path: root/drivers/net/phy/phy_device.c
2005-12-24[PATCH] missing license for libphy.koOlaf Hering
Andy, libphy has no license tag. Something like the attached (untested!) patch is needed. Hopefully such a change finds its way into 2.6.15. filename: /lib/modules/2.6.15-rc5-3-ppc64/kernel/drivers/net/phy/libphy.ko vermagic: 2.6.15-rc5-3-ppc64 SMP gcc-4.1 depends: srcversion: ACC921B5E82701BE1E6F603 drivers/net/phy/phy_device.c | 4 ++++ 1 files changed, 4 insertions(+) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05Remove linux/version.h include from drivers/net/phy/* and net/ieee80211/*.Jeff Garzik
Unused, and causes the files to be needlessly rebuilt in some cases.
2005-09-23[netdrvr] delete CONFIG_PHYCONTROLJeff Garzik
2005-08-28[PATCH] PHY Layer fixupAndy Fleming
This patch adds back the code that was taken out, thus re-enabling: * The PHY Layer to initialize without crashing * Drivers to actually connect to PHYs * The entire PHY Control Layer This patch is used by the gianfar driver, and other drivers which are in development. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-08-11phy subsystem: more cleanupsJeff Garzik
- unexport symbols never used outside of home module - remove dead code - remove CONFIG_PHYCONTROL, make it unconditionally enabled
2005-08-11Fix numerous minor problems with new phy subsystem.Jeff Garzik
Includes fixes for problems noted by Adrian Bunk, Andrew Morton, and one other person lost in the annals of history (and email folders).
2005-07-30This patch adds a PHY Abstraction Layer to the Linux Kernel, enablingAndy Fleming
ethernet drivers to remain as ignorant as is reasonable of the connected PHY's design and operation details. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
