path: root/drivers/net/phy/marvell.c
2008-04-04net: marvell.c fix sparse shadowed variable warningHarvey Harrison
The other if blocks don't redeclare temp, remove the redeclaration in the final if() block. drivers/net/phy/marvell.c:214:7: warning: symbol 'temp' shadows an earlier one drivers/net/phy/marvell.c:160:6: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-25netxen, phy/marvell, skge: minor checkpatch fixesJeff Garzik
2008-03-25Marvell PHY m88e1111 driver fixAlexandr Smirnov
Marvell PHY m88e1111 (not sure about other models, but think they too) works in two modes: fiber and copper. In Marvell PHY driver (that we have in current community kernels) code supported only copper mode, and this is not configurable, bits for copper mode are simply written in registers during PHY initialization. This patch adds support for both modes. Signed-off-by: Alexandr Smirnov <asmirnov@ru.mvista.com> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-01phylib: marvell: add support for TX-only and RX-only Internal DelayKim Phillips
Previously, Internal Delay specification implied the delay be applied to both TX and RX. This patch allows for separate TX/RX-only internal delay specification. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Tested-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-11-05phylib: Add ID for Marvell 88E1240Olof Johansson
Add PHY IDs for Marvell 88E1240. It seems to have close enough programming models to 1111/1112 for basic support at least. Also clean up whitespace in the ID list a bit. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10phylib: Add Marvell 88E1112 phy idOlof Johansson
Add 88E1112 PHY ID to the marvell driver. Seems to do fine with the 88E1111 inits. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-10phylib: cleanup marvell.c a bitOlof Johansson
Simplify the marvell driver init a bit: Make the supported devices an array instead of explicitly registering each structure. This makes it considerably easier to add new devices down the road. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-08phylib: m88e1111: enable SGMII modeKapil Juneja
If connected via SGMII, initialize with SGMII mode configured. Signed-off-by: Kapil Juneja <Kapil.Juneja@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-06-09phylib: add RGMII-ID mode to the Marvell m88e1111 PHY to fix broken ucc_gethKim Phillips
Support for configuring RGMII-ID (RGMII with internal delay) mode on the 88e1111 and 88e1145. Ucc_geth on MPC8360EMDS(the main user of ucc_geth) is broken after changed to use phylib. It is fixed by adding this internal delay. Also renamed 88e1111s -> 88e1111 (no references to an 88e1111s part were found), and fixed some whitespace. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-17phylib: Add support for Marvell 88e1111S and 88e1145Andy Fleming
Changes include: * New support for 88e1145 * New support for 88e111s * Fixing 88e1101 driver to not match non-88e1101 PHYs * Increases in feature support across Marvell PHY product line * Fixes a bunch of whitespace issues found by Lindent Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-11-05Remove linux/version.h include from drivers/net/phy/* and net/ieee80211/*.Jeff Garzik
Unused, and causes the files to be needlessly rebuilt in some cases.
2005-07-30This patch adds a PHY Abstraction Layer to the Linux Kernel, enablingAndy Fleming
ethernet drivers to remain as ignorant as is reasonable of the connected PHY's design and operation details. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
