83811 phy.
The DP83811 supports both rgmii and sgmii interfaces.
There are 2 part numbers for this the DP83TC811R does not
reliably support the SGMII interface but the DP83TC811S will.
There is not a way to differentiate these parts from the
hardware or register set. So this is controlled via the DT
to indicate which phy mode is required. Or the part can be
strapped to a certain interface.
Data sheet can be found here:
http://www.ti.com/product/DP83TC811S-Q1/description
http://www.ti.com/product/DP83TC811R-Q1/description
Signed-off-by: Dan Murphy <dmurphy@ti.com>
Add driver for Microchip LAN87XX T1 PHYs
This patch support driver for Microchp T1 PHYs.
There will be followup patches to this driver to support T1 PHY
features such as cable diagnostics, signal quality indicator(SQI),
sleep and wakeup (TC10) support.
Signed-off-by: Nisar Sayed <Nisar.Sayed@microchip.com>
After commit c59530d0d5dc ("net: Move PHY statistics code into PHY
library helpers") we made net/core/ethtool.c reference symbols which are
part of the library which can be modular. David introduced a temporary
fix with 1ecd6e8ad996 ("phy: Temporary build fix after phylib changes.")
which would prevent such modularity.
This is not desireable of course, so instead, just inline the functions
into include/linux/phy.h to keep both options available.
Fixes: c59530d0d5dc ("net: Move PHY statistics code into PHY library helpers")
Fixes: 1ecd6e8ad996 ("phy: Temporary build fix after phylib changes.")
Make PHYLIB boolean, because we reference phylib provided symbols now
from net/core/ethtool.c and therefore 'm' doesn't work.
The Asix Electronics PHY found on the X-Surf 100 Amiga Zorro network
card by Individual Computers is buggy, and needs the reset bit toggled
as workaround to make a PHY soft reset succeed.
Add workaround driver just for this special case.
Suggested in xsurf100 patch series review by Andrew Lunn <andrew@lunn.ch>
Currently, we create a LED trigger for any link speed known to a PHY.
These triggers only fire when their exact link speed had been negotiated
(they aren't cumulative, that is, they don't fire for "their or any higher"
link speed).
What we are missing, however, is a trigger which will fire on any link
speed known to the PHY. Such trigger can then be used for implementing a
poor man's substitute of the "link" LED on boards that lack it.
Let's add it.
Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name>
Add support for the TI DP83822 10/100Mbit ethernet phy.
The DP83822 provides flexibility to connect to a MAC through a
standard MII, RMII or RGMII interface.
In addition the DP83822 needs to be removed from the DP83848 driver
as the WoL support is added here for this device.
Datasheet:
http://www.ti.com/product/DP83822I/datasheet
Acked-by: Andrew F. Davis <afd@ti.com>
Signed-off-by: Bernd Edlinger <bernd.edlinger@hotmail.de>
Since the integration of PHYLINK, the configuration option which
used to be under the PHY infrastructure menu in menuconfig ended
up one level up (the network device driver section)
By placing PHYLINK option right after PHYLIB entry, it broke the
way Kconfig used to build the menu. See kconfig-language.txt, section
"Menu structure", 2nd method.
This is fixed by placing the PHYLINK option just before PHYLIB.
Fixes: 9525ae83959b ("phylink: add phylink infrastructure")
This patch fix an old information that mdio-mux-mmioreg can only handle
8bit registers.
This is not true anymore.
Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com>
Using tabs instead of space for indentation.
Support integrated ethernet PHY currently.
Signed-off-by: David Wu <david.wu@rock-chips.com>
Add support for SFP hotpluggable modules via sfp-bus and phylink.
This supports both copper and optical SFP modules, which require
different Serdes modes in order to properly negotiate the link.
Optical SFP modules typically require the Serdes link to be talking
1000BaseX mode - this is the gigabit ethernet mode defined by the
802.3 standard.
Copper SFP modules typically integrate a PHY in the module to convert
from Serdes to copper, and the PHY will be configured by the vendor
to either present a 1000BaseX Serdes link (for fixed 1000BaseT) or a
SGMII Serdes link. However, this is vendor defined, so we instead
detect the PHY, switch the link to SGMII mode, and use traditional
PHY based negotiation.
The link between the ethernet MAC and its PHY has become more complex
as the interface evolves. This is especially true with serdes links,
where the part of the PHY is effectively integrated into the MAC.
Serdes links can be connected to a variety of devices, including SFF
modules soldered down onto the board with the MAC, a SFP cage with
a hotpluggable SFP module which may contain a PHY or directly modulate
the serdes signals onto optical media with or without a PHY, or even
a classical PHY connection.
Moreover, the negotiation information on serdes links comes in two
varieties - SGMII mode, where the PHY provides its speed/duplex/flow
control information to the MAC, and 1000base-X mode where both ends
exchange their abilities and each resolve the link capabilities.
This means we need a more flexible means to support these arrangements,
particularly with the hotpluggable nature of SFP, where the PHY can
be attached or detached after the network device has been brought up.
Ethtool information can come from multiple sources:
- we may have a PHY operating in either SGMII or 1000base-X mode, in
which case we take ethtool/mii data directly from the PHY.
- we may have a optical SFP module without a PHY, with the MAC
operating in 1000base-X mode - the ethtool/mii data needs to come
from the MAC.
- we may have a copper SFP module with a PHY whic can't be accessed,
which means we need to take ethtool/mii data from the MAC.
Phylink aims to solve this by providing an intermediary between the
MAC and PHY, providing a safe way for PHYs to be hotplugged, and
allowing a SFP driver to reconfigure the serdes connection.
Phylink also takes over support of fixed link connections, where the
speed/duplex/flow control are fixed, but link status may be controlled
by a GPIO signal. By avoiding the fixed-phy implementation, phylink
can provide a faster response to link events: fixed-phy has to wait for
phylib to operate its state machine, which can take several seconds.
In comparison, phylink takes milliseconds.
- remove sync status
- rework supported and advertisment handling
- add 1000base-x speed for fixed links
- use functionality exported from phy-core, reworking
__phylink_ethtool_ksettings_set for it
Add an I2C MDIO bus bridge library, to allow phylib to access PHYs which
are connected to an I2C bus instead of the more conventional MDIO bus.
Such PHYs can be found in SFP adapters and SFF modules.
Since PHYs appear at I2C bus address 0x40..0x5f, and 0x50/0x51 are
reserved for SFP EEPROMs/diagnostics, we must not allow the MDIO bus
to access these I2C addresses.
I still see build errors in randconfig builds and have had this
patch for a while to locally work around it:
drivers/built-in.o: In function `xgene_mdio_probe':
mux-core.c:(.text+0x352154): undefined reference to `of_mdiobus_register'
mux-core.c:(.text+0x352168): undefined reference to `mdiobus_free'
mux-core.c:(.text+0x3521c0): undefined reference to `mdiobus_alloc_size'
The idea is that CONFIG_MDIO_BUS now reflects whether the mdio_bus
code is built-in or a module, and other drivers that use the core
code can simply depend on that, instead of having a complex
dependency line.
The conflicts were two cases of overlapping changes in
batman-adv and the qed driver.
After commit 90eff9096c01 ("net: phy: Allow splitting MDIO
bus/device support from PHYs") we could create a configuration where
MDIO_DEVICE=y and PHYLIB=m which leads to the following undefined
references:
drivers/built-in.o: In function `thunder_mdiobus_pci_remove':
>> mdio-thunder.c:(.text+0x2a212f): undefined reference to
>> `mdiobus_unregister'
>> mdio-thunder.c:(.text+0x2a2138): undefined reference to
>> `mdiobus_free'
drivers/built-in.o: In function `thunder_mdiobus_pci_probe':
mdio-thunder.c:(.text+0x2a22e7): undefined reference to
mdio-thunder.c:(.text+0x2a236f): undefined reference to
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
Add phylib support for the Marvell Alaska X 10 Gigabit PHY (MV88X3310).
This phy is able to operate at 10G, 1G, 100M and 10M speeds, and only
supports Clause 45 accesses.
The PHY appears (based on the vendor IDs) to be two different vendors
IP, with each devad containing several instances.
This PHY driver has only been tested with the RJ45 copper port, fiber
port and a Marvell Armada 8040-based ethernet interface.
It should be noted that to use the full range of speeds, MAC drivers
need to also reconfigure the link mode as per phydev->interface, since
the PHY automatically changes its interface mode depending on the
negotiated speed.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Add basic support for Cortina PHY drivers. Support only CS4340 for now.
The phys are not compatible with IEEE 802.3 clause 22/45 registers.
Implement proper read_status support. The generic 10G phy driver causes
bus register access errors.
The driver should be described using the "ethernet-phy-id" device tree
compatible.
Signed-off-by: Bogdan Purcareata <bogdan.purcareata@nxp.com>
Fix build errors by making this driver depend on OF_MDIO, like
several other similar drivers do.
drivers/built-in.o: In function `octeon_mdiobus_remove':
mdio-octeon.c:(.text+0x196ee0): undefined reference to `mdiobus_unregister'
mdio-octeon.c:(.text+0x196ee8): undefined reference to `mdiobus_free'
drivers/built-in.o: In function `octeon_mdiobus_probe':
mdio-octeon.c:(.text+0x196f1d): undefined reference to `devm_mdiobus_alloc_size'
mdio-octeon.c:(.text+0x196ffe): undefined reference to `of_mdiobus_register'
mdio-octeon.c:(.text+0x197010): undefined reference to `mdiobus_free'
Introduce a new configuration symbol: MDIO_DEVICE which allows building
the MDIO devices and bus code, without pulling in the entire Ethernet
PHY library and devices code.
PHYLIB nows select MDIO_DEVICE and the relevant Makefile files are
updated to reflect that.
When MDIO_DEVICE (MDIO bus/device only) is selected, but not PHYLIB, we
have mdio-bus.ko as a loadable module, and it does not have a
module_exit() function because the safety of removing a bus class is
unclear.
When both MDIO_DEVICE and PHYLIB are enabled, we need to assemble
everything into a common loadable module: libphy.ko because of nasty
circular dependencies between phy.c, phy_device.c and mdio_bus.c which
are really tough to untangle.
The Broadcom MDIO UniMAC driver uses routines provided by of_mdio.c which is
guarded by CONFIG_OF_MDIO.
As I understand it the Meson GXL PHY driver is only useful on one
architecture so only make it visible on that architecture.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Fixes: 7334b3e47aee ("net: phy: Add Meson GXL Internal PHY driver")
Cc: Neil Armstrong <narmstrong@baylibre.com>
Add driver for the Internal RMII PHY found in the Amlogic Meson GXL SoCs.
This PHY seems to only implement some standard registers and need some
workarounds to provide autoneg values from vendor registers.
Some magic values are currently used to configure the PHY, and this a
temporary setup until clarification about these registers names and
registers fields are provided by Amlogic.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
The BCM54810 PHY requires some semi-unique configuration, which results
in some additional configuration in addition to the standard config.
Also, some users of the BCM54810 require the PHY lanes to be swapped.
Since there is no way to detect this, add a device tree query to see if
it is applicable.
Inspired-by: Vikas Soni <vsoni@broadcom.com>
Signed-off-by: Jon Mason <jon.mason@broadcom.com>
